Notices
  • 1 Post By beachshoer
 Old 07-08-2012, 08:32 AM   #1
beachshoer's Avatar
Posts: 1,338   (View Stats)
beachshoer has disabled reputation
Default Valve Cleaning
Want to see what your valves look like after 96000 miles without an OCC? These are a few shots (not very good sorry) of what i spent a day cleaning. People, GET AN OCC and EGR DELETE KIT!!!!
96000 miles
EGR block off after 30k miles
sea foamed about 5 times over the past couple years.
No OCC, shut up I'm ordering one.
Some more pictures in our NATOR FL
http://www.mazdaspeedforums.org/foru...7/index67.html
MINE 2010 BM MS3
BNR S3
HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs
H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines
Works emotions cr-kai 18x7.5 ventus v12s for the street
TRM C3s 17x9 Hankook RS3s for track days
STRATIFIED TUNED
HERS 2010 VR MS3
JBR SSP. Autotech internals. JBR RMM. Turbosmart BPV. ETS TMIC JBR Knob. H&R Springs JBR RSB
NEW TRACK WHORE : 2001 Miata LS
Ready for full ghayness
beachshoer is online now   Reply With Quote
The Following 4 Users Say Thank You to beachshoer For This Useful Post:
daztdMS6 (07-08-2012), Pseud0logik (07-08-2012), pzr2874 (07-08-2012), thanox2 (07-08-2012)
 Old 07-08-2012, 08:43 AM   #2
pzr2874's Avatar
Posts: 3,930   (View Stats)
Groans: 89
Groaned at 103 Times in 69 Posts
96K in 2 years?
Is all of that highway miles? Might be the reason for the carbon buildup.... DingoDave jvella22
 Old 07-08-2012, 08:58 AM   #3
fooqr's Avatar
Posts: 556   (View Stats)
fooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the world
So, you've verified that Sea Foam doesn't do anything for these engines.
But, while an OCC and EGR delete would have helped a bit, I think you still would have needed to clean those valves after 96k. It's not like they are a magic bullet or anything.
08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
There are no stupid questions, but there are stupid people and some of them ask questions.
- A. Funicello
fooqr is offline   Reply With Quote
The Following 4 Users Say Thank You to fooqr For This Useful Post:
akagijoe (07-08-2012), MSMS3 (07-08-2012), Pseud0logik (07-08-2012), Tokay444 (07-08-2012)
 Old 07-08-2012, 09:05 AM   #4
SUB BOX MASTA
JTMS3's Avatar
Posts: 1,821   (View Stats)
JTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the world
Groaned at 21 Times in 15 Posts
If thats cyl 4.. mine looked the exact same way at 30k and was the worst of all the valves.
Mazdaspeed 3 2010 w/ tech package - Celestial Blah Blah Blah
4/15/12 dynojet results: 305whp / 355 tq
JTMS3 is offline   Reply With Quote
 Old 07-08-2012, 09:36 AM   #5
Dr. Speed's Avatar
Posts: 666   (View Stats)
Groans: 28
First "mods" on these cars should be OCC and EGR delete. Those are some dirty valves.
Did you notice any performance difference after cleaning?
 Old 07-08-2012, 11:43 AM   #6
DingoDave's Avatar
DingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the world
Groans: 43
Groaned at 8 Times in 4 Posts
Yep.. I'm only at 44k and I bet my valves are gonna be looking something like that. No OCC or EGR delete yet.. but those will be installed the same day I clean these valves. Also car just hasn't been running smoothly for good while. Hoping a good cleaning will help solve that.
2013 Black Mica Mazdaspeed 3
DingoDave is offline   Reply With Quote
The Following User Says Thank You to DingoDave For This Useful Post:
 Old 07-08-2012, 12:10 PM   #7
Gatorbait's Avatar
Posts: 107   (View Stats)
Gatorbait has much to be proud ofGatorbait has much to be proud ofGatorbait has much to be proud ofGatorbait has much to be proud ofGatorbait has much to be proud ofGatorbait has much to be proud ofGatorbait has much to be proud ofGatorbait has much to be proud ofGatorbait has much to be proud ofGatorbait has much to be proud of
Im at 95k and about to do this. I guess this is what I get to look forward to...did you use media blasting or the gun kit to clean it out?
'06 MazdaSpeed6 Current Mods: COBB SRI, COBB Inlet, Cobb AP, SU RMM, ETS TMIC, Ebay DP, SU Shifter Bushings, JB short shifter plate,Stoptech D/S rotors with EBC redstuff, Bilsteins w/Eibach springs. On the Horizon: need moar moniez
Gatorbait is offline   Reply With Quote
 Old 07-08-2012, 02:17 PM   #8
beachshoer's Avatar
Yes 96k miles in two years. Tons of highway driving.
OCC and EGR delete a magic bullet? no you're right they're probably not but im sure it would cut cleaning time and frequency in half.
Noticed a bigger difference in performance than i expected. As soon as i fired it up the idle was super smoother.
Cyl 1 and 4 were the worst
I used the carb cleaner and gun brushes. Already had a bunch of gun cleaning brushes so i figured i would try that first. Only part you really had to work at was the edge of the valve with a coat hanger and the backside of the valve. Took my time and got them as clean as any of the other pics of cleaned valves i've seen. I think the walnut shell blast might be easier but the cleaner and brush is cheaper. I got more time and patience than money.
MINE 2010 BM MS3
BNR S3
STRATIFIED TUNED
HERS 2010 VR MS3
The Following 2 Users Say Thank You to beachshoer For This Useful Post:
MSMS3 (07-08-2012), pzr2874 (07-08-2012)
 Old 07-08-2012, 03:25 PM   #9
Able
helmetface's Avatar
Posts: 4,434   (View Stats)
Groans: 128
Fuck that, just spray meth and watch those walls turn to glass!
 Old 07-08-2012, 03:51 PM   #10
pzr2874's Avatar
Groans: 89
How many miles do you have on yours since you started spraying? helmetfail
 Old 07-08-2012, 03:58 PM   #11
Able
helmetface's Avatar
Groans: 128
Not mine, but I literally just came from a valve cleaning..we attempted to do 5 cars but were rail roaded by some fail.
Anyhow, one gentlemen had been spray meth for just under a week, 80k miles on the odo and his runners and lifters were like 900 times cleaner than min and others with less miles.
Also, after spraying for this week, his carbon build-up was much looser and was able to be cleaned much easier and more effectively.
Needless to say, I'm throwing a DO kit on my CC....
The Following 2 Users Say Thank You to helmetface For This Useful Post:
 Old 07-08-2012, 06:04 PM   #12
beachshoer's Avatar
I have a full DO kit I'm fixing to put up for sale.
Can't run meth in scca racing so I don't feel like setting up for meth then retuning everytime I go race.
But yes meth is the way to go which is why I picked up the kit from a former member.
MINE 2010 BM MS3
BNR S3
STRATIFIED TUNED
HERS 2010 VR MS3
 Old 07-08-2012, 06:06 PM   #13
Able
helmetface's Avatar
Groans: 128
SCCA racing, period? Or a specific class?
I've not heard that rule yet.
Fucking sucks if they mean all brackets, fucking fairys.
 Old 07-08-2012, 06:06 PM   #14
Colin1337's Avatar
Posts: 1,103   (View Stats)
Colin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the world
God damn. I'm at 70k miles with no OCC or EGR block off. After seeing this, those are my next 2 buys...
2006 Mazdaspeed6 - COBB AP| 3' Magnaflow CBE | Autotech FPI | AEM CAI | NGK plugs | RMM | Megan springs | HKS SSQV3
1995 Miata - adjustable Tokiko Illumina shocks | FM springs | HardDog M2 rollbar w/Single diagonal | GV rep front lip | Flyin' Miata rear shock mounts.
Colin1337 is online now   Reply With Quote
 Old 07-08-2012, 06:27 PM   #15
beachshoer's Avatar
Yeah. Just read over the rules again to make sure. Basic solo rule is you have to run anything you can get at a gas station, any octane. That's including E85. That's it. BUT you can run water injection.
Trust me I would be running that shit from that start. Have tapped boost tubes with 3 nozzles, big tank, controller and even two jugs of meth mix sitting in my house laughing at me thru the window while I'm scrubbing my valves.
MINE 2010 BM MS3
BNR S3
STRATIFIED TUNED
HERS 2010 VR MS3
 Old 07-08-2012, 06:33 PM   #16
Able
helmetface's Avatar
Groans: 128
Side note, where did you tap 3 times?
Secondly, so I can run water injection huh, what says that I couldn't sneak in some meth on that 'Water Injection' ?
I know their safety check can be intensive..but I don't think they'd make me rip off my bumper and sniff my tank lol
 Old 07-08-2012, 06:43 PM   #17
beachshoer's Avatar
After I wrote that I realized it sounded like I had three tapped nozzles. I really meant I have three separate nozzles available to put in my one tapped tube.
Yeah you could put meth and probably get away with it easy.I had mine all hooked up and they never even asked. But it kinda goes against the whole grassroots old school mentality. And if it ever came out you'd be shunned. Yes shunned ...FOR. EV. VER.
tavio025 likes this.
MINE 2010 BM MS3
BNR S3
STRATIFIED TUNED
HERS 2010 VR MS3
The Following User Says Thank You to beachshoer For This Useful Post:
helmetface (07-08-2012)
Austin area valve cleaning session?? Cheeto Mazdaspeed3/6 General Discussion 3 07-05-2012 08:48 PM
Will be cleaning my EGR valve meciboy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 04-16-2012 01:15 PM
20k + miles inspection after valve cleaning Joe Isuzu Mazdaspeed3/6 General Discussion 20 02-09-2012 11:42 AM
EGR valve cleaning desertrat MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-06-2010 08:17 AM
Page generated in 0.39703 seconds with 29 queries
