 Old 03-31-2013, 08:02 PM   #1
poisonouschimp's Avatar
Posts: 59   (View Stats)
poisonouschimp has a spectacular aura aboutpoisonouschimp has a spectacular aura aboutpoisonouschimp has a spectacular aura about
Default What is wrong?
I did a few WOT pulls today and noticed a problem. At about 5k rpm in 4,5,6th the engine or something cuts out and I can't keep accelerating, then I get boost again and hit 5k again and same problem. It almost feels like a limiter or something. The current tune has the limit at 6700 and a speedlimiter set to 180.
When I first had the FMIC on I didn't have the hose clamps fully tightened and at 18psi one of the tubes popped off. Now with the stage 2 tune I run at 22psi and everything seems fine except for these freeway pulls. Around town it seems fine.
Mods:
Fuel pump upgrade
Corksport FMIC
Corksport long DP w/ high flow cat
Corksport CBE
Corksport TIP
Corksport SRI
COBB AP running Corksport stage 2 map with corresponding mods.
Any suggestions would be great! Sorry I didn't know what section to put this in because I don't know where the problem might be coming from.
poisonouschimp is offline   Reply With Quote
 Old 03-31-2013, 08:04 PM   #2
spals's Avatar
Posts: 305   (View Stats)
spals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the world
Logs?
CP Pistons 88mm, Manley H-Beams, Balanced Crank
BNRS3V2, Cobb Catted DP, ETS TMIC, 3.5" JBR Alum Intake, AT HPFP
GS EBCS, 3 Bar Map, JBR 88 RMM, DM OCC, TIGs, BSD+Baffle
SBC Stage 2 Daily, JBR RSB, Koni Yellow, Konig Miligrams 18x8.5, Nitto NT-05 245/45
Spalsbuilt-Freektuned
spals is offline   Reply With Quote
The Following User Says Thank You to spals For This Useful Post:
ABolewski (04-01-2013)
 Old 03-31-2013, 08:04 PM   #3
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
Groaned at 64 Times in 21 Posts
That's the k04 telling you to get fucked.
Also the stage 2 map targets 22 psi? That seems high.
2010 Mazdaspeed 3 Black Mica w/ Tech Package - Traded In
2014 Ford F150 FX4 Ecoboost - Current
Dmurray06 is offline   Reply With Quote
The Following 4 Users Say Thank You to Dmurray06 For This Useful Post:
ABolewski (04-01-2013), rfinkle2 (04-01-2013), Tokay444 (03-31-2013), Voltron (04-01-2013)
 Old 03-31-2013, 08:36 PM   #4
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,899   (View Stats)
Groans: 540
stage 2 targets like 18 psi, you're overboosting big time.
get a real tune.
94 M
06 MS6
The Following 3 Users Say Thank You to Pu Manchu For This Useful Post:
ABolewski (04-01-2013), cshunter (04-01-2013), Dmurray06 (03-31-2013)
 Old 03-31-2013, 09:34 PM   #5
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
I bet you're hitting boost cut.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
The Following 5 Users Say Thank You to Boosted Beluga For This Useful Post:
ABolewski (04-01-2013), adrager622 (04-04-2013), cshunter (04-01-2013), MS3G35 (04-01-2013), rfinkle2 (04-01-2013)
 Old 03-31-2013, 11:04 PM   #6
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
@Pu Manchu; is right. Stage two targets 18 or 18.5 PSI. Something is not going as planned unless you upped the boost your self then in that case I would go back to 18 or 19 PSI and slowly up the boost to see exactly at what point it happens again. If you are indeed over boosting then I would stay out of the throttle until you can get a real tune. Either way you can never go wrong hitting up one of the awesome etuners on this forum.
 Old 03-31-2013, 11:10 PM   #7
LumberJack's Avatar
LumberJack has disabled reputation
Groans: 57
Groaned at 21 Times in 13 Posts
Pretty sure your hitting boost cut if your getting that much boost. I believe the OTS Stage 2 maps have boost cut at like 20-21psi if I'm not mistaken. Back your boost down
2018.... Doing even more freeky things!
10.36@148 Fastest Gen 2
LumberJack is offline   Reply With Quote
The Following User Says Thank You to LumberJack For This Useful Post:
 Old 04-01-2013, 12:21 AM   #8
mxlplx71's Avatar
Posts: 3,265   (View Stats)
Groans: 128
the stock bpv wont hold that anyway
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 04-01-2013, 12:28 AM   #9
I have the hks ssqv bov running full recirc. I did not alter the boost myself, I downloaded the corksport tune from COBBs website and installed it. The peak boost on my ap logs at 21.6psi. How can I change the pretune maps to lower my boost manually to see if that would help?
 Old 04-01-2013, 12:31 AM   #10
Pu Manchu's Avatar
Groans: 540
@rfinkle2; @ms3blackmica;
94 M
06 MS6
 Old 04-01-2013, 12:36 AM   #11
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Definitely overboosting and hitting the fuel cut limiter.
Depending on which stage 2 map you are running, the fuel cut limit is ~2 psi above boost targets on OTS maps.
The new OTS maps are known for terrible calibrations.
What you need to do is lower your WGDC table for starters. It is in ATR in the wastegate tables.
I would multiply the entire table by 0.50 to get you started.
www.tunedbynishan.com
The Following 2 Users Say Thank You to ms3blackmica For This Useful Post:
cshunter (04-01-2013), rfinkle2 (04-01-2013)
 Old 04-01-2013, 12:40 AM   #12
would it just be best to go get a custom tune then to be safe? How would I tell if it fuel cuts or the turbo that is the problem? Why would I be getting fuel cuts with the fuel pump upgrade?
 Old 04-01-2013, 12:47 AM   #13
Pu Manchu's Avatar
Groans: 540
within your ecu map you can specify a map sensor psi where at which the ecu shall cut fueling.. you need to read up on the basics of tuning this platform or pay one of the etuners for a reliable map.
94 M
06 MS6
The Following User Says Thank You to Pu Manchu For This Useful Post:
 Old 04-01-2013, 12:51 AM   #14
ok thanks, ill look into a custom tune
 Old 04-01-2013, 08:41 AM   #15
Steven's Avatar
Posts: 634   (View Stats)
Steven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the world
I would flash a Stage 1 OTS map for the time being though.
2012 Mazdaspeed3 w/tech
Electronics: Cobb AP - Ultragauge - CS EBCS - Bosch 3 Bar
Engine: Autotech HPFP - Sure Aeros - Sure Return - HTP TIP - CS BPV - CS DP + RP - NGK 1 Step Colder Plugs
Steven is offline   Reply With Quote
 Old 04-01-2013, 02:48 PM   #16
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
Stage 1 is going to overboost like crazy with a downpipe, it's not going to hold steady, so he's gonna have the same problems as he's currently having just at a lower level. Which is better of course but still not much help.
Bone stock so far
 Old 04-01-2013, 02:52 PM   #17
Dimenus's Avatar
Posts: 2,825   (View Stats)
Dimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the world
Groans: 33
I would echo @ms3blackmica; and neuter your wastegate settings and see what kind of boost you're hitting there.
With a DP and OTS Stage 1 WGDC settings (which are lower than Stage 2) I was hitting almost 19.5 when the target is 18.5.
2012 Velocity Red Mica
Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC
Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps
Dimenus is offline   Reply With Quote
 Old 04-03-2013, 12:09 AM   #18
Here is a log I just took. I went from 4th to 5th then hit the problem. It is kinda hard to log on the freeway, let me know if I need to get a better log of it.
 Old 04-03-2013, 12:15 AM   #19
Lines 189-196 in excel is where the problem is. I have full throttle, yet the boost drops down
 Old 04-03-2013, 12:24 AM   #20
Attached is the map I am running
 Old 04-04-2013, 08:08 AM   #21
adrager622's Avatar
Posts: 745   (View Stats)
adrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the world
Groans: 46
Like others have said, you're experiencing boost cut. I would definitely look into getting an e-tune ASAP. COBB maps are ok as starters, but have their limits and are known to not be the greatest, especially with a stage 2 map.
2010 MS3 Black Mica
-JBR RSB, JBR Boost Tubes and BPV hose, JBR 80a RMM, CP-e Nano SRI, 6000K HIDs
adrager622 is offline   Reply With Quote
Something is wrong...HELP! luv2insanity Mazdaspeed3/6 General Discussion 48 06-19-2013 08:20 AM
Wtf is wrong with my car? ms3speeed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 10-07-2012 03:08 PM
Something wrong thanox2 Mazdaspeed3/6 General Discussion 0 04-21-2009 09:25 PM
Page generated in 0.64595 seconds with 33 queries
