Like Tree29Likes
 Old 12-07-2011, 12:52 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Default COBB AP/ATR Beta Fuel Scaling
Post your scaling information/experiences here; I'm sadly still waiting for my maps.
The Following 10 Users Say Thank You to Enki For This Useful Post:
Alpha (12-07-2011), Ckmazdaspeed3 (12-07-2011), Dano (12-07-2011), djuosnteisn (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), NJSPEED3 (12-08-2011), rfinkle2 (12-07-2011), silvapain (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 01:16 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Subbin. No results here since I'm currently on 93 octane.
-06 MS6
-Corn fed 07 MS3 - Sold
Enki (12-07-2011)
 Old 12-07-2011, 01:17 PM   #3
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
@silvapain will have some, as well as Dustin.
I have a map to test, but won't have data until either tomorrow or the weekend.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
Enki (12-07-2011), harryclay (03-04-2012), kritz (12-07-2011), NJSPEED3 (12-08-2011)
 Old 12-07-2011, 01:19 PM   #4
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
I was just testing the maps without changing anything else. Basically to make sure the fuel trims behaved as expected, without any changes in fuel or e85 mix ratio. So far, worked like a charm.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
Enki (12-07-2011), Nataphen (12-07-2011), NJSPEED3 (12-08-2011), rfinkle2 (12-07-2011)
 Old 12-07-2011, 01:19 PM   #5
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
Still waiting for Evan to get back to me, but in the meantime...
The Following 3 Users Say Thank You to wolly6973 For This Useful Post:
djuosnteisn (12-07-2011), Enki (12-07-2011), rfinkle2 (12-07-2011)
 Old 12-07-2011, 01:20 PM   #6
Posts: 7,290   (View Stats)
Rob, If you need another car to increase the testing data shoot me a map.
@rfinkle2
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
 Old 12-07-2011, 01:34 PM   #7
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
I'll send my maps today. subbed.
The Following 2 Users Say Thank You to RichieRichness For This Useful Post:
 Old 12-07-2011, 01:50 PM   #8
I don't have any MAF datalogs yet, but...
I'm using a map originally tuned for 93 octane pump gas that's been adjusted 40% by David at COBB. The LTFT/STFT combinations are higher than they were on pump gas, but based on discussions in other threads my theory is that it's attributed to the 40% increase in injector pulse width. This means the MAF scale is much more sensitive to errors. A simple MAF cal will fix it.
My CL AFRs are meeting their targets no problem. I'm seeing 1.07 lambda in light cruising (my CL target), and 1.00 lambda at idle in neutral (an AFR target from a yet unexposed fueling table).
I edited my current map in ATR and checked the box for 'keep non-table data' prior to saving. Afterwards I sent it to @David@COBB and he verified the beta changes were kept.
The Following 6 Users Say Thank You to silvapain For This Useful Post:
atvfreek (12-07-2011), Ckmazdaspeed3 (12-07-2011), Enki (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 01:53 PM   #9
Enki's Avatar
Groans: 189
I edited my current map in ATR and checked the box for 'keep non-table data' prior to saving. Afterwards I sent it to David@COBB and he verified the beta changes were kept.
Good to know we can still fuck with the maps and keep the scaling intact.
Edit: At least until these settings are exposed via ATR.
 Old 12-07-2011, 01:55 PM   #10
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
eff you guys in the eye...I'm jelly!
fuck it...I'm gonna go make the run out to that place and get me some E85...
-- Mario Andretti --
The Following 3 Users Say Thank You to Fobio For This Useful Post:
Alpha (12-07-2011), Enki (12-07-2011), phate (12-07-2011)
 Old 12-07-2011, 01:56 PM   #11
Captain
Groans: 79
Here's my initial data, somewhat cleaned up and consolidated:
I did a "maf cal log" last night on the way home, on my current 2 gal e85 mix map. Basically just getting a snap shot of the various fuel trims across the entire maf range. Then i flashed the new 20% scaled map from David this morning... put some miles on the car (commute to work is roughly 25 miles), and did another "maf cal log" on the last road to my work.
I combined both LTFT and STFT for a total trim... and included AFR so you can see that these trims are indeed resulting in the right AFR, and then tried to match the maf curves as close as possible, just to align the various LTFT break points.
Close enough to convince me though... the new "scaled" map is most certainly resulting in more fuel (more negative fuel trims). Roughly 15-17% more.
www.permtuning.com
The Following 10 Users Say Thank You to djuosnteisn For This Useful Post:
Alpha (12-07-2011), atvfreek (12-07-2011), Dano (12-08-2011), dougefresh_ (12-08-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), silvapain (12-07-2011), Speed_j23 (12-08-2011), wolly6973 (12-07-2011)
The Following User Says NO Thank You to djuosnteisn For This Un-useful Post:
charlesfist (12-14-2011)
 Old 12-07-2011, 02:00 PM   #12
Dustin, I should thank you for the info but groan you for the huge-ass graph.
The Following 7 Users Say Thank You to silvapain For This Useful Post:
Alpha (12-07-2011), atvfreek (12-07-2011), Dano (12-08-2011), djuosnteisn (12-07-2011), dougefresh_ (12-08-2011), Enki (12-07-2011), Speed_j23 (12-08-2011)
 Old 12-07-2011, 02:01 PM   #13
Captain
Groans: 79
Just cause you didn't say it explicitly... but your running your pump gas maf curve on 100% e85... with the 40% scaling, and indeed it's working as intended, right?
I'm not surprised that the trims are off "slightly", i mean 40% is kinda a shot from the hip unless you used an ethanol content analyzer and got super scientific on it lol. But close to zero, and the fact that your running 100% e on a pump gas maf curve says a ton.
Great to hear
Hahaha, it's not that big, but i can copy and resize if you want me to.
www.permtuning.com
Last edited by djuosnteisn; 12-07-2011 at 02:01 PM. Reason: MSF Database - Automerged Doublepost
The Following 5 Users Say Thank You to djuosnteisn For This Useful Post:
atvfreek (12-07-2011), dougefresh_ (12-08-2011), Enki (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011)
 Old 12-07-2011, 02:04 PM   #14
Great to hear
Correct; I'm on 100% E85 but using the MAF scale I made on straight 93 octane pump gas. As a matter of fact, my entire map is from my pump gas tune, just with some adjusted timing and AFR targets to optimize for E85. No MAF or load adjustments at all.
For reference, I scaled my MAF roughly 39% when I went from pump gas to E85. It's not a linear change, though; E85 needs even more fuel than pump gas at high MAF g/s to hit AFR targets. Therefore my MAF was scaled closer to 45-50% at higher voltages.
The Following 8 Users Say Thank You to silvapain For This Useful Post:
atvfreek (12-07-2011), Dano (12-08-2011), djuosnteisn (12-07-2011), dougefresh_ (12-08-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), phate (12-07-2011)
 Old 12-07-2011, 02:05 PM   #15
Captain
Groans: 79
Fucking dope.
www.permtuning.com
 Old 12-07-2011, 02:05 PM   #16
Enki's Avatar
Groans: 189
Great to hear
This can probably be accounted for with seasonal blends; the ethanol content in tank is most likely markedly less now than it would be in the summer time (which may even be dead on).
Honestly, I'd leave it pulling fuel as it is now so that when you switch blends you don't run lean (not that that will hurt anything except power output on pure e).
 Old 12-07-2011, 02:07 PM   #17
rfinkle2's Avatar
Groans: 298
I don't intend to derail this thread, but think your tune is still performing as well as it is because you are pure boost tuning.
Calculated loads will still need manual adjusting (correct me if I'm wrong here) if you just convert an old 93 map and still have some active load comp tables.
Enki (12-07-2011), laxplayermjd (12-07-2011)
 Old 12-07-2011, 02:08 PM   #18
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
So we just got about 15% more fuel out of the stock injectors with this new Beta software? (Sorry I'm a noob)
The Following User Says Thank You to Alpha For This Useful Post:
Enki (12-07-2011)
 Old 12-07-2011, 02:10 PM   #19
Enki's Avatar
Groans: 189
Since the MAF is no longer scaled, his calculated load values should be much more reasonable than they ever were when the map was manually adjusted for the fuel.
Logs?
I don't think we have any injector adjustment stuff in these maps. Correct me if I'm wrong, but I'm pretty sure we are just talking about scaling fuel requirements via scalar instead of MAF (for use eth guys).
Anyone?
Last edited by Enki; 12-07-2011 at 02:12 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-07-2011, 02:12 PM   #20
Calculated load is based on MAF g/s and RPM. Load is just another term for Volumetric Efficiency (VE), which is the percentage of actual airflow through the engine at a given RPM compared to the theoretical ideal.
My load values on E85 are all jacked up due to tricking the ECU by scaling the MAF. On the COBB beta map, my MAF isn't falsely scaled, so my load values are 'actual'. Therefore, I don't need to adjust any load-based tables.
Now, at WOT my car will hit higher load values on E85 now than it did with pump gas because I'm making more power. I may need to up my load targets for that reason to hit the boost I want, but I don't have to change it if I don't want.
The Following 9 Users Say Thank You to silvapain For This Useful Post:
atvfreek (12-07-2011), charlesfist (12-14-2011), Dano (12-08-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), speedms6 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:13 PM   #21
Enki's Avatar
Groans: 189
I wonder if this will resolve the issues seen over in Dano's boost tuning thread regarding some sort of artificial load limit capping output of the engine no matter what tables are modified.
 Old 12-07-2011, 02:13 PM   #22
Anyone?
Correct. This beta map from COBB let's those of use running Ethanol blends make one scalar value change and not have to use the MAF scale to 'trick' the ECU into running the correct amount of fuel to hit our AFR targets. This won't gain use any more injector headroom.
Alpha (12-07-2011), djuosnteisn (12-07-2011), dougefresh_ (12-08-2011), Enki (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:15 PM   #23
rfinkle2's Avatar
Groans: 298
Crappers.. mystyped when I said "adjust calculated load values"... intended to say load axis tables will need tweaking FML.
A big step foreward in ease of use, nonetheless.
Enki (12-07-2011), silvapain (12-07-2011)
 Old 12-07-2011, 02:16 PM   #24
Alpha's Avatar
Groans: 24
Gotcha, thanks!
The Following 2 Users Say Thank You to Alpha For This Useful Post:
 Old 12-07-2011, 02:17 PM   #25
I certainly hope so. I had no problems hybrid tuning on pump gas before going to E85 and scaling my MAF. The caveat is that I haven't load tuned on pump gas with the latest firmware revision; if the issues we're seeing now are due to a firmware change this won't fix it.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
 Old 12-07-2011, 02:18 PM   #26
Enki's Avatar
Groans: 189
I certainly hope so. I had no problems hybrid tuning on pump gas before going to E85 and scaling my MAF. The caveat is that I hadn't load tuned on pump gas with the latest firmware revision; if the issues we're seeing now are due to a firmware change this won't fix it.
One way to find out.
 Old 12-07-2011, 02:18 PM   #27
Eth Fiend
phate's Avatar
Anyone?
This is essentially an injector "adjustment". Meaning it is fooling the ecu into thinking we are taking in more air than what the MAF curve says, somehow. Of course we don't know the mechanics [yet], but it is the same thing we are doing with MAF scaling for E85. Because the fueling calc is based on the MAF curve, there has to be a multiplier in there somewhere (or actaully a multiplier scale, since the scaling is NOT linear on E85, as silvapain said).
So no actual injector head room was gained, we are just injecting more air per revolution, but without the scaled maf curve.
-06 MS6
Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), Speed_j23 (12-08-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:20 PM   #28
Captain
Groans: 79
...This won't gain use any more injector headroom.
Unless David has been making tweaks to inj latency, or something along those lines. I have my fingers crossed that he's found a way to actually make the injector open earlier than normal. That means we won't necessarily be "bound" between the intake valve opening and spark ignition events. We would theoretically be able to spray earlier, even with a closed intake valve, and significantly increase or fueling window.
Shit, honestly, i'd be willing to spray fuel at the tail end of the exhaust stroke if i could lol.
www.permtuning.com
The Following 7 Users Say Thank You to djuosnteisn For This Useful Post:
Alpha (12-07-2011), dougefresh_ (12-08-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:20 PM   #29
rfinkle2's Avatar
Groans: 298
IIRC Evan is adjusting injector latency.
djuosnteisn (12-07-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:21 PM   #30
Captain
Groans: 79
I think david is adjusting tables on fuel mass and latency or something along those lines.
www.permtuning.com
The Following 6 Users Say Thank You to djuosnteisn For This Useful Post:
Alpha (12-07-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:23 PM   #31
I plan on attempting to load tune on this beta map, or at least hybrid load/boost.
Enki (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:23 PM   #32
Captain
Groans: 79
Thanks finkle for your ninja forums skillz on finding this link:
Have you measured when the injectors...
That post shows the injector opening event hugging the intake valve opening event. So lower VVT and higher spark advance = much shorter fueling window.
www.permtuning.com
 Old 12-07-2011, 02:24 PM   #33
Enki's Avatar
Groans: 189
There has to be something else involved if the trims/AFRs are staying consistent with only the scalar change. The MAF curve isn't a linear one, so there's no way it could just be a simple scalar value IMO.
+1, WTB moar injector
On these maps? You sure about that?
djuosnteisn (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:25 PM   #34
Eth Fiend
phate's Avatar
Whatever it is, as long as it works and we don't have crazy load values anymore, I'm down
-06 MS6
atvfreek (12-07-2011), djuosnteisn (12-07-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:27 PM   #35
Alpha's Avatar
Groans: 24
That's what I was thinking too as I DID hear that they were working on getting us an additional 15%~ out of our stock injectors. (I'm assuming this is being worked on as we speak)
The Following 4 Users Say Thank You to Alpha For This Useful Post:
djuosnteisn (12-07-2011), Enki (12-07-2011), Nataphen (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:29 PM   #36
Enki's Avatar
Groans: 189
So we can use simple math to discern effective (current) max spray window based on map values across multiple tables...right?
Also, has anyone dyno proven that there is a benefit/detriment to running VVT values past spoolup?
This would be awesome and a HUGE step forward for our platform as a whole. You guys think I should update the thread title/OP with information regarding this fueling update as well? Basically make this thread about both fuel scaling and improved injector flow changes?
Last edited by Enki; 12-07-2011 at 02:29 PM. Reason: MSF Database - Automerged Doublepost
Alpha (12-07-2011), djuosnteisn (12-07-2011), Nataphen (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:32 PM   #37
rfinkle2's Avatar
Groans: 298
No. LOL.... "changes to your injector dwell time and mass of fuel scalar" are being changed.
If dwell time = latency than yes, if dwell time does not = latency than no, I'm not sure.
Bolded type is what is being tweaked.
 Old 12-07-2011, 02:34 PM   #38
Captain
Groans: 79
Yup, theoretically simple math. But I think adding VVT in higher rpms (esp on k04) result in drastically reduced maf g/s (e.g. decreased performance). And right now, all this injector control stuff is pure speculation. Nothing has been proven yet, so i'd leave the title as is.
.... until we prove it
www.permtuning.com
Alpha (12-07-2011), Enki (12-07-2011), Evan@COBB (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:37 PM   #39
Eth Fiend
phate's Avatar
Yessir. From the little testing I've done, we only saw IDC decrease because the air mass decreased as vvt increased in the higher rpms. On my most recent dyno session (not my car), I played with VVT on the bottom end and it didn't have any sort of effect on power (surprising).
-06 MS6
djuosnteisn (12-07-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), Speed_j23 (12-08-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:37 PM   #40
A very basic primer on how the ECU determines injector pulse width:
1. The ECU gets a voltage signal from the MAF, and using the MAF scale, turns that into mass airflow (g/s)
2. The ECU determines RPM and calculates load
3. Based on RPM and load, the ECU determines spark advance, VVT, and AFR target
4. Using mass airflow and AFR target, the ECU calculates fuel requirement in mass rate (g/s, lb/hr, whatever)
5. Using a scalar that represents injector size (lb/hr; on DI this would also incorporate fuel rail pressure), the ECU determines required injector pulse width (in milliseconds)
It's the scalar in item 5 that COBB is adjusting I believe. It's a static percentage.
The Following 5 Users Say Thank You to silvapain For This Useful Post:
Dano (12-08-2011), Fobio (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), Speed_j23 (12-08-2011)
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 303 08-22-2011 06:03 PM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning 2010 MS3 - ECU Computer Tuning 111 07-18-2011 10:46 AM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning Cobb Tuning 0 06-30-2011 03:32 PM
COBB BETA MAPS! bioevolve MazdaSpeed 3/6 - ECU Computer Tuning 51 05-20-2010 10:47 AM
Beta Testers for Vivid Motorsports Top Fuel system Vivid Motorsports Mazdaspeed3/6 General Discussion 84 02-11-2010 06:49 PM
Page generated in 0.62798 seconds with 30 queries
