-   -   COBB AP/ATR Beta Fuel Scaling (http://www.mazdaspeedforums.org/forum/f567/cobb-cobb-access-port-atr-beta-fuel-98939/)
rfinkle2 03-02-2012 12:09 PM
cld12pk2go is quiet about it, but has some big balls!
Sick VD.
Dano 03-02-2012 01:15 PM
so does Anthony.....to soon???
lol
RichieRichness 03-20-2012 09:23 AM
Not much talk of fuel scaling lately so i'll wake things up. I finally was able to test the fuel scalar. Here are my results from a 93 octane tune to a 3.5 gal mix of e85. I used the following settings.
Injetor Scalar = 1.1
Specific Fuel Gravity = 0.75
AFR Target = 12.1
Timing from 3k to 6k rpm:
Code:
3.00        4.00        5.00        5.50        7.00        8.50        10.00
Attachment 55458
Enki 03-20-2012 09:46 AM
You have quite a bit more room up top. I was running 14 @ 6k on 3 gal mix. Otherwise, looks like you only need a slight bump to correct the MAF. What do the trims look like?
RichieRichness 03-20-2012 12:41 PM
Oh yeah I know. I was running 14* @ 6000 rpm on my older map but wanted to put a side by side comparison together with the only change being the scalar.
Fuel trims are not terrible (between 0 and -5) but was not expecting them to be so far off considering my WOT values are so close.
Enki 03-20-2012 12:58 PM
Might need a bit of a tweak on the FSG value then; you're only off about 1.7% up top (assuming 12.2 peak afr @ WOT), so pulling up to 5% fuel could mean that you're flowing too much fuel due to the weight not being correct.
Assuming 3.5 gal mix, with e75 at the pump; this comes out to roughly ~e24 in your tank (might be lower, in which case you'd run richer with the following settings):
FSG: 0.7484
Scalar: 1.0747
Worst case is you run a 12.3-12.5 AFR if your MAF cal is actually off a bit; with so little timing in the engine though, don't think that will be a problem for testing.
Page generated in 0.17730 seconds with 11 queries
