Like Tree29Likes
 Old 12-07-2011, 02:41 PM   #41
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
A very basic primer on how the ECU determines injector pulse width:
1. The ECU gets a voltage signal from the MAF, and using the MAF scale, turns that into mass airflow (g/s)
2. The ECU determines RPM and calculates load
3. Based on RPM and load, the ECU determines spark advance, VVT, and AFR target
4. Using mass airflow and AFR target, the ECU calculates fuel requirement in mass rate (g/s, lb/hr, whatever)
5. Using a scalar that represents injector size (lb/hr; on DI this would also incorporate fuel rail pressure), the ECU determines required injector pulse width (in milliseconds)
It's the scalar in item 5 that COBB is adjusting I believe.
That still doesn't quite add up; step 5 amounts to a linear change, which we know doesn't work based on MAF scaling alone. What Finkle said about fuel mass makes more sense; more e = more oxygen getting into the cylinder (aside from the expected airflow) = higher scaled MAF value to equal the same AFR (if that makes sense).
If this is the way it is being done, it's pretty fucking smart. If not, please correct my understanding.
 Old 12-07-2011, 02:48 PM   #42
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Cobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the world
Groaned at 47 Times in 18 Posts
No. LOL.... "changes to your injector dwell time and mass of fuel scalar" are being changed.
If dwell time = latency than yes, if dwell time does not = latency than no, I'm not sure.
Bolded type is what is being tweaked.
To clarify, what I'm looking to do is change the flow rate table of the injectors in the ECU - what some people call its scalar. Now what that does in turn is tell the ECU the injectors are either smaller or larger (in flow). From that, it calculates IPW to hit the AFR target you ask of it. In the case of E85, you say the flow rate is LESS so it INCREASES open inj. time to accommodate the additional mass needed to meet stoic. If you have bigger injectors, you'll say it has more flow rate so it'll cut down on the IPW.
This is the "correct" way of changing the injector routines from a fundamental level - or else it'll be correct for only certain RPM/Loads and won't scale with your car's different pressure/RPM/load.
And as I said before, still in development. For those of you that have maps, give me the final LTFT's off (and be sure to include +/- on those LTFT) so I can remake them with a final adjustment.
-David@COBB
Cobb Tuning is offline   Reply With Quote
The Following 19 Users Say Thank You to Cobb Tuning For This Useful Post:
Alpha (12-07-2011), atvfreek (12-07-2011), AZSPEED3 (12-08-2011), charlesfist (12-14-2011), Dano (12-08-2011), djuosnteisn (12-07-2011), Enki (12-07-2011), Fobio (12-07-2011), jracer (12-08-2011), laxplayermjd (12-07-2011), Nataphen (12-07-2011), phate (12-07-2011), Pu Manchu (12-07-2011), Realgib3 (12-08-2011), silvapain (12-07-2011), speedms6 (12-07-2011), superskaterxes (12-08-2011), Todd98SE (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 02:55 PM   #43
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
Groaned at 8 Times in 2 Posts
Also, if any of you guys are still waiting for us to get you your maps, please send me an e-mail or PM. I was dealing with a pretty decent group of you yesterday and may have missed a couple.
The 'tweaked' maps that David is sending out are just estimates as to what "scalar" is needed for your fuel blend. I've been testing these for awhile now but we don't have it down to a science yet. We're still trying to figure out a good formula. The goal of having you guys see how it reacts on your cars is to try to figure out a formula that will work for any blend you have.
If you know your MAF scale is dead on for 93 and we sent you a scalar but now your trims are coming at -5 or so, that's because the scalar we gave you is really just our best guess as to what you need and may need some tweaking. Once these tables are released in ATR, you'll be able to go crazy with them to get yourself dialed in perfectly.
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD!
2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car
Evan@COBB is offline   Reply With Quote
The Following 16 Users Say Thank You to Evan@COBB For This Useful Post:
Alpha (12-07-2011), atvfreek (12-07-2011), AZSPEED3 (12-08-2011), charlesfist (12-14-2011), Dano (12-08-2011), djuosnteisn (12-07-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), phate (12-07-2011), Pu Manchu (12-07-2011), Realgib3 (12-08-2011), rfinkle2 (12-07-2011), superskaterxes (12-08-2011), Todd98SE (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 03:49 PM   #44
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Originally Posted by David@COBB View Post
To clarify, what I'm looking to do is change the flow rate table of the injectors in the ECU - what some people call its scalar. Now what that does in turn is tell the ECU the injectors are either smaller or larger (in flow). From that, it calculates IPW to hit the AFR target you ask of it. In the case of E85, you say the flow rate is LESS so it INCREASES open inj. time to accommodate the additional mass needed to meet stoic. If you have bigger injectors, you'll say it has more flow rate so it'll cut down on the IPW....
-David@COBB
David, have you seen any tables or logic that look like it may control the injector opening position? Basically a way for us to start spraying fuel earlier?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 8 Users Say Thank You to djuosnteisn For This Useful Post:
charlesfist (12-14-2011), Dano (12-08-2011), Enki (12-07-2011), jracer (12-08-2011), Nataphen (12-07-2011), phate (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 03:54 PM   #45
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
even if I can't directly benefit from the E85 scaling, it appears that the fueling discussion here will have wider implications for everyone.
-- Mario Andretti --
The Following 5 Users Say Thank You to Fobio For This Useful Post:
BlueStreak (12-08-2011), Enki (12-07-2011), Nataphen (12-07-2011), phate (12-07-2011), rfinkle2 (12-07-2011)
 Old 12-07-2011, 04:07 PM   #46
The benefit of this is several fold:
1. MAF will no longer need to be scaled artificially for different fuel blends meaning that going E85 etc will just be a scalar away - easier to tune.
2. Larger injector fuel potential again without messing with the MAF when and if injectors are available.
3. People hitting load caps because of MAF scaling have this issue resolved. **Here's something interesting ** Just like you can scale up for E85 you can also scale DOWN. If we have an unkown load cap/table at say ... 2.0 load - scaled your MAF DOWN so that you are at stockish loads and use this multiplier to get the correct AFR. This is called tricking the trick And it's a hack in the opposite direction to deal with an uncovered table or cap.
In terms of VVT. Increasing VVT even on the K04 results in higher flow but lower power at high RPMs. However, increasing it on a big boy turbo should allow more fuel and more power. Increasing timing also decreases the amount of fuel available so pick your battles
The Following 8 Users Say Thank You to Lex For This Useful Post:
charlesfist (12-14-2011), cld12pk2go (12-16-2011), Dano (12-08-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 04:09 PM   #47
Ansolutely. What David is doing will be needed if/when we have larger injectors available to us. The ECU will need to adjust the dwell time for the higher-flowing injectors.
I noticed there was a discussion about injector latency and dwell times earlier. They are not the same:
Dwell time = how long the injector is 100% open, usually defined in milliseconds. If you take dwell time and divide it by the total available time that the injector can be open, you get duty cycle, measured in %.
Latency = how long it takes the injector to go from one position to the other; either from closed to open when the ECU commands it to open, or from open to closed when the ECU commands it to close.
The Following 7 Users Say Thank You to silvapain For This Useful Post:
charlesfist (12-14-2011), Enki (12-07-2011), Fobio (12-07-2011), Nataphen (12-07-2011), Realgib3 (12-08-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 04:09 PM   #48
Enki's Avatar
Groans: 189
Actually, you can benefit, Fobio. Get a bigger MAF housing.
Fobio (12-07-2011)
 Old 12-07-2011, 04:48 PM   #49
To latch onto one of the topics - Injector duty cycle is calculated by a lot of things:
1) Crank Angle\RPM\VVT
2) Spark timing/advance
3) Load and airflow
4) Injector startup/duration/close time
5) HPFP pressure
6) Injector Flow rate size
This is why you can get 140-150% when using the old way of MAF scaling to run E85. Remember that it is an approximation.
As for opening injectors earlier, we need to find out if it actually moves the injection earlier for more time or just starts in the same place. This will ultimately determine if the stock injectors can run 100% E85 correctly.
-David@COBB
The Following 13 Users Say Thank You to Cobb Tuning For This Useful Post:
charlesfist (12-14-2011), Dano (12-08-2011), djuosnteisn (12-07-2011), dougefresh_ (12-07-2011), Enki (12-07-2011), Fobio (12-07-2011), jracer (12-08-2011), Nataphen (12-07-2011), radbrad (02-02-2012), Realgib3 (12-08-2011), rfinkle2 (12-07-2011), silvapain (12-07-2011), TiGraySpeed6 (12-08-2011)
 Old 12-07-2011, 04:49 PM   #50
Driver
Fobio's Avatar
Groans: 44
I am already running a bigger maf. But there's BlueStreak with the forged motor and aiming for 26psi+. He will likely benefit from the refined fueling control. This is exciting stuff guys!
The Following 4 Users Say Thank You to Fobio For This Useful Post:
Alpha (12-07-2011), BlueStreak (12-08-2011), Enki (12-07-2011), rfinkle2 (12-07-2011)
 Old 12-07-2011, 04:55 PM   #51
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I love to read the nitty gritty from all of you guys. I'm glad to have everyone contributing, and to have Cobb so involved in what was once an otherwise overlooked platform (@ least compared to other, more popular aftermarket platforms).
Thanks guys for the technical info, and David and Evan for working out some of the technical "stuff". (I'm particularly glad Evan has an ms3 and he and Phate are all about e85 LOL).
With companies like Deutchwerkes, Cobb and EFR working on shit for our cars, it opens up a whole new can of worms, imo.
AZSPEED3 likes this.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
Alpha (12-07-2011), AZSPEED3 (12-08-2011), Enki (12-07-2011), kritz (12-07-2011), Nataphen (12-07-2011)
 Old 12-07-2011, 05:19 PM   #52
Captain
Groans: 79
-David@COBB
www.permtuning.com
Alpha (12-07-2011), Enki (12-07-2011), rfinkle2 (12-07-2011)
 Old 12-07-2011, 07:04 PM   #53
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
Can of worms for the other platforms on the road.
The Following 5 Users Say Thank You to Alpha For This Useful Post:
djuosnteisn (12-08-2011), Enki (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-08-2011)
 Old 12-07-2011, 07:15 PM   #54
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
If we can get larger injectors, control the injector open/close, and get fuel and injector scalars in the next few months, I see even more breakthroughs for 2012 than we saw in 2011. This is exciting stuff. 500-600whp without pouring in meth by the gallon may be closer than we think.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
The Following 6 Users Say Thank You to Nataphen For This Useful Post:
Alpha (12-07-2011), Dano (12-08-2011), djuosnteisn (12-08-2011), Enki (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-08-2011)
 Old 12-07-2011, 07:18 PM   #55
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
this thread is win, someday when im not so cheap i can buy alot of go fast parts, all this work from you guys would make tuning easier. Sure am starting to wish i had some e 85 around here.
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
The Following User Says Thank You to laxplayermjd For This Useful Post:
Enki (12-07-2011)
 Old 12-07-2011, 08:12 PM   #56
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Subd.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 12-07-2011, 08:27 PM   #57
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
I hope all you fuckers have tiny dicks to make up for your super huge brains-----I'm so confused-----so much to learn yet. And I didnt even get a big dick.
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
The Following User Says Thank You to themytb For This Useful Post:
Enki (12-07-2011)
 Old 12-07-2011, 08:28 PM   #58
If you really want to know, pictures of my meat sword are conveniently located in the cock thread in VIP.
You're welcome.
 Old 12-07-2011, 08:36 PM   #59
POWERED BY POLSKA
themytb's Avatar
Groans: 38
ehh dont really wanna know, just jelly of the knowledge. Hard to catch up with you guys.
also sorry for fuckin up a good thread Ill stfu now
25%E85FREEKPERMED
 Old 12-07-2011, 09:41 PM   #60
@David@COBB @Evan@COBB
I got DTC P2096 - Target A/F feedback system too lean today. I cleared the code, and after a couple key cycles I got it again. I flashed a new map to clear the LTFT's and did a datalog; it appears my STFT's are maxing out at +25 at very light throttle in 5th and 6th. See attached datalog.
File Type: csv Stage2+SF 93 v135 40p Scale 100 E85.csv (157.1 KB, 7 views)
Enki (12-07-2011), Nataphen (12-08-2011), rfinkle2 (12-07-2011)
 Old 12-07-2011, 10:36 PM   #61
Enki's Avatar
Groans: 189
If it was fine just after flashing the map, the issue is either due to a vacuum leak or an injector sticking shut.
 Old 12-07-2011, 10:42 PM   #62
The log is from just after flashing the map. It was also happening before flashing the map.
It only started after going to the COBB beta map.
rfinkle2 (12-08-2011)
 Old 12-07-2011, 11:49 PM   #63
Silva throw in injector PW in the log.
I am suspecting this is due to the poor resolution of the MAF at that low airflow. The MAF reading is almost the same as at idle.
For shits and giggles multiply the 1.37 to 1.60 V region by 1.1 in the MAF table and smooth the 1.60 to 1.76V and 1.29 to 1.37V regions.
Alpha (12-08-2011), Dano (12-08-2011), Nataphen (12-08-2011), rfinkle2 (12-08-2011), silvapain (12-08-2011)
 Old 12-08-2011, 06:27 AM   #64
Will do for the next log.
I wanted to get input from COBB before I did any MAF corrections, to see if there was any more information they needed from me.
Evan@COBB (12-08-2011), rfinkle2 (12-08-2011)
 Old 12-08-2011, 08:23 AM   #65
Evan@COBB's Avatar
Have you loaded up your 45% fuel map yet?
The Following User Says Thank You to Evan@COBB For This Useful Post:
 Old 12-08-2011, 09:17 AM   #66
You need more fuel - the STFT's are at their max allowed error correction, so we need to up the amount.
Try the 45% and see if it helps. We might need to go higher if your STFT's are still too far.
-David@COBB
The Following User Says Thank You to Cobb Tuning For This Useful Post:
 Old 12-08-2011, 09:24 AM   #67
-David@COBB
I know the max trims allowed are +/- 25%. My question was why is it only at this specific point? My LTFTs are within +/- 8% otherwise; not ideal by any means, but well within the CL adjustment range if the ECU.
 Old 12-08-2011, 09:45 AM   #68
-David@COBB
Dave, take a look at my comment a few lines above. His STFTs are only high at very low airflow values.
 Old 12-08-2011, 09:50 AM   #69
For reference, here's an Excel file of my pump gas MAF scale and my E85-adjusted MAF scale to show the percentage difference.
My averaged percent difference is 41%; hence the reason I'm using the 40% scalar
 Old 12-08-2011, 09:51 AM   #70
Never seen that before. Your car seems to be the only one that is having this issue.
are the LTFT's you are having typically positive or negative?
EDIT: One of our calibrator's looked at your logs, and said that it is most likely a MAF scaling issue - so try to change it and give it a shot.
-David@COBB
The Following 2 Users Say Thank You to Cobb Tuning For This Useful Post:
 Old 12-08-2011, 09:53 AM   #71
Could also be a slight air/vacuum leak past the MAF but less likely because it wasn't there prior to the calibration change.
 Old 12-08-2011, 10:01 AM   #72
Captain
Groans: 79
Is your fuel pressure still all fucked up below 3k rpm?
www.permtuning.com
 Old 12-08-2011, 10:05 AM   #73
-David@COBB
I have both positive and negative LTFT's. That's the primary reason I don't think I need to go to the 45% scaled map.
Dustin, My HPFP issues have been resolved (at least temporarily) by cleaning the spill valve thoroughly. You can see in the datalog I posted earlier that I'm maintaining fuel pressure throughout the log.
djuosnteisn (12-08-2011), rfinkle2 (12-08-2011)
 Old 12-08-2011, 10:16 AM   #74
Driver
Fobio's Avatar
Groans: 44
the one time my LTFT kept worsening, was when I had a leak at the manifold/turbo gasket.
The Following User Says Thank You to Fobio For This Useful Post:
 Old 12-08-2011, 10:31 AM   #75
To test this parameter why even jump directly to 40%? Why not use a smaller step size that you can monitor directly without even having to use E85 in the car - just use the same fuel (same tank) and make small changes that can be tracked through trims and commanded PW changes as well as AFRs under WOT. This way there are less variables to consider.
Dustin also made a very good suggestion of making smaller increments such as 10, 20% and then scaling the MAF back by those same percentages. Then observing trims and WOT AFRs. No need to ACTUALLY use E85 and many map variations to test a fuel scalar.
 Old 12-08-2011, 10:35 AM   #76
If I was going from pump gas to E85 just now, that's how I would do it.
I don't know if the data table COBB uncovered is 0-D or 1-D, but if it's 1-D I'd get my MAF dead-on with pump gas, then incrementally increase E85 concentration and use the new table to adjust the MAF accordingly. That way I'd know my mass airflow readings are 'actual', and not skewed due to recalibration for E85.
I could easily fix any LTFT errors I'm having now by simply rescaling the MAF; but then I might be back where I started with mass airflow and load values that don't mean anything because they've been skewed too much.
 Old 12-08-2011, 10:42 AM   #77
Just change one variable at a time and don't let it be the gas since that's hard to control.
Slowly increment the scalar and scale down the MAF to maintain the same AFR under WOT and trims.
 Old 12-08-2011, 10:45 AM   #78
What I'm saying is that if the point is to maintain legitimate mass airflow values in the MAF table when going from pump gas to E85, you would want to adjust the fuel scalar table instead of the MAF table to hit AFR targets.
 Old 12-08-2011, 10:56 AM   #79
Captain
Groans: 79
I think right now David's just looking for "proof of concept", and trying to establish how much of a tweak is required to get X percentage increase. From that data, he'll be able to wrap it all up nice and cute for ATR, and all we'll have to do is plug in a simple scalar.
www.permtuning.com
The Following 5 Users Say Thank You to djuosnteisn For This Useful Post:
Alpha (12-08-2011), Realgib3 (12-08-2011), rfinkle2 (12-08-2011), silvapain (12-08-2011), wolly6973 (12-08-2011)
 Old 12-08-2011, 12:51 PM   #80
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Look at the correlation between boost (vacuum) and the STFT's. You have very high STFT's as vacuum increases. That looks like a very small vacuum leak, to me.
This is obvious, but: To check, just flash back to your other map and see if it does the same thing. If STFT's go crazy, it's a vac leak. If all is peachy, then it's the scalar.
-06 MS6
-Corn fed 07 MS3 - Sold
Fobio (12-08-2011), rfinkle2 (12-08-2011)
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 303 08-22-2011 06:03 PM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning 2010 MS3 - ECU Computer Tuning 111 07-18-2011 10:46 AM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning Cobb Tuning 0 06-30-2011 03:32 PM
COBB BETA MAPS! bioevolve MazdaSpeed 3/6 - ECU Computer Tuning 51 05-20-2010 10:47 AM
Beta Testers for Vivid Motorsports Top Fuel system Vivid Motorsports Mazdaspeed3/6 General Discussion 84 02-11-2010 06:49 PM
Page generated in 0.60667 seconds with 34 queries
