![]() | | #121 | ![]() |
| Not Ranked : 0 score
If I post it up will you guys be willing to look through it for me? Tapadatass
__________________ | |
![]() | | #122 | ![]() |
Groans: 298
| Not Ranked : 0 score Oh. I thought you were having good luck with the beta scaled map.^ |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Enki (12-17-2011) |
![]() | | #123 | ![]() |
| Not Ranked : 0 score My initial impression was good, but I then noticed the continuing issues stated above. Tapadatass
| The Following User Says Thank You to silvapain For This Useful Post: | Enki (12-17-2011) |
![]() | | #124 | ![]() |
Groans: 79
| Not Ranked : 0 score Here's my data. Rather than experimenting with different e85 mixes for the maps, i had David send me 5 different maps, a 10%, 20%, 30%, 40%, & 50% scaled versions of my previous 2 gal e85 mix map. I then adjusted the maf on each scaled map by the inverse percentage (1/1.1, 1/1.2, 1/1.3..... 1/1.5). Here's my preliminary data, simply combined fuel trims, AFR, calc load, and MAF g/s. I'll email my complete logs to David, and anyone else who wants em, they're attached below. One thing to remember though, each higher % scaled map has the maf considerably lowered, so it took a fair amount more "air" to register the same "g/s". This may certainly have skewed the data some. For instance, the fuel trims @ 50 g/s on my initial non scaled map would correspond to the fuel trims @ 33.3 g/s on the 50% map. Here's lè data: Initial map MAF: ![]() And initial plot: ![]() 10p map MAF: ![]() 10p plot: ![]() 20p map MAF: ![]() 20p plot (series names got screwed up but it's obvious what's what): ![]() 30p map MAF: ![]() 30p plot: ![]() 40p map MAF: ![]() 40p plot (note y axis minimum is now -10 instead of -5 in upper plots): ![]() 50p map MAF: ![]() 50p plot (note y axis minimum is now -10 instead of -5 in upper plots): ![]() I'll go through the data a bit later. One more hectic day, then a day of travel, and then i can finally kick back for a few days. But figured you guys could chew on this for the time being. My first blush opinion is that fuel trim's slope becomes more and more positive (increasing with higher g/s) as the scalar is increased. This is probably a side effect from having to scale down the maf so far to compensate.... almost like the maf curve is becoming more linear and losing the appropriate exponential shape corresponding to the maf tube diameter. Pure speculation on my part, i'd have to think about it some more to determine if that could indeed be possible. Aside from that, i think the scalar is doing a pretty good job. I mean considering i was dropping the maf down to 66% of what it was, and my trims weren't astronomical. I think the scalar could certainly be used to compensate for e85 mixes, if matched with a proper maf cal.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #125 | ![]() |
Groans: 298
| Not Ranked : 0 score You guys must be further along in testing than I am. I was asked to send my current e85 based map, along with my 93 octane maf curve (@ least I think that is what I was asked). I had to take all of my tables with load axis down, as well as some other minor things. I also probably spooked David when I forgot the "toggle". Oh well. I guess I will wait for the e85 scaled maps to come to fruition.?! |
![]() | | #126 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008
Rep Power: 2549 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
Groaned at 47 Times in 18 Posts
| Not Ranked : 0 score So to answer a few of the questions from this thread: -There are several parameters that also change when you change to a different fuel - not just the scalar. There are lots of things to test and tweak. Seeing how "customized" these parameters need to be to each vehicle gives us data on how we should present the controls when we are ready to release them. -We've used an in-house car at a stage 2 level, and we've used mixes from 30% E85 to 100% E85. Without tweaking the MAF, we've gotten the trims to settle in all fuel trim ranges. I'm relatively confident in what I've found, but as always we need verification of it. This beta test that I'm running is to see if those changes apply to the masses just as easily. -For clarification, the method in which I'm making the E85 changes isn't just a hack to the final pulse width - I'm making changes to the injector size/flow rate and fuel weight references/calculations. I'm trying to make changes at the fundamental level. Not making the changes at the fundamental level will result in issues with closed loop, open loop, STFT/LTFT, shifting, cold start, weird map behavior from MAF scaling, etc. -David@COBB |
| The Following 18 Users Say Thank You to Cobb Tuning For This Useful Post: | 08cosmic3 (12-28-2011), Alpha (12-18-2011), atvfreek (12-17-2011), charlesfist (12-19-2011), Ckmazdaspeed3 (12-28-2011), cld12pk2go (12-18-2011), Dano (12-18-2011), djuosnteisn (12-27-2011), dougefresh_ (01-01-2012), Enki (12-19-2011), Fobio (12-19-2011), GoSpeed3Go (12-17-2011), jracer (12-28-2011), Nataphen (12-20-2011), rfinkle2 (12-17-2011), silvapain (12-18-2011), superskaterxes (12-19-2011), wolly6973 (12-19-2011) |
![]() | | #127 | ![]() |
![]() Join Date: Jun 2009 Location: placerville, CA
Groaned at 27 Times in 8 Posts
__________________ https://www.facebook.com/NorCalTintZone instagram: sharpdetails | |
![]() | | #128 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Excellent. I wonder if those of us with high trim numbers (By high I mean +-10 or higher) at idle have something else going on...
![]() | | #129 | ![]() |
Groans: 298
| Not Ranked : 0 score I had some high trim numbers (about -10 iirc), but @ the second breakpoint. (5.7-18) rather than idle. Last edited by rfinkle2; 12-19-2011 at 12:51 PM. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Enki (12-19-2011) |
![]() | | #130 | ![]() |
I'm going to do a MAF cal just for my lowest LTFT breakpoint to correct. Tapadatass
![]() | | #131 | ![]() |
| Not Ranked : 0 score By the way, I made some changes to my beta tune with respect to the clutch tables and timing, and the car is running MUCH better. No DTCs either. I still need to sort out the stutter at extremely low throttle position though. Tapadatass
![]() | | #132 | ![]() |
Groans: 298
My studder had something to do with the way I was limiting boost per gear with the APP tables, and again, @ that time, my map loads were all off due to scaling. Setting my APP tables back to ots cleared it right up, although I haven't had a chance to look @ the APP tables vs throttle req load A, B, and C to see where the problem came from . | |
![]() | | #133 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I put in for my e85 map to get "the treatment" but have yet to hear back
![]() | | #134 | ![]() |
| Not Ranked : 0 score Working up a second beta that involves some other changes. You'll hear back from me in January. We are doing some research on the Dyno w/ an oscilloscope to determine if it is doing injector phasing to lengthen the time, or if it is using just a plain addition of injector open time. The other thing to note is if we are legitimately running out of injector at 100% E85. We now have a way to control and test it in a controlled environment. Stay tuned for updates ![]() -David@COBB |
| The Following 15 Users Say Thank You to Cobb Tuning For This Useful Post: | Alpha (12-28-2011), AZSPEED3 (01-17-2012), Ckmazdaspeed3 (12-28-2011), cld12pk2go (12-28-2011), djuosnteisn (12-28-2011), dougefresh_ (01-17-2012), Enki (12-28-2011), jracer (12-28-2011), kritz (12-28-2011), Nataphen (12-28-2011), rfinkle2 (12-28-2011), Todd98SE (12-28-2011), warlord (12-28-2011), wolly6973 (12-28-2011) |
![]() | | #135 | ![]() |
| Not Ranked : 0 score I can tell you I'm over 100% IDC if I use WOT AFRs richer than 0.86 lambda. Tapadatass
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #136 | ![]() |
Groans: 79
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | Alpha (12-28-2011) |
![]() | | #137 | ![]() |
| Not Ranked : 0 score hell your car doesn't even run long enough to test the scalar out...lol j/k
![]() | | #138 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Sadly, that's true. Plus, with the latest developments, I'll be going back to an unscaled 3 gallon mix, so there's little point now. Lol
| The Following User Says Thank You to Enki For This Useful Post: | Dano (12-28-2011) |
![]() | | #139 | ![]() |
| Not Ranked : 0 score I have this >< much room to talk...my fueling issues cropped up again....momentary drop to 900PSI for no apparent reason...usually unplugging the FP sensor connector and reconnecting it back solves the issue...for awhile at least. bah! maybe time for a new sensor.
| The Following User Says Thank You to Dano For This Useful Post: | djuosnteisn (12-28-2011) |
![]() | | #140 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
Groans: 24
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() | |
![]() | | #141 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to Cobb Tuning For This Useful Post: | Alpha (12-28-2011) |
![]() | | #142 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Um, come again? Direct replacement you say? no modifications for any year 'Speed?
![]() | | #143 | ![]() |
Groans: 24
| Not Ranked : 0 score Nice! And the second part of my wishlist? Haha! (2500+ psi)
![]() | | #144 | ![]() |
Another thing to remember is skyactiv is DI, but not turbo. So their sensor won't have to go up that high anyways as they aren't having the same cylinder pressures a the MS3/6 cars. Why re-engineer something you don't have to? However, it still will be limited to the same restrictions, so don't go thinking it'll allow you to read higher pressures. That still requires a LOT of work on the ECU side (not as easy as the MAP sensor) -David@COBB | |
| The Following 4 Users Say Thank You to Cobb Tuning For This Useful Post: |
![]() | | #145 | ![]() |
Groans: 24
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() Last edited by Alpha; 12-28-2011 at 03:14 PM. | |
![]() | | #146 | ![]() |
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
Groaned at 54 Times in 43 Posts
| Not Ranked : 0 score Subbing.
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ |
![]() | | #147 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Cobble Cobble....I has datas. Also looks like I need to do a MAF cal.
![]() | | #148 | ![]() |
| Not Ranked : 0 score what type of mix are you doing Enki?
![]() | | #149 | ![]() |
Groans: 189
![]() | | #150 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Any updates on availability of the new beta, @David@COBB?
| The Following User Says Thank You to Enki For This Useful Post: | cld12pk2go (01-16-2012) |
![]() | | #151 | ![]() |
| Not Ranked : 0 score yes how is this testing coming along?
![]() | | #152 | ![]() |
Groans: 79
| Not Ranked : 0 score And don't forget the "max KR allowed" tables @David@COBB ![]() And it would be awesome if you could find the odd load table that drops WGDC in certain conditions (high fuel requirements possibly???).
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | Lex (01-17-2012), mrmonk7663 (01-17-2012) |
![]() | | #153 | ![]() |
| The Following 10 Users Say Thank You to Cobb Tuning For This Useful Post: | Alpha (01-17-2012), atvfreek (01-18-2012), cld12pk2go (01-17-2012), Dano (01-17-2012), djuosnteisn (01-17-2012), Enki (01-17-2012), Lex (01-17-2012), phate (01-17-2012), rfinkle2 (01-17-2012), wolly6973 (01-17-2012) |
![]() | | #154 | ![]() |
| Not Ranked : 0 score Step 1: Clone yourself [rinse repeat as necessary] Step 2: Expose all tables and fix everything in one week Glad you're on our side @David@COBB
| The Following 2 Users Say Thank You to Dano For This Useful Post: | BlueStreak (02-15-2012), Teethkikr (01-30-2012) |
![]() | | #155 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #156 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Bawls Guarana > RedBull any day.
| The Following User Says Thank You to Enki For This Useful Post: | bewsted (01-17-2012) |
![]() | | #157 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score Any time I see Guarana, I always think of Guano first. mmm... bat shit... |
![]() | | #158 | ![]() |
Groans: 189
*puppydog face*
| The Following User Says Thank You to Enki For This Useful Post: | rfinkle2 (01-29-2012) |
![]() | | #159 | ![]() |
-David@COBB | |
![]() | | #160 | ![]() |
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! | Cobb Tuning | MazdaSpeed 3/6 - ECU Computer Tuning | 303 | 08-22-2011 06:03 PM |
| COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 | Cobb Tuning | 2010 MS3 - ECU Computer Tuning | 111 | 07-18-2011 10:46 AM |
| COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 | Cobb Tuning | Cobb Tuning | 0 | 06-30-2011 03:32 PM |
| COBB BETA MAPS! | bioevolve | MazdaSpeed 3/6 - ECU Computer Tuning | 51 | 05-20-2010 10:47 AM |
| Beta Testers for Vivid Motorsports Top Fuel system | Vivid Motorsports | Mazdaspeed3/6 General Discussion | 84 | 02-11-2010 06:49 PM |
