It starts the car at lower rpms so it's not so loud |
I meant for full E. |
I just realized that your "Unicorn" has no horn, effectively making it just a gay pony. :tongue: |
"gay pony" Totally lol'd at that! |
It totally has a horn, just not where you expect it to be. Why do you think the tail is so fluffed up like that? |
Sent From a Galaxy, Far Far Away... |
On pump gas, I can pull the spill valve connection and the car will start first crank. On full e, even with >500 psi it doesn't want to start on the first go. |
1 Attachment(s) Quote:
Also, its been in the 20's if not high teens here most mornings for the past month. A few long cranks but thats it. @littleloogy; that's all far too much thought and effort at 430 am when I leave for work. Sit in car, eyes still closed, turn key until magic happens......profit. |
Got a video of the cold start "stumble". I have new NGK plugs coming tomorrow. Also will be switching to 5w-40 RP from 5w-30 RP, hopefully will help calm down the annoying FP internals squeak. Other than that, everything has been running well. Only getting around 16-17MPG, but that's expected. https://www.youtube.com/watch?v=K6FA5JVv_ww - Like i said, it's very minor, but it is there. I think after the next oil change and cleaning of the HPFP it will go away. |
When I was testing E mpg I was in the mid twenties. Now I just want to go fast and am getting on average 15mpg Sent From a Galaxy, Far Far Away... |
Yeah, I had set that actually on my pump tune, noticed an increase in MPG. Although when I did the same for my e mix tune, I didn't notice anything extra, but I think that's because of the heavy foot I had at the time after enjoying tuning on e. I'll get that set up next revision. |
I'm not sure you want to go that hard on the afrs/timing. Leaning out too much reduces power output, and again, you need a certain amount of power (throttle in this case) to sustain a set speed. I don't really recall much gains when going from say 15 AFR target to 17, and it didn't drive as good. Right now I'm running 14.7 and getting the best MPG I've ever had due to driving style changes alone. |
When I was on a 42.5/33 mix of e, I was getting around 200 each tank at the start. After not being so pedal happy, I would easily get 300 a tank. I see no reason why I can't get 250 a tank on e without making any changes. If leaning it out won't do that much, I won't even bother. I did notice it "hiccup" a bit on my pump tune, not much, but it was noticeable sometimes. I'm about 500 miles in, loving the $30 fill-ups. |
I typically get 220-230 miles per tank on full E. During the few days we had bad snow etc here I got 250 soemthing. Thats with 1/4 a tank of normal driving. If you babied the shit out of it I could see 275 but then whats' the point of running full E? |
@Enki; ..... lol I meant if you babied the shit out of it I could see getting 275 miles to the tank but if your going to feather foot it everywhere then whats the point of running E? Not as in why is running full E better than 50/50 Quote:
you think thats bad? plug "meth" in on craigslist at work and see the looks you get :261: |
So, ordered RP from amazon, had the dexos-1 specs and all that good stuff. And instead I got sent this, wish I had a European Mazda... http://i57.tinypic.com/2j51bup.jpghttp://i58.tinypic.com/15mh2r5.jpg Going to see if I can just exchange it at Wal-Mart here, don't feel like dealing with shipping it back and hoping I get sent the stuff I want. |
Why not just run it and see what happens? |
RP doesn't have anything on their site that has Dexos labels on it. Might be the same shit. Worst case, you get the correct one next time. |
I don't know if it's a completely different "formula", but it mentions nothing about GM or dexos on the back of this stuff. http://i59.tinypic.com/2qxojn9.jpg |
Then return it. |
I don't have access to RP but other brands I do have access to are the same with the different viscosities |
Back on additives, the red line is not easily (or cheaply) obtainable to me. However, I can get the RP Max-Clean Any word on this vs the SI-1? |
At least redline has a mid-SAPS oil that - they say - meets european specifications. All others are full-SAPS. Probably mid-SAPS works better in DI engines, and this is what I've used so far. |
Thanks for posting that, couldn't find it using my phone. I've never done chemistry or anything... Does the RP have the right stuff (in high enough %) as the red line? |
Certain blends of polyether anime will actually help prevent gummy buildup. Which is what we want. Techron claims that their additive accomplishes this, but I have yet to prove/disprove because of laziness. |
Yeah I've found its hard to tell because from what research I've done "polyether anime" isn't a set thing and they chemical can vary from product to product. RP has a low naphtha so if that's the main solvent then it will not be as good as the red line |
Curious, how much does it cost to buy some redline off of Amazon and get it shipped there? Srs, no knowledge at all on international shipping. |
$26 apparently in Australia - Redline Oil RED60103 Complete SI 1 Fuel System Cleaner 15oz Bottle | eBay @cletusb; |
Oh, thats not bad. It didn't even take me half a bottle to do my pump. Honestly after that I used a coffee filter to strain what I used and dumped it back in haha. Still half almost a full bottle. |
@littleloogy; are you still running the spring solenoid valve mod with the new current way of adding Si-1? I tried reading through the whole thread and found nothing of you mentioning if your still using it or not with new setup. Looking to jump on this bandwagon next spring and just trying to read up on everything. |
I suggest keeping a spare button valve, a spare SV, and a bottle of SI-1 with you at all times. Having these items have saved my ass a few times in the past. I switched back to gas for a month, I felt as though my car and my clutch needed a break from the sauce. I now have switched back to E85 and since then I have had nothing but problems. You may do everything correct and still develop death in your pump. I am taking notes on my journey back to a problem free pump like @MSP6; |
That suck's that your having issues after switching. I store my car durring the winter months and always switch back to full 91 oct. Makes me wonder if I will run into the same problem every time I switch. Did you rebuild the pump when you switched or just let it be? |
| All times are GMT -7. The time now is 11:45 AM. |
