 Old 04-25-2011, 08:24 PM   #41
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Originally Posted by MATT DAMOND View Post
From what I've researched, for valve build-up on direct injection cars, we have the least amount of deposits sticking to our valves.
That's certainly good to know. I've seen some of the horror stories from VW/Audi forums in their FSI engines. Holy donkey dicks. Intake valves that look like Chinese teriyaki meat-on-a-stick
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following 2 Users Say Thank You to Cataphract_40 For This Useful Post:
MATT DAMOND (04-25-2011), Nataphen (04-25-2011)
 Old 04-25-2011, 09:04 PM   #42
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
I was going to mention what Matt was saying about pulling the intake and cleaning the valves earlier, but I didn't think that anyone would want to go to the trouble. If you could do without your car for about a weekend every 30k miles, you could keep them pretty clean.
Roll the car while in gear to make sure that the valves close, then pour a little sea foam, or whatever cleaner, in there and let it soak. Scrub it off with a toothbrush or long swabs after it's had a couple of hours to soak, then use a tube or narrow attachment on a shop vac to suck all that mess out of there. After that is done, roll the car until the next valves close, and repeat until all four sets of valves are done.
Time consuming, but not terribly hard provided you can pull the IM.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
The Following User Says Thank You to Nataphen For This Useful Post:
Boosted Beluga (04-25-2011)
intake valves with 82k miles, no catch can mrkdspd MazdaSpeed 6 - Engine, Transmission & Driveline 10 04-08-2011 08:55 AM
Video: Porsche resurrects 1900 Semper Vivus full-hybrid for Geneva display Haltech Automotive News 0 02-24-2011 02:10 PM
Recycling Tech from the 1900 Electric Lohner-Porsche Haltech Automotive News 0 07-21-2010 04:00 PM
Page generated in 0.23168 seconds with 22 queries
