![]() | | #1 | ![]() |
![]() Join Date: Jan 2011 Location: Richmond, Va
Rep Power: 751 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,149
Groans: 202
Groaned at 33 Times in 18 Posts
(Thread Starter) | Not Ranked : 0 score I have some money I can start spending again on modding and I am pretty stuck on what I want to do next. Putting the $ toward paying the car off or debt is not an option, nor am I looking to go BT. I'm stuck between getting CO's, or getting Koni Yellows, electronic cut out and some new exhaust tips. My car is pretty much fully bolted with the exeption of a catback due to wanting to keep the noise down in the neighborhood when I leave early or come home late. Is there anything else I'm missing or something you guys would put the money toward as far as mods are concerned? Oh yeah, I also have a brand new set of tires sitting in the garage waiting for the current set to wear out, along with my winter set up. I guess I just can't decide what I will be more happy with between co's and struts, as far as ride comfort and the low's are concerned. Any input appreciated.
__________________ 2010 CBM W/ Tech, Cobb AP Tuned by rfinkle2, PTP HPFP, Ported IM, HTP 3.5" Intake, CS DP, CS TP w/QTP E Cut out, ETS TMIC, D.O WMI D07, NGK Iridium Ix, JBR EGR Delete, Coolant Bypass, JBR IM TIG, GS EBC 3 Port Mode JBR TMM 70, JBR RMM 88, JBR SSB, JBR AP Holder, Sure SSP Swift Springs, Koni Yellows, GC Bump Stops, CS RSB, Ebay Adj. Camber Arms, Sonic Tuning ST8'S 18x8.5 on 245/40/18 NT-05 |
![]() Join Date: Nov 2011 Location: Naperville, IL
Rep Power: 2090 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 350
Groaned at 46 Times in 31 Posts
/thread
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete. | |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | SLOWHATCH (08-13-2012) |
Groans: 202
(Thread Starter) | Not Ranked : 0 score FWIW, the car seems VERY solid even without it. I added some support to the PMM and engine is pretty solid. Would rather not add any more NVH to the cabin if it's not necessary. At this point it doesn't seem like I need it. Even at the track.
![]() | | #4 | ![]() |
Rep Power: 11917 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,906
Groans: 235
I know it is not a well received mod on msf, but I just got the Tanabe strut tower brace and it seems to make the car flatter through fast turns. There is not much difference in regular driving, but when cornering fast, I think it makes a pretty substantial improvement. The bars can be had for around $120.00. I noticed a post by JTMS3 on another forum and he and I share many of the same mod opinions. He said he saw an improvement, so I bit and am glad I did.
| The Following 5 Users Say Thank You to rfinkle2 For This Useful Post: | helmetface (08-13-2012), Seatime3 (08-13-2012), SLOWHATCH (08-13-2012), StayBroke (08-13-2012), Toymachinespeed (08-14-2012) |
![]() | | #5 | ![]() |
| Able ![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 3286 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,159
Groans: 125
This is of course based on speculation but I've been mulling over the idea as of late. Oh and @OP - Tires!
__________________ ![]() | |
![]() | | #6 | ![]() |
Groans: 202
(Thread Starter) | Not Ranked : 0 score Oh and @OP - Tires![/QUOTE]
![]() | | #7 | ![]() |
Groans: 125
Are you doing drag or track time? I'd say put some money towards an instructor if you've got the means to burn..you'd be surprised how much you'll learn. And if that isn't your thing..would you even consider a lesser BT such as a BNR3? You could really pick up a lot that way..otherwise you're kinda "done" heh time to enjoy it.
| The Following User Says Thank You to helmetface For This Useful Post: | SLOWHATCH (08-13-2012) |
![]() | | #8 | ![]() |
Groans: 202
An instructor would be a great investment, since I drag race more than anything. However I'll be needing new dampers soon either way, hence the CO's vs the Yellows.
![]() | | #9 | ![]() |
Groans: 125
| Not Ranked : 0 score Forgot about dampers, obviously you know your choices, for specifically drag- Yellows would be completely adequate. I started on Bilsteins+CS springs and while they were one of my favorite mods, I wanted adjustability. And ultimately sold that setup and upgraded to MS Coils and I absolutely love them.
![]() | | #10 | ![]() |
Groans: 202
Only reason I want co's is so I can go a hair lower. I could probably sell my swifts for a couple hundred and have a similar investment while having adjustable dampening and ride height. But on the other hand, I could have better handling and also have a few extra hp with the cut out plus get rid of the hideous oem exhaust tips. I tend to over think every purchase I make, but the good thing is I don't regret ANY mod I have done so far. Just want to keep it that way.
| The Following User Says Thank You to SLOWHATCH For This Useful Post: | rfinkle2 (08-14-2012) |
![]() | | #11 | ![]() |
Groans: 125
![]() | | #12 | ![]() |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
Groaned at 53 Times in 26 Posts
I would go bilsteins over the konis.. I know for me (and some others) the rear went a lil lower after the bils were installed...the fronts can be made to go lower if you cut or bend the stopper tab and let the strut slide all the way down till it hits the knuckle bolt (similar to how OEM is) ...Maybe this will solve the "hair lower" problem? .. I'm seriously in love with mine, especially after my custom alignment.. If you want CO's and on the budget the only two I would consider are the KW 1 and H&R's. As far as sound.. I like my UR.. Gen2 are harder to make sound good...but the UR does a good job without making it obnoxious... Maybe you can do try cutting out the resinator if you haven't done so already. As far as power, you have done pretty much all the "cheaper" stuff. All I can think of is a 3 inch intake. edit.. Almost forgot...I know this isn't what you were thinking of ..but cpe- stage2 rmm and TWM full replacement shifter does wonders on how the car feels. Upgraded stock style rmm just isn't all that good after you feel the different cpe stage 2 makes.. And comparing an SSP to the TWM is a joke. It's not even a comparison.
__________________ *COBB: AP, shifter weight *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, 88TMM, EGR delete, WP *Grimmspeed: EBCS *TWM: Full Shifter *Tomei: Shift knob *KDM: HPFP internals *Ford: syn trans fluid *UR: TP, CBE *Bremmer Kraft:18x8 et45 BR05 (5mm rear spacers) *Dunlop: 245/40/18 Sport Maxx TT * Bilstein: B8 Sport *SWIFT: Spec-R springs *gtspec: 4point ladder brace, rear subframe brace * AC DELCO : Adj. camber arms *Denso:ITV22 *Stoptech: Performance pads *MORIMOTO: 5K HID elite *OEM: Gutted primary cat Last edited by specvspeedfreak; 08-14-2012 at 11:50 AM. |
| The Following User Says Thank You to specvspeedfreak For This Useful Post: | SLOWHATCH (08-14-2012) |
![]() | | #13 | ![]() |
![]() Join Date: Jul 2011 Location: Glendale Heights, IL
Rep Power: 285 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
I'm with the TWM full replacement. It is awesome. I can't tell a difference since I drive with it everyday and it's been 6k since I switched. But I drove a buddies genjuan the other day and holy fuck. The shifts are a mile
__________________ Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC// |
| The Following User Says Thank You to Jhornbrook For This Useful Post: | rfinkle2 (08-14-2012) |
| Opinions for TIP? | FTMazdaS3 | Gen2 MS3 General Discussion | 23 | 08-11-2012 10:03 PM |
| Would like opinions on my WOT log | GODspeed7 | 2010 MS3 - ECU Computer Tuning | 7 | 04-13-2012 06:32 PM |
| Need opinions | copulat0r | Mazdaspeed3/6 General Discussion | 15 | 09-16-2011 07:18 PM |
