-   -   WTF boost cut?!?! (http://www.mazdaspeedforums.org/forum/f544/wtf-boost-cut-91677/)
boosted_out 09-13-2011 06:50 PM
WTF boost cut?!?!
Alright so today on my way home from the gym i decided to go wot in 3rd gear and looked at the shitty stock boost gauge that for some reason I couldnt hit full boost??! When I go WOt I look at my boost gauge and boost goes all the way up till the before last line. For some reason I cant hit the last boost line?? My engine mods is only a COBB sri which i had for a few months and had no problems hitting full boost before and I dont have a cel. Is it possible I have leak? Possibly maybe my sri loossen up?
G26 09-13-2011 07:04 PM
Well, first off thats not boost cut, boost cut would be an immediate power cut that feels like shit.
Also, keep in mind the stock tune is a load targeting tune, meaning it will adjust your boost to hit that load target. You could also have a boost leak post turbo, which could be one of your stock boost tubes. A pre-turbo leak should not really effect boost levels, it would affect afr.
Without the ap and data logs, it could be anything.
boosted_out 09-13-2011 07:20 PM
Its rly pissing me off lol ill try uninstalling my sri and putting it bk in tomorow
Raider 09-13-2011 07:23 PM
Check hot and cold pipe, as well as stock bpv. And get a real boost gauge, not that VTEK meter!
boosted_out 09-13-2011 07:29 PM
Alright, would the cold weather have anything to do with it?
captain slow 09-13-2011 07:29 PM
This happened to me once but then I realized I took my foot off the gas....
Seriously tho, are you feeling power loss or is the gauge just not making it to full boost?
boosted_out 09-13-2011 07:31 PM
Well I dont feel that my mazdaspeed is fast but that might have to do with getting used to it.
captain slow 09-13-2011 07:36 PM
Lol. Potential boost leak. Maybe its cuz its a factory gauge.
Also, my car could outrun a jetcar when I got it, but after a few weeks I feel as is if my old grand am could keep up. Every mod has its woah time then its like meh...
SLOWHATCH 09-13-2011 07:40 PM
Guessing you didn't get the whole part where @G26 was trying to explain to you how the stock map is a torque targeting map vs boost based?
Yes the colder weather will cause lower boost.
boosted_out 09-13-2011 07:41 PM
But the thing is even tho its factory shit gauge, before it would show full boost
captain slow 09-13-2011 07:44 PM
Yeah. Makes sense Fo sho. This could be it as well.
Sent from my DROIDX using Tapatalk
SSinstaller 09-13-2011 07:46 PM
The problem is most likely you not understanding how the system works...
HIGH IAT+more boost=ECM HITS LOAD TARGET=less boost+LOW IAT
SLOWHATCH 09-13-2011 07:50 PM
might want to write out the abbreviations for the less informed. ^^^
2k4_8 09-13-2011 07:56 PM
Not much of an abbreviation to explain unless I am wrong...but IAT=Intake Air Temp
In short, the colder the air and the more dense equals the same torque level as hotter air that is less dense that has been boosted to a higher pressure in order to achieve said torque level. My gauge reads only 13-14 psi if the temps are less than 50 ambient, any other time it will peg out the stock gauge....not that I trust that for true boost level.
captain slow 09-13-2011 08:09 PM
+1 Someone paid attention in science class!!!
boosted_out 09-13-2011 08:10 PM
Alright thx guys, I was freaking out fir nothig and with no ap to check logs... Still funny how the day i got my speed i thought it was so fast and now its barely anything haha
captain slow 09-13-2011 08:23 PM
Get an AP and learn to tune. You'll still get used to it after a while but at least as u adjust the little things you can gauge how fast you rock thru the gears and what each little thing u tweak does for performance.
stang9779 09-13-2011 08:27 PM
Get an AP and or some form of a gauge. I'm getting the aeroforce for this kind of a reason. Stock boost gauge sucks.
mrmonk7663 09-13-2011 08:52 PM
Make sure your DSC button is turned OFF too. I had an instance the other day where this limited my boost even though I had no wheelspin...don't know how or why. My boost would spike to max with the DSC on, but 2500 log pull would result in 12-13psi all the way through. I reflashed my car, turned off DSC, and voila fixed.
G26 09-14-2011 09:53 AM
Actually the stock gauge is pretty accurate.
I feel you, when I first test drove the car, the low end torque scared the shit outta me. Now it feels slooowww.
Paul 09-17-2011 09:39 AM
Stock it will have limited torque 1 2 3 gears?.... Im pretty sure I can't get the last bar in 2nd and 3rd on stock parts... I'll check later today.
AP will unlock the Torque available in the first 3 gears I believe.
Page generated in 0.18559 seconds with 11 queries
