Turbo manifold and do gasket Ok so I am being somewhat cheap here. When I first did my dp I reused the stock gasket and copper sprayed it. Worked great with no leaks. Put new gaskets in when installing the bnr. Do you think when installing the k04 back into the car I could get away with copper spraying both the manifold gasket and dp gasket and no have issues? |
Sure, I think I must have reused my gaskets like 5 times now, no leaks whatsoever. |
| All times are GMT -7. The time now is 02:20 AM. |
