 Old 07-10-2019, 09:02 AM   #1
spinfly's Avatar
Posts: 22   (View Stats)
spinfly can only hope to improve
Default upper spoiler removal
How do i separate the upper spoiler from the lower spoiler?
Thanks.
spinfly is offline   Reply With Quote
 Old 07-10-2019, 05:19 PM   #2
MSMS3's Avatar
Posts: 2,691   (View Stats)
Groans: 150
Thanks.
Not sure which “spoiler” you are referring to. Maybe post a photo? Gen 1 or Gen 2. Front or rear? True spoiler or splitter, air dam or what? Lots of aero pieces on the Speed 3 cars.
What are you trying to do?
 Old 07-10-2019, 06:27 PM   #3
spinfly's Avatar
Sorry. Genpu rear spoiler. The upper one with out the 3rd brake light.
 Old 07-11-2019, 05:56 AM   #4
MSMS3's Avatar
Groans: 150
It is one spoiler. There are two halves. So, you want to disassemble it? Take it apart? Why?
Whatever the reason, it seems to me that you will need to remove it (the whole thing) from the hatch first.
There are YouTube videos on how to install/replace the entire hatch. I’ve not done this, but the videos seem clear. You will have to unbolt it from the inside of the rear hatch. I don’t think there is a way to take it apart without first removing it.
help with upper intake tube 07 ms3 Savo1997 Mazdaspeed3/6 General Discussion 39 02-27-2015 08:44 PM
Upper radiator hose help siguime MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 07-28-2014 06:57 AM
Rear lip spoiler removal??? Swinger13 Mazdaspeed3/6 General Discussion 1 10-16-2012 12:11 PM
Page generated in 0.24053 seconds with 21 queries
