Water Temp Gauge Question I searched about this topic some today at work and found a thread that had some hints of installing a water temp gauge on a 2010 model, but i couldn't really find a definitive answer. (I'll admit that I'm not always the best searcher though).Has any one put one in? Where did you install the sensor for it? |
I would just get the dash hawk or something similar that hooks up to the obd port. I am running the aeroforce interceptor with one setting always on coolant temp. And the other with cycle through. Or if you had a AP you could do this too |
Torque pro app $4.95, Mazdaspeed plug in $9.95, Blue tooth reader $10 and an android devise. Total spent $25 and you can monitor everything an AP will. You really need an AP though if you are going to mod this car. Screen shot of my Galaxy phone. http://i245.photobucket.com/albums/g...719-202357.png 7" Android tablet. |
Searching harder would find your answer. The new temp sensor isn't too difficult install with an inline pipe that you splice into the radiator hose. |
Point me to any gauge that is 100% accurate. It works well enough to be within 5ish degrees of what the one mounted to the engine sees. |
What is your reasoning for wanting a water temp gauge only? |
You can get a used V2 AP for around $250. A quality gauge with sensor set up will cost almost that much. With the AP you can monitor 30 parameters and get a much safer as well as more powerful tune. |
Why bother with a temp gauge when an AccessPORT can monitor coolant temp more accurately and can also do many other incredibly useful things as well? Like someone mentioned, a used V2 AP is mad cheap nowadays. A quality coolant temp gauge is still going to run you $100+ (and that's still on the cheap side) and you get no added benefit. |
| All times are GMT -7. The time now is 04:10 AM. |
