Like Tree80Likes
 Old 12-16-2014, 08:51 AM   #561
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Keep in mind you might still encounter issues after first switching to RP; it may take another oil change to stabilize the pump due to remnants of the old oil.
You may also immediately have no issues. Hard to tell.
Thanks for the info, good to know. Other than the obvious fuel pressure dipping and bogging, anything else to look out for? Got SI-1 and a 32mm wrench in the car with me to be able to get to the spill valve in case things go south.
Amazingly when cleaning the fuel pump, it wasn't very dirty at all. Honestly, when I first installed the internals last year, I didn't clean it. When I pulled it yesterday, it was almost spotless, I was surprised.
 Old 12-16-2014, 09:08 AM   #562
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Originally Posted by littleloogy View Post
This is true. I am experiencing issues trying to convert back. Two oil changes ago I accidentally put in regular royal purple instead of dexos. Since then my spill valve and internals has been getting really sticky. I hope it goes away after my next oil change/pump rebuild.
Sent From a Galaxy, Far Far Away...
So then there is a difference between the Dexos branded one and the non. I can't even find the Dexos branded bottle pictured on the RP website; do you know which one you picked up that was the wrong one?
What oil you running? What mix of corn?
littleloogy (12-16-2014)
 Old 12-16-2014, 10:44 AM   #563
g00s3y's Avatar
Groans: 438
So then there is a difference between the Dexos branded one and the non. I can't even find the Dexos branded bottle pictured on the RP website; do you know which one you picked up that was the wrong one?]
I was running a 42.5 mix with rotella. Will now be going 100% e85 with royal purple dexos 5w-30.
I also bought the car used with 37,xxx on it. Now have 54,800
 Old 12-16-2014, 11:04 AM   #564
Enki's Avatar
Groans: 189
So you were running 50/50 then; there shouldn't be any issues with that in the short to medium terms.
 Old 12-16-2014, 11:11 AM   #565
littleloogy's Avatar
Posts: 4,005   (View Stats)
I bought the 5 quart jug from Kagen Orily's. It said on the front high performance oil, but did not mention anything about meeting gm dexos spec. I did not notice until I did my recent oil change where I saw the different bottle on my self. I am sure I threw it away, but I'll check when I get home.
Enki (12-16-2014)
 Old 12-16-2014, 01:54 PM   #566
g00s3y's Avatar
Groans: 438
I did notice while looking online, a lot of the pictures did not have the "dexos-1" label on the front. But when I went to wal-mart, every bottle I saw there had it.
This is the jug i picked up from wal-mart along with another quart of it.
The Following 2 Users Say Thank You to g00s3y For This Useful Post:
Easter Bunny (12-22-2014), Enki (12-16-2014)
 Old 12-16-2014, 02:01 PM   #567
Don't mistaken it for grape sofa, it does not taste very good.
The Following 2 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (12-22-2014), g00s3y (12-16-2014)
 Old 12-16-2014, 02:09 PM   #568
Enki's Avatar
Groans: 189
I have two of those jugs, because they didn't have individual quarts. Also because oil leak/consumption.
 Old 12-16-2014, 03:17 PM   #569
MSP6's Avatar
Posts: 1,246   (View Stats)
MSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the world
This is the one you want, note the symbol to the right of the volume of the container.
File Type: jpg royal-purple-synthetic-oil-RPL-51530-bm_6410.jpg (55.3 KB, 261 views)
Speed 6 Gone for 3+ years and still not happy about it
2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP
Enki - "High mixes of corn = all the wastegate all the time for great justice."
MSP6 is offline   Reply With Quote
The Following User Says Thank You to MSP6 For This Useful Post:
tbcota25 (12-17-2014)
 Old 12-16-2014, 03:33 PM   #570
g00s3y's Avatar
Groans: 438
damn, mine doesn't have the purple unicorn... ZZB imminent...
 Old 12-16-2014, 04:51 PM   #571
SteelJM1's Avatar
Posts: 35   (View Stats)
SteelJM1 is a splendid one to beholdSteelJM1 is a splendid one to beholdSteelJM1 is a splendid one to beholdSteelJM1 is a splendid one to beholdSteelJM1 is a splendid one to beholdSteelJM1 is a splendid one to beholdSteelJM1 is a splendid one to behold
After i take possession of my booze burning car, I'm going to start experimenting with different dexos-spec oils. Namely mobil 1, castrol edge, and PPU.
SteelJM1 is offline   Reply With Quote
The Following User Says Thank You to SteelJM1 For This Useful Post:
Enki (12-16-2014)
 Old 12-17-2014, 05:21 AM   #572
g00s3y's Avatar
Groans: 438
So, filled up yesterday, everything is running fine, except at WOT. Fuel pressure is having little bit of a hard time, in the early RPM's after going WOT staying above 1600. I see a few (5-6) cells in logs that are 1550+, quite a few in the 1600 range. I'm going to guess that's probably from what @enki; said, remnants from the rotella in there giving it a hard time?
Log attached, need to change up a few things in the tune. I'll probably wait until the next oil change to really get on it, maybe, I don't feel like blowing or bending anything...
 Old 12-17-2014, 06:43 AM   #573
MSP6's Avatar
Nope, just your fp having to work harder to pump full E IMO. Mine did the same thing after going from 50/50 to full. Bumped pressure up in ATR by 100 or so in the weak spots, problem solved.
 Old 12-17-2014, 06:52 AM   #574
tbcota25's Avatar
Posts: 1,542   (View Stats)
tbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the world
OK soooo I'm not sure if I missed something here... So if I'm running E85 (a 40% mix) I should be running dexos approved oil?
2012 Black Mica
Mods
CS catless DP, CS RP
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
CS Short Shit Kit and Shifter Bushings
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
JBR Reticulation Tube
Cobb AP v2
H&R springs
JBR Rear Sway Bar
Self Built 3 Port EBCS
maisonvi Shift Knob
Tuned on 93 and corn
tbcota25 is offline   Reply With Quote
 Old 12-17-2014, 07:04 AM   #575
g00s3y's Avatar
Groans: 438
I was running rotella running both a 33% mix and 42.5% mix, never had any problems. Fuel pump was still very clean also when I took it out to clean it, extremely minor buildup.
I did sort of the same, having it command 1800 instead of 1749. I swear I remember reading on here somewhere to bump it to 1800 on e85, but leave it at 1749 on pump. Made some other revisions also, can't wait to get out of work and go drive some more, hoping to get 200 miles out of a tank at least.
Last edited by g00s3y; 12-17-2014 at 07:04 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-17-2014, 07:11 AM   #576
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
I've been just ghosting this thread for the most part, and haven't really paid any attention to Dexos anything till last week when I started thinking about giving RP a try at my next oil change. I just can't run more than an e30 blend without running out of IDC when it's cold, and that's enough for me to see all I'm comfortable putting down on a stock bottom end. Now that this Dexos business has peaked my interest tho I've started doing some reading up.
Would somebody be kind enough to point out the approximate post count range of this thread when it was defined just what it is about Dexos makes it work magic for 100% e85? As compared to, say, GF-5 synthetics? I'd rather go read up on the conversation that already happened than ask people to rehash an old topic.
Based on reading I've done this morning Dexos is sort of different, I just haven't seen a detailed enough spec to define why, or what it is that's different from GF-5 to make it do what it does for our needs. For example, Thom Smith, a vice-president with Valvoline, stated that GM created the dexos specification by "taking some of the requirements of API, some of the requirements for ACEA and some engine tests on their own, and put together a specification of their own. It does take some additional chemistry to pass all those tests as compared to the basic ILSAC GF-5 type products. There are also some different physical requirements that are more stringent than API."
That was early on when Valvoline was fighting against having to pay ~$0.35 per qt for the Dexos license. Since then they've pretty much gone all in on the Dexos train, along with other holdouts like Castrol.
The current full list of Dexos 1 certified oils-
dexos1 Brands | GM
In the end, if not all Dexos oils work for the 100% e85 sticky/black death issues, wouldn't that mean it's not Dexos standards doing the magic, but rather something specific to the blends of a specific manufacturer?
340hp / 371tq
 Old 12-17-2014, 07:41 AM   #577
g00s3y's Avatar
Groans: 438
Looking at my recent logs, I notice after 5krpm i'm hitting 100-104 IDC. This is with 50*-55* "winter weather" here in Florida.
I'll admit, I have no idea when it comes to specifications and things of that nature of oil and all that. I just read through everything that almost everyone was having great results with RP that has the Dexos1 label on it, so I decided to go with that.
I do have a BlackStone Labs UOA kit at home. Either the next oil change, or the one after I'll be filling it up and sending it off to get some results.
 Old 12-17-2014, 07:50 AM   #578
Originally Posted by TiGraySpeed6 View Post
Would somebody be kind enough to point out the approximate post count range of this thread when it was defined just what it is about Dexos makes it work magic for 100% e85? As compared to, say, GF-5 synthetics? I'd rather go read up on the conversation that already happened then ask people to rehash an old topic.
dexos1 Brands | GM
I would agree that its not the dexos licence. There was something that royal purple did that made it much more compatible with E85, they even claim it as such. As far as why, I don't believe that was discussed.
The Following 4 Users Say Thank You to littleloogy For This Useful Post:
Enki (12-17-2014), g00s3y (12-17-2014), tbcota25 (12-17-2014), TiGraySpeed6 (12-17-2014)
 Old 12-17-2014, 10:05 AM   #579
Enki's Avatar
Groans: 189
We don't know. IIRC, it was my suggestion that we try a Dexos oil because they are more hardened against the pitfalls of running ethanol fuels; it just so happened that the first (and only) Dexos oil I tried (because it was the ONLY one available where I live) had a dramatic improvement.
You are more than welcome to test other oils and let everyone know what you find, but be warned that you may need to run more than one oil change of an oil to see any impact, depending on just how adverse the affects of the prior oil were.
As for me, I've had my heart broken in the past testing full corn and I only need to change my oil twice a year at most so I'm just going to stick with what I know works.
littleloogy (12-17-2014), TiGraySpeed6 (12-17-2014)
 Old 12-17-2014, 11:56 AM   #580
Sandman978's Avatar
Posts: 1,441   (View Stats)
Sandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the world
@Enki; how much time/mileage between changes? Twice a year? Awesome, but that sounds like not daily driven.
2012 CWP Speed3 |:| Cobb V3 AP |:| Resonator Delete |:| Magnaflow Exhaust |:| 4" Exhaust Tips |:| CorkSport SRI |:| Autotech Internals |:| SnailPerformance
Sandman978 is offline   Reply With Quote
 Old 12-17-2014, 12:28 PM   #581
MSP6's Avatar
I have mine tapering down as rpm increases both for pump and on E.
The 1749 number is more or less to keep you below the 1850 psi crack limit of the RV. I had 1900-2000 psi all day everyday on my speed 6 targeting 1850 across the board...for about a month til my rv shit the bed. Now I tweak the tables to keep pressure in the 1700's with as few blips above 1800 as possible.
I did have to bump it over by 50-100 psi in spots after the switch to full E
 Old 12-17-2014, 01:02 PM   #582
g00s3y's Avatar
Groans: 438
Thanks for the info, I actually kind of took Enki's FP table he posted, and sort of mimicked that to a degree. Now it will just be a lot of driving, logging, and making appropriate changes.
I must admit it was nice filling up at one station, and it only costing $31 for 14 gallons.
 Old 12-17-2014, 04:05 PM   #583
Enki's Avatar
Groans: 189
Last oil change was 2014-5-5, and I'm a little over 5500 miles in. It's the only running vehicle I own, so it is my daily, but no I don't drive every day. Working from home ftw.
 Old 12-17-2014, 04:08 PM   #584
My oci is every 3000 or 3 months.
 Old 12-17-2014, 04:10 PM   #585
Enki's Avatar
Groans: 189
I have a 2100 PRV; this table actually gets me fuel cut due to overpressure before I can even hit rev limit. I'm working on turning up the load up top to help with this, but the Autotechs make retarded pressure. Rail pressure stays above 1800 PSI pretty much the whole time, btw.
I kind of have to wonder if it isn't related to three lobes not lining up with injection events and a commanded DC % with overshoot to ensure proper fueling for when the injection event does come.
Wonder if someone can look into this with a scope or something; log DC% of spill valve along with voltage from rail sensor.
 Old 12-17-2014, 04:18 PM   #586
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Enki, I went lower commanded pressures than that with the 2100 valve...nothing made it not cut. Even John at PTP couldn't make it "not cut" He sent me several maps a couple years ago trying...to no avail.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 12-17-2014, 04:36 PM   #587
Enki's Avatar
Groans: 189
One of my older maps on the AP was doing well, then I went and fucked with it and it stopped behaving. I'm still trying to source a new PRV in the 2000 PSI range that's not from him, but it's proving difficult.
 Old 12-17-2014, 04:45 PM   #588
mrmonk7663's Avatar
Good luck man. I ended up getting him to make me a valve with a 1975 cracking pressure and after I modified the fuel maps, it has been good to go. I've been running it like 2 years.
 Old 12-17-2014, 09:45 PM   #589
Could the raised fuel pressure be affecting the way the spill valve operates? I have noticed as you guys are playing around with higher pressure, you seem to have less and less control.
 Old 12-17-2014, 10:06 PM   #590
Enki's Avatar
Groans: 189
Higher pressure? More like runaway pressure. Compare my posted pressure map above to your stock one.
Basically, the PRV is forcing higher pressure, which the spill valve ultimately controls. Stock PRVs are venting anything over 18x psi, but it's still climbing due to flow limits.
I'm betting this isn't a tuning issue, but a stock ecu logic issue. Going to make a request in the VT feature request thread for spill valve duty cycle to see if this is the case.
mrmonk7663 (12-17-2014)
 Old 12-17-2014, 10:11 PM   #591
mrmonk7663's Avatar
Ultimately, our problem is the fuel rail sensor. If we had a sensor that could read to 2500psi, we would be golden...unfortunately 2074 is all we get.
 Old 12-17-2014, 10:36 PM   #592
Enki's Avatar
Groans: 189
We can get another sensor that will read that high, but I don't think we have a way to change the parameters like we do with the MAP sensor.
6 in one hand, half a dozen in the other.
 Old 12-18-2014, 05:26 AM   #593
MSP6's Avatar
Same exact thing for me. He sent me 3 or 4 revisions but when the last one commanded something like 900 psi at 6500rpm I had him refund me. He actually did ask me if I wanted a 1950 valve sent but I said no and sourced a stocker. He was helpful for the most part but kept trying to convince me that it was a tune issue and not a hardware issue lol
 Old 12-18-2014, 08:43 AM   #594
mrmonk7663's Avatar
Yep, he tried to convince me it was a tune issue as well lol. It isn't...at least as far as what we are able to do with ATR. Thankfully, he swapped mine out so I didn't have to pay twice.
 Old 12-18-2014, 08:46 AM   #595
g00s3y's Avatar
Groans: 438
So car sat outside last night in the Florida "cold", had a tiny bit of trouble starting up. Nothing major at all, and once it started up, it was fine the whole drive to work.
Looking like I might actually be able to get 200+ miles out of the tank.
Enki (12-18-2014), littleloogy (12-18-2014)
 Old 12-19-2014, 05:54 AM   #596
MSP6's Avatar
Did it stumble and fake death for a second or did it just take longer to crank? I've had a few longer cranking episodes on sub 20* mornings but AFAIK that's a given with E. Had em on 50/50 sometimes too when it was that cold.
 Old 12-19-2014, 08:10 AM   #597
Enki's Avatar
Groans: 189
In my experience, it takes a couple tries to get it started. VersaTune, however, has tables that should specifically take care of that by allowing temperature based enrichment, so if I ever go back to full E, I should get one crank starts every time, much like what can be achieved on PI cars.
littleloogy (12-19-2014), twenty5psi (12-19-2014)
 Old 12-19-2014, 09:14 AM   #598
To make the car not start like shit on full corn Turn on ignition on, monitor actual FP, hold the gas and clutch down to the floor, crank engine, as the fuel pressure begins to climb release the throttle. You will get a nice crisp start.
After a while you will get a "feel" for how it builds pressure, you won't need to monitor pressure as startup.
g00s3y (12-19-2014), ItsNox (12-26-2014)
 Old 12-19-2014, 09:25 AM   #599
g00s3y's Avatar
Groans: 438
It sort of half stumbles (maybe) & takes 1-2 more cranks, it really isn't major at all, at least that's what I feel. Along with the VTCS delete, the first 20 seconds of a cold start make it seem like my car is dying lol.
 Old 12-19-2014, 09:29 AM   #600
Enki's Avatar
Groans: 189
Does this work when there's snow on the ground too?
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e-85-cure-fuel-additives-166953/
????????? ???? (L3K9-12-615) This thread Refback 12-02-2015 05:22 AM
Senor Blanco Big Turbo Build Thread - Page 5 - DFW Mazdas This thread Refback 03-27-2014 08:14 AM
Fuel/oil additives Jap11g Mazdaspeed3/6 General Discussion 6 03-05-2014 02:38 PM
Visiting the Shell Technology Center, Part 1: The Rise of Additives [w/video] Haltech Automotive News 0 02-19-2014 01:30 PM
Kr above 5000rpm, not really sure how to cure it nick779 2010 MS3 - ECU Computer Tuning 20 01-30-2012 12:28 PM
Cure for the AIDS nut wdautrem MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-20-2011 03:57 AM
Does WI cure KR? MS3 Ventura MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 01-18-2009 10:55 AM
Page generated in 0.60805 seconds with 29 queries
