-   -   Wheel Scapers Rattling (http://www.mazdaspeedforums.org/forum/f544/wheel-scapers-rattling-131971/)
JFord 12-04-2012 10:17 AM
A couple months ago I intalled some Ichiba wheel spacers.
They worked great. No wheel shake.
But in the past week or so I have noticed a rattling sound coming from the front right wheel.
I took the wheel off and noticed that the center ring had rattle loose from the actual spacer.
I push the ring back into the spacer and reinstalled the wheel.
Everything seemed fixed for about 30 miles but now im starting to hear the rattle again.
It seemd the ring just keeps rattling out of the spacer.
By the way, this is the only wheel doing this out of the four.
Any suggestions on how to fix this?
Thank you,
KevMS6 12-04-2012 10:26 AM
I've heard of people using instant gasket so that the spacer won't move... Obviously gasket the spacer to the hub and it can be removed easily enough when required.
I've got the JBR 5mm spacers and they fit on very tightly and required persuasion with rubber hammer...
Only a suggestion :)
razor3232 12-07-2012 06:59 PM
@KevMS6
Is there any noticeable difference with the JBR spacers? I was thinking about asking the wife to get me those for Christmas but don't want to bother if there isn't much of a visual or handling difference.
thanks
KevMS6 12-09-2012 04:22 PM
Visual improvement is ok but don't expect a massive change... I like them and glad I got them for my stock wheels as they were too far in the arch and the spacers made a noticeable improvement, however as I'm running slighter wider wheels I don't really require them so I'm going to remove next time I need the wheels off.
Also my current wheels are over a kilo lighter so better of without heavy spacers :)
I would say go for it
Page generated in 0.16271 seconds with 11 queries
