  • 1 Post By Phoenix
 Old 07-01-2014, 07:38 PM   #1
Rugger619's Avatar
Posts: 19   (View Stats)
Rugger619 can only hope to improve
Groaned at 9 Times in 3 Posts
Default Used fuel pump internals
My buddy is offering me his used autotech fuel pump internals from his 2010 ms3 that he used the pump for 10K miles. is it worth it to install on mine, or should I just get a new one? How long will these internals last. Tried searching for a lifespan on these but havne't had any luck. Sorry if its a dumb question
Rugger619 is offline   Reply With Quote
 Old 07-01-2014, 07:40 PM   #2
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
get em if its a deal.. monitor with an ap. should be fine.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 07-01-2014, 07:41 PM   #3
Knight F Mohawk's Avatar
Posts: 149   (View Stats)
Knight F Mohawk has a reputation beyond reputeKnight F Mohawk has a reputation beyond reputeKnight F Mohawk has a reputation beyond reputeKnight F Mohawk has a reputation beyond reputeKnight F Mohawk has a reputation beyond reputeKnight F Mohawk has a reputation beyond reputeKnight F Mohawk has a reputation beyond reputeKnight F Mohawk has a reputation beyond reputeKnight F Mohawk has a reputation beyond reputeKnight F Mohawk has a reputation beyond reputeKnight F Mohawk has a reputation beyond repute
They should be fine, thank your friend and enjoy.
2006 MS6
2007 Accord EX
1995 F150 4x4
Knight F Mohawk is offline   Reply With Quote
 Old 07-02-2014, 05:33 AM   #4
Yousuf's Avatar
Posts: 1,398   (View Stats)
Yousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the world
Groans: 128
I don't see it specified in your post, but for free, why the hell not
Mod-bug's back...
Yousuf is offline   Reply With Quote
 Old 07-02-2014, 11:18 AM   #5
SnailSpeed3's Avatar
Posts: 278   (View Stats)
SnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond repute
Shouldn't be any issues, lots of guys run internals for waay longer than 10k with no issues (can't verify by personal experience because I've only had mine for 5k) and if they are free, you can take the $350 you would have spent on internals and put that towards an AP (assuming you don't already have one, add mods to sig)
2013 Liquid Silver MS3
Mods so far:
FUNCTIONAL-
Cobb AP
HTP 3" Intake
C(u)NT 3" Catless Downpipe
JBR OCC, EGR delete, Under Engine Piping
Treadstone TR6 FMIC and brackets
Damond RMM, PMM, TMM
JBR SSP & BUSHINGS
Autotech HPFP Internals
AESTHETIC-
DIY Mudflaps, DDM 55W HL/35W FL
SnailSpeed3 is offline   Reply With Quote
 Old 07-02-2014, 11:57 AM   #6
mxlplx71's Avatar
Groans: 128
getting an avitar and donating would be a cool mod for you also
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 07-02-2014, 12:09 PM   #7
SpencerC's Avatar
Posts: 2,159   (View Stats)
SpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the world
Lots of people sell used Internals. Shouldn't have an issue.
SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount -
CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit
1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights
Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3?
SpencerC is offline   Reply With Quote
 Old 07-02-2014, 12:13 PM   #8
^this too, best part is the access to FS section, lots of money to be saved buying used parts, plus this forums FS rules are pretty strict so you're not too likely to get burned
Mods so far:
FUNCTIONAL-
Cobb AP
HTP 3" Intake
JBR SSP & BUSHINGS
AESTHETIC-
 Old 07-02-2014, 12:20 PM   #9
Jtaylor's Avatar
Posts: 656   (View Stats)
Jtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the world
panis
08 MazdaSpeed3
| Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 |
| AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM |
| Black Powdercoated Stockers | Built Motor |
| Mahle 88mm Pistons | Manley H-Beam Rods |
Jtaylor is offline   Reply With Quote
 Old 07-02-2014, 12:40 PM   #10
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
45k miles on my internals and no signs of a problem. As long as they were installed and removed correctly without damaging them they're fine.
Blue Pu.
 Old 07-02-2014, 01:47 PM   #11
anavrinIV brings up a good point... check for surface wear on the internals before you install them and if you see and nicks or gouges or otherwise fucked looking bits maybe don't install them.
I somehow doubt that if they are coming from your friends car, and they have been used for 10k miles that there are any issues with them, but your friend still could possibly jack them up upon removal...
Mods so far:
FUNCTIONAL-
Cobb AP
HTP 3" Intake
JBR SSP & BUSHINGS
AESTHETIC-
 Old 08-05-2014, 06:30 PM   #12
Phoenix's Avatar
Posts: 124   (View Stats)
Phoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant future
Why not just swap the whole pump?
Sent from my PC36100 using Tapatalk 2
Knight F Mohawk likes this.
SURE Full3 Aeros - UR DP - Test pipe - Magnaflow catback - RMM - Autotech internals - AP self tuned - 3 Port EBCS
Phoenix is offline   Reply With Quote
The Following 2 Users Say Thank You to Phoenix For This Useful Post:
IshiKage (08-06-2014), Knight F Mohawk (08-06-2014)
 Old 08-06-2014, 08:11 AM   #13
ABOSWORTH's Avatar
Posts: 467   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
That's not a bad idea. It would be easier. It does seem kind of pointless to rip both pumps apart to swap the internals.
2012 Speed3 - Velocity Red Mica
Current Mods
JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob
ABOSWORTH is offline   Reply With Quote
Fuel pump internals. Limeybastard Gen2 MS3 General Discussion 18 03-07-2013 01:03 PM
Fuel Pump Internals Vlad 2010 MS3 - Engine, Transmission & Driveline 6 06-21-2012 06:47 AM
Page generated in 0.32445 seconds with 29 queries
