![]() | | #1 | ![]() |
| RIP: November 21, 2012 ![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
(Thread Starter) | Not Ranked : 0 score I was about to post this in the Turbo forum but was on the fence and though I'd get more exposure in here. Mods correct me if I'm wrong. So Gen2s have this hood scoop that forces air through the intercooler; the volume of air going in is based on the forward speed of the vehicle (+/- headwind). What happens to that air after it goes through the intercooler? Well, it must get heated somewhat, on the order of 10s of degrees F. But it does what aerodynamically, just smash down on top of the engine and its valve cover and spread out in all directions under the hood? I have seen aerodynamic anomalies with the hood when driving at very high speeds (> 130mph), that seem to back up my theory. My hood will start shaking from all sides and eventually the air seems to escape out the cowl side, given enough forward speed and pressure on the hood scoop. I searched the forums and found nothing related to this. Now, we don't all drive 130mph all the time, but even at 30mph or 60mph, perhaps we can harness that slightly heated "used" up air to do something more useful than unsettle the hood. What if we could point it at the back of the engine, where the turbo is located, and let it escape underneath the car? I had some ideas: 1) Simply remove some combination of sealing and or underbody panels to achieve this effect. 2) Design a "plate" that sits on the underside of the intercooler that is higher on the leading edge than the trailing edge, with perhaps a downturned lip at the final edge (pointing air toward the turbo/rear of the engine bay). 3) Perhaps some sort of "spacer" or even just a combination of washers on the underside of the intercooler to give it more space to allow the air to be dispersed at a lower speed but higher volume (note this effect may not help force air to the rear of the engine, but it might lower the pressure of the air as it hits the valve cover, slowing the air down and allowing it to spread in more directions underhood). 4) ??? Am I way off base here? We all know that the rear of the engine, and the turbo etc get very very hot. I know that we need a certain amount of EGT to make the turbo work. But has anyone thought of, or tried to, a way to utilize the air coming in from the hood scoop to do something other than cool the intercooler?
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... |
| The Following User Says Thank You to fortressofcomfort For This Useful Post: | bertrand_CX_7 (08-21-2012) |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 546
Groaned at 44 Times in 32 Posts
| Not Ranked : 0 score I was expecting to open the stupidest thread known to man when I clicked it.. but this is a valid question in a way. Ultimately a plate going underneath the IC to divert air to the exhaust mani is just going to act as a giant hot plate. Since heat rises, its gonna end up heating up cooking and whatevers beneath it (like an oven). So youd end up killing the coil packs much sooner.
__________________ ![]() 2008 Cosmic Blue Mazdaspeed3 1986 Mazda RX7 2002.5 Sunlightsilver Protege5 (sold 12/26/09) Hey you should read this: http://www.mazdaspeedforums.org/foru...ler-you-58361/ |
| The Following 5 Users Say Thank You to NCZ13 For This Useful Post: | AZSPEED3 (08-22-2012), ChidoriSpeed (08-21-2012), f-castrillo (08-21-2012), Pseud0logik (08-21-2012), uncorked11 (08-21-2012) |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score The air in engineering terms is assumed to be ambient...ie there is soo much coming through there that the heat it picks up from the intercooler is considered negligible. Makes life easier...but you're probably right...might be 5-10 degrees warmer. But either way it gets forced out of the engine bay. Its not perfect and you'll have stagnant zones that are hotter...but thats why a lot of us remove the weather stripping. Allows some air to escape upwards. Don't know what you're getting at about turbine and egt's heat though. You could try to re-route air somewhere else but it's not going to do much. Solution...unbolt and take off hood.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
| The Following 3 Users Say Thank You to 86AmishMs3 For This Useful Post: |
![]() | | #4 | ![]() |
| I have candy in my van ![]() Join Date: Apr 2009 Location: Chicago, IL
Rep Power: 2810 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,091
| Not Ranked : 0 score Back when I had my MS6, I was intending to replace the TMIC with a heat exchanger for a LAIC. I had plans of making a plate to sit atop the valve cover, under the HE, to direct air to a hole cut in the hood, similar to a c-class benz: But then I sold my MS6, and bought a van. I'd suggest making a panel to fit under the TMIC, testing it out, and seeing if there is any benefit. It's hard to direct hot air around the top of the engine, without finding a quick way for that air to travel... hence M Benz hood idea.
__________________ Current Fail: 2008 Mazda5 DD/Mazdaspeed5 BT project |
| The Following 3 Users Say Thank You to MATT DAMOND For This Useful Post: |
![]() | | #5 | ![]() |
![]() Join Date: Jul 2012 Location: Aberdeen, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 313
| Not Ranked : 0 score To add to this, I'm curious about how the Corksport ram air intake + FMIC might impact this situation as it pertains to the aerodynamic anomalies mentioned with the hood. Uninformed guesswork would be that the problem would be reduced, since more of the air actually has somewhere to go, but that the problem would still persist to a lesser degree. Also, wouldn't routing air under the car potentially result in more lift?
__________________ Last edited by bislag; 08-21-2012 at 09:13 AM. Reason: irrelevant sentence removed |
![]() | | #6 | ![]() |
Solution: buy FMIC. Let hood scoop cool engine directly lol. Damn, I wanted a cheap solution to lower underhood temps where they heat up the most (by the firewall). Matt Damond is on the right track with what I was trying to imagine.
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... | |
| The Following User Says Thank You to fortressofcomfort For This Useful Post: | Chimmike (08-21-2012) |
![]() | | #7 | ![]() |
Groans: 793
| Not Ranked : 0 score The under tray is designed to pull that air down behind the engine and out under the car.
![]() | | #8 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score well its a very small thing but have you removed the rear weather-stripping? alot of hot air gets out the back of the hood if you do. just make sure you don't remove the ducting to the i/c, the gen2 scoop is very efficient in cooling compared to the gen1 and ms6 with the ducting on there. personally i have never noticed the hood bouncing around, but thinking in terms of raising it with washers/spacers isn't the worst idea ever. it will give a tad more room for the air to dissipate around the head, just have to make sure it still clears the hood and the under-hood ducting is still functional
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
| The Following User Says Thank You to snailD For This Useful Post: | fortressofcomfort (08-22-2012) |
![]() | | #9 | ![]() |
![]() Join Date: Aug 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,995
Groans: 88
Groaned at 186 Times in 83 Posts
| Not Ranked : 0 score holy random quetsion, batman subbing for updates.
__________________ ![]() radonelement.com |
![]() | | #10 | ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5051 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
| Not Ranked : 0 score ^I did this on the past few subies I've owned and they referred to it as tilting to get more air directed to the IC..... Then again, the "unused air" just goes flowing down to the DP area and under the car. Matt's Idea is probably the best out there. Nice post. A better air splitter/diverter on the gen2 would probably help with the hood bouncing. |
![]() | | #11 | ![]() |
| Will fuck up ur day ![]() Join Date: Feb 2010 Location: Parrish, FL
Rep Power: 4200 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,803
Groans: 433
/thread if you want to design some good aero shit, fab yourself some brake ducts and some ducting to direct air into the radiator and not just into and around it
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
![]() | | #12 | ![]() |
Groans: 88
| Not Ranked : 0 score i dunno, but i would't want to "cool off" the exhaust manifold. remember, that hot gases is what propels the turbo, cooling them down does the opposite.
| The Following User Says Thank You to Alejo_NIN For This Useful Post: | Chimmike (08-21-2012) |
![]() | | #13 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
| Not Ranked : 0 score It has to do with pressure. Refer to the venturi effect "When air hits the front of a car it causes a stagnation point, high pressure. So for air to flow across the radiator, there must be an area of relative low pressure on the engine side. The larger the difference in pressures, the more air will flow across. To increase this movement of air across the radiator, it's very important to shroud all edges so that air MUST flow through the radiator instead of around it. After air passes through the radiator, what happens to it all? Well some of it quickly exits through the under-body, but not much because air flow under a car is slow from all the drag caused by the gearbox, exhaust, suspension, etc... The rest of it stays inside the engine bay and creates a lot of turbulence as it collides with the engine and other components. This is therefore the limiting factor as it creates a high pressure, slow moving air (turbulent), so now the difference between pressures in front and behind the radiator is dramatically reduced. Air flow across the radiator decreases as a result..."
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
| The Following User Says Thank You to forcedinduktion For This Useful Post: | pzr2874 (08-21-2012) |
![]() | | #14 | ![]() |
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
Groans: 32
| Not Ranked : 0 score very good quesion...hmmmm...
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
![]() | | #15 | ![]() |
Groans: 793
| Not Ranked : 0 score This is why I feel the companies that build fmic kits should include shrouds that seal to the rear of the front number cover.
![]() | | #16 | ![]() |
![]() Join Date: Sep 2009 Location: Rosemead, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 717
Groans: 27
| Not Ranked : 0 score hood louvers
__________________ 08 MS3 () Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX () Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms () Centric Slotted Rotors/ Posi-Quiet pad () Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90 |
![]() | | #17 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
Groans: 52
Groaned at 145 Times in 38 Posts
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. |
| The Following User Says Thank You to bertrand_CX_7 For This Useful Post: | motherfnmonsta (08-21-2012) |
![]() | | #18 | ![]() |
Groans: 27
| Not Ranked : 0 score ^ hes talking about the air that cools the intercooler
![]() | | #19 | ![]() |
Groans: 793
| Not Ranked : 0 score Lol.
![]() | | #20 | ![]() |
Groans: 146
| Not Ranked : 0 score |
![]() | | #21 | ![]() |
Groans: 793
| Not Ranked : 0 score I'm not tooling up a brake press for it.
| The Following User Says Thank You to Tokay444 For This Useful Post: | pzr2874 (08-23-2012) |
![]() | | #22 | ![]() |
![]() Join Date: Jan 2012 Location: Sutton, Massachusetts
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 329
Groaned at 41 Times in 16 Posts
![]() | | #23 | ![]() |
| Not Ranked : 0 score that, and when i installed my front mount mazda had plastic pieces that forced the air into the radiator instead of letting it go around, which i had to remove to fit the front mount. i've been thinking of fabbing up new ones so the air thru the grill has to go thru the fmic and not around it. i'll wait til i get the new core in though
![]() | | #24 | ![]() |
Groans: 793
| Not Ranked : 0 score Everywhere. Top, bottom and both end tanks.
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score @NCZ13: "I was expecting to open the stupidest thread known to man when I clicked it" That's how most of my threads read so no worries. @86azms3: True, the higher the speed of the car, the smaller the difference between the temperature of the air going into the intercooler (which is just an air to air radiator/heat exchanger) and the temperature of the air exiting the intercooler. So heat soak is still there, correct. @MATT DAMOND: Your design I like... It is essentially like "taking the weatherstripping off but in a larger and more orderly way. Make it and paint it primer black and I'll test it for ya No really, its brill. If anything we'd see solutions coming from Germany, no?@bislag: "Also, wouldn't routing air under the car potentially result in more lift?" I would have to think so. This brings me (us) to the point of what is the problem we're trying to solve? a) reduce hood flutter at high speeds b) gain performance across the powerband c) help car stick to the road by reducing lift. As far as I'm concerned, B is the concern I'm trying to address. I rarely go REALLY fast, and the two times I've had the car to indicated 146mph (probably 140mph really), it stuck to the road like glue. Obviously things happen quickly and you have to be smooth, but that's what driving racecar is all about. In other words, I did not notice any "lift of the car, front or rear" anomalies, just hood flutter. And I know all about lift of the car. Try riding in an early 90s Toyota MR2. Here's a car that they put all their money into the styling and engine (at least the turbo engine) but none into the stick to the ground factor. My buddy had a NON-turbo MR2 and as we struggled to hit triple digit speeds, the front end became so light that I about shit myself. That rarely happens. I mean car turned into airplane. It changed lanes by itself. The MS3, even at 140mph (nearly 2squared or (2*2) ) was generating 4 times the aerodynamic trends and is still stuck to the road. Like I said, SOME attention was paid by Mazda to the aerodynamics of this car, but its like they ran out of money lol. @snailD: I have heard that many people remove their rear (cowl side) hood sealing. This would apparently allow more of the air that comes in the front of the car (the hood scoop, the radiator area, etc.) to escape directly our the cowl of the car, but a little less would be diverted under the car (maybe a good thing?). @Tokay444: derailed the thread just a little in post #15 (although truly it began to go astray on post #5 by bislag) by changing the topic from TMIC to FMIC. I understand your concerns with the FMIC, but let's stay on topic here since most of us still unfortunately have a TMIC. Much love though Tokay444 ![]() @pzr2874: Not addressing what I'm asking, but this is another modification that we could apply to the hood scoop. Basically you are saying, the subie guys make the *hood scoop better*. @Alejo_NIN: Point well taken. The turbo is driven by the Exhaust Gas Energy. This consists of both the velocity of the air and the heat in that (volume of) air. At best we could cool off the turbine housing a few negligible degrees, with a better air flow under the hood, resulting in a negligible difference. But what about keeping the intake side of things cool? Or where your intake sucks in air? For example, I've noticed that my IATs are always 10*F higher than ambient, even if I'm driving 40mph or more. Why is that? Must be a pocket of slightly hotter air up at the front battery side of the engine compartment. IATs must be measured before the turbo right? So let's cool that pipe. That's kind of my idea. The overall reduction of heat will outweigh any changes we could possibly make to the turbo's performance. @forcedinduktion: Understood. This is obviously not an MS3 specific chart so its kind of useless. But its good for showing folks why manufacturers test cars in wind tunnels these days. You'd be surprised at how much difference a little panel here, a little panel there, can make to the performance/aerodynamic abilities of the car. Do we know if a similar "wind tunnel" flow chart exists for the MS3? (yeah right). @easy: Not a bad idea. Obviously they would need to be located behind the hood scoop (between the hood scoop and the passenger compartment). Might make GenPu look better? How about SMILEY LOUVERS ?? ![]() @bertrand_CX_7: Other than giving us a little better sense of the external dimensions and shape of the engine, that video is not related to the discussion at hand. ![]() **** SUMMARY SO FAR: Lots of good ideas... - It seems that we need to define our/my goals better. I'm saying, for this thread, that reduced, and reduced more quickly, under-hood temps is the goal for those of us with TMICs. The more I think about it, the more it all comes down to heat-soak. I mean look at the FMIC guys all trapping 110mph+. Show me one K04'ed TMICed car that can do that on K04/93 only. If we don't have the $1,000 it takes to put a FMIC on our cars, then what do we do? I think what we do is GET THE AIR OUT OF THE ENGINE COMPARTMENT AS FAST AND QUICKLY AS POSSIBLE. I want to see IATs equal to ambient. As soon as I start moving I want more of the air that has stagnated under the hood for the last 2 minutes waiting at a stop light to get the hell out of my engine compartment. - It seems that removing the rear cowl insulation is an easy way to let more air "out of the engine compartment" thus hopefully allowing us to move more (cooler) air INTO the engine compartment. But at what cost to lift disturbances at high speeds, I don't know. Also, like @snailD eluded to, why not just raise the entire rear of the hood, maybe doubling the "gap" made by now not having insulation back there ? ![]() - I did personally, physically look at the factory setup and there's not much room under the factory TMIC to put *anything*. Spacers looked like a more complex idea than I originally thought. - We didn't talk much about improving the design of the factory hood scoop. - What about, not only taking the rear cowl insulation off the car (so there is a gap), but making this gap bigger, as big as possible. Anything else? I would certainly give up a bit of high speed instability (and lost wiper blades) for a car that heat soaks less and is like 10*F cooler under the hood, even in the "pockets" at all times, wouldn't you? Can someone get us an "underbody" shot of a GenPu? Maybe while its up on a rack? Can someone who has removed the rear cowl insulation post some pictures here? Has anyone added washers to the rear hood hinges in an effort to gain a couple more millimeters of clearance at the cowl side? Now what?
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... Last edited by fortressofcomfort; 08-22-2012 at 06:37 PM. |
![]() | | #26 | ![]() |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
As far as a plate under the intercooler, I wouldn't suggest that. There's not a ton of space under it (as you found) and if you put a plate to direct air there's a good chance you'll decrease the flow across the intercooler and raise your BATs. Matt Damond had the best idea IMO, venting the hood behind the IC to allow air to escape. It's the same theory as the weather stripping/hood spacing. Your best bet is the FMIC if you want to really lower under hood temps.
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." | |
| The Following User Says Thank You to anavrinIV For This Useful Post: | fortressofcomfort (08-22-2012) |
![]() | | #27 | ![]() |
![]() Join Date: Feb 2012 Location: Gibsonville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score Damn @fortressofcomfort you should be writing a novel or something because you really enjoy typing, JK Always love your posts/threads because I always learn something and you are informative but makes my head hurt. Condense your thoughts a little more for easier reading.
__________________ [SIGPIC] [/SIGPIC] 2012 Black Mica W/Tech Cobb AP AutoTech Internals JBR 88DM RMMJBR Heavy Knob JBR 3" WP JBR Rear camber arms UR TP Ford MOFO Tranny juice Rotella T6 Self Tune - (Work in Process) NGK Step 1 colder 5/7 corn fed |
| The Following User Says Thank You to Printman For This Useful Post: | jeopardy98 (08-23-2012) |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score OK, so what are the negatives of having a big gap at the cowl side of the hood? - Less air going under the car, maybe that's a good thing? - More wiper blades flying off? - Does water get down into the engine compartment during heavy rain? What gets messed up? I always like to question the design as it stands, so to those who have weather stripped/hood spaced, what problems have you run into?
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hey isn't Matt Damonds idea similar to what they did to the 2000s Firebird WS6? Didn't they combine a hood scoop with louvers? Why weren't those louvers "smiley?"
I like people to see my thought process, that's all.
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... Last edited by fortressofcomfort; 08-22-2012 at 07:00 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #30 | ![]() |
Groans: 433
| Not Ranked : 0 score All you need is a small brake, some thin aluminum, rivet gun and 2 sided tape, honestly. I've been contemplating doing this on my car for a while, direct air straight to the fmic.
| The Following User Says Thank You to Chimmike For This Useful Post: | Tokay444 (08-22-2012) |
![]() | | #31 | ![]() |
Groans: 146
| Not Ranked : 0 score I have the stripping off and hood raised 1/4 of an inch,, helps,,, but nothing in writing. Gen1 as well |
| The Following 2 Users Say Thank You to pzr2874 For This Useful Post: | anavrinIV (08-22-2012), fortressofcomfort (08-22-2012) |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score I dunno if its pic worthy, but if so, @pzr2874 can you show us the "gap" with the hood closed. More importantly, any issues like electrical, or wipers flying off? How'd you "lift the back of the hood? Unbolt hinges, put some washers, I guess 1/2" in between, and bolt back up? I guess if you do one at a time then no alignment should be necessary. Awesome, thanks. I will respect your result without numbers or metrics lol.
![]() | | #33 | ![]() |
| Police - Grammarhead ![]() Join Date: Sep 2009 Location: Metro Detroit, MI
Rep Power: 3749 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,748
Groans: 1,911
During the testing for the MZR 2.3L engine, there was a lot of difficulty in getting EGTs low, and the whole line of engines (both the DISI and the MZR 2.3 N/A) were delayed by several months after it was discovered that the insulation that was being used to reduce heat soak in the engine bay and passenger compartment was discovered to be inadequate. How do I know? I have a relative who worked on this issue. As we all know, there isn't all that much room under the hood, and in particular, the exhaust manifold doesn't get much air movement around it. That being said, it apparently gets a lot MORE now than it did at the beginning of the design process. What am I getting at? Well...basically, while I think it's an interesting experiment to see if we can reduce EGTs and heat soak issues (and possibly high-speed hood movement), it may be quite challenging to make real progress without making some very serious compromises for those of us who have daily-driven vehicles. I'm not sure why this hasn't been brought up before, or has only been hinted at, but there is something else we should be considering here. Hood flutter is likely caused by a pressure differential between the under-hood area and the air moving across the surface of the car. This is a little different than saying that there's and excess of air pressure under the hood. Moreover, if we divert more air up and over the car, the likelihood is that we'll eventually begin to see minor issues with high-speed stability. Basically, I'd like to see us figure out a way to channel more air UNDER the car. The higher the rate of flow beneath the car, the less lift the car will generate. Moreover, if we can channel air from the front of the car through the engine-bay, and then down past the exhaust manifold, we'll be able to lower our EGTs a bit and the expansive nature of hot air will help accelerate the flow of air beneath the car even further. As an added benefit, the pressure differential between the under-hood area and the air flowing across the surface of the car will be less significant, meaning there will likely be less hood flutter. TL; DR --> Mazda/FoMoCo spent a long time working on airflow through the engine-bay; if we're changing this, we should try and push more air through the engine bay and then out the BOTTOM of the car, NOT up through the cowl.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! ![]() | ||
| The Following User Says Thank You to Vansquish For This Useful Post: | Chimmike (08-23-2012) |
![]() | | #34 | ![]() |
![]() Join Date: Jun 2011 Location: Wilmington, Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 612
Groaned at 25 Times in 10 Posts
| Not Ranked : 0 score will post pics tomorrow. What i did. Removed cowl weather stripping, raised hood 1/2 inch, removed iner tmic ducting, fabed up a diy heat shield that goes under the tmic to help slow heat soak, raised tmic about one inch off the motor. this way there is more air movement across the top of the engine and less direct heat exposed to the bottom of the tmic.
__________________ If your not first your last. ![]() 03 Speed Protege.. SOLD 10 Speed3 BT and getting my DRANK on!!! |
![]() | | #35 | ![]() |
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 | |
![]() | | #36 | ![]() |
Groans: 793
| Not Ranked : 0 score And here I was accused of thread derailing.
![]() | | #37 | ![]() |
Groans: 793
| Not Ranked : 0 score You don't want any MORE air flowing under the car. That will create drag and lift. You want the air flowing under the car already, to be faster than the air flowing over the car.
| The Following 4 Users Say Thank You to Tokay444 For This Useful Post: |
![]() | | #38 | ![]() |
Groans: 433
![]() | | #39 | ![]() |
![]() Join Date: Jul 2012 Location: Glen Burnie, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 464
Anyone try ceramic coating the valve cover reduce the heat being transferred into the TMIC?
__________________ 2006 CSRT8 CAI, Tune | |
![]() | | #40 | ![]() |
| gonads and strife ![]() Join Date: Jul 2009
Rep Power: 241 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
| Not Ranked : 0 score Somebody needs to build an undertray/skidplate that reduces engine bay pressure as much as possible. That's the best solution for moving more air through the IC and evacuating the hot air out of the engine bay. Problem solved. |
| GI: TRZ Top Mount Intercooler | CaptainKRM | Mazdaspeed3/6 General Discussion | 218 | 03-03-2009 08:09 PM |
