Like Tree80Likes
 Old 04-23-2014, 11:05 PM   #161
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Originally Posted by littleloogy View Post
I do need to change my oil soon. I got a lot of requests to test Rotella with this additive. It seems to be the most popular choice of oils.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
First, awesome results so far.
Do you think it would be more beneficial to get a larger sample size with oils before switching? I ask because I know there was quite a bit of difference in oil's tested in the King's of Corn thread.
For what it's worth, I run T6, so I am without a doubt interested in seeing it tested. I also have been using this additive with each fill up of my 50/50 mix. I started that after last oil change about 1500 miles ago, and cleaned my pump before at the time, it didn't need it. I plan on getting UOA after another 1500 mi, and inspecting the pump then as well.
I would, maybe open to running full e with t6 in tandem with your testing.
TL/DR--MOAR DATA=BETTER, MAYBE?
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
The Following 4 Users Say Thank You to WetzMS3 For This Useful Post:
Easter Bunny (04-25-2014), ItsNox (04-28-2014), Kyle Undefined (04-25-2014), mazdafreak (04-24-2014)
 Old 04-23-2014, 11:31 PM   #162
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
So test it.
ItsNox (04-28-2014), mazdafreak (04-24-2014), WetzMS3 (04-25-2014)
 Old 04-24-2014, 12:20 AM   #163
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
So you still running 1:1 or w.e or u running less additive now?
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 04-24-2014, 11:10 PM   #164
littleloogy's Avatar
Posts: 4,005   (View Stats)
Same additive content as before. I am hesitant to lean it out as this is my daily driver. This weekend I finally will have a few days to myself, and can risk some car trouble. Therefore I will run a 1oz to 2 gallon ratio and see how she does.
The Following 6 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (04-25-2014), El_Diablo (04-30-2014), Enki (04-24-2014), ItsNox (04-28-2014), Kyle Undefined (04-25-2014), PapaSmurf (04-25-2014)
 Old 04-25-2014, 07:07 AM   #165
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Groans: 112
Default E-85 Cure With Fuel Additives
My engine is about a month or so out from being in my car, after break in I am really debating running full E with this additive along with redline 20w50. Hopefully there is more data by then but if not I am still up for it.
Sent from your girlfriends tapabedroom
860whp/677wtq
2.7 V6 Ecoboost
The Following 3 Users Say Thank You to PapaSmurf For This Useful Post:
Easter Bunny (04-25-2014), Kyle Undefined (04-25-2014), mazdafreak (04-25-2014)
 Old 04-25-2014, 09:47 AM   #166
I hope I can deliver. What are you looking for as far as data goes? Tonight is my HPFP teardown and write up night. Maybe I can address some of your questions at that time.
sidekick likes this.
The Following 3 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (04-26-2014), Enki (04-25-2014), ItsNox (04-28-2014)
 Old 04-25-2014, 01:35 PM   #167
PapaSmurf's Avatar
Groans: 112
I guess by "data" I meant more people running full e successfully like you are. I will for sure be running 20w50 just because the thicker oil will help keep oil temps down. The reason I picked redline is because you have been successful with redline oil already. Hopefully different oil viscosity's dont play a roll in if "black death" occurs or not.
860whp/677wtq
2.7 V6 Ecoboost
The Following User Says Thank You to PapaSmurf For This Useful Post:
 Old 04-25-2014, 02:18 PM   #168
I understand. Let's see how the pump looks tonight. I called Redline today, the "tech" was out for the day. I will be calling again on Monday to discuss the testing of the product and possible side effects from prolonged use. I do not want to take a chance is being responsible for killing motors.
Edit:
Redline by default runs cooler and thicker as it is. When my Redline oil (10w30) warms up it actually becomes close to a 10w40. So a 20w50 may actually be a 20w60...
Easter Bunny (04-26-2014), ItsNox (04-28-2014), PapaSmurf (04-25-2014)
 Old 04-26-2014, 05:57 AM   #169
Mfinlay04's Avatar
Posts: 827   (View Stats)
Mfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the world
I'm praying for this to work out. If it does when my vvt is fixed I'll be running 100% E85. I've been running chevron delco for a few months. I was planning on getting a uoa anyways. So we can compare before and after to see if it affect the oil any.
2006 MS6 Titanium Grey
BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3
Tuned with
Mfinlay04 is offline   Reply With Quote
 Old 04-26-2014, 07:12 PM   #170
Removal of the pump was delayed a day due to mother nature being a bitch.
I was really disappointed when I removed my internals this morning. I guess in the back of my head I knew they would look like this, but I was hoping for better results.
These internals have not been touched for 3000 miles on Full E. The internals were in good shape considering. Not to much black death, but were coated in sticky death.
When I tried to pull the internals apart they were damn near seized. I was able to pull them apart with my hands, but it was really tough. I GOPROed the removal if anyone wants to see it what it was like.
When I think back I remember my cold startups have not always been crisp. The engine would briefly (less then a second) stumble until the pump worked itself loose then would idle and run flawlessly. This is caused by the fuel drying out between the piston and the sleeve as the pump sits over night. When the motor turns over it forces fresh fuel onto the sleeve and piston freeing up the internals for normal operation.
The Following 12 Users Say Thank You to littleloogy For This Useful Post:
Constantin (04-26-2014), crutch77 (04-27-2014), Easter Bunny (04-28-2014), El_Diablo (04-30-2014), Enki (04-26-2014), ItsNox (04-28-2014), kolosok17 (04-28-2014), Kyle Undefined (04-27-2014), purpledrank (04-28-2014), pzr2874 (04-26-2014), sidekick (04-26-2014), udntknw (04-26-2014)
 Old 04-26-2014, 10:19 PM   #171
Enki's Avatar
Groans: 189
I don't care what anyone says man, 3000 miles on full E is a fucking victory in my book.
Mfinlay04 and littleloogy like this.
The Following 16 Users Say Thank You to Enki For This Useful Post:
12blkms3 (04-27-2014), Constantin (04-27-2014), cshunter (04-27-2014), Easter Bunny (04-28-2014), El_Diablo (04-30-2014), ItsNox (04-28-2014), Kyle Undefined (04-27-2014), littleloogy (04-27-2014), mazdafreak (04-27-2014), Mfinlay04 (04-27-2014), PapaSmurf (04-27-2014), purpledrank (04-28-2014), Roddiy (04-28-2014), sidekick (04-26-2014), SLOWHATCH (04-27-2014), udntknw (04-26-2014)
 Old 04-26-2014, 11:39 PM   #172
JgamB's Avatar
Posts: 2,566   (View Stats)
I know we don't have VW'esque cam follower deterioration, but I have to wonder what this is doing to the follower or cam lobe with the additional resistance. If it's just on startup, it's probably not a big deal.
Is everyone running this test using ATs? Anyone using the CS internals and what might be a different coating on the piston?
The Following 4 Users Say Thank You to JgamB For This Useful Post:
Easter Bunny (04-28-2014), El_Diablo (04-30-2014), Koke382 (04-27-2014), littleloogy (04-27-2014)
 Old 04-27-2014, 12:09 AM   #173
I pulled my Cam Follower and it still looked new. Even after running like this for 30 miles... Cam follower slapping HPFP:
Edit: This was from my first experience with black death. Fun times...
Easter Bunny (04-28-2014), El_Diablo (04-30-2014), JgamB (04-27-2014)
 Old 04-27-2014, 10:12 AM   #174
Jap11g's Avatar
Posts: 287   (View Stats)
Jap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond repute
Groaned at 7 Times in 5 Posts
@TiGraySpeed6; interesting read if you haven't already seen it, man. Let me know what you think.
Also, does anyone in here think there is an advantage to running a round of redline through my car just to clean things up a bit? I work at O'Reillys so the stuff is basically free for me. I'd like to clean up if I can, even if I'm only on 4 gallons of E right now.
Tapa Tapa Tapa
JP
Jap11g is offline   Reply With Quote
 Old 04-27-2014, 10:33 AM   #175
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Tapa Tapa Tapa
This was asked earlier in the thread. "try it" and let us know.
The Following 2 Users Say Thank You to pzr2874 For This Useful Post:
Enki (04-27-2014), littleloogy (04-27-2014)
 Old 04-27-2014, 10:36 AM   #176
Jap11g's Avatar
Oh shit ya I did ask that. I couldn't remember if I did, or just thought about it and never got around to it.
Alright. Well, I don't see how it would do any damage do I'll try it out and see if it helps.
I'm only getting like 10mpg right now and can't figure out why... So I'm hoping something like this redline stuff will clean everything up a bit and help.
Tapa Tapa Tapa
JP
Last edited by Jap11g; 04-27-2014 at 10:36 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-27-2014, 06:35 PM   #177
jtms6's Avatar
Posts: 51   (View Stats)
jtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud of
does the pump prime itself with the ignition on? the only way to break the gunk loose is actually turning it over right? ive been on fulle E for quite a while now, my situation is my car sits for 4 days and i drive it on the weekend, cold starts are a bit stumbly but once it warms up its all good
" THE list " Cobb AP // CPE catback exh w/ resonator // CORKSPORT TMIC // Autotech HPFP // ITV22's // COBB SF+TIH // AWR PMM,TMM // JBR RMM // CPE Rear diff mt // EGAY catless DP // BANJO BOLT // SPC balljoints // speed daddy springs
self tuning journey of fail begins
jtms6 is offline   Reply With Quote
 Old 04-27-2014, 07:06 PM   #178
The pump only receives the pressure the ITFP sends which is 60 PSI in my case. This is the only prime it sees.
I am a 12' with tech package so this may not apply to everyone: After my speed sits for a few days or on really cold startups I floor my gas pedal and clutch so my engine turns over but does not start. I monitor my fuel pressure closely, when it climbs past 1000 PSI I release my gas pedal and my engine will start without a stumble.
I don't usually do this because the battery in my car is about shot. And I don't want to kill my starter with prolonged low voltage cranking.
 Old 04-27-2014, 11:25 PM   #179
Mfinlay04's Avatar
What oil have you been running? I didn't see a post from you in the king of corn thread
Tuned with
 Old 04-27-2014, 11:38 PM   #180
I went for a drive tonight. Raced a few cars got on it like usual, but something just was not feeling right. I start to take it easy as I just did not feel comfortable. My radio was on so I turned it off, then I hear that all to familiar sound... "Squeek squeek squeek." The damn relief valve is going off like there ain't no tomorrow. I look closer at my Fuel pressure, sure shit fuel pressure spike into the high 1800's. I get home and find this sticky shit...
A non sticky button valve! Yey. But unfortunately I also found this...
I decided to go back to my Spill valve upper spring Mod. This worked great at allowing the spill valve to work with the sticky death. I took out the spring mod when I started this additive.
I wanted to see if the upper spring mod was mandatory or not. Clearly you will need this mod if you are to run a maintenance free full E85 for over 1500 miles.
I reinstalled the modified spill valve without cleaning anything. Here is the hpfp mod thread in case you want more info. E85 Remedy with HPFP Hardware modifications
The Following 9 Users Say Thank You to littleloogy For This Useful Post:
Constantin (04-28-2014), Dano (05-14-2014), El_Diablo (04-30-2014), Enki (04-27-2014), jtms6 (04-28-2014), mazdafreak (04-28-2014), Roddiy (04-28-2014), Spec (04-28-2014), WetzMS3 (04-30-2014)
 Old 04-28-2014, 01:57 PM   #181
mazdafreak's Avatar
Groans: 124
Looks like ill need to mod my spill valve.
713whp/569wtq!
 Old 04-28-2014, 01:59 PM   #182
Jap11g's Avatar
@CouldaHadaDodge;
Tapa Tapa Tapa
JP
 Old 04-28-2014, 02:25 PM   #183
Enki's Avatar
Groans: 189
I've done some orifice measuring on the spill valve and found inconsistencies in available flow area; while I'm not sure that modifying the pump will actually accomplish anything, it will be interesting to try. I also still need to take a look at a fuel pump body as well, but it might get destroyed if modified (which I want to avoid).
I'll post a thread on this later after I've had a chance to give a pump body a once-over.
Jap11g (04-28-2014), littleloogy (04-28-2014)
 Old 04-28-2014, 03:01 PM   #184
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
i just bought two bottles from amazon for 11.95 free shipping each, i found same price on ebay. I dont run any E85 but all cars get 10% ethanol Via normal gas so I plan on running a bottle trough my ms3 and cx7 just to clean shit up.
I am thinking i should maybe split the bottle in half per tank instead of a bottle per tank.
i know this does not help you guys run E85 but the issues could occur with normal gas over long time.
 Old 04-28-2014, 03:31 PM   #185
I tried running lean on the additive with negative results. I was having a bad time driving to work. Pressure got really inconsistent. I ended up pouring some additive directly into my spill valve area to stop my internals from sticking... Shit worked almost instantly.
Now I have another idea... Direct injection for the additive, directly into the pump. It will be Controlled by a button in the cab, when internals start to stick... Hit the goo button. Similar to an IV, But pressurized.
The Following 4 Users Say Thank You to littleloogy For This Useful Post:
Constantin (04-28-2014), Easter Bunny (04-28-2014), Jap11g (04-28-2014), mazdafreak (04-28-2014)
 Old 04-28-2014, 04:19 PM   #186
SpeedEngineer's Avatar
Posts: 1,589   (View Stats)
SpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the world
Groaned at 20 Times in 19 Posts
Maybe not something where you press a button but something that flows a small amount continuously or something similar to a meth kit. That way it takes the guess work out so to speak ..hmmn
Sent from my HTC One using Tapatalk
2010 MS3 GenPu Blue Mica
ETS TMIC | ATP 3" Downpipe | OBX Catback | HTP 3" Intake | 3 Bar MAP Senosor | Cobb Accessport | CorkSport Battery Box | JBR Shift weight| JBR 88 duro RMM | JBR 88 duro TMM | JBR 80 duro PMM | JBR IM and TB TIGS | JBR Boost Tubes | Forge V1 | SSP Full EGR Delete | Balance Shaft Delete | Iridium one step colder sparkplugs | Autotech internals | Koni Yellow Shocks and Struts | Swift Springs | Defi Boost Guage | DDM 6000k 55W Headlights | 5000k 35W Fogs
4 GAL E85 CORN BY THE FREEK
Blue 2011 Triumph Daytona 675 Triple
SpeedEngineer is offline   Reply With Quote
The Following User Says Thank You to SpeedEngineer For This Useful Post:
Jap11g (04-28-2014)
 Old 04-28-2014, 04:30 PM   #187
I like buttons though...
Jap11g likes this.
Constantin (04-28-2014), Easter Bunny (04-28-2014), Jap11g (04-28-2014), Roddiy (04-28-2014), udntknw (04-28-2014), WetzMS3 (04-30-2014)
 Old 04-28-2014, 04:33 PM   #188
You can press my buttons anytime
I was just throwing out an idea for the preventative side
 Old 04-28-2014, 04:41 PM   #189
Enki's Avatar
Groans: 189
It does, actually. 3k miles is further than anyone really ever gets without some kind of issue.
It does, actually. Worst pump I ever saw had seized stock internals from black death in a 100k mile CX7. Pretty sure the engine went as a result.
Easter Bunny (04-28-2014), kolosok17 (04-29-2014), littleloogy (04-28-2014)
 Old 04-28-2014, 04:41 PM   #190
Jap11g's Avatar
I like this brainstorming!
Tapa Tapa Tapa
JP
 Old 04-28-2014, 05:48 PM   #191
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
So your saying I should clean my 45000 mile pump that has never been touched.
I hugged rfinkle2
Enki (04-28-2014), littleloogy (04-28-2014)
 Old 04-28-2014, 06:08 PM   #192
Roddiy's Avatar
Posts: 5,388   (View Stats)
Roddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the world
Groans: 279
Groaned at 58 Times in 47 Posts
Shit man, that's some frankenstein shit.
I like it.
and thanks for all the work you're putting in man, this is turning out to be a pretty big breakthrough for the power-hungry fellas who just need that 100% E85.
Pretty sure something like this would make the difference between 794whp and 800+whp... hehehe
2010 LSM Speed3
Bolted + Corn + Meth + ACT 6-Puck
#BakeryTuned
Roddiy is offline   Reply With Quote
 Old 04-28-2014, 06:32 PM   #193
Mazda Love's Avatar
Posts: 662   (View Stats)
Mazda Love is the leader of the worldMazda Love is the leader of the worldMazda Love is the leader of the worldMazda Love is the leader of the worldMazda Love is the leader of the worldMazda Love is the leader of the worldMazda Love is the leader of the worldMazda Love is the leader of the worldMazda Love is the leader of the worldMazda Love is the leader of the worldMazda Love is the leader of the world
It definitely wont hurt.... win win if you ask me. and if anyone wants they can shoot me real quick how to add 30% to my speed 6 and ill fine tune myself and help with the oil testing. i am currently running 5w30 royal purple. i have my rx-8 up and running now so i can park my 6 when it needs a fuel cleaning. i have a cpe hpfp also.
2007 MS6 (Beautiful Black)
CP-E CDFP / Custom 3" FMIC / Custom Intake / 70 JB RMM / COBB V3 / E-BAY DP / Snow WMI Stage 2 Kit W/D010 Spray / HKS Bov / Custom 3" Borla Cat-Back / Duel Air Temp Gauge (After Turbo, Before Throttle Body) / Boost Gauge / Individual EGT Probe Gauge / 3 Bar Map / Dual GrimmSpeed BCS (working in push/pull mode) / Battery Relocation To Truck / Forged Block Internals
2004 RX8 (Beautiful Black) (Race Car/ Not Street Legal)
(E-85 Tune) Borla Cat-Back / OBX Header / RB Race Pipe / Custom K&N Intake / Custom Vented Hood / COBB AP / Drilled & Slotted Rotors / BEAR Brakes / Custom Fuel Return Line / 297 BHP (Peak 9650 RPM) / 223 FT. LB. TORQUE. (Peak 6850 RPM) / 2,698 lb. (Curb Weight)
2003 VW PASSAT W8 4-MOTION (Nobody Cares Blue)
Intake / Glass Pack Exhaust. ******FOR SALE*******
Mazda Love is offline   Reply With Quote
 Old 04-28-2014, 07:35 PM   #194
Enki's Avatar
Groans: 189
Best place to "inject" would be off the blue or yellow clip line; a hole in the pump anywhere else is asking for trouble. You should be able to get an inline tap style setup like what people use for 5th port.
littleloogy (04-28-2014), Roddiy (04-28-2014)
 Old 04-28-2014, 09:03 PM   #195
That is an excellent idea. That will give the additive time to mix into the fuel. I will most likely choose this route. However, I do have a pump off of a 2.0t motor. I might swap out the baffle covers and run the additive through there as the cover lines up perfectly.
If this works well I will work on a Plug and play style kit, that will more likely tap into the relief valve. But I guess it does not matter much.
Constantin (04-28-2014), Easter Bunny (04-29-2014), jtms6 (04-29-2014), PapaSmurf (08-11-2014), sidekick (05-03-2014), TiGraySpeed6 (04-29-2014)
 Old 04-28-2014, 09:16 PM   #196
Enki's Avatar
Groans: 189
This might actually be a good option for creating a return style fuel system for use with 5th/manyport injection, and provide additional cooling to the HPFP...
The Following 6 Users Say Thank You to Enki For This Useful Post:
Easter Bunny (04-29-2014), jtms6 (04-29-2014), littleloogy (04-28-2014), marcobleedsblue (11-27-2014), Roddiy (04-28-2014), sidekick (05-03-2014)
 Old 04-28-2014, 09:22 PM   #197
Jap11g's Avatar
History is in the making...
Tapa Tapa Tapa
JP
The Following 2 Users Say Thank You to Jap11g For This Useful Post:
blackms3_71 (04-28-2014), sidekick (05-03-2014)
 Old 04-28-2014, 09:37 PM   #198
kolosok17's Avatar
Posts: 1,104   (View Stats)
kolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the world
Groans: 47
Yup, I had a lot of sticky in my pump when I was swapping in Autotechs at around 17k miles.
2012 CWP Non-Tech MS3
JBR SSB, Mazda Rear Bumper Guards, JBR Mud Flaps, JBR 88a RMM, Mazda All-Weather Floor Mats,
COBB AP V2B, JBR RSB with Tru-Torsion brackets, Autotech Internals, CorkSport SRI+TIP, JBR Stage 2 OCC,
Mazda Rear Cargo Tray, Stratified S-OTS+ Stage 1 Map, NATOR NorCal Sticker
kolosok17 is offline   Reply With Quote
The Following 2 Users Say Thank You to kolosok17 For This Useful Post:
littleloogy (04-28-2014), spals (04-29-2014)
 Old 04-28-2014, 11:29 PM   #199
Mfinlay04's Avatar
I had some black death in my pump when I first out internals in. Never ran e85 before that obviously. But pump gas contains up to X% of ethanol. I've been on 50/50 corn for three years and never had to clean my pump. Although startups have been getting a little weird so im sure there is black death waiting for me
Sent from my SCH-I605 using Tapatalk
Tuned with
The Following User Says Thank You to Mfinlay04 For This Useful Post:
 Old 04-28-2014, 11:40 PM   #200
Well here are some more pictures of the baffle cover in case you want to see more.
I like that this plate could be used to monitor the low pressure side during WOT pulls. To see if we are getting a pressure drop from the low side.
El_Diablo (04-30-2014), Enki (04-29-2014), Jap11g (04-29-2014), jtms6 (04-29-2014), Mfinlay04 (04-28-2014), sidekick (05-03-2014), TiGraySpeed6 (04-29-2014), WetzMS3 (04-30-2014), wolly6973 (04-29-2014)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e-85-cure-fuel-additives-166953/
????????? ???? (L3K9-12-615) This thread Refback 12-02-2015 05:22 AM
Senor Blanco Big Turbo Build Thread - Page 5 - DFW Mazdas This thread Refback 03-27-2014 08:14 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Fuel/oil additives Jap11g Mazdaspeed3/6 General Discussion 6 03-05-2014 02:38 PM
Visiting the Shell Technology Center, Part 1: The Rise of Additives [w/video] Haltech Automotive News 0 02-19-2014 01:30 PM
Kr above 5000rpm, not really sure how to cure it nick779 2010 MS3 - ECU Computer Tuning 20 01-30-2012 12:28 PM
Cure for the AIDS nut wdautrem MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-20-2011 03:57 AM
Does WI cure KR? MS3 Ventura MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 01-18-2009 10:55 AM
Page generated in 0.63449 seconds with 36 queries
