I have decided to stop using Si-1 in my fuel tank. It is expensive and I feel that we may just be wasting the product. Therefore, I will be adding 2 ML of additive directly into the HPFP every night when I get home from work. In theory, as the additive sits in the pump it will soften and/or eliminate any sticky buildup that will be developing as the fuel boils in my pump. I also believe that this will help with my sticky internal morning start up. At any time my internals start to stick when I am driving, I will pull over and add a 2 ML's of additive directly into the pump, like so... http://img.tapatalk.com/d/14/04/29/ebyba2yq.jpg Take some fuel out so it does not over flow. http://img.tapatalk.com/d/14/04/29/evezy8e6.jpg http://img.tapatalk.com/d/14/04/29/edy9u2y5.jpg http://img.tapatalk.com/d/14/04/29/9uhepa4e.jpg This will simulate (more/less) how my direct additive injection will work, and how the pump will react to the short high dosage of Si-1. |
Not to mention the potential benefits of having a return style secondary fuel source cooling the pump body off. |
with an upgraded ITFP that should not be needed with the FPR crush mod, as far as preventing cavitation |
Epic find guys super stoked to see if we can try another test with a possible baffle mod. seems like an awesome idea.. You said that was off a 2.0t? |
Yes. Audi AND VW with the 2.0t engine. Pumps are very similar, the internals of the pump are the same. IMO There is a better seal on the retaining nut for the piston on their pumps. Unfortunately the pump has a different bolt pattern which inhibits us from bolting directly to the MZR. They are new on eBay for 200 bucks. If anyone wants to grab one. Sent from my SAMSUNG-SGH-I747 using Tapatalk |
Is the retaining nut similar as far as the threads go? |
Completely identical to ours. Sent from my SAMSUNG-SGH-I747 using Tapatalk Except a better seal. Stock piston size is the same as well. Sent from my SAMSUNG-SGH-I747 using Tapatalk |
HMMMMMM.... It sure would be nice if our flow limit on the HPFP was due to cavitation and resolving that would actually allow 400 WHP on full e85... Can you compare measurements on the retaining nuts? |
Yes, tonight. To bad we are talking about modding the fuel pump in an additive thread, we get a little excited... And organization goes to shit [emoji33] |
Yes, but it's for science. Make a new one and tag me in it and we can go all Scientists Gone Wild. |
I don't know about all that. Someone might get the wrong idea start posting nudes while preforming science. Which would be OK with me, depending on how they look. Sent from my SAMSUNG-SGH-I747 using Tapatalk |
This is how similar the pumps are... http://img.tapatalk.com/d/14/04/30/tu9e9u5u.jpghttp://img.tapatalk.com/d/14/04/30/ada7u9ug.jpghttp://img.tapatalk.com/d/14/04/30/5adyde6y.jpghttp://img.tapatalk.com/d/14/04/30/tadegaze.jpghttp://img.tapatalk.com/d/14/04/30/7y4asupy.jpghttp://img.tapatalk.com/d/14/04/30/6a5ymyve.jpghttp://img.tapatalk.com/d/14/04/30/6adydehu.jpghttp://img.tapatalk.com/d/14/04/30/sudy7uqu.jpghttp://img.tapatalk.com/d/14/04/30/ysu2u3u6.jpghttp://img.tapatalk.com/d/14/04/30/a9ahute2.jpghttp://img.tapatalk.com/d/14/04/30/u3ete6eh.jpghttp://img.tapatalk.com/d/14/04/30/pa6epaha.jpghttp://img.tapatalk.com/d/14/04/30/esa5ysub.jpg I fucked up that retaining nut in the hopes that the scraper was pressed in. In case anyone wants to know... It is not. |
I could have told you that the scraper is a thin piece of plastic backed by an oring. I had a retaining nut that I was able to remove the scraper from...I don't recommend trying to run it like that though. |
How far off is the bolt pattern on the housings? just tapa it in. |
If I remember right the pattern was the same, but one side was a little more spaced out then the other pump. It is unfortunate, I was sad when it would not line up... Sent from my SAMSUNG-SGH-I747 using Tapatalk |
So far so good on the additive direct injection testing. I have gotten to know my car pretty well over the past year from being on E mixes. I can now tell early stages of sticky death by sounds, feel of the car, and fuel pressures. For example. Every morning as I have documented, my fuel pump sticks then breaks loose. Then the first 2-3 miles I can hear my relief valve squeak and my fuel pressure bounce all over until is stabilizes. After I started injecting 2ml of additive directly into my pump (under the button valve) after the last shutdown of the day. The nasty startups in the morning before work have became smooth. No relief valve squeak, no harsh slapping of the pump and a very stable idle fuel pressure +/-10 psi of target. I was able to drive over 60 miles this evening without having any episodes of the fuel problems like I experienced after leaning out my mixture of additive in my tank. I will continue to run this way as well as document my findings. Sent from my SAMSUNG-SGH-I747 using Tapatalk |
I have been subscribed and lurking since the beginning. I just want to express my sincere gratitude toward you guys with all the research and testing that you are putting into this. |
I'm with Kay on this. Thanks to everyone who has contributed for the better of the community. I plan to be running full E soon, and look forward to doing so as more testing is done. Sent from my SGS4 |
Can you use this stuff in your oil instead of gas tank? |
... You can not be serious. Aww you changed your statement I would not recommend that |
Lmao. I realized what I said after I pressed post lol. Def wasn't thinking on that one. |
I just got home from a 200 mile road trip and Pulled in my driveway. I started my timer at the same time I clicked my engine off. I rushed into my garage and grabbed my tools. I pulled my spill valve and waiting for the boiling point. It took 2 minutes 48 seconds for my fuel to start boiling in my pump housing. If you pull your SV before boiling point, pressure is very minimal. Anyway, the drive went good. I did not have any pressure spikes or loss, the pressure stayed pretty consistent. I hit 400 miles tonight on this new direct injection method. I have yet to see any early signs of sticky death. I have used less then 1 OZ since I started this experiment. I am not going to get my hopes up, death shows up when you least expect it. Sent from my SAMSUNG-SGH-I747 using Tapatalk |
Ever since I started working at VW, I've been intrigued by how similar the pumps were, but I never thought that plate would bolt right on. Does everything internal still line up with that plate from the 2.0T? I should check and see what my price is on a 2.0T pump, but knowing VW, it'll still be ridiculous even with employee pricing. |
Boiling? I have no other words..... I'm dumbfounded |
Boiling fuel: |
I also check craigslist for cars that have a 2.0t engine that are being parted out part out. Sent from my SAMSUNG-SGH-I747 using Tapatalk |
Do you know the purpose of the baffle cap inlet/outlet for that motor? |
Edit - should probably continue this discussion in @littleloogy;s HPFP hardware thread |
Fuel in the pump is actually cold right after shutdown. I can put my finger in it and get a chill. Temperature increased drastically once fuel stopped moving. Literally, one second its cold the next its seems to almost burn my finger. I think if we setup a return line for after shutdown, we can prevent the sticky from forming in the first place by keeping temps below boiling point. Sent from my SAMSUNG-SGH-I747 using Tapatalk |
It's just boiling off. |
There isn't a return hence I would assume the sticky problem Sent from my HTC One using Tapatalk |
I'd rather run the additive than putting it in right after shut down. Seems like too much work. And I don't daily my car it shouldn't be too expensive running the additive. Guess we'll see. Car will be up and running in a week or two. |
I think he is seeing if it in fact works then he might or someone might devise a direct injection device that would keep the need from injecting it manually. That shouldn't be too hard. Like he said earlier. A button you press right after shut down Sent from my HTC One using Tapatalk |
Ahh yes yes....My bad. for time being ill just run additive in the tank! |
I have started creating a parts list and doing a bit of studying for the best parts for this kit. The hardest part will be finding VW/Audi covers, as I don't believe the covers are sold separately. |
Ohh I kno it's easy to do, taken my Cpe pump apart 50+ times when I ran 100% E. Now I'm trying to get my car put together to run full E again tho. |
Here is what my pump looked like after about 500 miles of just adding 2 ML of additive under the button valve every night. http://img.tapatalk.com/d/14/05/05/a2a9ezub.jpghttp://img.tapatalk.com/d/14/05/05/5uhujuqa.jpghttp://img.tapatalk.com/d/14/05/05/rahane4e.jpghttp://img.tapatalk.com/d/14/05/05/ape7u5e8.jpghttp://img.tapatalk.com/d/14/05/05/e3e9u8u2.jpghttp://img.tapatalk.com/d/14/05/05/y5umyve9.jpghttp://img.tapatalk.com/d/14/05/05/9uvysusy.jpghttp://img.tapatalk.com/d/14/05/05/ge6a5ypy.jpg Internals had a slight sticky feel. But was able to wipe off without the need for a cleaning agent. They came right apart. No black death on piston or retainer the black you see was soft, it was not sticky Sent from my SAMSUNG-SGH-I747 using Tapatalk |
Cap off the outlet on the VW cover, get some sort of solenoid on the inlet with a small cap/opening/tank for dumping in some of this additive. Wire it up to be a switch or button you hold for 2 seconds and it'd be a cakewalk to maintain. |
@littleloogy; and @Enki; , the mad scientists! Little loogy, you are stubborn and it gives results! What you guys are doing for e85 on this plattform is epic and will go down as its own chapter in the msf chronicles! |
May be a dumb idea but could you possibly tap in the hard fuel line and make a drip with the additive alone? Or maybe a version of 5th port to directly add the additive? Just thoughts. |
The only dumb thought is the one not mentioned ;D Tapa Tapa Tapa |
1 Attachment(s) I want to apologize for the lack of updates. I am currently Running into a problem. The problem is that I do not have a problem. I have been waiting for death to attack my pump so I can actually collect some data with this oil and install the injection system. I do not know if it is the oil @Enki; suggested I use, or if it is because I used the additive as a Cleaner/Lubricant when I cleaned and installed the pump. I have 800 miles on the pump since the last rebuild, I have opened the spill valve a few times to check for stickiness, which has been minimal. Here is the Log incase anyone wants to see, its hot outside :angryfire: Attachment 161417 I have decided not to wait any longer for death as it seems as though it will never appear. This week I will try to get the prototype injection system installed and try my best to calibrate it If time allows. I am hoping it works, its about time we all find out. |
Can hardly wait for future update on this! |
Hell yea dude. That is actually great news. Have you figured out where/what you might install the prototype injection system onto? |
Thank you for all the testing and research that you have put into this. I will be watching this thread closely. |
looking very promising. hope you can get a system up and running soon! |
In before injection system is made from parts of penis pump. |
That would be good news! Since everybody here will be able to replicate it immediately. |
I'm still trying to figure out why it's imperative we can run 50-100% E. We don't have the injector headroom and 96 RON ~ 3/9 mix will get you to MBT -2. I'm drunk but this pursuit seems silly for nothing more than beating an obstacle that ... isn't really an obstacle. Splain this shit to me James, and it better be more than "cuz stubborn". |
Ethanol carries oxygen. More ethanol = more oxygen AND more cooling. It's going to be a game changer for stock turbo cars, OR cars with 5/xth port and high comp pistons or redicuboost. |
I will refrain from adding further drunken comments damning the project, as my faux IDCs are currently happy at 95-96% feeding the beener, and a meth kit is my next great hope for defeating the staging lane heat soak. |
Also, send me a log; love to see what an AZ BNRS3 can do. |
Its quite simple really. I do not like that when people say things can't be done. I take it as a personal challenge. So yes, stubbornness... Besides that, after going full E for an extended period of time. I have been working very hard on my tune, at least 40 revisions. With advise from everyone as they converse among themselves in various threads. I have picked up tips on fueling. playing with phasing, VTT, Timing, @and boost, which has enabled me to develop a custom tune that not only is safe to run, but also very fuel efficient (almost as good as petrol). The one thing that amazes me, is that I am mostly stock. I only have a racepipe, and an intake and I am doing the 60-100 in 5.5 seconds. Answer me this @JgamB; do you want to mix fuel the rest of your life? I sure as hell don't. Would it not he bad ass to top off with E and not have to worry about about how much fuel you have left and calculating ratios? Mixing fuel sucks, fuel trims are always changing because the fuel is never constant. Sent From a Galaxy, Far Far Away... |
Ain't no going back now...http://img.tapatalk.com/d/14/05/29/neheqama.jpg FUCK! Sent From a Galaxy, Far Far Away... |
Nice, thanks for all your hard work on this! |
Any update @littleloogy; ? |
What's the deal, any recent updates or findings? |
Yup. Got it figured out. 6,000 miles. Full E. No pump rebuilds. Doing more testing before I say if it actually works or not. Here is the new type of back death after my latest mod. New Black Death E85: Sent From a Galaxy, Far Far Away... |
Recently my car caught on fire and it now gone. I'm saying this bc I want to wish good luck to this project as I'm leaving the mazdaspeed scene. Enjoy your rides and consider keeping a fire extinguisher in the car. It could have saved my ms6. I don't mean to derail the thread, so don't worry about posting about this. Enjoy all |
So it feels gritty or like a fuckin booger? |
I threw that injection mod shit out the window. It was pretty fun playing with and it worked OK, but for my daily driver it was impractical. I wanted to keep this simplified Sent From a Galaxy, Far Far Away... |
So in essence, it could go away the longer it stays there. Did you take it apart for giggles or because of drops in pressure? |
I will admit I have taken my spill valve apart before every long road trip just for piece of mind, not because of failure. When I change my oil i will take my pump apart, I'll take some pictures with some instructions on how I did everything. Then I guess I will need to find a new hobby. Sent From a Galaxy, Far Far Away... |
I'll see about getting more testers for whatever this new method is on board here in AZ. |
That is awesome if you think have this figured out well enough to make full E(or even aggressive blends like past 50/50) a practical option for this platform. I guess it begs the question, what can the stock fuel system support power-wise on full E? @rfinkle2 @TiGraySpeed6 |
So... We did determine the running redline fuel system cleaner helped though, right? Even if it isn't used as an automated injection system? |
I can say @twenty5psi; , stock turbo, bolted (minus mani's) making about 300 @ 3000ASL, I was running 105% + IDC's @ 11.8 afr. Edit: on full E |
1. 50/50 is fine for extended periods of time. I ran it for years. This has been covered in this very thread numerous times. 2. Big turbo cars will be limited on how much they can flow boost/GS wise. I ran out of fuel @ 10 PSI on my EFR, but I had fuel pump issues so no idea what it would be at now. |
I'm out of fuel on 50/50 at 15psi on a 3076. |
Do you have stock boost control/boost reference or have you modded ebcs/reference/wga? |
Boost sourced from compressor or intake manifold? |
Elevation is a hell of a thing. |
Have you tried or seen the Lucas oil ethanol treatment? It says prevents gunk but doesn't say what is in it. Just saw it at the store and going to grab a bottle |
I am not sure, give it a shot. If you want to experiment with different cleaners make sure you Check the data sheets. Look for items with high concentrations of PolyEther Amine and Aliphatic Naphtha. These are the agents that will help keep the death at bay. And keep your SV from getting sticky. Sent From a Galaxy, Far Far Away... |
sorry must have stepped on your ego. Was at the store looking at them and forgot that was mentioned. Anyways....shall we continue with the path we are on. |
Easter bunny....you hurt my feelings with the words you used and I would like an apology or you can just end your life whatever is easier on you...not really but you get the point that this argument you hold has a greater affect on your life |
Uh oh someone's feelings got hurt. |
Here is the stuff I plan on trying, Solvent naphtha (petroleum), medium aliphatic 60 - 100% .http://lucasoil.com/products/fuel-tr...th-stabilizers |
Just start your own thread instead of cluttering up a useful one. |
How about you both stop being faggots before threadbans come out. Do the research/testing, post results. Post ideas, possible solutions, or confirm other findings. Enough bullshit. |
1 Attachment(s) Here is a Data Log Attachment 170359 to expose how well the pump is working. It sure does not have trouble pumping E fuel or maintaining pressure; Even after 5,000 + miles of straight E85 without any additive treatment in the fuel. I am going to try to change my oil tomorrow. Lets all hope I find the time to do so and to post up some info for you. |
I'm excited to hear what youre currently doing for 5k plus miles on E, just caught up with the thread today. |
Ohh im excited! I bought the fuel additive, but idk if i want to use it...So i just been doing a 60/40 mix for now cause im out of fuel on the 35r after 5k.... Hooking up PI this week. |
Got the pump out yesterday. Here is what the internals and pump looked like. The bore was not seized on the piston, it came apart with ease. http://tapatalk.imageshack.com/v2/14...20e8499380.jpghttp://tapatalk.imageshack.com/v2/14...48757593f8.jpghttp://tapatalk.imageshack.com/v2/14...4a8e06e4d1.jpghttp://tapatalk.imageshack.com/v2/14...ee79369177.jpghttp://tapatalk.imageshack.com/v2/14...7bebb14646.jpghttp://tapatalk.imageshack.com/v2/14...168ff45a17.jpghttp://tapatalk.imageshack.com/v2/14...66b531564f.jpghttp://tapatalk.imageshack.com/v2/14...7785bef093.jpghttp://tapatalk.imageshack.com/v2/14...6d12966713.jpg The crap on the piston was not sticky, it was like chalk or a powder and wiped away with ease. So this new method should help keep costs down for people who want to run E all the time like I do, since it only uses a few MLs per pump rebuild. |
| All times are GMT -7. The time now is 11:45 AM. |
