Turbo sizing inquiry I have an HTA3576 that I was planning on actually getting to install this spring. Unfortunately for me, switching jobs changed my commute from driving 90% interstate to 80% incredibly hilly, backroad highways instead so that changes my general driving style quite considerably. My question is: Will I get enough response at low load/partial throttle from the turbo to keep my commute tolerable? I need some help from the K04 to keep my RPMs reasonable (2750~3000 RPM) while scaling up these huge hills. I'm driving ~250 miles/week for the commute back and forth and I'm trying to keep my gas mileage fair/keep my revs down. I know there isn't really any info on the HTA3576, but I'm just trying to get a general idea of what to expect and if I should consider switching to a smaller turbo. |
I'd go smaller. When I had a 3071 on my gen1 it was okay in hilly situations but I was always a gear lower than I was with the k04....a 35 will be at least a few hundred rpm worse than that. I'd go witha 28 series or something like a 5858 if you want bigger, it should spool better than a similarly sized garrett. |
Not sure about your power goals but sounds like you might want a BNR S3. From what Ive read they are one of the most responsive, and its what I plan on going with since my HP goals are not over 400. |
GTX 2971 or EFR 6758. :smokin: |
I had a Garrett GTx3576, and while it made damn good power, it was a complete dog around town... and i didn't even have hills to deal with. I'd suggest smaller, a 3071 should be fine, i remember mine responding pretty well before i swapped to the 35. |
Thanks everyone. I was looking towards the 5558 or 5858 as the most likely replacement at this point. I wish I could do an EFR but I don't want to have to sell an organ to do it lol |
Regardless, if you want the high hp and great response, I'd totally recommend anything Forced Performance makes. They have the formula down for that. Otherwise, just hit up a GTX3071 or 2971 and win. |
posted about it here. |
Alternatively you cold give the BNR S4 a shot. It's a 3076 which is a little big, but still way smaller than you originally had in mind. The best thing about that turbo is how dirt cheap it is for what you get. |
Just been chatting with Xona Rotor/FP about the 5448 (HTZ2871) to the 5756 (HTZ3073) range. The only complication would be getting a TiAL flange for the downpipe AFAIK. The T3 flange would be easier since it comes with a V Band outlet but unfortunately AFI is the only one I know that makes one for us and you can't even get an external wastegate on them because of their design. |
The previous owner of my car switched from T3 w/ Steedspeed mani to the cpe mani w/ tial and dramatically decreased the EGT's and brought the spool time down to something a little more reasonable (with this giant 35R) according to the documentation that I have. But, that being said, I don't think you are going to miss TOO much going either way when you start talking about those smaller framed turbos. |
I figured I may as well go with TiAL anyway, if I have the option to go bigger in the future it'd be a better transition. Does the CPE manifold only create issues with stock turbo positioning when using a Precision or is it for all of them? |
| All times are GMT -7. The time now is 03:51 AM. |
