Like Tree29Likes
 Old 12-08-2011, 01:45 PM   #81
Look at the correlation between boost (vacuum) and the STFT's. You have very high STFT's as vacuum increases. That looks like a very small vacuum leak, to me.
This is obvious, but: To check, just flash back to your other map and see if it does the same thing. If STFT's go crazy, it's a vac leak. If all is peachy, then it's the scalar.
I'm getting a steady 21 inHg vacuum at idle and my idle trims are stable, so I don't think it's a leak. I can do a vacuum and boost test anyways to verify.
I'll flash back to my MAF-scaled E85 tune tonight and see.
Enki (12-08-2011), phate (12-08-2011), wolly6973 (12-08-2011)
 Old 12-08-2011, 01:47 PM   #82
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
This is the exact same thing I was seeing. I pulled my inlet, patched any rough/scraped/scratched areas with RTV, lubed up the connections to ensure a positive fit, then retightened the easily accessible bolts on my intake mani and so far that seems to have fixed my high vacuum trim climb.
phate (12-08-2011), rfinkle2 (12-08-2011), silvapain (12-08-2011), wolly6973 (12-08-2011)
 Old 12-08-2011, 02:35 PM   #83
Posts: 9,484   (View Stats)
I have nothing to contribute at this time except a round of
at a boys! great work from all.
The Following 5 Users Say Thank You to Dano For This Useful Post:
Alpha (12-08-2011), Enki (12-08-2011), Fobio (12-08-2011), rfinkle2 (12-08-2011), silvapain (12-08-2011)
 Old 12-08-2011, 03:12 PM   #84
Enki's Avatar
Groans: 189
To clarify my above statement:
My trims would only climb ABOVE 12 inches of vacuum. Idle and WOT was pretty much dead on.
laxplayermjd (12-08-2011), phate (12-08-2011), silvapain (12-08-2011)
 Old 12-08-2011, 09:18 PM   #85
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
So if you're boost based, what is the difference between using these scalars I haven't seen (on Cobb's site somewhere?) for E85, and just re-calibrating your maf? I run a D010 w/m w/ 50/50 and just calibrating the maf for it.
Sorry for the noob q, I just came across this stuff tonight, and learning the E85 ropes for the big switch (well, small switch... 2 gals).
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
kritz (12-09-2011), rfinkle2 (12-08-2011)
 Old 12-08-2011, 10:38 PM   #86
Enki's Avatar
Groans: 189
Uh, changing one cell vs 100?
 Old 12-08-2011, 11:43 PM   #87
If that's all it does, I can see it being very useful if you want to try multiple mixtures of E85 if there are set scalars for different % mixtures. I thought there was more to it than that, but it's late and I'm tired.
I saw a few people mention FTs... so these scalars just for your fuel trims and not wot afrs? I'm still playing w/ my meth, and boost, and will likely run a couple gallons of E85 in the near future to gain some timing. I don't mind recaling my maf twice, lol. I still think I'm missing something here :/
rfinkle2 (12-09-2011), RichieRichness (12-09-2011)
 Old 12-09-2011, 04:59 AM   #88
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I think the goal of the project is to enable people with a decent 93 octane maf cal to easily convert a map to a particular e85 mixture through the scaling done "back office".
I think David may have mentioned (in one of the threads) that if necessary, tweaks can still be made to your maf cal, but the idea is to get you pretty close to running the afr's you were on pump both open and closed loop.
Good to see you around Douge.
dougefresh_ likes this.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
dougefresh_ (12-09-2011), Enki (12-09-2011), Fobio (12-09-2011), kritz (12-09-2011), Nataphen (12-09-2011)
 Old 12-09-2011, 05:10 AM   #89
atvfreek's Avatar
Posts: 7,787   (View Stats)
Right now to run 3+ gallons of e85 we have to scale the the shit out of the maf sensor, which causes an overly inflated maf reading. Doing this causes all of the load tables to also read very high, and you literally have to adjust a shit load of tables to keep things happy. They are trying to get it so we can basically change one fuel table and be pretty much ready to go. To get an idea 4gallons of e needs about 10% more fuel.
From what I've played with though is 2 gallons needs very little adjustment, so if that's all you want to run. Toss it in at your next fill up and start playing. Lol.
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 7 Users Say Thank You to atvfreek For This Useful Post:
dougefresh_ (12-09-2011), Enki (12-09-2011), Evan@COBB (12-09-2011), mrmonk7663 (12-09-2011), Nataphen (12-09-2011), phate (12-09-2011), rfinkle2 (12-09-2011)
 Old 12-09-2011, 08:07 AM   #90
roger that...if your petrol maf cal is good there is no need to change it with 2-2.5 gallons of E. There should be no AF shift with that little concentration. I had to hit 4 gallons before I saw any shift and I went from 2.5 to 4 so somewhere in between there is when the shift occurred.
also between the two I had to add a shit ton of timing to make up for the slower burn
The Following 8 Users Say Thank You to Dano For This Useful Post:
atvfreek (12-09-2011), dougefresh_ (12-09-2011), Fobio (12-09-2011), kritz (12-09-2011), Nataphen (12-09-2011), phate (12-09-2011), RichieRichness (12-13-2011)
 Old 12-09-2011, 08:24 AM   #91
i had to adjust my trims after my first 2 gallons. MS6 tank is bigger too.
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
atvfreek (12-09-2011), dougefresh_ (12-09-2011), kritz (12-09-2011), Nataphen (12-09-2011), rfinkle2 (12-09-2011)
 Old 12-09-2011, 08:26 AM   #92
rfinkle2's Avatar
Groans: 298
My wot afr's were good through 3 gallons, but @ 3 gallons, my trims were pretty bad.
Can't explain it, but it happened.
 Old 12-09-2011, 08:40 AM   #93
rfinkle2's Avatar
Groans: 298
Ahhh shit. I may have made a table change and resaved the map without the "keep non-table data" option checked. Can anyone confirm this error would effectively take the e85 tweaks out the guys are working on for us?
 Old 12-09-2011, 09:21 AM   #94
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Cobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the world
Groaned at 47 Times in 18 Posts
Making ANY changes in ATR to that map is pretty risky, as you would need to have that box checked or it wipes my change to your maps out.
-David@COBB
Cobb Tuning is offline   Reply With Quote
The Following 4 Users Say Thank You to Cobb Tuning For This Useful Post:
atvfreek (12-09-2011), Enki (12-09-2011), Fobio (12-09-2011), silvapain (12-09-2011)
 Old 12-09-2011, 10:14 AM   #95
rfinkle2's Avatar
Groans: 298
-David@COBB
Understood. (one of the reasons I wanted to be sure before flashing)
I tried to e-mail you yesterday so I could run the map, but you must be swamped with work.
Changes made remain in the map per our e-mail.
 Old 12-09-2011, 10:37 AM   #96
Thanks fellas, that helps a lot. I didn't realize that after a certain %a big change can occur. I only ran 2 gals of E85 once (to rule out false kr... it wasn't false, lol), and it didn't affect my trims much, maybe 4-5%. I'm leaning towards 3 gallons now, so it sounds like this will def be helpful.
atvfreek (12-09-2011), rfinkle2 (12-09-2011)
 Old 12-09-2011, 01:47 PM   #97
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
whoa, how did I miss this thread. will have to catch up tonight
The Following 2 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
Enki (12-09-2011), rfinkle2 (12-09-2011)
 Old 12-10-2011, 09:09 AM   #98
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Todd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the world
I just went from 2 gallons to 3ish gallons per tank and my trims skyrocketed to anywhere between +4 to+9. I was slightly worried but everyone's comments seem to confirm the same thing.
Did I mention how much I love E85, it makes Cali 91 octane cars actually fun to drive without constantly worrying about BAT's and KR all day.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
The Following 3 Users Say Thank You to Todd98SE For This Useful Post:
Nataphen (12-11-2011), rfinkle2 (12-10-2011), silvapain (12-10-2011)
 Old 12-10-2011, 09:46 AM   #99
that does seem to be the tipping point for LTFT to shift but OL can go higher before AF shift is seen. @cld12pk2go first ran into this back in the spring with ramping up his E85 concentration. He saw LTFT shift way before he saw AF shift at WOT. I too experienced the same an in fact I am not scaled yet on E35. IIRC, my LTFT is +10ish but I am not too worried about CL trims ATM. My WOT AF is about .1 leaner so I have seen no reason to rescale my entire map for that. I am glad cobb is on this scalar before I make my jump to 5050 so I won't need to scale all my load related tables in the spring when I make the switch.
Perhaps @David@COBB would care to speculate on the lack of AF shift at WOT?
Fobio (12-10-2011), rfinkle2 (12-10-2011)
 Old 12-10-2011, 11:15 AM   #100
On my third day using my original MAF-scaled E85 tune and no DTCs.
I did notice the same +25 STFTs at extremely low throttle though. Perhaps it was always that way; never really payed close attention to STFTs before.
I'll go back to the COBB beta scaled map, do a MAF cal, and see of that helps.
EDIT: I think instead I'll take my E85 adjusted MAF scale, reduce all values by 40%, and then put it into my COBB beta map. My trims should theoretically be identical to what they are now.
 Old 12-10-2011, 12:34 PM   #101
Enki's Avatar
Groans: 189
Don't forget the checkbox, Silva.
 Old 12-10-2011, 01:25 PM   #102
LOL. Thanks.
 Old 12-10-2011, 01:54 PM   #103
rfinkle2's Avatar
Groans: 298
I felt like a , although it wasn't the first time, and definitely won't be the last.
I felt almost as silly as when cld12pk2go caught a decimalization error when I posted one of my comp tables.
 Old 12-11-2011, 02:08 PM   #104
Took my E85-adjusted MAF scale and divided it by 1.40 (%40) and put it into my COBB beta map. flashed my car with the beta map, and took it to Best Buy in town for an errand. DTC 2096 popped up shortly before I got back home; so it took just two key cycles and ~30 miles to get the DTC.
I'm going to go through my beta map thoroughly to make sure I didn't miss anything.
rfinkle2 (12-11-2011), wolly6973 (12-12-2011)
 Old 12-11-2011, 02:50 PM   #105
rfinkle2's Avatar
Groans: 298
I was able to put about 50-60 miles on a test map Cobb provided, as well as get some good logs for David.
I just e-mailed him everything 10 minutes ago.
 Old 12-14-2011, 09:58 AM   #106
For those of you I have made maps for, please Email me back your notes/observations/logs.
Thanks,
-David@COBB
The Following 3 Users Say Thank You to Cobb Tuning For This Useful Post:
djuosnteisn (12-14-2011), Enki (12-14-2011), rfinkle2 (12-14-2011)
 Old 12-14-2011, 10:09 AM   #107
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
I'm on the 2nd of 5 scaled maps. I'll be flashing the 3rd at lunch, and should have the last 2 done tomorrow. Then i'll compile all the results.
So far, your scaling percentages are looking great David.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 12-14-2011, 10:25 AM   #108
An interesting thing I've noticed:
My current MAF-scaled E85 tune has all LTFTs either at 0 or slightly negative (~ -2% to -4%). When I took that MAF scale and divided by 1.4 and placed it into the COBB beta map, all my LTFTs were positive (~ +5% to +12%). My LTFT breakpoints have been setup to be equivalent (i.e. I multiplied my pump gas breakpoints by 1.4 to get my E85 breakpoints).
I've been working a shit-ton this week and haven't been able to play more with the tunes; I'll try tonight.
Alpha (12-14-2011)
 Old 12-14-2011, 11:20 AM   #109
rfinkle2's Avatar
Groans: 298
Thanks,
-David@COBB
Do you need me to re-send my logs David?
 Old 12-14-2011, 12:51 PM   #110
Enki's Avatar
Groans: 189
Thanks,
-David@COBB
Due to weather, I have not been able to install my brakes for testing, and haven't bothered to flash the map (as I've not driven the car in more than two weeks). Hopefully I'll be able to provide some relevant data in the next couple of days.
 Old 12-14-2011, 02:49 PM   #111
Nope. Your logs looked fine.
One of my calibrators would like if you could go back to full 93 octane and dial in the MAF again - and then we'll re-run the test with another patched map. It's hard to make good graphs/plots without a good base(93) to compare to.
-David@COBB
 Old 12-14-2011, 03:05 PM   #112
rfinkle2's Avatar
Groans: 298
-David@COBB
Ohhh. I hope I followed the directions correctly.
I would be happy to do that if that is what is asked.
It will likely take me about a week to burn through this tank of e85 mix, but will get on this right away.
Alpha (12-14-2011)
 Old 12-14-2011, 03:19 PM   #113
david,
i havent done any testing for you guys but certainly would like to. im about a 30% blend and my tank is almost empty.
right now my curve is pretty dead on but i can go back to 93 since im empty and double check and then u can send me a rev. let me know.
 Old 12-14-2011, 04:32 PM   #114
Enki's Avatar
Groans: 189
Brakes getting done tomorrow morning, will have relevant data the next afternoon (at the latest).
 Old 12-14-2011, 05:31 PM   #115
a week or 10 WOT runs...lol
atvfreek (12-14-2011), rfinkle2 (12-14-2011), wolly6973 (12-15-2011)
 Old 12-16-2011, 08:52 AM   #116
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Since the MAF is no longer scaled, his calculated load values should be much more reasonable than they ever were when the map was manually adjusted for the fuel.
Logs?
I don't think we have any injector adjustment stuff in these maps. Correct me if I'm wrong, but I'm pretty sure we are just talking about scaling fuel requirements via scalar instead of MAF (for use eth guys).
Anyone?
Correct. This beta map from COBB let's those of use running Ethanol blends make one scalar value change and not have to use the MAF scale to 'trick' the ECU into running the correct amount of fuel to hit our AFR targets. This won't gain use any more injector headroom.
Whatever it is, as long as it works and we don't have crazy load values anymore, I'm down
A very basic primer on how the ECU determines injector pulse width:
1. The ECU gets a voltage signal from the MAF, and using the MAF scale, turns that into mass airflow (g/s)
2. The ECU determines RPM and calculates load
3. Based on RPM and load, the ECU determines spark advance, VVT, and AFR target
4. Using mass airflow and AFR target, the ECU calculates fuel requirement in mass rate (g/s, lb/hr, whatever)
5. Using a scalar that represents injector size (lb/hr; on DI this would also incorporate fuel rail pressure), the ECU determines required injector pulse width (in milliseconds)
It's the scalar in item 5 that COBB is adjusting I believe. It's a static percentage.
3. People hitting load caps because of MAF scaling have this issue resolved. **Here's something interesting ** Just like you can scale up for E85 you can also scale DOWN. If we have an unkown load cap/table at say ... 2.0 load - scaled your MAF DOWN so that you are at stockish loads and use this multiplier to get the correct AFR. This is called tricking the trick And it's a hack in the opposite direction to deal with an uncovered table or cap.
I guess I am late to the show here, but this scaler is going to be pure WIN!
I am really curious if it will push up the power level that we hit Load Cap V2™, as the calculated load will be dropping by a large percentage if we don't have to fudge the MAF curves.
How do I get in on the Beta SW?
Hell yeah.
The Following 4 Users Say Thank You to cld12pk2go For This Useful Post:
atvfreek (12-16-2011), djuosnteisn (12-16-2011), Enki (12-17-2011), rfinkle2 (12-16-2011)
 Old 12-16-2011, 08:56 AM   #117
rfinkle2's Avatar
Groans: 298
@cld12pk2go, PM David and Evan.
David is a bit more active on msf.
 Old 12-16-2011, 09:18 AM   #118
I wonder if this new scalar is the same or similar to what the scoobies have to set their injector size in CC? Cobb is just telling the ECU we have smaller injectors than OE so IPW is increased to meet the fueling demand.
 Old 12-16-2011, 10:43 AM   #119
That's exactly what this does in effect. I don't know I the number specifically represents the injector size, or if it's just a percentage adjustment though.
Too bad it just doesn't work on my car. On the COBB beta map my car hunts around for idle upon pressing the clutch, the AFRs are all over the map, I get a P2096 DTC, and the car feels slow as crap.
 Old 12-16-2011, 10:46 AM   #120
roger that...what it is "called" is up to cobb...lol in Romraider its called injector size or something like that...not sure if that's the only scalar they use but I did see it.
sorry to hear the cobb scalar isn't working on your car....are you sure you aren't running boost_creep's ECU? lol
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 303 08-22-2011 06:03 PM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning 2010 MS3 - ECU Computer Tuning 111 07-18-2011 10:46 AM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning Cobb Tuning 0 06-30-2011 03:32 PM
COBB BETA MAPS! bioevolve MazdaSpeed 3/6 - ECU Computer Tuning 51 05-20-2010 10:47 AM
Beta Testers for Vivid Motorsports Top Fuel system Vivid Motorsports Mazdaspeed3/6 General Discussion 84 02-11-2010 06:49 PM
Page generated in 0.59358 seconds with 32 queries
