-   -   Turbo Back Exhaust - Insanely Loud Cold Start? (http://www.mazdaspeedforums.org/forum/f544/turbo-back-exhaust-insanely-loud-cold-start-204789/)
Harshmellow 08-23-2016 10:22 AM
I have an ultimate racing catted DP, with a CS test pipe and catback exhaust, fully tuned. My cold start in my underground parking literally triggers car alarms. Overall it sounds healthy, but the extreme noise lasts for about 15 - 20 seconds at 2k rpm.
Is this normal or can it be tuned out?
WetzMS3 08-23-2016 10:27 AM
You can bypass the cold start by blipping the throttle as you turn the motor over. It will also be very loud, but only last as long as the blip.
Djohns 08-23-2016 10:32 AM
This^ my neighbors wanted to call the cops on me because of my exhaust. I just do what wetz told me and so far I haven't seen any cops waiting for me to start it.
WetzMS3 08-23-2016 10:34 AM
And @Djohns; exhaust is loud as fuck. Surprised the hell out of me that it was comparable if not louder than my car with less exhaust flow than I have.
Djohns 08-23-2016 11:32 AM
Tis' true. Scares me for when the s4 goes in.
Harshmellow 08-23-2016 11:50 AM
Out of curiosity, does anyone know what causes this amount of noise on a cold start, and why a 'throttle blip' makes it go away?
WetzMS3 08-23-2016 11:52 AM
ECU logic puts the car into open loop on a cold start in order to bring it up to operating temperature faster. Blipping the throttle bypasses this and lets the car go into closed loop right away, reducing cold start idle to normal operating temp idle.
Tifosi42 08-23-2016 12:40 PM
Welcome to the club, this is why I push my car out of the garage and roll it to the end of the driveway before starting it at 5:30 in the morning with sleeping wife and kids. I live in a rural area so I've never had any neighbors complain. Thanks for the tip @WetzMS3;on blipping the throttle at start though, I'll definitely be trying that out tomorrow morning. I would think a larger turbo turbine (i.e. BNR S4) would help quiet the exhaust some by consuming more energy to move the rotating assembly and thus reducing the sound energy left over, but I could be wrong. This is just my inclination as my car is much louder than my friends big turbo integra, well for the exception of when his wastegate is open.
PearlySpeed 08-23-2016 12:47 PM
3" catless turboback here, talk about insanely loud cold start. Thankfully I only have 1 neighbor who runs his lawn equipment the same time I leave and my wife works the same hours as me, or else Id be screwed.
WetzMS3 08-23-2016 12:48 PM
I wasn't necessarily pointing at my larger turbo being the increased exhaust flow compared to David. That's just one piece of the puzzle. In my experience, tubular exhaust manifold created the largest increase in volume on my car. I think David's mufflers just create an oddly, extremely loud sound. I wouldn't be surprised if his exhaust is slightly more restrictive than mine, even though it is louder.
Just spit balling here. Other than the tubular mani causing a huge increase in sound. Full Race, FTW.
Djohns 08-23-2016 01:04 PM
I question if there's anything in my mufflers or if they're just for show. Bought it custom second hand so it's all a mystery.
WetzMS3 08-23-2016 01:08 PM
Based on the grumbliness of your exhaust I am assuming there is some baffling in there. Spit-balling, like I said. I know the UR exhaust on my car is one of, if not the least restrictive muffler on OTS exhausts. The sound of your exhaust really seems to create noises that the motor doesn't make naturally, if that makes any sense, lol.
We could always make you straight pipped and cut open those mufflers!! For science.
Djohns 08-23-2016 01:12 PM
That would be a science lesson followed by many tickets and pissed off neighbors.
WetzMS3 08-23-2016 01:13 PM
I wonder if "For Science" is a valid excuse to get out of tickets??
Djohns 08-23-2016 01:15 PM
I would assume that depends on the officer and his/her current mood.
MRR 08-23-2016 07:25 PM
That's just the way it is, hi flow bigger exhaust are noisy, and if its an everyday car, its either you or your neighbours will get sick of it not to mention the cops will love you.
If it is a concern, I would start looking for other exhaust set up that is more silent.
Search Varex mufflers
WetzMS3 08-23-2016 07:29 PM
Bruh
Sent from my XT1254 using Tapatalk
PapaBone 08-23-2016 07:36 PM
OK I'll bite, you wouldn't happen to have a vid of your exhaust would ya? I need to hear this freak of nature.
Sent using smoke signals
Harshmellow 08-24-2016 10:03 AM
The throttle blip fixed my issue. One loud blast is better than a 20 second space shuttle launch. Thank you.
crankshaft 08-24-2016 10:36 AM
....Buys obnoxiously loud exhaust system.
...then complains that it's obnoxiously loud.
Harshmellow 08-24-2016 10:43 AM
I don't find it obnoxiously loud other than the cold start. When I bought the car used I didn't say, "I hope it's loud when I start it, but that's the only time".
Yatta 08-24-2016 11:07 AM
Only exhaust mod for me is the gutted second cat; my neighbors couldn’t believe it was stock exhaust... blipping the throttle is the way to go.
crankshaft 08-24-2016 11:07 AM
Isn't it ironic?
Back in "the day", we used to blip the throttle to set the choke and get 1 squirt out of the accelerator pump so the car will run cold.
Then this fancy electronic fuel injection comes along, and now the carputer does it for us....almost flawlessly.
Now, I'm blipping the throttle again to avoid the high revs on a cold start. I don't wanna burn the extra fuel or let my engine rev cold, and I don't wanna wake my kids who sleep in the room right next to the garage.
802MS3 08-24-2016 12:31 PM
I typically just press the accel pedal about 10% while cranking the key, and as soon as it starts to fire up, let off. You can do it with a loud "blip" but it takes the correct timing. I wish we could just disable that cat warm-up procedure in ATR. Maybe its a feature we can ask for in Versatune?
Djohns 08-24-2016 08:01 PM
I do but I have no clue how to upload videos.
blackms3_71 08-24-2016 08:22 PM
just so you guys know.... the idle tables have values for different ect. u can bring down the rpms it is reving too. I also found out on some cars this doesn't work. so under load max a,b tables for 500,1000,1500 rpm u can lower the load there and get the same results 500=.50 1000=.60 and 1500=.70 try that.
SpeedBen 08-25-2016 08:23 AM
Originally Posted by crankshaft (Post 3077533)
Isn't it ironic?
English is not my native langage...what do you guys do when you say "Blip the throttle" ?
MS3Shadow 08-25-2016 08:26 AM
rev the gas pedal
Djohns 08-25-2016 08:46 AM
Hold the gas petal down slightly while starting the car then letting off upon the car starting.
SpeedBen 08-25-2016 09:09 AM
Originally Posted by MS3Shadow (Post 3077783)
rev the gas pedal
Thanks!
Page generated in 0.19045 seconds with 11 queries
