bnoon 08-15-2011 12:43 PM
Wrong address fail. Thinking of ordering internals for mine sometime soon to give more E85 a try.
bewsted 08-15-2011 01:37 PM
MOAR e85 is lovely....once i finish this tank of 93...im back again bitches lol
djuosnteisn 08-15-2011 02:01 PM
I really wish someone would go quantify some of this e85 stuff on the dyno. When mica was on the rollers, we compared a 12.4 AFR pull with an 11.7 AFR pull, all else the same, and saw no appreciable difference in power.
I would love to see some factual data from the other e85'ers out there.
He was only running 2.5 gallons with wmi.
phate 08-15-2011 02:19 PM
If someone wants to help fund some 93 octane vs race gas vs E85 dyno testing, my car can be the mule :P If we were really ambitious, we could do all of the above with WMI, as well.
bewsted 08-15-2011 02:26 PM
Yea i was getting play by play...
I am going to hit the dyno in the next couple weeks if my move goes as planned.
MOAR E85
wolly6973 08-15-2011 02:32 PM
If you want a good dataset (well, 2 is better than 1), I will head down and meet up with phate. I need to get on the dyno sometime. Have to work out my wmi tune first though...
phate 08-15-2011 02:36 PM
Incoming PM...
bewsted 08-15-2011 02:40 PM
Where is said dyno @?
Maybe i will treck up there to enter this dyno day.
phate 08-15-2011 02:42 PM
The dyno is located in Seneca, IL - Snowdance Enterprises. It's just south of I-80 and West of I-55.
If you guys are serious about getting a few cars on, I'll call them back to get things set up. They are a general repair shop and they said they don't use their dyno too often. I'm sure we could get it for a full day if we wanted.
cld12pk2go 08-15-2011 05:20 PM
My plan is to re-dyno as soon as the temps drop so I can get some decent load with the K04. Probably 6-8 weeks out...
phate 08-15-2011 05:31 PM
wolly6973 and I should both be on the rollers Friday at this shop. We have similar bolt on parts, but he has meth. Should be a pretty good comparison between E85 & 93 w/meth.
Edit: having the internals sent to the wrong address turned out well. I just picked them up :D
wolly6973 08-15-2011 08:35 PM
I only brought the D05 nozzle with me, left the D07 at home. Wasn't planning on getting on the dyno just yet...
O well, it will be nice to know where I'm at.
@phate - could you bring a feeler gauge? need to double check the gap on my plugs...
phate 08-15-2011 09:10 PM
Car is better :) Man, did I miss boost.
@wolly6973 - For sure, I plan on bringing my top box.
superskaterxes 08-16-2011 06:58 AM
phate i would throw you a few bucks to do the testing. can we set a plan first with A/B/C testing @ X psi or w/e.
bewsted 08-16-2011 07:45 AM
I am planning to hit the dyno since @driver311 is failing at getting on one.
Plan to make a pull on my 93 tune.
Then a pull on my E85 tune.
Then a adjusted pull with the E85 tune.
Crossing my fingers for some win LOL.
Dano 08-16-2011 08:19 AM
just like that with cool down between runs.
When you do your first adjusted E85 tune first leave the boost and timing alone and lean those AFs out to mid to high 12s to see if any power is made on AF alone. Apparently Dustin made none to speak of on Mica's pulls w 2.5 gallons of corn in the tank.
then go to work on the rest..K?
superskaterxes 08-16-2011 08:20 AM
are you going to add the E85 between the 93 and E85 tunes?
phate 08-16-2011 08:34 AM
Yeah, for sure. Let's get through Friday's session before we start the planning, though. If the difference between my car and wolly's car is insignificant, we may not want to do any further testing...[But I'm counting on there being a difference, lol.]
wolly6973 08-16-2011 08:45 AM
Just to add some fuel to the fire...
Originally Posted by MicaBlueMS3 (Post 992569)
i know for a fact e85 did nothing for me because i was already maxing out the turbo with meth.
Quoted from...
http://www.mazdaspeedforums.org/foru...tml#post992569
It would be nice to be able to have a tune for e85 and be able to throw some in when you really want to have extra power, like a track day or something.
That way you wouldn't have all the worries of meth leaking/running dry/no flow/etc...
bewsted 08-16-2011 08:56 AM
I am going to go in on empty....Take a 5 gallon jug of 50/50 with me....Make a pull......Then add the 50/50.....
Thats the plan at least.
Well when dustin was here and I got on the dyno I was running mid 12 afr.....
But it was hot as balls out.
So I plan to make a map with a little lower afr target and timing. Then make a pull with the current e85 map I am running. Which seems to be just as good maybe a hair better than what I was running when Dustin was here.
The main thing I want to accomplish is the difference between 93 and 50/50 in the same day.
JacksonMS30 08-16-2011 09:15 AM
Could the amount of e85 play a role in whether or not a gain is seen from leaning out? Dustin saw no apreciable gain by leaning out the afr's on a mix of 2.5 gal. What if it was a 5 gal mix? Would the amount change the way the car responds to the afr?
Just a thought...
bewsted 08-16-2011 09:19 AM
Just a thought...
I guarentee the amount plays into how it responds.
phate 08-16-2011 09:24 AM
Yes, the amount will have an affect. This is what we need to test, really.
Without optimizing AFR and timing for each mixture, you are not comparing anything of value. [I think I've mentioned this once or twice, lol.]
bewsted 08-16-2011 09:31 AM
True....
The timing is key.....And of course making your LAMBDA properly scaled LMAO.
djuosnteisn 08-16-2011 10:02 AM
AFR theoretically should make a difference on any type of fuel. We weren't doing a pump vs e85 mix comparo. We did a rich AFR vs a lean AFR on mix. Timing was as optimized as it was gonna get, we saw no gains from more timing.
So imo, that's about as apples to apples as you can get. I'd like to see it done again on pump gas, and a higher mix of e85 personally, so we can build up a more complete idea about how various afrs with differing mixes of e85 add up on these cars.
It was completely opposite what i expected to see, but it was what it was.
phate 08-16-2011 10:13 AM
Gotcha. I was thinking you didn't change timing to see the effect. That is surprising it (power/timing with different AFR) didn't change, though.
djuosnteisn 08-16-2011 10:17 AM
We didn't change timing at the various afr's, only cause time is always limited on the dyno, but timing was verified before we changed any of the afr's.
bewsted 08-16-2011 10:20 AM
The trq curve looked real similar to what I seen on my pull.
tapa dat ass
phate 08-16-2011 11:41 AM
I will say the changes shouldn't be dramatic between the two fueling curves, but I would expect each to need a certain amount of timing to be optimal. I don't like beating dead horses or being the squeaky wheel, but I don't feel like that is a conclusive comparison. There are so many damned variables with afr/combustion rate/flame speed/timing, it's almost impossible to theorize about what is "right".
I HOPE some of this will be seen Friday. This is the whole reason I want to optimize two fueling curves via timing, initially, then really zero it in from there. Like you said, though, dyno time is limited.
@wolly6973, I'm probably going to get there earlier than I originally said. I'm willing to thrash my car for 3-4 hours in this session if needed. I want you to be able to get on the rollers for as long as needed without it getting really late.
bewsted 08-16-2011 11:44 AM
@phate
Are you just going to run your .82 and .86 maps?
Or do you have plans to run a lower map as a base?
wolly6973 08-16-2011 11:45 AM
Sounds good. I shouldn't need too much time I wouldn't think. Just long enough to find some timing the car likes, and then a power pull or 2.
If the shop needs to close down at whatever time and you are still rolling, that's fine with me. I can always get on a dyno some other time/place.
phate 08-16-2011 11:50 AM
I'm going to see what timing curves work best with both the .82 and .86 lambda tunes. Depending on what AFR makes more power in a given RPM range, I'll richen it up or lean it out beyond what was tested for that specific rev range.
That might sound confusing, so:
if .82l makes more power from 3k-4.5k, then I'll richen that range up and play with timing to see if more power can be had. At the same time, I'll lean out the 4.5k-6.5k and play with timing to see where "optimal" AFR and "optimal" timing are. Rinse and repeat until power falls off by going too lean or too rich in a given range.
This is why I need the flexibility of being on the rollers for more than a couple hours. We have no idea where max power will occur, and playing with 1-2° of timing each pull could take a while.
Nah man, if you drive down, you'll get time on the dyno.
bewsted 08-16-2011 11:52 AM
Right....
I was thinking of having 2 maps....Do a base on each like your saying. Then adjust up or down depending on which makes the better "BASE" power.
I'd like to think that my timing is pretty close to perfect but as you stated 1 degree or 2 degrees could result in signifigant power loss or gain.
phate 08-16-2011 12:51 PM
If you are near empty, you could empty the tank by pulling the soft fuel line on the CDFP and letting the ITFP empty the fuel into a container right there. Should be pretty painless and you'll know the actual mix. Seeing as how the fuel lines are tiny (~1/4" ID), there isn't much in the lines, either. Once the mix is in, purge the system to be sure that is what you're running on first startup ;)
superskaterxes 08-16-2011 01:00 PM
i would rather run the car on the dyno then let the ITFP run dry........
NJSPEED3 08-16-2011 01:01 PM
Yes lets get some data going!! excited for this guys thank you!
phate 08-16-2011 01:02 PM
lol, I've run mine dry twice...once at an autocross.
djuosnteisn 08-16-2011 01:07 PM
Hahahha, okay, your the pro. Good luck man. Can't wait to see 100% mbt dialed in at each afr break point / boost / BAT / IAT / e85 mix ratio / moon gravitation influence
Seriously though, in for results.
And your right, you'll probably need a minimum of 2 hours to get some conclusive data.
superskaterxes 08-16-2011 01:11 PM
lol not a good practice, ESP under load haha
PapaSmurf 08-16-2011 01:16 PM
I honestly think the gains if any will be minimal at the most.
Either running Meth or e85 and you will MBT your K04. Since its so damn small.
I think doing these tests on a BT MZR is where you will see the difference since you wont have a turbo shitting the bed on you. Which im sure dustin will do when he gets his shit running.
Page generated in 0.22362 seconds with 11 queries
