A peak of 300hp that falls off quickly on either side is not going to be fast. A 280hp tune that holds it from 4500-6000rpms will be the faster car. Oh and I got you all beat. 400whp on a K04. According to VDyno. It was a run down Pikes Peak near the bottom but who cares? So many variables. Dyno to dyno, self-testing methodologies, settings differences, weather, a ringer, good fuel/bad fuel, fuel with octane booster in it, etc etc. That's why I say get the shit out on the street (or preferably the strip) and see what it will do. 2 cars side by side running down the same piece of asphalt; can't get any more closely matched for comparison than that. |
No straight 93 Peak tq @ 4k - 360 lb-ft 300hp @ 4.5k 325hp @ 5500 300hp @ 6k ~280hp @ redline Chassis dyno, 0 correction factor, 0 smoothing same one double and kmac both hit 500 on |
I try to work on trade when possible, trying to hold out for a dyno shop that needs some work done before I shell out the cash. *I think we about covered it here, the dyno finish for the tune is the next step for the bang for the buck. Now let me get back to editing my pron* |
1. I am fairly certain your tuner gave you some suggestions to increase HP. 2. Since it appears that you are running a stock interfooler, you could probably pick up a used aftermarket TMIC that could put you over the top for $300 or less. You may or may not need to retune. Run some Logs and post them. 3. If you don't have them already, 1 step colder plugs could let you run more timing to get you over the hump. Your tuner can handle that for you. Its like $40 for a set and make sure you gap them to .026 to .028. 4. You could wait till the ambient temperature drops 20 to 30 degrees. Turbos make more power in cooler weather. 5. You could install a new DP but it is a pain in the ass to install, will cost you a few hundred $, and you will need to retune to get that power. That is all I have to get the power you want on a budget. If your tuner thinks he can get you more power for $150 on the Dyno, that seems like a bargain. Honestly though, you have decent power for the mods you do have. |
@iggy097 - Let me know and we can do a remote dyno session :) |
Phate, so in a nutshell, 30%+ E-85 eliminates the need for a FMIC and 1 step colder plugs? |
But, a lot of guys want to make good power on straight gas, as well, so they benefit from the extra parts when they're running it. I never cared about making power on 93...it's used to get me to the next E85 station ;) |
So for someone who still has a K04 and already has the plugs and the FMIC, the difference in power going to E-85 will be much less than someone who has the stock plugs and a TMIC. That explains the 45hp jump when I go from 91 to E-85 mix. Being in the hippy tree-hugger state, I figure E-85 would be more plentiful around here but it is not. I have to go 35 miles out of my way to get it :(. |
i have seen no such numbers on a mustang dyno |
Here we go, for those that haven't seen it. This is buried in another good thread talking about gains from parts and whatnot: http://www.mazdaspeedforums.org/foru...ml#post1389059 ^^It explains why I say 'no gains beyond intake/downpipe' with E85. |
Tapadatass |
My gs is so low 230-250s depending on temps even with e85 I think I would gain more power from tmic then dp Sent from my dizzLe using RaWr powers! |
Boost but even moreso timing could radically change the motor's output irregardless of g/s. There is still a correlation but it isn't as direct. You can flow as much air (and therefore fuel) through the engine as you'd like; but how that air/fuel mixture is converted from potential chemical energy into mechanical energy (pistons pushing down on the rotating assembly) happens well after the MAF reading. There are many other variables that are "loosely" related to g/s readings but all in all it is a reasonable way to keep an eye on your engine's health. So to some extent g/s is like the old adage "it's not how big you are, its how you use it." lol |
Then when you want to throw some eth or meth into the equation....it's very easy to skew these things. |
That's why Dizzy is #1 in my book (just a tiny tiny bit ahead of other very good tuners like Hypnotic and ATVFreeks company and Stratified). I always learn something from Phates or Bucker's posts and they always seem to be in a good mood. I suppose I could say the same thing about Lex and Justin too. It shows their passion is true, their knowledge is bountiful, and taking time to work with the customer (in this sense, answering a question or comment on the forum) shows their true motivation. |
By the way on vdyno my 230g/s on vd 1.8.9 dj smoothing 6 is 290hp hp and cold 250s is 308hp. Sent from my dizzLe using RaWr powers! |
http://www.moccforums.com/forums/ind...?topic=30303.0 They're saying they got this on 91...no way... |
tapafuck |
tapafuck |
to add to the g/s indicator being a bad benchmark @daafish and I dynod same day,he was at 16psi or so and put down 29xhp I push anywhere from 280g/s - 300 g/s depending on conditions @ 20-21psi and that was only good for 25ish HP the gains of running high boost on the k04 are crippled due to how far off the compressor island you get. tbh i feel almost no difference between 3/4 throttle and WOT |
G/S is a crappy indicator car to car. I know someone making 400 hp flowing ~ 330 g/s. @fortressofcomfort :moon: |
Within the same car however, it could be used as part of a set of health measurements, just like dyno numbers, no? I dunno I always log it and check it. I don't know where I said it is a useful value to compare car to car Rob :nana: You know how I hate these car to car number comparison threads. |
| All times are GMT -7. The time now is 03:06 AM. |
