I'll flash back to my MAF-scaled E85 tune tonight and see. |
I have nothing to contribute at this time except a round of at a boys! great work from all. |
To clarify my above statement: My trims would only climb ABOVE 12 inches of vacuum. Idle and WOT was pretty much dead on. |
So if you're boost based, what is the difference between using these scalars I haven't seen (on Cobb's site somewhere?) for E85, and just re-calibrating your maf? I run a D010 w/m w/ 50/50 and just calibrating the maf for it. Sorry for the noob q, I just came across this stuff tonight, and learning the E85 ropes for the big switch (well, small switch... 2 gals). |
Uh, changing one cell vs 100? |
I saw a few people mention FTs... so these scalars just for your fuel trims and not wot afrs? I'm still playing w/ my meth, and boost, and will likely run a couple gallons of E85 in the near future to gain some timing. I don't mind recaling my maf twice, lol. I still think I'm missing something here :/ |
I think David may have mentioned (in one of the threads) that if necessary, tweaks can still be made to your maf cal, but the idea is to get you pretty close to running the afr's you were on pump both open and closed loop. Good to see you around Douge. |
From what I've played with though is 2 gallons needs very little adjustment, so if that's all you want to run. Toss it in at your next fill up and start playing. Lol. Tappin |
roger that...if your petrol maf cal is good there is no need to change it with 2-2.5 gallons of E. There should be no AF shift with that little concentration. I had to hit 4 gallons before I saw any shift and I went from 2.5 to 4 so somewhere in between there is when the shift occurred. also between the two I had to add a shit ton of timing to make up for the slower burn :) |
i had to adjust my trims after my first 2 gallons. MS6 tank is bigger too. |
My wot afr's were good through 3 gallons, but @ 3 gallons, my trims were pretty bad. Can't explain it, but it happened. |
Ahhh shit. I may have made a table change and resaved the map without the "keep non-table data" option checked. Can anyone confirm this error would effectively take the e85 tweaks out the guys are working on for us? |
-David@COBB |
I tried to e-mail you yesterday so I could run the map, but you must be swamped with work. Changes made remain in the map per our e-mail. |
Thanks fellas, that helps a lot. I didn't realize that after a certain %a big change can occur. I only ran 2 gals of E85 once (to rule out false kr... it wasn't false, lol), and it didn't affect my trims much, maybe 4-5%. I'm leaning towards 3 gallons now, so it sounds like this will def be helpful. |
whoa, how did I miss this thread. will have to catch up tonight |
I just went from 2 gallons to 3ish gallons per tank and my trims skyrocketed to anywhere between +4 to+9. I was slightly worried but everyone's comments seem to confirm the same thing. Did I mention how much I love E85, it makes Cali 91 octane cars actually fun to drive without constantly worrying about BAT's and KR all day. |
that does seem to be the tipping point for LTFT to shift but OL can go higher before AF shift is seen. @cld12pk2go first ran into this back in the spring with ramping up his E85 concentration. He saw LTFT shift way before he saw AF shift at WOT. I too experienced the same an in fact I am not scaled yet on E35. IIRC, my LTFT is +10ish but I am not too worried about CL trims ATM. My WOT AF is about .1 leaner so I have seen no reason to rescale my entire map for that. I am glad cobb is on this scalar before I make my jump to 5050 so I won't need to scale all my load related tables in the spring when I make the switch. Perhaps @David@COBB would care to speculate on the lack of AF shift at WOT? |
On my third day using my original MAF-scaled E85 tune and no DTCs. I did notice the same +25 STFTs at extremely low throttle though. Perhaps it was always that way; never really payed close attention to STFTs before. I'll go back to the COBB beta scaled map, do a MAF cal, and see of that helps. EDIT: I think instead I'll take my E85 adjusted MAF scale, reduce all values by 40%, and then put it into my COBB beta map. My trims should theoretically be identical to what they are now. Tapadatass |
Don't forget the checkbox, Silva. |
Tapadatass |
I felt almost as silly as when cld12pk2go caught a decimalization error when I posted one of my comp tables. |
Took my E85-adjusted MAF scale and divided it by 1.40 (%40) and put it into my COBB beta map. flashed my car with the beta map, and took it to Best Buy in town for an errand. DTC 2096 popped up shortly before I got back home; so it took just two key cycles and ~30 miles to get the DTC. I'm going to go through my beta map thoroughly to make sure I didn't miss anything. |
I was able to put about 50-60 miles on a test map Cobb provided, as well as get some good logs for David. I just e-mailed him everything 10 minutes ago. |
For those of you I have made maps for, please Email me back your notes/observations/logs. Thanks, -David@COBB |
I'm on the 2nd of 5 scaled maps. I'll be flashing the 3rd at lunch, and should have the last 2 done tomorrow. Then i'll compile all the results. So far, your scaling percentages are looking great David. |
An interesting thing I've noticed: My current MAF-scaled E85 tune has all LTFTs either at 0 or slightly negative (~ -2% to -4%). When I took that MAF scale and divided by 1.4 and placed it into the COBB beta map, all my LTFTs were positive (~ +5% to +12%). My LTFT breakpoints have been setup to be equivalent (i.e. I multiplied my pump gas breakpoints by 1.4 to get my E85 breakpoints). I've been working a shit-ton this week and haven't been able to play more with the tunes; I'll try tonight. Tapadatass |
One of my calibrators would like if you could go back to full 93 octane and dial in the MAF again - and then we'll re-run the test with another patched map. It's hard to make good graphs/plots without a good base(93) to compare to. -David@COBB |
I would be happy to do that if that is what is asked. It will likely take me about a week to burn through this tank of e85 mix, but will get on this right away. |
david, i havent done any testing for you guys but certainly would like to. im about a 30% blend and my tank is almost empty. right now my curve is pretty dead on but i can go back to 93 since im empty and double check and then u can send me a rev. let me know. |
Brakes getting done tomorrow morning, will have relevant data the next afternoon (at the latest). |
I guess I am late to the show here, but this scaler is going to be pure WIN! I am really curious if it will push up the power level that we hit Load Cap V2™, as the calculated load will be dropping by a large percentage if we don't have to fudge the MAF curves. How do I get in on the Beta SW? Hell yeah. :popcorn: |
I wonder if this new scalar is the same or similar to what the scoobies have to set their injector size in CC? Cobb is just telling the ECU we have smaller injectors than OE so IPW is increased to meet the fueling demand. |
Too bad it just doesn't work on my car. On the COBB beta map my car hunts around for idle upon pressing the clutch, the AFRs are all over the map, I get a P2096 DTC, and the car feels slow as crap. Tapadatass |
roger that...what it is "called" is up to cobb...lol in Romraider its called injector size or something like that...not sure if that's the only scalar they use but I did see it. sorry to hear the cobb scalar isn't working on your car....are you sure you aren't running boost_creep's ECU? lol |
| All times are GMT -7. The time now is 12:02 PM. |
