Unicorn Blood/Jizzum Installed & my thoughts... Well my car just rolled over 30k and i decided it was time to try out the Motorcraft fluid (AKA Unicorn Blood or Jizzum). Holy shit!!! I have only had it in the car about 20 miles so far and the difference was immediately noticeable. While I never had any real problems with grinding, I'd have to say that the overall smoothness of the shifting is greatly improved. If you haven't done this yet, do it! I will never go back to factory fluid after this. :smlove2: |
nice.. i actually might do it when i do my oil change. i just hit 17k in 6 months FML....... |
Motorcaft > redline? |
you just have to chance it, pick one and see how it goes. i have motorcraft. been in for 30k, still shifts as beautifully as this trans is capable of. |
I just use 50% redline and 50% motorcraft. Sent from my iPhone using Tapatalk |
Been thinking of doing this, at 24k now. I guess it is as easy as buying some fomoco synthetic fluid draining the old shit and re-filling? What specifically do I ask for at the ford dealership? I pass one everyday. |
dont forget the FoMoCo friction modifier. you could use that in combination with stock or redline shit and im sure it would work just as well. i had the fomoco fluid and it felt pretty crispy. definitely smoother than stock. not a HUGE difference for me as I didnt experience any problems other than those which are user induced =) |
I was told to stay away from the friction modifier. |
I haven't used friction modifier for the 15k miles ive had motocraft. It would be cool to see the difference. Every once in a while i hear people trying redline or royal purple. But I always hear motorcraft is the least susceptible to cold weather symptoms |
if you add friction mod it won't hurt, same goes for if you don't add it so whatever helps you sleep at night i wont be adding it |
I've run the Motorcraft with and without friction modifier. It feels much better with the modifier. |
I am sure I could search and find it but I am drinking and lazy. Why we are on the topic, how many quarts does it take? |
I will try friction modifier next time... in... is it every 40 k miles? Im guessing id subtract from my motocraft fill to make room for the friction modifier when i do it |
I've been meaning to do this for, oh I don't know... 40K miles or so. I'm glad I saw this post, and that its working well. You may have inspired me to get off my arse. |
Is the stock fluid synthetic? I guess its all a balance... lighter oil/less friction = smoother shifts, quieter, less parasitic loss heavier oil/more friction = tougher shifts, a bit of noise but better performance from the LSD etc. etc. Everything in life is a balance no? Some kind of fucking compromise it seems just venting. |
| All times are GMT -7. The time now is 05:19 AM. |
