![]() | | #161 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
Groans: 24
| Not Ranked : 0 score
Would the new DW intank pump help alleviate those issues past 100% IDC?
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() | |
| The Following User Says Thank You to Alpha For This Useful Post: | phate (01-30-2012) |
![]() | | #162 | ![]() |
| Not Ranked : 0 score I don't think anyone really knows the answer to that question. 100% is a calculated figure...but what does 100% represent? My car runs fine seeing that high of IDC, so I'm not terribly concerned about it unless someone can show me evidence of it being harmful.
| The Following User Says Thank You to phate For This Useful Post: | Alpha (01-30-2012) |
![]() | | #163 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | rfinkle2 (01-30-2012) |
![]() | | #164 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score The IDC % doesn't seem to change with variances in VVT and/or timing, so we aren't even sure it's an accurate number to go off of in the first place.
__________________ |
![]() | | #165 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45886 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
![]() We should probably steer away from clones and stick with the original where ATR is concerned. | |
| The Following 4 Users Say Thank You to Erich For This Useful Post: |
![]() | | #166 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008
Rep Power: 2549 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
Groaned at 47 Times in 18 Posts
| Not Ranked : 0 score Okay guys, it's time to round up everything, as I'm pretty much done with researching the fuel scalar and what it takes to run E85. Looking at the data djuosnteisn compiled, along with other datalogs and tests, I'm confident we have the controls to run E85 mixes in the MS3 with minimal Map changes. If you look at the data djuosnteisn has provided, we can see that the injector opening is getting dangerously close to the allowed injection window before the intake cycle. In essence, we've found that Mazda has put in relatively small injectors to get the resolution they need for low load and RPM, and then use the DI system to ramp up to the level needed during high load and boost. Changing the engine's way that it calculates how much fuel it needs at the fundamental level, as well as injector size, allow us to run the system with alternative fuels without too much effort. Running 50% or 75% mixes are easy to do with the current controls I've been using. That being said, I'd like to hear from the people who were in the beta to chime in on if the changes I made to the maps, and if they were happy with the results - and if not, what other things would they like to see. -David@COBB |
| The Following 12 Users Say Thank You to Cobb Tuning For This Useful Post: | Alpha (02-08-2012), atvfreek (02-08-2012), Dano (02-08-2012), djuosnteisn (02-08-2012), Enki (02-08-2012), evidence (02-10-2012), Fobio (02-08-2012), Nataphen (02-09-2012), Nliiitend1 (02-10-2012), phate (02-08-2012), superskaterxes (02-08-2012), wolly6973 (02-08-2012) |
![]() | | #167 | ![]() |
Groans: 298
My 50/50 map ran very well. It is infinitely easier to create a good working map using the correct calculated loads and other variables than fudging the maf curve. My apologies for not being able to provide more data, but I drive < 3000 miles a year. | |
![]() | | #168 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
basically have you found a way to stretch the stock fuel system even more?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 5 Users Say Thank You to superskaterxes For This Useful Post: | Alpha (02-09-2012), Ckmazdaspeed3 (02-08-2012), Dano (02-08-2012), Fobio (02-08-2012), rfinkle2 (02-08-2012) |
![]() | | #169 | ![]() |
Based upon our research, you can run up to 75% E85 mixed with 25% 93 Octane, and not touch 100% IDC. This was tested on a stage2 car with all the bolt-ons and a FMIC. -David@COBB | |
| The Following 8 Users Say Thank You to Cobb Tuning For This Useful Post: | Alpha (02-09-2012), atvfreek (02-08-2012), Ckmazdaspeed3 (02-08-2012), djuosnteisn (02-08-2012), Enki (02-08-2012), Fobio (02-08-2012), Nataphen (02-09-2012), wolly6973 (02-08-2012) |
![]() | | #170 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score So, new maps in the works? Edit: New maps as in new beta maps; or are you going to release the new modifiers with information so we can just update our existing maps?
| The Following User Says Thank You to Enki For This Useful Post: | rfinkle2 (02-11-2012) |
![]() | | #171 | ![]() |
edit: does it take 100% IDC to reach the max optimal fueling window or much less like 80%? @David@COBB
![]() | | #172 | ![]() |
when my car hits 100% its like a monsoon in my cylinder and i get extreme blowout and the car pops and fires and goes nuts. its only when i hit 100% exactly on the dot. i have millions of logs if u need to see anything. this is the whole reason i went 5th injector with dustin so that i wasent relying so heavily on meth as extra fuel. turns out the 1000cc injector i bought was useless as its worse then the meth. just picked up a 2200 that i will hopefully have by saturday =D
| The Following 5 Users Say Thank You to superskaterxes For This Useful Post: | Alpha (02-08-2012), djuosnteisn (02-08-2012), Fobio (02-08-2012), rfinkle2 (02-08-2012), wolly6973 (02-08-2012) |
![]() | | #173 | ![]() |
I'm not sure what you mean by "optimal fueling window". Can you clarify a bit more? -David@COBB | ||
![]() | | #174 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score He's talking about in reference to port injection, where you don't normally want to exceed 80% IDC. Edit: 2 weeks?
![]() | | #175 | ![]() |
| Not Ranked : 0 score Soooo ready to get this control as I am still having the throttle close up top with the latest ATR release. I suspect that having my loads shift down 10% will greatly help with this on my higher gear pulls. It should also allow me to actually tune 3rd gear for decent power with traction. I am currently using DBW tables to limit load, but I cannot go over the 1.94 load row without screwing up WOT in higher gears that target > 2.00. ![]() Let me know if you need another BT Beta tester...
| The Following 4 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #176 | ![]() |
oh and by BT I mean big turbo...lol more air needs more fuel
![]() | | #177 | ![]() |
Groans: 298
I agree some people feel that ~85% is optimal, but Phate was running >100 IDC's and reported the car ran well. | |
![]() | | #178 | ![]() |
the engineers here @Ziggo have calculated the time window needed to complete the injection event...IDK what it is so I asked ![]() I think Dustin also worked with an Oscope to calculate said window...
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 02-08-2012 at 04:18 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Dano For This Useful Post: | rfinkle2 (02-08-2012) |
![]() | | #179 | ![]() |
![]() As for the "fueling window" with IDC - unless all your calibration is correct for MAF/Fuel, etc, it'll be hard to trust the ECU's calculation of IDC. Looking at the ECU's output with an oscope is a bit more telling. With Direct injection, if you continue the spray longer than normal (closer to the spark), it won't necessarily atomize correctly, and you'd have diminishing returns. So there will be less gain by running over 75% mix E85, as you'll be pushing the limits of the stock fuel system and injectors. So staying below that is the key here (unless you get bigger injectors). So to answer your question, optimal fueling is less than 75%-80% E85 mixed with 93. That rides the line between atomizing well, as well as measurable power gains vs. other mixes. You'd be surprised how a 50/50 mix compares to race gas ![]() -David@COBB | |
![]() | | #180 | ![]() |
-David@COBB | |
![]() | | #181 | ![]() |
| Not Ranked : 0 score thanks for the clarification David.
| The Following User Says Thank You to Dano For This Useful Post: | Fobio (02-08-2012) |
![]() | | #182 | ![]() |
so wait, your telling me with this new scalar we have enough fuel for 450-500whp?
| The Following User Says Thank You to superskaterxes For This Useful Post: | rfinkle2 (02-08-2012) |
![]() | | #183 | ![]() |
Groans: 79
| Not Ranked : 0 score David, we're you guys able to determine if, indeed, the injector start time was opening earlier and earlier (even before the intake valves open)? Did the experiments shed any light on the possibility of inj phasing?
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #184 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score When will it be released??? Is it possible to also make a table in excel or something that can calculate the load necessary to have dialed into the map in conjunction with the fuel. The Throttle requested load ABC tables affect the map a large deal, even when boost tuning, and with e85, they have to be adjusted a great deal, and it is hard to properly adjust it because there is nothing to really go off of in the lower load areas.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #185 | ![]() |
| Not Ranked : 0 score See this thread for more info: Logged Injector pulsewidth is incorrect I found that IDC as calculated by the ECU\logged by the AP is exactly the logged pulsewidth (which is incorrect) divided by the time to complete 360* of rotation. The real IDC has to be compensated by for fuel pressure and cylinder pressure. That I would expect to be a very complicated calculation. I also have a chart there in the first post that addresses an estimation of the IDC we log vs the effective IDC based on spark advance, VVT, and the SAE specified 3ms atomization time (which might be a conservative number when considering the higher temperatures and densities of a turbo'ed charge) the real key is that because the atomization time is a fixed time interval, the desired maximum logged IDC will probably go down as RPM goes up. Thats one of the thing I asked DJ to pin down using supplimental fueling.
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | djuosnteisn (02-09-2012), rfinkle2 (02-09-2012) |
![]() | | #186 | ![]() |
-David@COBB | ||
| The Following 4 Users Say Thank You to Cobb Tuning For This Useful Post: |
![]() | | #187 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Assuming, of course, that aftermarket HPFP can keep up with the demand as well. From what I saw in Phate's logs, he was at the edge of what the pump could handle on stock turbo.
| The Following 4 Users Say Thank You to Enki For This Useful Post: |
![]() | | #188 | ![]() |
Groans: 298
Calculated loads will be accurate vs. shifting everything up from maf curve manipulation. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | wolly6973 (02-09-2012) |
![]() | | #189 | ![]() |
| Not Ranked : 0 score My beta map runs great on 100% E85 with IDCs < 100% at WOT. Tapadatass
![]() | | #190 | ![]() |
| Not Ranked : 0 score Yes, I understand that for sure. But how will you effectively set the throttle load abc tables...there are alot of cells to populate. Its easy to log load at full throttle, but logging load at all throttle positions and rpms to dial in the table is almost impossible. You would think a formula could be made that based off of max load, load at idle, and some other factor that the cells coud be autopopulated via an excel speadsheet or something.
![]() | | #191 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score You could probably start by multiplying the table by the same scalar you used for the MAF table.
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #192 | ![]() |
| Not Ranked : 0 score Hmm, I might try that when the new revisions are released. I worked a shitload on my load tables with E85, and it was a pain in the ass to get to where I wanted it. It was good, I thought I could make it better...and in some regards I did, but at the sacrifice of driveability. I saw large mpg changes depending on how the tables were set up, and I saw massive changes in throttle respons and when/how boost came on, by solely adjusting the 3 throttle req load abc tables.
![]() | | #193 | ![]() |
Groans: 298
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | Enki (02-10-2012), mrmonk7663 (02-10-2012) |
![]() | | #194 | ![]() |
| Not Ranked : 0 score My beta map is just my 93 map with the scaling, plus a slight MAF adjustment in the high voltage range because E85 adjustment isn't linear. Oh, and increased timing and load targets because E85 is the shit. Tapadatass
| The Following 6 Users Say Thank You to silvapain For This Useful Post: | djuosnteisn (02-14-2012), Enki (02-10-2012), mrmonk7663 (02-10-2012), phate (02-10-2012), rfinkle2 (02-10-2012), wolly6973 (02-10-2012) |
![]() | | #195 | ![]() |
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
| Not Ranked : 0 score When tuning @Schmitty5's car I had to add 5% to the entire curve for a 3/9 gallon e85 mix. When we went 50/50 it was about additinal 5%.
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 ![]() |
![]() | | #196 | ![]() |
| Not Ranked : 0 score Yes, to the maf curve I had to do about the same.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN | |
![]() | | #197 | ![]() |
Groans: 298
![]() | | #198 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score On the topic of throttle/load adjustment: Last month I had to go home from the track and dial the tune WAY back because the car was aggressive/part throttle un-drivable; coming out of a turn at mid to high rpms, tipping in the throttle a bit would just blow the tires off at full boost. I guessed at a rescale for the TRL tables and drove around the rest (note that it drove fine either WOT or regular city driving). Today for lunch I took a stage appropriate OTS map and dropped a scaled up version of it in the table, and the result is MUCH easier to drive. Not perfect, but much, much better.
![]() | | #199 | ![]() |
| Not Ranked : 0 score Enki, I did the same thing 2 nights ago. I used the stage 2 map, and scaled the load tables, which yielded much better driveability than I previously had. The e85 release will be cool but it will force all of us on e85 to retune the car over again grr.
![]() | | #200 | ![]() |
Like I said, I have a beta map with the scaling. I sent @David@COBB my last 93 map, and he put in the scaling. Then I took my MAF-scaled tune and scaled down the MAF calibration by the amount David adjusted my beta map. I also reverse-load-adjusted my load-based tables from my E85 tune via an Excel file I created, then threw those into the beta map. That way my increased timing and load targets would be in the new map and correct for the MAF. Took me an hour or so, and the tune worked great. Matter of fact, when I went back on 93 gas, I took that beta MAF calibration and put it on my pump gas tune. Worked great with no adjustment necessary. Tapadatass
__________________ | |
| The Following User Says Thank You to silvapain For This Useful Post: | rfinkle2 (02-11-2012) |
| COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! | Cobb Tuning | MazdaSpeed 3/6 - ECU Computer Tuning | 303 | 08-22-2011 06:03 PM |
| COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 | Cobb Tuning | 2010 MS3 - ECU Computer Tuning | 111 | 07-18-2011 10:46 AM |
| COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 | Cobb Tuning | Cobb Tuning | 0 | 06-30-2011 03:32 PM |
| COBB BETA MAPS! | bioevolve | MazdaSpeed 3/6 - ECU Computer Tuning | 51 | 05-20-2010 10:47 AM |
| Beta Testers for Vivid Motorsports Top Fuel system | Vivid Motorsports | Mazdaspeed3/6 General Discussion | 84 | 02-11-2010 06:49 PM |
