Like Tree80Likes
 Old 05-05-2014, 10:41 AM   #241
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Originally Posted by littleloogy View Post
Its not that bad actually. It takes me 4 minutes to complete the direct injection process. I do not do it after every shutdown. I do it at the last shutdown of the day, Right before I go sleepy time.
I have started creating a parts list and doing a bit of studying for the best parts for this kit. The hardest part will be finding VW/Audi covers, as I don't believe the covers are sold separately.
if this works out, having a cover machined specifically for this use wouldnt be that much of a hassle.
I hugged rfinkle2
The Following 5 Users Say Thank You to Easter Bunny For This Useful Post:
cocoanton (05-10-2014), Enki (05-05-2014), Jap11g (05-05-2014), littleloogy (05-05-2014), PapaSmurf (08-11-2014)
 Old 05-10-2014, 08:22 AM   #242
Emew's Avatar
Posts: 217   (View Stats)
Emew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond repute
Cap off the outlet on the VW cover, get some sort of solenoid on the inlet with a small cap/opening/tank for dumping in some of this additive. Wire it up to be a switch or button you hold for 2 seconds and it'd be a cakewalk to maintain.
Flow Student
'07 Speed6 TiGrey: SURE ID300/Shift Plate+Weight/Breather Hose, Forge BPV v2, CX-7 Antenna, ProSport Boost Gauge, Block8Head's MS6 Pod, Cobb AP v3, ITV22 1SC Plugs, TWM Short Shift, Stage 2 Clutch, JBR Shifter Bushings/Shift Knob/RMM/EGR Delete, Euro LED Tails, AutoTech FP Internals, M2 DP, ETS TMIC, Techna-Fit SS Brake Lines/Clutch Line, Hawk HPS Pads, ATE 200, MD OCC VTA v2, 3-Bar MAP, AWR TMM, CP-E RDM, Whiteline RSB, RB Rear Endlinks, Moog Front Endlinks, Bilstein HD6 Shocks, Corksport Springs.
Emew is offline   Reply With Quote
 Old 05-10-2014, 09:46 AM   #243
littleloogy's Avatar
Posts: 4,005   (View Stats)
Gee why didn't I think of that? Oh wait...
I tried running lean on the additive with negative results. I was having a bad time driving to work. Pressure got really inconsistent. I ended up pouring some additive directly into my spill valve area to stop my internals from sticking... Shit worked almost instantly.
Now I have another idea... Direct injection for the additive, directly into the pump. It will be Controlled by a button in the cab, when internals start to stick... Hit the goo button. Similar to an IV, But pressurized.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Read the thread before posting shit that has already been mentioned.
The Following 3 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (05-10-2014), Mauro_Penguin (05-19-2014), SpeedEngineer (05-11-2014)
 Old 05-10-2014, 11:18 AM   #244
cocoanton's Avatar
Posts: 168   (View Stats)
cocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the world
@littleloogy; and @Enki; , the mad scientists! Little loogy, you are stubborn and it gives results! What you guys are doing for e85 on this plattform is epic and will go down as its own chapter in the msf chronicles!
cocoanton is offline   Reply With Quote
The Following 3 Users Say Thank You to cocoanton For This Useful Post:
Enki (05-10-2014), littleloogy (05-10-2014), OverBoosted (08-09-2014)
 Old 05-10-2014, 11:46 AM   #245
Emew's Avatar
Consider it approval of your genius idea! I'm not tryin to rip off you more so thinking out loud, it sounds like a sweet setup!
Flow Student
The Following 2 Users Say Thank You to Emew For This Useful Post:
cocoanton (05-11-2014), littleloogy (05-10-2014)
 Old 05-25-2014, 11:16 AM   #246
rolanblack's Avatar
Posts: 2,110   (View Stats)
rolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the world
May be a dumb idea but could you possibly tap in the hard fuel line and make a drip with the additive alone? Or maybe a version of 5th port to directly add the additive? Just thoughts.
rolanblack is offline   Reply With Quote
The Following User Says Thank You to rolanblack For This Useful Post:
mazdafreak (05-25-2014)
 Old 05-25-2014, 11:16 AM   #247
Jap11g's Avatar
Posts: 287   (View Stats)
Jap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond repute
Groaned at 7 Times in 5 Posts
The only dumb thought is the one not mentioned ;D
Tapa Tapa Tapa
JP
Jap11g is offline   Reply With Quote
The Following 4 Users Say Thank You to Jap11g For This Useful Post:
Easter Bunny (05-27-2014), Enki (05-25-2014), mazdafreak (05-25-2014), MTLspeed6 (08-10-2014)
 Old 05-26-2014, 03:16 PM   #248
I want to apologize for the lack of updates. I am currently Running into a problem. The problem is that I do not have a problem. I have been waiting for death to attack my pump so I can actually collect some data with this oil and install the injection system. I do not know if it is the oil @Enki; suggested I use, or if it is because I used the additive as a Cleaner/Lubricant when I cleaned and installed the pump. I have 800 miles on the pump since the last rebuild, I have opened the spill valve a few times to check for stickiness, which has been minimal. Here is the Log incase anyone wants to see, its hot outside
No problem.csv
I have decided not to wait any longer for death as it seems as though it will never appear. This week I will try to get the prototype injection system installed and try my best to calibrate it If time allows. I am hoping it works, its about time we all find out.
rolanblack likes this.
The Following 17 Users Say Thank You to littleloogy For This Useful Post:
Bratschist (05-26-2014), Cheapspeed (05-26-2014), cocoanton (05-26-2014), Constantin (05-26-2014), crutch77 (05-27-2014), Dano (05-28-2014), Easter Bunny (05-27-2014), Enki (05-26-2014), ItsNox (05-26-2014), jtms6 (06-20-2014), Mauro_Penguin (05-29-2014), Pointless (08-10-2014), pzr2874 (05-26-2014), Riztnack (05-28-2014), snailD (05-28-2014), spals (05-28-2014), wolly6973 (05-26-2014)
 Old 05-26-2014, 04:03 PM   #249
cocoanton's Avatar
Can hardly wait for future update on this!
 Old 05-28-2014, 12:50 AM   #250
rolanblack's Avatar
Hell yea dude. That is actually great news.
Have you figured out where/what you might install the prototype injection system onto?
 Old 05-28-2014, 11:24 AM   #251
Riztnack's Avatar
Posts: 34   (View Stats)
Riztnack is a jewel in the roughRiztnack is a jewel in the roughRiztnack is a jewel in the rough
Thank you for all the testing and research that you have put into this. I will be watching this thread closely.
Riztnack is offline   Reply With Quote
 Old 05-28-2014, 12:15 PM   #252
squilliam's Avatar
Posts: 266   (View Stats)
squilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the world
looking very promising. hope you can get a system up and running soon!
2009 CWP MS3: CP-E FMIC / CP-E RMM / Cobb SRI / Cobb TIP / Cobb AP V3/ HKS BOV / PTP HPFP Internals / UR V1 Catted DP / UR Racepipe / Cobb SS Catback Exhaust / Swift Spec-R Lowering Springs w/Koni Yellow
squilliam is offline   Reply With Quote
 Old 05-28-2014, 07:23 PM   #253
Raider is mah Homie
Groans: 2,978
In before injection system is made from parts of penis pump.
I hugged rfinkle2
The Following 7 Users Say Thank You to Easter Bunny For This Useful Post:
Constantin (05-28-2014), Jeremy M (05-28-2014), littleloogy (05-28-2014), Mauro_Penguin (05-29-2014), PapaSmurf (08-11-2014), Pointless (08-10-2014), white'swhiteMPS (06-20-2014)
 Old 05-28-2014, 07:26 PM   #254
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
That would be good news! Since everybody here will be able to replicate it immediately.
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
The Following 6 Users Say Thank You to Constantin For This Useful Post:
Cheapspeed (05-31-2014), Code Monkey (08-09-2014), Easter Bunny (05-28-2014), JgamB (05-28-2014), Mauro_Penguin (05-29-2014), PapaSmurf (08-11-2014)
 Old 05-28-2014, 10:15 PM   #255
JgamB's Avatar
Posts: 2,566   (View Stats)
I'm still trying to figure out why it's imperative we can run 50-100% E. We don't have the injector headroom and 96 RON ~ 3/9 mix will get you to MBT -2. I'm drunk but this pursuit seems silly for nothing more than beating an obstacle that ... isn't really an obstacle. Splain this shit to me James, and it better be more than "cuz stubborn".
The Following 2 Users Say Thank You to JgamB For This Useful Post:
Easter Bunny (05-29-2014), Ferdball (05-28-2014)
 Old 05-28-2014, 10:37 PM   #256
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Ethanol carries oxygen. More ethanol = more oxygen AND more cooling.
It's going to be a game changer for stock turbo cars, OR cars with 5/xth port and high comp pistons or redicuboost.
Easter Bunny (05-29-2014), JgamB (05-28-2014), Mauro_Penguin (05-29-2014)
 Old 05-28-2014, 10:46 PM   #257
JgamB's Avatar
I was sorta applying this to your current setup with the EFR kit and pre-HPFP replacement woes. Seemed like injector headroom would be more important with your pressures normalized, and meth providing much better BATs for your AZ temps.
I will refrain from adding further drunken comments damning the project, as my faux IDCs are currently happy at 95-96% feeding the beener, and a meth kit is my next great hope for defeating the staging lane heat soak.
 Old 05-28-2014, 10:49 PM   #258
Enki's Avatar
Groans: 189
Meth is all well and good, but it's far, FAR better to reduce the temperature of the air *INSIDE* the cylinder as that has the greatest effect on volumetric efficiency.
Also, send me a log; love to see what an AZ BNRS3 can do.
Mauro_Penguin (05-29-2014), WetzMS3 (06-04-2014)
 Old 05-28-2014, 11:14 PM   #259
Its quite simple really. I do not like that when people say things can't be done. I take it as a personal challenge. So yes, stubbornness...
Besides that, after going full E for an extended period of time. I have been working very hard on my tune, at least 40 revisions. With advise from everyone as they converse among themselves in various threads. I have picked up tips on fueling. playing with phasing, VTT, Timing, @and boost, which has enabled me to develop a custom tune that not only is safe to run, but also very fuel efficient (almost as good as petrol). The one thing that amazes me, is that I am mostly stock. I only have a racepipe, and an intake and I am doing the 60-100 in 5.5 seconds.
Answer me this @JgamB; do you want to mix fuel the rest of your life? I sure as hell don't. Would it not he bad ass to top off with E and not have to worry about about how much fuel you have left and calculating ratios? Mixing fuel sucks, fuel trims are always changing because the fuel is never constant.
Sent From a Galaxy, Far Far Away...
The Following 8 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (05-29-2014), Enki (05-28-2014), ItsNox (05-30-2014), Mauro_Penguin (05-29-2014), mazdafreak (05-30-2014), Roddiy (05-29-2014), SamiChicago (08-09-2014), WetzMS3 (06-04-2014)
 Old 05-28-2014, 11:21 PM   #260
Ain't no going back now... FUCK!
The Following 18 Users Say Thank You to littleloogy For This Useful Post:
Constantin (06-04-2014), crutch77 (06-05-2014), Enki (05-28-2014), Fjager (05-29-2014), ItsNox (05-30-2014), Mauro_Penguin (05-29-2014), Mazda Love (06-03-2014), mazdafreak (05-30-2014), mazdas4me (07-02-2014), Mfinlay04 (05-30-2014), Mochi (05-29-2014), Roddiy (05-29-2014), SparkySparks (06-05-2014), SpeedEngineer (06-05-2014), speed_freak91 (06-05-2014), swd120 (05-28-2014), udntknw (05-31-2014), WetzMS3 (06-04-2014)
 Old 06-04-2014, 10:10 PM   #261
Scott4957's Avatar
Posts: 171   (View Stats)
Scott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the world
Nice, thanks for all your hard work on this!
Scott4957 is offline   Reply With Quote
 Old 06-20-2014, 12:40 PM   #262
Dimenus's Avatar
Posts: 2,825   (View Stats)
Dimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the world
Groans: 33
Any update @littleloogy; ?
2012 Velocity Red Mica
Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC
Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps
Dimenus is offline   Reply With Quote
 Old 08-08-2014, 10:24 PM   #263
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
What's the deal, any recent updates or findings?
2015 Mazda 6
 Old 08-09-2014, 01:46 PM   #264
Yup. Got it figured out.
6,000 miles. Full E. No pump rebuilds. Doing more testing before I say if it actually works or not.
Here is the new type of back death after my latest mod.
New Black Death E85:
The Following 19 Users Say Thank You to littleloogy For This Useful Post:
ArmanRus (08-10-2014), Blown_Dan (08-09-2014), btstarcher (08-10-2014), Constantin (08-09-2014), Easter Bunny (08-10-2014), Enki (08-09-2014), IshiKage (08-09-2014), jtms6 (08-09-2014), LatinKraze (08-10-2014), Mauro_Penguin (08-10-2014), mazdafreak (08-10-2014), Mochi (08-10-2014), OverBoosted (08-09-2014), pzr2874 (08-09-2014), SamiChicago (08-09-2014), SparkySparks (08-09-2014), TiGraySpeed6 (08-09-2014), twenty5psi (08-10-2014), vtekken (08-09-2014)
 Old 08-09-2014, 04:13 PM   #265
Bratschist's Avatar
Posts: 79   (View Stats)
Bratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud of
Recently my car caught on fire and it now gone. I'm saying this bc I want to wish good luck to this project as I'm leaving the mazdaspeed scene. Enjoy your rides and consider keeping a fire extinguisher in the car. It could have saved my ms6. I don't mean to derail the thread, so don't worry about posting about this. Enjoy all
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  3. CorkSport LED light kit
  4. TWM Performance Shifter
  5. SLS Test Pipe
  6. CorkSport FMIC and SR air intake
  7. SURE Motorsport Torq R6
  8. AccessPort Stage 2+ Map
  9. QTP Electronic Exhaust Cut-Out
  10. KMD HPFP Internals Upgrade
  11. CorkSport Downpipe
Bratschist is offline   Reply With Quote
The Following 3 Users Say Thank You to Bratschist For This Useful Post:
ItsNox (08-12-2014), Jap11g (08-10-2014), littleloogy (08-10-2014)
The Following User Says NO Thank You to Bratschist For This Un-useful Post:
 Old 08-09-2014, 04:18 PM   #266
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
So it feels gritty or like a fuckin booger?
 Old 08-09-2014, 11:45 PM   #267
Enki's Avatar
Groans: 189
New Black Death E85: New Black Death E85 - YouTube
This post is conflicting. Discovering a new type of black death doesn't really bode well, but 6k miles does. I'm assuming this is using your injection system to keep the pump healthy...?
Mauro_Penguin (08-10-2014), SamiChicago (08-09-2014)
 Old 08-10-2014, 03:09 AM   #268
Let's not call it black death that was incorrect. Let's call it brown mushy goo. @pzr2874; It is soft, and not sticky. I found this after my initial test of the new method. After I re installed the pump I have not touched it. I assume the goo is in my pump, just not affecting operation.
I threw that injection mod shit out the window. It was pretty fun playing with and it worked OK, but for my daily driver it was impractical. I wanted to keep this simplified
Constantin (08-10-2014)
 Old 08-10-2014, 03:17 AM   #269
Yes, more like a soft booger. You know, not hard but not too wet. Just a nice well rounded boogie that you can flick and stick on the window at work.
The Following 11 Users Say Thank You to littleloogy For This Useful Post:
Constantin (08-10-2014), cshunter (08-11-2014), Easter Bunny (08-10-2014), Enki (08-10-2014), Mauro_Penguin (08-10-2014), PapaSmurf (08-11-2014), pzr2874 (08-10-2014), redneck4Christ (08-24-2014), speed_freak91 (08-11-2014), twincitySPEED6 (08-13-2014), wolly6973 (08-10-2014)
 Old 08-10-2014, 04:11 AM   #270
pzr2874's Avatar
Groans: 146
So in essence, it could go away the longer it stays there. Did you take it apart for giggles or because of drops in pressure?
 Old 08-10-2014, 08:23 AM   #271
I took it apart after a few hundred miles just to see if the new idea did anything different. Sure enough, it did. I have been seeing how far I can go, and the results have been incredible.
I will admit I have taken my spill valve apart before every long road trip just for piece of mind, not because of failure. When I change my oil i will take my pump apart, I'll take some pictures with some instructions on how I did everything. Then I guess I will need to find a new hobby.
The Following 9 Users Say Thank You to littleloogy For This Useful Post:
Constantin (08-10-2014), Easter Bunny (08-10-2014), Enki (08-10-2014), ItsNox (08-12-2014), Mauro_Penguin (08-13-2014), OverBoosted (08-10-2014), PapaSmurf (08-11-2014), SamiChicago (08-10-2014), twenty5psi (08-10-2014)
 Old 08-10-2014, 08:44 AM   #272
Enki's Avatar
Groans: 189
I'll see about getting more testers for whatever this new method is on board here in AZ.
littleloogy (08-10-2014), Mauro_Penguin (08-13-2014), PapaSmurf (08-11-2014)
 Old 08-10-2014, 08:51 AM   #273
twenty5psi's Avatar
Posts: 213   (View Stats)
twenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the world
That is awesome if you think have this figured out well enough to make full E(or even aggressive blends like past 50/50) a practical option for this platform. I guess it begs the question, what can the stock fuel system support power-wise on full E? @rfinkle2 @TiGraySpeed6
2013 MS3 VRM w/Tech
-unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings
FlowTuned 2 Gallon E85 blend 307whp/336wtq
twenty5psi is offline   Reply With Quote
 Old 08-10-2014, 08:53 AM   #274
Jap11g's Avatar
So... We did determine the running redline fuel system cleaner helped though, right? Even if it isn't used as an automated injection system?
JP
 Old 08-10-2014, 12:25 PM   #275
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
I can say @twenty5psi; , stock turbo, bolted (minus mani's) making about 300 @ 3000ASL, I was running 105% + IDC's @ 11.8 afr.
Edit: on full E
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
udntknw is offline   Reply With Quote
 Old 08-10-2014, 12:26 PM   #276
Enki's Avatar
Groans: 189
Originally Posted by twenty5psi View Post
That is awesome if you think have this figured out well enough to make full E(or even aggressive blends like 50/50) a practical option for this platform. I guess it begs the question, what can the stock fuel system support power-wise on full E?
Two things.
1. 50/50 is fine for extended periods of time. I ran it for years. This has been covered in this very thread numerous times.
2. Big turbo cars will be limited on how much they can flow boost/GS wise. I ran out of fuel @ 10 PSI on my EFR, but I had fuel pump issues so no idea what it would be at now.
Easter Bunny (08-10-2014), Mauro_Penguin (08-13-2014), rfinkle2 (08-10-2014), TiGraySpeed6 (08-11-2014), twenty5psi (08-10-2014)
 Old 08-10-2014, 12:36 PM   #277
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
I'm out of fuel on 50/50 at 15psi on a 3076.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
 Old 08-10-2014, 01:02 PM   #278
twenty5psi's Avatar
Two things.
Whoops! I meant to say past 50/50, but seems useless for most people to blend past 50/50;at that point you're not going to see K04 gains and BT you'd need more fuel. I figured on full E you could run into fueling issues even on the K04.
2013 MS3 VRM w/Tech
 Old 08-10-2014, 01:18 PM   #279
Yes. I ran out of fuel on the K04. After a lot of fine tuning and work I was able to successfully maintain fuel pressure and IDC without sacrificing airflow. I am worried about winter though.
The Following 6 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (08-10-2014), Enki (08-10-2014), Mauro_Penguin (08-13-2014), OverBoosted (08-10-2014), rfinkle2 (08-10-2014), TiGraySpeed6 (08-11-2014)
 Old 08-10-2014, 03:27 PM   #280
Enki's Avatar
Groans: 189
Do you have stock boost control/boost reference or have you modded ebcs/reference/wga?
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e-85-cure-fuel-additives-166953/
????????? ???? (L3K9-12-615) This thread Refback 12-02-2015 05:22 AM
Senor Blanco Big Turbo Build Thread - Page 5 - DFW Mazdas This thread Refback 03-27-2014 08:14 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Fuel/oil additives Jap11g Mazdaspeed3/6 General Discussion 6 03-05-2014 02:38 PM
Visiting the Shell Technology Center, Part 1: The Rise of Additives [w/video] Haltech Automotive News 0 02-19-2014 01:30 PM
Kr above 5000rpm, not really sure how to cure it nick779 2010 MS3 - ECU Computer Tuning 20 01-30-2012 12:28 PM
Cure for the AIDS nut wdautrem MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-20-2011 03:57 AM
Does WI cure KR? MS3 Ventura MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 01-18-2009 10:55 AM
Page generated in 0.63372 seconds with 39 queries
