![]() | | #41 | ![]() |
| Police - Grammarhead ![]() Join Date: Sep 2009 Location: Metro Detroit, MI
Rep Power: 3749 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,748
Groans: 1,911
I've got the supplies to fab up a sort of shitty full-length undertray and I've been meaning to do so for some time now (almost a year). This topic is something I hadn't really considered and now I'm having some pretty big second-thoughts about whether or not it's a good idea to do one without doing a bit more R&D into engine-bay airflow and stagnation. I suspect that the reason that the stock MS6 undertray has its innate convex shape is to create a low-pressure zone behind the front wheels. This would help to draw air out of the engine bay and pull it under the car. If you look at the general shape of the underbody of the MS6, it starts low at the front (with the skid tray) and rises gradually towards the tail end of the vehicle. In essence, it looks a bit like an inverted airplane wing (no doubt intended to improve high-speed stability). I wonder if it'd be possible to modify the skid plate such that it is still more efficient at drawing air down through the engine bay by creating some rearward-facing openings that hang into the airstream beneath the car, essentially sucking air out of the engine bay near the firewall.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! ![]() | |
![]() | | #42 | ![]() |
Groans: 793
| Not Ranked : 0 score With the correct placement of naca ducts, you'll still achieve the rearward draw from the engine bay.
![]() | | #43 | ![]() |
Groans: 1,911
Edit: I don't want to derail the thread, but what do you guys think about doing a mock-up/test for something along these lines using these as a starting point?: http://www.walmart.com/ip/ATP-Extra-...p-Pan/16778234 ![]() It's 47.0" x 25.0" x 0.5", and I realize that it's paper-thin and won't last more than a few decently large rocks, but it might give us something to go on.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! ![]() Last edited by Vansquish; 08-23-2012 at 10:56 AM. | |
![]() | | #44 | ![]() |
| RIP: November 21, 2012 ![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
(Thread Starter) | Not Ranked : 0 score I can be a guinea pig if you want for whatever. So who's it gonna be; to fashion up a GenPu hood with scoop and louvers and send to me for a low low price. Black or carbon fiber please.
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... |
![]() | | #45 | ![]() |
![]() Join Date: Jun 2012 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score This is a very interesting thread on a subject I tried to wrap my head around the first time I looked under the hood. I was surprised by a couple things: ·How much air is allowed to bypass the TMIC via the extra holes in the plastic hood ductwork. I understand the need to certain extent just not why it was designed to allow so much air bypass the IC. ·How close the TMIC is mounted to the valve cover hampering airflow at higher speeds. While I think a tray below the IC as mentioned before is not an ideal design it’s not a bad idea. What I mean by that is rather than mount a tray to direct the air to the back side of the engine create composite ductwork to be attached to the sides of the IC and lower back side (rear bottom for lack of better terminology) which can be exhausted either through hood louvers/vents or via a gap created by removing the seal and raising the rear of the hood. This should work pretty well as the hood scoop will be pressurized by ram air and there will be a venture effect caused by the exhaust vents thereby helping draw more air through the IC. Reversed NACA ducts can help create a significant negative air flow but they need to be placed on a surface that has high velocity air passing over them (side of fender, side window, etc). Mounting them to the rear of the hood is far from ideal as that area of the hood generally has stagnant air flow. As a side note I have a fantastic article on the development of the NACA ducts on my computer at home which I can post if anyone is interested.
__________________ '10 VRM MS3 3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3 Strive for perfection in everything. Take the best that exists and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough. Sir Henry Royce |
![]() | | #46 | ![]() |
| Will fuck up ur day ![]() Join Date: Feb 2010 Location: Parrish, FL
Rep Power: 4200 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,803
Groans: 433
| Not Ranked : 0 score I think you guys don't realize just how little air goes through the ducting to the IC, and the fact that it's not moving at 900 miles an hour, it still flows out through the back bottom of the engine bay. There are several dozen more important things most of you could work on until this stuff becomes necessary. Shit, most of you don't even have 300whp, let alone are big turbo with built motors making significant power.
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. |
![]() | | #47 | ![]() |
Groans: 1,911
| I hear you, but I'd still like to see my IAT/BAT/ and fuel economy improve. If better airflow through the engine bay can be achieved without an increase in drag...why the heck not try?
| The Following User Says Thank You to Vansquish For This Useful Post: | f-castrillo (08-23-2012) |
![]() | | #48 | ![]() |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
Yes, an imidiate decrease in Coolant temps and Intake temps was noticed, however only at crusing speeds, lets call them 40+ mph. However, this is direct airflow to the front of the car which explains why an impat was seen on the radiator (IE: coolant temps) and only more so with a decent bit of speed. To get going fast enough where enough air would be getting drawn out the back of the Engine bay, youd be going fast enough, or have already been driving long enough that would you no longer be heat soaked anyways... The only way to reduce heatsoak im thinking is to reduce the stagnant heat/air that results from sitting / low speed driving.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() | | #49 | ![]() |
Groans: 793
| Not Ranked : 0 score No one said anything about putting naca ducts on the hood. Lol. We were talking about a full under tray.
![]() | | #50 | ![]() |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
| Not Ranked : 0 score Yeah, NACA ducts at the rear of the front undertray.....
__________________ ![]() "I only do what the voices in my wife’s head tell her to tell me to do" |
![]() | | #51 | ![]() |
![]() Join Date: Oct 2011 Location: El Paso, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
__________________ ![]() 2011 MS3, HTP 3.5 intake/TIP, 51R battery box, Treadstone TR8L w/ Protégé Garage Piping, Autotech Internals, UR catless DP and test pipe, AP V2 (RichTuned 3:9 E85) ITV22 plugs. Vanilla scented air freshener. | |
| The Following User Says Thank You to HavasuSpeed3 For This Useful Post: | Chimmike (08-23-2012) |
![]() | | #52 | ![]() |
![]() Join Date: Jun 2011 Location: Wilmington, Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 612
Groaned at 25 Times in 10 Posts
__________________ If your not first your last. ![]() 03 Speed Protege.. SOLD 10 Speed3 BT and getting my DRANK on!!! | |
![]() | | #53 | ![]() |
![]() Join Date: Mar 2012 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
Groaned at 18 Times in 4 Posts
| Not Ranked : 0 score Im thinking there may be some way of incorporating something like this into the gentwo hood, on the sides of the scoop. Would need alot of R/D but I think with proper placement, the high pressure going over the hood would pull sufficient air out of the hood so that it wouldn't cause unnecessary turbulence under the hood at high speeds. And with more air being pulled out from under the hood, it (in theory) should increase the amount of downforce generated by the aerodynamic shapes and styling of the car because the pressure under the car would, in effect, be less.
__________________ Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11 Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS) [SIGPIC][/SIGPIC] K04 POWER FIGURES 277HP/325TQ SixTuned On 93 314HP/356TQ Rfinkle2 Tuned With 33% Corn S360 POWER FIGURES 365HP/356TQ Purple Drank Tuned ON 93 421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING |
![]() | | #54 | ![]() |
Groans: 433
| Not Ranked : 0 score I find that extremely hard to believe with tmic and removed ducting.
![]() | | #55 | ![]() |
| Not Ranked : 0 score Also, with the added venting, it would suck specifically the HOT air out from under the hood, which would lower the underhood temps and effectively lower IAT's as well. Lower IAT's = lower BAT's = MOAR POWAH!!
![]() | | #56 | ![]() |
| Not Ranked : 0 score When i get home i will post my logs
![]() | | #57 | ![]() |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
| Not Ranked : 0 score Not really. High air temps are caused by the compression of the air in the turbo. BATs can only be as cool as the ambient air (in a perfect world; in reality they will be at best 10-15 deg above ambient)...that's what the intercooler is for. Theoretically lower IATs will create lower boost temps pre-intercooler, but in reality the effect is minimal. And besides, with the IC the temperature of the air coming out of the turbo is irrelevant until you start stretching outisde of a turbo's efficiency range. so yeah...Lower IAT=/=Lower BAT
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." |
![]() | | #58 | ![]() |
| Not Ranked : 0 score @anavrinIV Quit raining on my parade...lol Can't just let me have a moment? Maybe comment on the vented hood idea and how it could possibly positively/negatively effect the car's performance? Gotta pick one vague statement that's correct (only to a degree and not perfect) and pick on it...jeez...some people...lol
![]() | | #59 | ![]() |
A full under tray? Wasn't there some mention about reasonable cost in previous posts? You're quickly getting back to installing a FMIC if intake temps are that high on your hit list.
__________________ '10 VRM MS3 3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3 Strive for perfection in everything. Take the best that exists and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough. Sir Henry Royce | |
![]() | | #60 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 | |
| The Following User Says Thank You to snailD For This Useful Post: | Vansquish (08-23-2012) |
![]() | | #61 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score This is just slightly off topic...has anyone ever used an intercooler water spray system to reduce heat soak in a speed? Nevermind... Thoughts on Intercooler sprayer Last edited by ASmith; 08-23-2012 at 11:44 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says NO Thank You to ASmith For This Un-useful Post: | Chimmike (08-24-2012) |
![]() | | #62 | ![]() |
Groans: 793
Unsubbing. Call me back in when the undertray goes to the wind tunnel.
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
![]() | | #63 | ![]() |
Groans: 433
| Not Ranked : 0 score I think you missed the whole fucking point of this thread. The engine bay has a specific airflow pattern to it. IF you disrupt it by adding various vents wherever the fuck you want, there will just be random flow out of the engine bay and likely won't have the effect you're looking for, let alone a well-thought-out system.
| The Following 2 Users Say Thank You to Chimmike For This Useful Post: | fortressofcomfort (08-24-2012), Tokay444 (08-24-2012) |
![]() | | #64 | ![]() |
| Not Ranked : 0 score I didn't miss it. I know the point. And after I posted I found myself realizing that what I HAD posted was off topic. I had good intentions though. Just poorly planned ones.
| The Following 3 Users Say Thank You to Ray Danger 2020 For This Useful Post: |
| GI: TRZ Top Mount Intercooler | CaptainKRM | Mazdaspeed3/6 General Discussion | 218 | 03-03-2009 08:09 PM |
