![]() | | #321 | ![]() |
![]() Join Date: Jul 2011 Location: Elk Grove Village, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,411
Groans: 124
| Not Ranked : 0 score Well thanks for all ur hard work to help figure this all out. Goes for u too enki
__________________ DBB Gen2 Pte6266, kozmic pte top mount manifold kit, Kozmic 4'' Intake, kozmic hood exit Dp+Dump, 11:1 Custom Wiesco Pistons + Monlar rods, Freek PnP head w/Supertech springs&retainers, L19 Head Studs, JMF PI Intake Manifold W/ custom single Walbro 450+ Fuelab Inline Pump, HKS BOV, Cp-e Stage2 RMM, Trz Tranny Mount, MD PMM, JBR Egr Block Off Plate, Cp-e Fuel Pump, Sheepey Built Fmic Core, 3.5 Bar Map Sensor, Precision Wastegate, TWM Shifter bushings, Freak Tuned! 713whp/569wtq! FIRST MS3 IN 10s! 10.963 @ 136.79 (8/12/2015) 10.72 @ 139.44! (10/1/2015) 10.43 @ 140.95! 10/9/2015 10.35 @ 140.86 (10/30/2015) New Time! Fastest Ms3 to date 10.27 @ 141.55 (5/22/2016) |
| The Following User Says Thank You to mazdafreak For This Useful Post: | littleloogy (08-14-2014) |
![]() | | #322 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
(Thread Starter) | Not Ranked : 0 score Time will tell. Testing will be needed to prove/ Disprove this theory. |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | SamiChicago (08-14-2014), twenty5psi (08-15-2014) |
![]() | | #323 | ![]() |
![]() Join Date: Dec 2012 Location: Venice,FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
| Not Ranked : 0 score It certainly seems like the best solution yet, plus you could continue to run SI-1 through the tank for more protection. If this could get through 2-3 oil changes consistently I think you have a solid solution at hand.
__________________ 2013 MS3 VRM w/Tech -unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings FlowTuned 2 Gallon E85 blend 307whp/336wtq |
| The Following User Says Thank You to twenty5psi For This Useful Post: | OverBoosted (08-15-2014) |
![]() | | #324 | ![]() |
![]() Join Date: May 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score This probably doesn't belong in this exact thread, but.... Does anyone here know a mechanical engineer who could redesign the pump to outperform the OEM version? I realize that this is designed to deliver fuel at extreme pressure, but surely SOME improvement could be made to prevent the underlying issue altogether. Just a thought. Thanks for all your hard work @littleloogy; @Enki;
__________________ __________________ 2011 MazdaSpeed 3 RichTuned | Cobb SRI | Cobb TIH | SU TMIC | CS Racepipe | CS Downpipe | CS TMM Insert | KMD 2.1 | CPE Stage 2 RMM | ITV 22's | Sent using VTEC |
![]() | | #325 | ![]() |
![]() Join Date: Mar 2013 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
I know many engineers and all fields. Question is, DO YOU have the resources and funds?
__________________ '07 MS6: HTP 3 Inch Intake.Cobb AP.CorkSport CBE.ATP DP.FMIC.AutoTech Internals.Bosch 3 Bar map sensor.GRIMMSPEED 3 PORT EBCS. BNR S4.WISECO 9:5 pistons. Manley H-Beam rods. Keyed Crank by APEX. SouthBend Stage 3 clutch kit. Bilstein shocks. H&R Springs. | |
| The Following 2 Users Say Thank You to SamiChicago For This Useful Post: | Easter Bunny (08-15-2014), spals (08-20-2014) |
![]() | | #326 | ![]() |
If it's a NATOR member, I would hope that they would donate at least some of their time to the cause. With 3D computer modeling and 3D printing, I don't see any reason why this couldn't be figured out pretty cheaply.
__________________ __________________ 2011 MazdaSpeed 3 RichTuned | Cobb SRI | Cobb TIH | SU TMIC | CS Racepipe | CS Downpipe | CS TMM Insert | KMD 2.1 | CPE Stage 2 RMM | ITV 22's | Sent using VTEC | |
![]() | | #327 | ![]() |
Groans: 189
| Not Ranked : 0 score All we need is a new retaining nut that leverages a valve guide type of a setup (like the cobalts use) or is two piece with a solid PTFE bushing as a seal instead of o-rings. Or something.
__________________ |
![]() | | #328 | ![]() |
E85 Remedy with HPFP Hardware modifications | |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | Easter Bunny (08-15-2014), SamiChicago (08-15-2014) |
![]() | | #329 | ![]() |
![]() Join Date: Apr 2013 Location: san antonio tx
Rep Power: 0 ![]() ![]() Thanks: 0
| Not Ranked : 0 score So i didnt know that this thread existed...but i have also been looking for a chemical coating solution for the internals....im going to try this additive this week, but here are some of the coatings i have found. EP21TPND Product Description | MasterBond.com http://damonq.com/red-kote.html Tell me your thoughts. -phillip Last edited by StikUpKid210; 08-17-2014 at 04:39 PM. Reason: include signature |
![]() | | #330 | ![]() |
Groans: 189
| Not Ranked : 0 score Chemical coatings won't work on the internals; the tolerances are tight enough that it will probably cause lubrication problems if you tried.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | aromig (08-17-2014), Mauro_Penguin (08-24-2014) |
![]() | | #331 | ![]() |
![]() Join Date: Oct 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score Surface max temp of.250*....
__________________ " THE list " Cobb AP // CPE catback exh w/ resonator // CORKSPORT TMIC // Autotech HPFP // ITV22's // COBB SF+TIH // AWR PMM,TMM // JBR RMM // CPE Rear diff mt // EGAY catless DP // BANJO BOLT // SPC balljoints // speed daddy springs self tuning journey of fail begins |
![]() | | #332 | ![]() |
| Not Ranked : 0 score Shit, littleloogy got banned. :/
![]() | | #333 | ![]() |
![]() Join Date: Mar 2014 Location: St. Louis, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score For what? |
![]() | | #334 | ![]() |
![]() Join Date: Aug 2011 Location: Fuckin Topeka, Kansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,200
Sent from my GS3 running CM11, via FapDaCock
__________________ "I apologize for nothing!" - Hedonismbot ![]() | |
![]() | | #335 | ![]() |
Groans: 189
![]() | | #336 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
![]() | | #337 | ![]() |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score He hooked me up with a spill valve after I broke my connector. We broke fs rules by negotiating before pics were posted. Then he jokingly told mod staff to blow him, sarcasm doesn't translate well on the interwebs. I feel really bad about it, dude saved my ass and caught a suspension over it.
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
| The Following 10 Users Say Thank You to ASHMS3 For This Useful Post: | Easter Bunny (08-18-2014), IshiKage (08-19-2014), ItsNox (08-19-2014), JgamB (09-10-2014), Mauro_Penguin (08-24-2014), PapaSmurf (08-19-2014), pzr2874 (08-18-2014), Roddiy (09-18-2014), SamiChicago (08-18-2014), WetzMS3 (08-22-2014) |
![]() | | #338 | ![]() |
Groans: 189
| Not Ranked : 0 score Technically, he sarcastically asked for a suspension, if memory serves. He got one.
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #339 | ![]() |
Groans: 126
| Not Ranked : 0 score Still sucks.
| The Following User Says Thank You to ASHMS3 For This Useful Post: | IshiKage (08-19-2014) |
![]() | | #340 | ![]() |
| Not Ranked : 0 score Don't sweat it, we all need a break from the forms at times! |
![]() | | #341 | ![]() |
![]() Join Date: May 2010 Location: Homestead, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
Groans: 112
| Not Ranked : 0 score Anyone else start trying the latest method?
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
| The Following User Says Thank You to PapaSmurf For This Useful Post: | Easter Bunny (08-23-2014) |
![]() | | #342 | ![]() |
Groans: 189
| Not Ranked : 0 score I'm lining up locals now...Just a matter of time.
| The Following 5 Users Say Thank You to Enki For This Useful Post: | Easter Bunny (08-23-2014), Fjager (08-24-2014), ItsNox (08-25-2014), Mauro_Penguin (08-24-2014), pzr2874 (08-23-2014) |
![]() | | #343 | ![]() |
Groans: 189
| Not Ranked : 0 score First conversion/test happening with a local tomorrow, so long as everything leading up to it goes well. Results to follow.
| The Following 5 Users Say Thank You to Enki For This Useful Post: | darth_speeder (08-25-2014), ItsNox (08-25-2014), Mauro_Penguin (08-24-2014), PapaSmurf (08-24-2014), WetzMS3 (08-24-2014) |
![]() | | #344 | ![]() |
Groans: 112
| Not Ranked : 0 score I'm hoping I'm up and running in a week or so and both Dustin and I will be trying it out, I'll be breaking in on pump then switching over after like 500 miles
| The Following 3 Users Say Thank You to PapaSmurf For This Useful Post: |
![]() | | #345 | ![]() |
Groans: 189
| Not Ranked : 0 score Vehicle #1 is undergoing testing. Initial test (with me chasing) went very well. I'll be monitoring logs and driver impressions/observations for the duration. With only 40% APP (14 psi peak, 11 psi @ redline), it hauls ass and redline is punctuated by about 8" of fire out the exhaust and the sounds of gunfire. Good shit. Side note: I manually actuated the pump internals a few times (with spring attached) to make sure that the redline stuff was circulating/penetrating the entirety of the internals. Also, test vehicle is on Rotella T6.
| The Following 14 Users Say Thank You to Enki For This Useful Post: | Constantin (08-25-2014), Easter Bunny (08-25-2014), Fjager (08-24-2014), IshiKage (08-26-2014), ItsNox (08-25-2014), Mauro_Penguin (08-27-2014), Mochi (08-26-2014), PapaSmurf (08-24-2014), Roddiy (09-18-2014), SamiChicago (08-25-2014), SarcasticOne (08-24-2014), sidekick (09-12-2014), SparkySparks (08-24-2014), WetzMS3 (08-25-2014) |
![]() | | #346 | ![]() |
Groans: 124
| Not Ranked : 0 score I'm gonna run this method starting Tuesday.... Gonna inject that shit in there
| The Following 2 Users Say Thank You to mazdafreak For This Useful Post: | Mauro_Penguin (08-27-2014), PapaSmurf (08-29-2014) |
| The Following User Says NO Thank You to mazdafreak For This Un-useful Post: |
![]() | | #347 | ![]() |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score My AP, autotech's and rmm are in the mail for my 100% stock 07 speed 3. I'll be a tester for this as well as getting some #'s for a stock everything (minus fp and ap of course) speed on E. I didn't go 50/50 on my speed 6 until long after mods and AP etc etc.
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
![]() | | #348 | ![]() |
Groans: 189
| Not Ranked : 0 score Primary test subject has this to say tonight:
Edit: Wheelspin in third, partially due to shitty tires.
__________________ Last edited by Enki; 09-02-2014 at 01:59 PM. | |
![]() | | #349 | ![]() |
Groans: 189
| Not Ranked : 0 score First tank down. 12.3 gallons and 150 miles later... I guess the tune is nearing completion, as it's been dialed back a bit but still needs some MAF/boost work. Looking over the logs there is a LOT left in this thing, they are shooting for 18 PSI and only have 16.5 timing @ 6k. I asked him why he wanted the tune dialed down a bit and he responded thusly:
__________________ | |
| The Following 12 Users Say Thank You to Enki For This Useful Post: | Cheapspeed (09-03-2014), cocoanton (09-03-2014), Constantin (09-02-2014), darth_speeder (09-03-2014), Dimenus (09-03-2014), IshiKage (09-02-2014), Mauro_Penguin (09-07-2014), ms6mil (09-02-2014), SamiChicago (09-08-2014), sidekick (09-12-2014), speed_freak91 (09-08-2014), twenty5psi (09-03-2014) |
![]() | | #350 | ![]() |
![]() Join Date: Nov 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groans: 33
| Not Ranked : 0 score 12 gallons and 150 miles. lol.
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() |
| The Following 6 Users Say Thank You to Dimenus For This Useful Post: | Mauro_Penguin (09-07-2014), OverBoosted (09-07-2014), PapaSmurf (09-03-2014), Roddiy (09-03-2014), speed_freak91 (09-08-2014), twenty5psi (09-03-2014) |
![]() | | #351 | ![]() |
| Not Ranked : 0 score Once the fuel trims settle and you have a tune that can leverage the E85 at cruise(lean burn anyone?) the MPG shouldn't be too bad. @Enki do you think it has the fuel for ~320-330whp?
![]() | | #352 | ![]() |
Groans: 189
| Not Ranked : 0 score Potentially. Once the tune is locked down on this car I'm going to ask for a 4th gear log on a known good stretch of road for final vdyno numbers, which I'll post here. I'll probably get video, too (speedo shot).
| The Following 5 Users Say Thank You to Enki For This Useful Post: | cocoanton (09-03-2014), Easter Bunny (09-08-2014), Mauro_Penguin (09-07-2014), MSP6 (09-08-2014), twenty5psi (09-03-2014) |
![]() | | #353 | ![]() |
| Not Ranked : 0 score AP received, 93 tune near finished.....AT's ready to install and I can't find any Redline locally. @Enki; @PapaSmurf; Where did you find yours?
![]() | | #354 | ![]() |
![]() Join Date: Mar 2011 Location: St. Boni, MN
Rep Power: 485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
Groans: 34
| Not Ranked : 0 score |
![]() | | #355 | ![]() |
Groans: 112
| Not Ranked : 0 score O'Reillys carries it local for me.
![]() | | #356 | ![]() |
| Not Ranked : 0 score No O-reillys within 50 miles of me unfortunately. Been to NAPA, Advance and Autozone and struck out.
![]() | | #357 | ![]() |
| Not Ranked : 0 score pep boys? dunno if they are nationwide?? thats where i picked mine up. ive been lazy and havent pulled apart the internals to lubricated them. gone about 4 tanks with no additives?? lol idk why i havent had any hpfp woes. prob tear it down this coming wknd to do this process. Enki i have brian (max's old ms6) switched over to full E he will be testing with us as well in phx.
![]() | | #358 | ![]() |
Groans: 189
__________________ | |||
| The Following User Says Thank You to Enki For This Useful Post: | MSP6 (09-08-2014) |
![]() | | #359 | ![]() |
I ordered a bottle off Amazon this morning I was just hoping to find one local because I'm impatient.
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." | |
![]() | | #360 | ![]() |
Groans: 189
| Not Ranked : 0 score Status update on the only current local test car: ![]() Yep, that's all there is to report.
| The Following 10 Users Say Thank You to Enki For This Useful Post: | 2012MS3MJB (03-06-2015), cocoanton (09-12-2014), dsb_chicago (09-11-2014), mazdafreak (09-11-2014), MSP6 (09-12-2014), OverBoosted (09-11-2014), PapaSmurf (09-11-2014), sidekick (09-12-2014), speed_freak91 (09-14-2014), udntknw (09-12-2014) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e-85-cure-fuel-additives-166953/ | ||||
| ????????? ???? (L3K9-12-615) | This thread | Refback | 12-02-2015 05:22 AM | |
| Senor Blanco Big Turbo Build Thread - Page 5 - DFW Mazdas | This thread | Refback | 03-27-2014 08:14 AM | |
| Fuel/oil additives | Jap11g | Mazdaspeed3/6 General Discussion | 6 | 03-05-2014 02:38 PM |
| Visiting the Shell Technology Center, Part 1: The Rise of Additives [w/video] | Haltech | Automotive News | 0 | 02-19-2014 01:30 PM |
| Kr above 5000rpm, not really sure how to cure it | nick779 | 2010 MS3 - ECU Computer Tuning | 20 | 01-30-2012 12:28 PM |
| Cure for the AIDS nut | wdautrem | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 04-20-2011 03:57 AM |
| Does WI cure KR? | MS3 Ventura | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 4 | 01-18-2009 10:55 AM |
