Try to get the one with the DEXXOS label. THAT is the monster shit there. |
1 Attachment(s) |
3/4 of a tank down @ 200 miles, should be 250-260ish to the tank which while not great is a far cry from the 150 miles that @Enki; 's tester got, and only 40-50 miles less per tank than I got on 93. This is with a handful of logs, some dicking around and a run in with a 370z that left him butthurt x3. @Enki; that dude must have a HELL of a lead foot lol. |
That and his trips are short so the car might not be fully up to temp too (big impact on mileage; has to spray extra fuel to account for the fuel that doesn't vaporize when it hits the piston). With the proper tune and bolt ons, you *can* get as good MPG as you got stock; driving style is the tank breaker though. |
Ah ok. Yeah I expect once the newandshiny of full E85 wears off I'll make some mpg tweaks and see how close I can get to my 93 mileage.....which wasn't very good anyways heh. |
The single best piece of advice I can give for full corn MPG is to shift a lot earlier than you're used to...It makes so much more torque down low it's ridiculous; you'll have to experiment but I vaguely recall shifting before 2500 rpm and cruising 45 mph in 6th. |
But then how will I hear my bpv at every shift???? I insist EVERYONE in traffic around me knows I haz turbo. |
Sent From a Galaxy, Far Far Away... |
Someone has already made a product to replicate the noise! |
I can tell you, I have had my car since December of 2006. The "new and shiny" doesn't wear off. No matter the fuel you use. |
From the thread: http://www.mazdaspeedforums.org/foru...ecific-138097/ Quote:
A e48 mix allows you to exceed MBT already, just wondering what the difference is in it... |
1 Attachment(s) The chemical formula for Ethanol is C2H6O; this is important for that last little atom on the end (oxygen). The more you spray into the cylinder, the greater the cooling effect, and the more oxygen that comes in WITH the fuel; thus, compounding the amount of fuel you can burn (via charge cooling AND chemical addition of oxygen). I assure you, the difference between 50/50 and 100% is impressive. Edit: This would be with the same timing/AFR/boost targets; boost targets, incidentally, become more difficult to hit on full e85 as the airflow into the cylinder goes up with WGDC already pegged; thus, a drop in available peak boost. At last check, I think the Tucson test car was hitting 4.4 MAF volts @ 14 PSI (Mazdaspeed CAI converted to SRI) in cooler weather. Edit 2: Trimmed log attached; car is not making full WGDC in this log; still, shits bonkers. |
Thanks @Enki; really appreciate you sharing your knowledge :D I'm looking to go full e85 early next year (e85 station 2km up the road) so am following yours and @littleloogy;'s results through all this closely :) |
I want to see someone spray some meth on 100% E, shit would have combustion temps cooler than ambient temps(I keed)! Might be nessesary to add some fueling headroom anyways to max out the K04 with full E. 350whp? |
There's a limit to how cool you *want* the boost temps. Too low, and the e85 wont atomize properly, causing poor combustion and loss in power. I'd say 80 is probably the lowest you'd want, with 100 being probably pretty close to perfect (per findings of others). If I were to switch back to full e85, I'd probably start with a baseline run and drop my wmi nozzle size then compare the two (same day). I'm pretty sure too cold and it doesn't run as good. |
Here is some more info to think about: I run Methanol in my karts (Briggs flathead). Temperature of the head plays role in combustion. When the head temps lower id est 60-190°, the performance suffers. I have to manually lean my fuel mixture out while i am warming up to get my temps above 220° before my kart starts to make good power. Then I have to richen the mixture back to maintain that temp. When I am racing, the hotter my temp gets the more power my kart has. When the temps get colder my performance suffers. I suggest that increasing our engine coolant temperature to help yield more power with the same amount of fuel. Is there any after market thermostats available for our platform? Sent From a Galaxy, Far Far Away... |
I'm not sure ECTs are the way to go, when just dialing back the intercooling can yield the same effect; I do remember (vaguely) that when I was on full corn, the car would run like complete shit until the ECTs hit a magical number (between 100 and 140 IIRC) and then it would just come alive. After that, though, there were no performance detriments based on ECTs that I can recall. |
Potential failure in the local test car. 3 full tanks gone without issue, currently on the 4th. 45 seconds to start today, constantly breaking up when trying to drive led to using his daily instead. Cause still unknown, but assuming fuel pressure loss. Diagnosis, cause analysis and repair process information will be forthcoming when available. |
It is unfortunate that Rotella and E just don't mix together. I jumped back on board with the additive testing with RP to verify my pervious results. Sent From a Galaxy, Far Far Away... |
Yep his hpfp took a shit. 50-60 psi @ idle. I'll be heading down to tear it down and diagnose in about 3 hours or so. I'll be getting the test car to switch over to RP at some point as well, because he don't wanna go back. |
2 Attachment(s) OK so I forgot to bring *all* the tools needed to do a full breakdown, and I have limited time for lunch today due to surprise customer buttsecks so I took the pump home with me for detailed analysis and cleaning later today. Strangely, even though the outside of the spill valve was somewhat sticky, the needle itself was not. The internals, however, do not move freely and are definitely short stroking/sticking. The pump (inside) looks terrible. Here's a sneak preview of the horrors that await me: |
so far so good on my VR1. The car has 1 tank through it and currently on my 2nd tank, dont drive it much though. |
Even one full tank is still progress. I'm assuming that the local here was getting about 200/tank, maybe a bit less, but still, that's between 500 and 600 miles on T6 before it crapped out. I'll take that progress any day. |
lead foot. |
@Enki; Was that on AT's? |
6 Attachment(s) Quote:
I will note that the difference between cleaning this pump with the additive used previously and a pump that had not used it was significant; just squirting a bit on some of the parts removed gunk/sticky down to bare metal, which prompted me to fill a bowl with naphtha and let shit roll around for a bit (this got most of it off, but I did use q-tips and paper towels for the thick shit). It took a bit longer than it usually does for me to clean a pump, but I flushed it out real good as there were bits of black shit in the buffer compartment that needed to get the fuck out. Otherwise, it was easy. Hopefully I'll be able to get this car back on the road in a couple hours, depending on if/when the owner wakes up. Anywho, this is what the damage was (warning, full-res pictures): (Not pictured: I also tore my pants.) |
I'm hoping this is just because rotella. Even if my pump only lasts two tanks, it takes me about a month to go through 2 tanks. So I would be more then willing to rebuild a pump every two tanks. Takes a whole 20 min if that. |
It probably is because rotella. Honestly, it might even be feasible to just pull the spill valve and flush with the redline, which I was going to try but couldn't find an automotive syringe that would allow me to do that. It's on the list for next time, which will come in another 3-4 tanks most likely. |
So what oils are recommended, here in europe we dont have same asortment of oils, can't find royal purple or rotella for example. I see papasmurf mentioning VR1, if that is Valvoline we can get that. Best source right now for oil for me is http://opieoils.co.uk or http://mapodo.de (mostly castrol). What are we looking for in an oil going full E on our platform? |
We have http://castroledge.com.au/oils/ much more readily available... |
Considering doing the @Enki; e85 + oil boiling test... Figure that's about the only way you'd be able to find out about local oils... |
More on this?, must have missed this... |
E85 lists... Racing 5 (5w30) for race tho the 5w30 isn't an SN rated oil. The "every day" oil they recommend is ENVIRO+ GF-5 5W-30 |
http://www.mazdaspeedforums.org/foru....php?p=1565150 Boiling e85 by itself = evaporates cleanly Boiling e85 with t6 added = black gunk I saw pictures somewhere, but can't for the life of me find them... |
Please continue oil discussions here. http://www.mazdaspeedforums.org/foru...d.php?t=107141 Sent From a Galaxy, Far Far Away... |
| All times are GMT -7. The time now is 11:45 AM. |
