  • 1 Post By Sensei
 Old 08-02-2019, 06:46 AM   #1
ABOSWORTH's Avatar
Posts: 459   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
Default Vapor canister vent valve
Has anyone replaced this? Looks like I'll need to drop the rear crossmember in order to gain access to this. You can barely even see it, let alone replace it without doing something. I found a thread detailing how to completely remove the rear crossmember/subframe on a Speed6 but I'm wondering if anyone has replaced the canister vent valve without completely removing it on a Speed3. Obviously looks much different than the Speed6 since the Seed3 has no rear diff. I think if I could drop it 6 inches or so, I could replace this. I'm getting P0442 and P0455 so I'm pretty sure this is the culprit. I've already done the purge valve and gas cap.
Stupid design on Mazda's part putting this part in such an inaccessible spot.. Thought I'd ask before I start going at it. I don't really want to completely remove the crossmember if possible. I'd like to just be able to drop it a few inches so I can get at the vent valve.
2012 Speed3 - Velocity Red Mica
Current Mods
JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob
ABOSWORTH is offline   Reply With Quote
 Old 08-02-2019, 04:00 PM   #2
Sensei's Avatar
Posts: 318   (View Stats)
Sensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the world
I have no experience with this particular part but I'd suggest looking through the FSM (factory service manual) to see how Mazda says to remove the vent valve.
ABOSWORTH likes this.
2009 MS3: Freektune 280/330, CS SRI+TIP, 3" Test Pipe, TR8 FMIC, AT internals, APv3, JBR SSP/CW/SB, JBR RMM 88a, JBR PMM 80, Koni FSD/Stock Springs
Sensei is offline   Reply With Quote
Replacing Vapor Canister 2007 Mazda 3 HB Rob137 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 06-06-2015 09:55 PM
DIY vent valve OCC dooderek MazdaSpeed 6 - How-To's 5 07-20-2014 09:26 AM
DIY vent valve OCC dooderek MazdaSpeed 3 - How-To's 34 09-04-2012 05:48 PM
Page generated in 0.23452 seconds with 21 queries
