![]() | | #841 | ![]() |
Groans: 189
| Not Ranked : 0 score
__________________ |
![]() | | #842 | ![]() |
![]() Join Date: Jun 2008 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 752
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score I would get/still get them rather often. But I attribute that to the VTA bov.
__________________ Wiseco OTS pistons, Eagle Rods, ARP mainstuds, JBR BSD w/ baffle,GT2871R, 51R battery, JBR V1 3.5 aluminum widepath, CP-e Catted DP, custom 3in cat-back, Treadstone TR8L core w/ COBB piping, Damond OCC, HKS SSQV3 (full VTA), autotech HPFP internals, Self tune 33% E85, Grimmspeed EBCS (3port), JBR TM & PM, TRZ Rmm, COBB short shifter, COBB Front/Rear swaybars, Koni STR.T struts, AXIS Circuits 18x8.5 45offset **Old Motor** Best 1/4 -13.19 Stock Turbo/ street tires Best trap speed - 112mph **New Motor** Best 1/4 - 13.35 Stock turbo/ street tires Best trap speed - 112.5 |
| The Following User Says Thank You to udntknw For This Useful Post: | Enki (04-16-2015) |
![]() | | #843 | ![]() |
| Not Ranked : 0 score the more open the exhaust system the more prone to after fires as you have removed the muffling effectiveness of the orig system in both reduction of mechanical barriers to the sound (baffles/CATs) and fluid dynamics (backpressure). Add alternate fueling and it will almost always happen. Within ATR you can modify the Shift Control Tables (Beta) to reduce or enhance it with: IGN timing clutch in/out Ign timing (Throttle Closed) @Enki. your ECT compensation within the above tables is likely why it only occurs when the car is hot..tweak them to reduce the negative ign (-13.5) and you may reduce or eliminate it. (that is if you care lol) cut that in half -7.00 and see what it does. Ignore the low ECT tables and only mod the others. I have def changed the characteristics of my afterfires with these tables. I think you can even tune them out completely with a VTA setup which is quite an accomplishment. I believe these tables are also used in part for MegaSpool/antilag. i.e. clutch out = more neg timing ( more afterfires/spool)...throttle closed = more fuel delivery (also afterfires/spool). they will also spool the turbo with little to no load for boost at launch.
| The Following 7 Users Say Thank You to Dano For This Useful Post: | Blown_Dan (04-19-2015), Constantin (04-21-2015), Enki (04-16-2015), JgamB (04-17-2015), JSmith (04-17-2015), Mauro_Penguin (04-17-2015), wolly6973 (04-16-2015) |
![]() | | #844 | ![]() |
![]() Join Date: Apr 2013 Location: Pleasantville, 925
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 589
| Not Ranked : 0 score I must learn this... ![]() Fapped over pics of Laguna Seca
__________________ 2012 CWP Speed3 |:| Cobb V3 AP |:| Resonator Delete |:| Magnaflow Exhaust |:| 4" Exhaust Tips |:| CorkSport SRI |:| Autotech Internals |:| SnailPerformance |
![]() | | #845 | ![]() |
Groans: 189
| Not Ranked : 0 score Thanks @Dano;, though it's rare enough that I (still) enjoy shooting fireballs at the people behind me.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Dano (04-16-2015), Mauro_Penguin (04-17-2015) |
![]() | | #846 | ![]() |
| Not Ranked : 0 score haha I thought as much. I can't shift without after fires with any more than ~40% throttle...I think that happens to coincide with my WMI kicking it at >8PSI. I had it tuned out at some point but then changed E85 ratio/scalar/offset, or Meth nozzle size or any number of other variables changed and I have not cared to go back in and tweak it. Keeps the peeps around me honest ![]() lol surely there is an entire thread dedicated to it but IDK where. The drag racers especially, have used them a lot. IIRC some launch at 20+PSI. @Realgib3; do you know of any threads that cover this (see my post below #844 ) or are you guys keeping it a secret
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 04-16-2015 at 01:51 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to Dano For This Useful Post: | Easter Bunny (04-17-2015), littleloogy (04-16-2015) |
![]() | | #847 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
(Thread Starter) | Not Ranked : 0 score So now that I have a job again, i has monies. So I am ordering a few a few fuel level senders and will be soaking them in E85. I will be applying different treatments to each test subject. Once I get it figured on the bench I'll throw it in my car for some more testing. Sent from my iPhone 6 |
| The Following 10 Users Say Thank You to littleloogy For This Useful Post: | cletusb (04-17-2015), Constantin (04-21-2015), Easter Bunny (04-19-2015), Enki (04-17-2015), JgamB (04-17-2015), Mauro_Penguin (04-17-2015), pzr2874 (04-18-2015), Sandman978 (04-17-2015), someguyondrugs (06-24-2015), TiGraySpeed6 (04-17-2015) |
![]() | | #848 | ![]() |
| Not Ranked : 0 score so Mark comes in here and likes a post but totally ignores my request for knowledge on the megaspool...guess that is an answer of sorts regarding its secrecy. ![]() let's try this again...ya know just to make sure... @Realgib3;
| The Following 4 Users Say Thank You to Dano For This Useful Post: | Easter Bunny (04-19-2015), littleloogy (04-17-2015), Mauro_Penguin (04-17-2015), Sandman978 (04-17-2015) |
![]() | | #849 | ![]() |
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
![]() | | #850 | ![]() |
| Not Ranked : 0 score No you didn't... Lmao 1hr... Wanted to hulk smash my phone three minutes in.... Fapped over pics of Laguna Seca
![]() | | #851 | ![]() |
__________________ Wiseco OTS pistons, Eagle Rods, ARP mainstuds, JBR BSD w/ baffle,GT2871R, 51R battery, JBR V1 3.5 aluminum widepath, CP-e Catted DP, custom 3in cat-back, Treadstone TR8L core w/ COBB piping, Damond OCC, HKS SSQV3 (full VTA), autotech HPFP internals, Self tune 33% E85, Grimmspeed EBCS (3port), JBR TM & PM, TRZ Rmm, COBB short shifter, COBB Front/Rear swaybars, Koni STR.T struts, AXIS Circuits 18x8.5 45offset **Old Motor** Best 1/4 -13.19 Stock Turbo/ street tires Best trap speed - 112mph **New Motor** Best 1/4 - 13.35 Stock turbo/ street tires Best trap speed - 112.5 | |
| The Following User Says Thank You to udntknw For This Useful Post: | littleloogy (04-20-2015) |
![]() | | #852 | ![]() |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 3292 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,280
Groans: 52
| The Following User Says Thank You to Realgib3 For This Useful Post: | Mauro_Penguin (04-20-2015) |
![]() | | #853 | ![]() |
| Not Ranked : 0 score O I C.
| The Following User Says Thank You to Dano For This Useful Post: | pzr2874 (04-21-2015) |
![]() | | #854 | ![]() |
| Not Ranked : 0 score Then I say, off with his head!
![]() | | #855 | ![]() |
![]() Join Date: Oct 2013 Location: Fort Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 976
Groans: 438
| Not Ranked : 0 score So, little update that doesn't really pertain to much about e85. I've been trying to empty my tank by driving around (yes I know there are easier ways, but they aren't as much fun), so I can go back to 93 and see if it fixes the fuel sender problem since I just replaced it around a month and a week ago I believe and it shouldn't be dead this quickly. This morning as I was driving down past my local shell station, I was literally 500-750 feet away, I feel my car hiccup a bit, and just kind of go limp. I'm literally able to coast to the light, turn left, then turn into the Shell station, and stop at a pump. Tried to start the car, no gas. Either I'm fucking awesome with my calculations, or I'm just lucky, i'd like to think i'm fucking awesome, but that's just my opinion. I filled up 93, switched to my 93 tune, drove home, fuel level went up to 2 bars, CEL went off for the fuel level sender. So going to see if this fixes the "problem". Hopefully it will keep going up the more I drive. If so, I might just be staying on pump for a while (groan, i know, but I do like knowing how much fuel I have). If I still have an issue with the sender, then fuck it, back to full e85. Also, I haven't done anything to the fuel pump, or added anything since about a month ago when I put about a half bottle of SI-1 in the tank and went to a 50/50 mix, after a fill-up with e85 started giving the sender problems already. So if this doesn't work, and I go back full e85, I still won't touch the pump and see how long before/any/if problems arise, for science!
__________________ All good things must come to an end... |
![]() | | #856 | ![]() |
| Not Ranked : 0 score Was your issue on the connector or on the float arm? Can't remember, and the phone isn't search friendly. @g00s3y;? Fapped over pics of Laguna Seca
![]() | | #857 | ![]() |
Groans: 438
Went 70 miles so far today, fuel level is only showing 2 bars, and range says 63 miles left. When I filled up, range was at 37 left.
__________________ All good things must come to an end... | |
![]() | | #858 | ![]() |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
Permatex® Clear RTV Silicone Adhesive Sealant 3oz Tube 80050 Temp, chem resistant etc like the grease but would be a more permanent seal as opposed to being subject to washing off gradually. @Enki; @littleloogy; thoughts?
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." | |
| The Following User Says Thank You to MSP6 For This Useful Post: | Mauro_Penguin (05-04-2015) |
![]() | | #859 | ![]() |
Groans: 438
I'm actually going to be free tomorrow, I may pull it to inspect since I can get to it from the top. I won't be replacing it, but I'll post up some pics of what it looks like if I inspect. I'm really questioning how this new sender went so quickly (lasted less than 2000 miles), when the original one went 53k+ until problems started.
![]() | | #860 | ![]() |
Groans: 189
| Not Ranked : 0 score I think the issue is that the contacts corrode so using RTV will just permanently keep them from working...Unless I'm misunderstanding the situation there's not a way to keep the fuel off of them (which is what causes the corrosion) without disabling the fuel level sender. Maybe it would be better to either solder over each individual pad or replace the contacts with something that won't fail like this...
| The Following User Says Thank You to Enki For This Useful Post: | Mauro_Penguin (05-04-2015) |
![]() | | #861 | ![]() |
![]() Join Date: Mar 2012 Location: Warrenville, IL/Big Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,349
| Not Ranked : 0 score Just out of curiosity, maybe I missed it, but has anyone ran the RP Dexos oil without S1?
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings |
| The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post: | Enki (05-04-2015), Mauro_Penguin (05-04-2015) |
![]() | | #862 | ![]() |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | Mauro_Penguin (05-04-2015), Mazdazilla6 (05-04-2015) |
![]() | | #863 | ![]() |
Groans: 189
I'm well over 1k miles now, without a hiccup. Also, I have not touched my pump since the last time, which was several months before I even switched over to full corn.
__________________ | |
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #864 | ![]() |
Going off of this picture it seems the contacts themselves could be covered/sealed completely in with RTV. It won't affect the signal as the line underneath is still complete. We did this in the Navy all the time with wires and connections for jet parts that had to deal with corrosion. ![]() Though in another thread @Voltwings; said he "covered" his contacts with "silicon" so IDK if he meant RTV or what? Or whether it worked out for him.
| The Following 2 Users Say Thank You to MSP6 For This Useful Post: | Mauro_Penguin (05-04-2015), Voltwings (05-04-2015) |
![]() | | #865 | ![]() |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score Those with bad fuel level sensors For the life of me i cant remember what i used. It may have been some sort of di-electric grease?
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
![]() | | #866 | ![]() |
You running E? Or did you switch back to petroleum? Sent from my iPhone 6 | |
![]() | | #867 | ![]() |
So, i dont know if i should attribute it working to the grease / silicone, or going down in concentration, but going down in concentration on other cars i tuned seems to have prevented that problem for them. Lots of ifs, ands, and buts, but that's my assessment of the situation.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() | | #868 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ah, got you. I'll tell you what. I'll test this sometime in the future on your behalf with 100%E. If it works then we will give you credit for fixing the gen2 fuel level sender unit. Sent from my iPhone 6 |
| The Following 3 Users Say Thank You to littleloogy For This Useful Post: |
![]() | | #869 | ![]() |
Groans: 438
| The Following 2 Users Say Thank You to g00s3y For This Useful Post: | Mauro_Penguin (05-04-2015), Voltwings (05-04-2015) |
![]() | | #870 | ![]() |
| Not Ranked : 0 score I wonder if there is just something that makes some cars more prone than others, because it seems a lot of people who have this problem have had it multiple times, and usually in quick succession after the first replacement ... interesting.
![]() | | #871 | ![]() |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score Deluxe Liquid Gold Plating System Jewelry Immersion Kit Gold Plating Kit | eBay "It will NOT work, however, on stainless steel, lead, pewter, tin, aluminum, lacquered or non-metallic surfaces." I'm not sure what the current contact is made from, but it might be worth $30 to try it.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
![]() | | #872 | ![]() |
(Thread Starter) | Not Ranked : 0 score E85 Remedy with HPFP Hardware modifications E85 Remedy with HPFP Hardware modifications Post 372 and so on... Sent from my iPhone 6 |
![]() | | #873 | ![]() |
Groans: 438
| Not Ranked : 0 score So, just pulled mine again, here's what it looks like.
| The Following User Says Thank You to g00s3y For This Useful Post: | Mauro_Penguin (05-06-2015) |
![]() | | #874 | ![]() |
(Thread Starter) | Not Ranked : 0 score You have a meter? Edit: Does it ohm out okay? Sent from my iPhone 6 |
| The Following User Says Thank You to littleloogy For This Useful Post: | Mauro_Penguin (05-06-2015) |
![]() | | #875 | ![]() |
Groans: 438
| Not Ranked : 0 score To be honest, I didn't even check, could clearly see the corrosion and that it wasn't making contact. Phone pictures, sorry they couldn't be better. Just finished soldering it and will be checking everything before it gets all put back together.
| The Following 2 Users Say Thank You to g00s3y For This Useful Post: | littleloogy (05-04-2015), Mauro_Penguin (05-06-2015) |
![]() | | #876 | ![]() |
That a baby. Hope it works! Sent from my iPhone 6 | |
![]() | | #877 | ![]() |
Groans: 438
| Not Ranked : 0 score She's alive!!!!
| The Following 5 Users Say Thank You to g00s3y For This Useful Post: | Enki (05-04-2015), littleloogy (05-04-2015), Mauro_Penguin (05-06-2015), Sandman978 (05-04-2015), TiGraySpeed6 (05-05-2015) |
![]() | | #878 | ![]() |
![]() | | #879 | ![]() |
Groans: 438
| Not Ranked : 0 score Just an update, went out to my car today, started her up, gauge reads 0... So, pulled it again, found out the contacts on the little "swinger arm" were no longer touching, must have bent them reassembling. Bent them back a little bit so they would make contact, all is now good. Cutting up the interior a little to get to this thing was the greatest idea ever, because fuck dropping the tank each time to do this...
| The Following 3 Users Say Thank You to g00s3y For This Useful Post: |
![]() | | #880 | ![]() |
You want to rig it so there is clamping force on the contacts. Mine still working great! It sure is depressing watching how fast my fuel level drops. Sent from my iPhone 6 | |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | Mauro_Penguin (05-06-2015), Sandman978 (05-05-2015) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e-85-cure-fuel-additives-166953/ | ||||
| ????????? ???? (L3K9-12-615) | This thread | Refback | 12-02-2015 05:22 AM | |
| Senor Blanco Big Turbo Build Thread - Page 5 - DFW Mazdas | This thread | Refback | 03-27-2014 08:14 AM | |
| Fuel/oil additives | Jap11g | Mazdaspeed3/6 General Discussion | 6 | 03-05-2014 02:38 PM |
| Visiting the Shell Technology Center, Part 1: The Rise of Additives [w/video] | Haltech | Automotive News | 0 | 02-19-2014 01:30 PM |
| Kr above 5000rpm, not really sure how to cure it | nick779 | 2010 MS3 - ECU Computer Tuning | 20 | 01-30-2012 12:28 PM |
| Cure for the AIDS nut | wdautrem | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 04-20-2011 03:57 AM |
| Does WI cure KR? | MS3 Ventura | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 4 | 01-18-2009 10:55 AM |
