Weird Jingle So I've searched for some input on this with no real answers . The car is a 2011 MS3 basic bolt on mods and the car is running fine . When normal acceleration from a stop through second gear there is a pronounced jingle sounds like loose change . Does not do it when stopped and just giving throttle input seems to only happen when there is a load . Any direction in this I would appreciate . |
Where is the sound coming from? |
Mine does the same exact thing... I thought it was the intake rubbing on ECU... got new battery box and it still happened.... I've givien up and brushed it off as Autotech HPFP internal rattle. |
What clutch you got on the car? May be chatter |
Not sure if the HPFP is it the problem but keep in mind the HPFP will chatter a little on throttle tip in under load, the key part here is under load aka driving not sitting still free revving. |
I was going crazy trying to figure out a rattle a while back and it was my garage door opener [emoji14] Aside from that I have a squeak that happens when i apply throttle at low speeds, hpfp rattle, and some other loud rattle that seems to be coming from drivers dash when I'm easing into first from a stop. Basically I ignore it all at this point I hate the new tapatalk version and hope its replaced soon |
Thanks for the input hopefully someone will chime in eventually as I seem to not be the only one who has this odd noise . I'd rule out a hpfp . |
Did it just start randomly? Or did it start after doing a repair/mod? |
Ok this might sound weird but check the dust shield on your exhaust. I've heard of similar issue on newer Ford trucks and audi"s |
Mine always makes a jingle like that when I hit a bump on the drivers side. It has done it since the day I bought it. I have looked but never found it. I hope this was not helpful at all. |
It's a high pitched almost like keys jingling together on the key ring sound (have ruled out the key jingle by the way). It only happens for me right at tip-in in first and second and is usually more pronounced when its cold out. |
Do you have a CAI? When I had mine I had the sound you are describing. Took off that rice and put it on my wifes speed and same sound happened on hers. I think its the mounting point in the fender wall. |
Well I don't know then. I'm guessing you checked the muffler bearings already. Good luck dude! |
Did someone throw a bell into your engine compartment? Take a screwdriver and just start taping shit, tap heat shields around manifold, tap shift weight, tap tap tap. Try to find something that sounds similar to what you are hearing. Check cv axels, check for anything touching the hardline. Loose washers. Borrow buddies go pro, pull off hood, sucky cup inside engine. |
| All times are GMT -7. The time now is 04:10 AM. |
