![]() | | #1 | ![]() |
![]() Join Date: May 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score I also programmed boost pressure, engine temp, and fuel rail pressure. Those three worked, but the RPM zone is black, no digits at all. I made a support ticket on their website and have had no luck with their techs. It seems pretty clear to me, but they still don't understand what I'm trying to tell them. Does anyone else here have the UG, and does the RPM show up if you program it? At this point, I've emailed them a video and am not hopeful that I'll get anywhere with them. I don't think the alarm will be fast enough to trust, either and without that alarm, I don't need the tach on the UG. Thanks. |
![]() Join Date: Apr 2013 Location: Jacksonville, Fl 904 - Detroit, MI 313
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
| Not Ranked : 0 score whenever you dont have ur UG programed does it show the RPMs? also have u tryed moving the values around a little instead of 6500 maby 6700 or 6200 etc? and i would trade RPMs for fuel pressure personally* |
![]() Join Date: Jun 2012 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,322
Groans: 156
| Not Ranked : 0 score Yes, my UG displays RPM, and with the programed displays. Do you have an AP? If that reads RPM, you can tell them that your car OBDII is not the problem. I got mine for same reason, nice to know engine temp.
__________________ -2012 CWP MS3 - - COBB AP V2b - Autotech HPFP Internals - JBR 3.0 WP - CP-E TMIC - UR TP - NGK ILTR6A-8G # 3787 plugs - EGR delete - Bosch 3-bar TMap - DO WMI 50/50 - JBR RMM 88a - JBR PMM 70a + JBR TMM 70a - JBR OCC S2 - JBR SSP - JBR SSB - JBR RSB - - Block8head single defrost pod - VDO Vision Boost Gauge - Maisonvi Custom Stainless Steel Ball Shift Knob - - Self Tuning 91 octane of fail with 50/50 WMI of win - |
![]() | | #4 | ![]() |
| Not Ranked : 0 score also i belive the value has to be set after the action has taken place.... e.g. run the engine to the rpm u want thin go into the menu to see that value and set the alarm (but that may be for older versions dont hold me to that, ill see if i can find that info tho) **we talking see the RPMs at all OR seeing them once alarm values are set just to clarify??? |
![]() | | #5 | ![]() |
Groans: 156
| Not Ranked : 0 score Not on the one I have, you just go to alarms, and scroll to RPM and set High alarm. I don't personally use it, but a friend uses the UG RPM high alarm (i set it while he was driving), and it does not go off half the time, or has a delay.
![]() | | #6 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to pharaoh313 For This Useful Post: | VulgarKyle (05-09-2013) |
![]() | | #7 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, I still don't know what the issue is with this thing, and their tech support guys are absolute idiots, so given that the alarm won't do what I want it to do (safely and reliably) I may just give up the issue. My AP shows RPM whenever I log. The main reason I got this is because it was only $60, so if some nitwit sees it in my window and steals it, it's cheaper than the running off with my AP, and I also don't have to deal with AP about getting the stock tune back for any of the reasons I'd need it back. The way I see it, for $60 I would have just had a temp gauge, and I'd have to install it and pretty it up. With this UG, I have a bunch of gauges (although now I don't trust which ones work and which don't) and it was the easiest gauge installation ever...truly plug and play. Their tech support guy (or guys) are just morons. They remind me of every IT person that I've ever had. |
![]() | | #8 | ![]() |
| Not Ranked : 0 score after reading alil it does say the max value on the RPM for alarm is 4000* and maby this will help... The Alarm thresholds for RPM, MPH and KPH can not be set normally. Please do not change the Minimum alarm value for any of these. If you do, you may restore the values by executing the menu command: Menu --> Alarms --> Load Default Alarms The work around for setting the high alarms is to force the value of the gauge to read the value desired and then enter the menu system and set the alarm. Once Menu is pressed, it locks in the value and will allow that value to be set. For example, RPM would be set as follows: 1. While in neutral run the engine up to the desired RPM 2. Press Menu 3. release the accelerator and allow the engine to idle 4. Go to the alarm setting for RPM. The only value that can be set is now the value of RPM just prior to pressing MENU. For MPH or KPH you will need to be driving at the desired speed. This will require a second person as the driver should never use the menu system while driving. other thin ^that heck if i know' |
![]() | | #9 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for finding that 4000 RPM info, Pharaoh. I'm not even going to mess with that gauge anymore. I'll set something else there. Thanks for the replies. I'll give up with their tech douches until another gauge doesn't work. |
![]() | | #10 | ![]() |
![]() Join Date: Mar 2011 Location: HACKNSACK, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
Groaned at 16 Times in 6 Posts
| Not Ranked : 0 score I was thinking about getting an ultragauge. Overall do you guys think it's worth it?
__________________ Black Mica Mazdaspeed 6 [SIGPIC][/SIGPIC] NJSpeed P&P IM, KMD internals, SU TMIC, BNR STG 1, Sure V1 Aeros, Cobb TIP, Turbosmart BOV, Magnaflow CBE JBR Trilogy, Jugg & Dread, Corksport Strut tower brace & rear seat brace, Tein Super Street C/Os 18x8 OZ Ultraleggeras, 225/45/18 Dunlop SportMaxx, 17x8 Enkei SC03, 235/45/17 Bridgestone Blizzaks, Evo Brembo mod, StopTech rotors, Techna-Fit S/S brakelines, StopTech & EBC Greenstuff pads The Mad Scientist Tunings |
| The Following User Says Thank You to 6ixof1 For This Useful Post: | evil MS3 (05-09-2013) |
![]() | | #11 | ![]() |
![]() Join Date: Jul 2012 Location: Seminole, FL
Rep Power: 1270 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,116
Groans: 55
| Not Ranked : 0 score I'd like to pick one up myself just for some monitoring right now until I pick up an AP
__________________ |
| The Following User Says Thank You to evil MS3 For This Useful Post: | VulgarKyle (05-09-2013) |
![]() | | #12 | ![]() |
![]() Join Date: Jan 2013 Location: glen burnie md
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,659
| Not Ranked : 0 score I love mine , All my gauges work that are compatible with ms3. I also like that I can clear codes on my car and anyone else's car that is obd2. The only thing that I don't like is the refresh rate. Its only able to go to 0.3 so rpm is a useless gauge. does your tach in dash not work? tapatalk isn't texting so it isn't illegal
__________________ 2011 VELOCITY RED MAZDASPEED3 W/TECH RICHTUNED |
![]() | | #13 | ![]() |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 1301 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 649
| Not Ranked : 0 score I use ug to monitor.. Boost fp psi, long and short trims, eng temp, intake temp. Rpm alert is set to 5500(as I'm k04) but +1 to delays
__________________ Sold: 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Brakes: CorkSport Pads; Centric Blanks Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Official 60-100mph Times Official Video battles Official Youtube Channels
:-( 2014 - Dodge Dart.. (Blue Turtle) Last edited by ms3rick; 05-09-2013 at 07:06 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to ms3rick For This Useful Post: | VulgarKyle (05-09-2013) |
![]() | | #14 | ![]() |
Groans: 55
| Not Ranked : 0 score Can you set an alert for FP?
![]() | | #15 | ![]() |
Maybe I like analog gauges better than digi. I'm sure you can tapatalk isn't texting so it isn't illegal
__________________ 2011 VELOCITY RED MAZDASPEED3 W/TECH RICHTUNED | |
![]() | | #16 | ![]() |
Groans: 55
| Not Ranked : 0 score Yeah, then I just thought about that....if you set it to go off under a certain PSI it would be going off all the time unless you were WOT lol Maybe set it to go off at a certain value, like 1200psi
__________________ Last edited by evil MS3; 05-09-2013 at 07:18 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #17 | ![]() |
Mine reads FP, stft, ltft, boost psi, eng temp, mph, ecu volts, and maf just for the hell of it. I don't know if you can set values above a certain rpm I will try. tapatalk isn't texting so it isn't illegal
![]() | | #18 | ![]() |
Groans: 55
| Not Ranked : 0 score See if you can set an alarm so if FP hits 1200 PSI exactly. Just a thought.
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
Groans: 55
| Not Ranked : 0 score Yeah, kinda what I was figuring haha
![]() | | #21 | ![]() |
nope'
http://ultra-gauge.com/ultragauge/su...ser_manual.pdf | ||
![]() | | #22 | ![]() |
I'm willing to lose 80$ not so much 550$ for ap tapatalk isn't texting so it isn't illegal
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think it's only $69 shipped. If I were to have gotten a temp gauge, that alone would have cost at least that much, plus something to mount it in, and the hassle of finding a place to put the sending unit. This UG does that, plug and play no less, and 80 some odd other gauges. It's well worth it, in my opinion. I finally got the RPM to work...all I had to do was set that same zone to Battery Voltage, and RPMs popped up. I cleared all the gauges and started over and it's all set. I'm not using RPM anymore. The only reason I wanted RPM was to set an alarm at around 6200 so it would let me know when to shift. The consensus here is that it isn't fast enough to alert me in time. |
| The Following User Says Thank You to deyomatic For This Useful Post: | VulgarKyle (05-09-2013) |
| Ultra Gauge layout | fishin53 | 2010 MS3 - ECU Computer Tuning | 32 | 03-14-2014 08:30 AM |
| Ultra-gauge AFR update link? | Voltwings | Gen2 MS3 General Discussion | 0 | 11-19-2012 02:13 PM |
