 Old 01-05-2018, 08:15 AM   #1
Solarsurge's Avatar
Posts: 570   (View Stats)
Default Troubleshooting Smoke
So, last week I suspected my stock K04 blew and I was pouring smoke from my exhaust. When I pulled it, it had about a pretty sizeable pool of oil inside the compressor and the shaft had lots of play, so I ordered a BNR S4, did the swap, and retuned.
When I started it back up it was still pouring smoke, but thatís to be expected because there is likely still oil in the downpipe. I was told to let it idle for a while and drive it for a while. The smoke subsided, but never fully went away. I was told it would take a while to burn all of it off. I was out of town and thought everything was OK, so I drove it about 300 miles back home. I didnít drive it at all yesterday.
Today, I started it up and the smoke was awful. My car was literally a rolling fog machine and it smelled so bad ó like burned clutch mixed with burned plastic coming from the exhaust. I pulled over into a meineke parking lot and the mechanic there immediately said anytime he sees someone smoking that bad itís usually a blown head gasket. I told him about my recent turbo swap and he said itís possible thereís coolant leaking internally in the new turbo. I checked the coolant level and sure enough the reservoir was almost empty. The coolant also appeared dirty. Itís brand new coolant, replaced with the turbo.
Any ideas out there?
 Old 01-05-2018, 08:20 AM   #2
SSinstaller's Avatar
Posts: 3,915   (View Stats)
Groans: 57
Do a leakdown test.
Soon to be installed:
 Old 01-05-2018, 02:57 PM   #3
Solarsurge's Avatar
I don’t have a compressor to do a leak down test, but I did do a compression test:
Cyl 1: 152psi
Cyl 2: 151psi
Cyl 3: 151psi
Cyl 4: 152psi
So, it seems the cylinders are fine... Still checking things out.
 Old 01-06-2018, 01:55 PM   #4
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
What color was the smoke
Sent from my SM-N950U using Tapatalk
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 01-06-2018, 02:30 PM   #5
Solarsurge's Avatar
It’s a dirty white, kind of brownish tinge. But it’s thick. It seems to only be bad after the car sits for a while or if I let it idle. My coolant was a bit low (still hadn’t been fully burped after a coolant flush), and simply topping off the coolant and driving it a bit seems to have made the smoke greatly subside. Going to take her back out today and see if it’s any better.
 Old 01-07-2018, 10:44 AM   #6
Solarsurge's Avatar
Went out to car this morning and checked fluid levels. Coolant is fine, oil was totally off the dipstick. Apparently the smell is burning Rotella T6. Oil is dumping into the exhaust. I’m losing my mind here.
 Old 01-07-2018, 10:51 AM   #7
tmillner's Avatar
Pull your plugs see if piston top is wet. I had great compression, took the engine apart 3 out of 4 ringlands broken.
 Old 01-07-2018, 11:21 AM   #8
Djohns's Avatar
Posts: 3,945   (View Stats)
Groans: 112
Good luck
2010 black mica speed3
Soon:built motor
 Old 01-07-2018, 11:58 AM   #9
Solarsurge's Avatar
1, 2, & 4 are bone dry. The top of the piston in 3 is wet.
 Old 01-07-2018, 12:25 PM   #10
tmillner's Avatar
How new is the valve cover gasket? I know you said you didnt have a compressor but it might be time for a leak down test.
Does it still pull pretty well when you drive it hard?
Last edited by tmillner; 01-07-2018 at 12:25 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-07-2018, 12:33 PM   #11
Solarsurge's Avatar
Stock valve cover gasket. Thereís also a noticeable amount of oil seeping out around the VVT solenoid. Thatís new.
I really didnít push it because itís obvious thereís something wrong. I did open it up a bit when the smoke subsided and it drives perfectly fine. Itís just a rolling fog machine.
Side note: Cylinder 3 has a VERY strong odor of what Iíve been smelling out my exhaust, so itís likely at least part of the problem.
Last edited by Solarsurge; 01-07-2018 at 12:33 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-07-2018, 12:39 PM   #12
tmillner's Avatar
Do you have an occ?
 Old 01-07-2018, 12:41 PM   #13
Solarsurge's Avatar
Yes
 Old 01-07-2018, 12:43 PM   #14
tmillner's Avatar
Any chance you can post video of it smoking?
 Old 01-07-2018, 01:17 PM   #15
Solarsurge's Avatar
Itís low on oil, so I donít want to start it up. However, this lovely photo is what is coming out of my tailpipe. IMG_0194.JPG
 Old 01-11-2018, 10:26 AM   #16
Solarsurge's Avatar
Took it to a shop and the mechanic did a full diagnostic on everything. The leak down test was fine. It was 20% across the board while cold. He said itís definitely bad seals in the compressor. Looks like Iíll be pursuing a warranty replacement on the brand new BNR S4.
 Old 01-11-2018, 10:27 AM   #17
tmillner's Avatar
That's actually good
 Old 01-11-2018, 10:29 AM   #18
Solarsurge's Avatar
I take care of my baby. I was gonna be pissed if I broke her at only 90k. You have no idea how relieved I am.
 Old 01-13-2018, 09:20 PM   #19
Solarsurge's Avatar
So, in a interesting turn of events, I now know exactly what happened. It was basically a chain of events and just bad luck set in motion by the original turbo blowing:
1. Coolant and oil mixed as a result of the original blown turbo.
2. The water in the coolant vaporized and was ďcollectedĒ by my oil catch can extremely rapidly due to cold.
3. Due to the arctic temperatures we had, the catch can literally froze into a block of ice.
4. Catch can feed hose got clogged and crank case pressurized.
5. Excess pressure in the crank case pushed up the oil return line from the new turbo, preventing it from draining oil properly.
6. Unable to drain, the turbo just dumped the oil down the exhaust.
Itís been driven fairly hard and temps dropped again tonight. No smoke, no oil loss.
As for the S4, it seems to not be an issue with the new turbo at all. Bryan at BNR Supercars deserves all the credit for immediately knowing it was a crank case ventilation issue where 3 mechanics told me I either had a bad engine or a bad turbo. That dude knows his turbos.
 Old 01-13-2018, 09:28 PM   #20
tmillner's Avatar
How the hell did he figure that out?
 Old 01-13-2018, 09:32 PM   #21
Solarsurge's Avatar
He was very adamant about the quality of his turbo. He was like ďI HIGHLY doubt itís the turbo,Ē and he told me right away it sounds like itís a crank case pressure issue. I figured out the rest on my own lol
 Old 01-13-2018, 09:35 PM   #22
tmillner's Avatar
Man that's awesome. I'm burning oil as well can't tell where from. I have a bnrs4 so I have some figuring to do
 Old 01-13-2018, 09:36 PM   #23
Solarsurge's Avatar
Check that crank case pressure
 Old 01-13-2018, 09:37 PM   #24
tmillner's Avatar
Blew my dipstick out twice already so Im leaning that way
 Old 01-13-2018, 09:39 PM   #25
Solarsurge's Avatar
Yeah if you blew out your dipstick that is 100% your issue. I am running the Corksport OCC set up as in this photo. The red X is the back port of the IM capped off.
 Old 01-13-2018, 09:42 PM   #26
tmillner's Avatar
Interesting, how much boost are you running? Didn't want to go with one from pcv to manifold and one between valve cover and intake?
I'm thinking about getting the oil cap breather instead of another can. I might try your method
 Old 01-13-2018, 09:49 PM   #27
Solarsurge's Avatar
I have to drain the can often due to condensed moisture, so itís definitely doing something.
Right now Iím only on a base map, as I just put the S4 in last week. So itís just running wastegate spring pressure. Iím hitting around 18psi. Dual catch cans are a bit excessive unless youíre pushing some serious power.
Last edited by Solarsurge; 01-13-2018 at 09:49 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-13-2018, 09:52 PM   #28
tmillner's Avatar
Not true, recommended over 24psi, I'm hitting 30 occasionally
 Old 01-13-2018, 09:54 PM   #29
Solarsurge's Avatar
Donít forget I was running a K04 last week. Dual catch cans with a K04 is just a waste of money lol
 Old 01-13-2018, 09:55 PM   #30
tmillner's Avatar
Get ready for some fun, you guys have e85 close by dont you?
 Old 01-13-2018, 09:56 PM   #31
Solarsurge's Avatar
Iíve got a Snow water/meth kit. Iím not messing with E85 lol
 Old 01-13-2018, 09:57 PM   #32
tmillner's Avatar
I'm running both, e85 is the way to go if you can get it
 Old 01-13-2018, 09:59 PM   #33
Solarsurge's Avatar
Let me get the darn thing stable first
Severe exhaust smoke troubleshooting... RusianKid 2010 MS3 - Troubleshoot/Diagnostics 28 05-14-2015 12:03 PM
FYI O2 troubleshooting car46999 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 06-08-2012 09:10 PM
need some help/troubleshooting Nefarion 2010 MS3 - Troubleshoot/Diagnostics 15 08-30-2011 06:32 AM
©Copyright 2008 ; 2018 Cymru Internet Services LLC | FYHNô Autosports HQ
Page generated in 0.48377 seconds with 24 queries
