I did some pre-dyno maintenance/inspection today, for tomorrow. The HPFP looked really clean after ~1,000 miles. This is probably the cleanest it's been since I started running E85 :) I thought I was screwed afterwards, though. The pump wouldn't build over ~900psi of pressure...turns out I didn't tighten the solenoid down quite far enough. Once that was snug, pressure was fine. Checked my MAF cal and it's within +-.5% on the high end where it matters. Hopefully this all works out. I'm headed up north in just a while and should be on the rollers first thing in the morning :) |
:popcorn: BTW I think I am an official meth and eth head :) Haven't had time to tune for my 2.5 gallons of corn but the car does love it. GL on the rollers Phate Quote:
injector scaling FTW so we can get back to real load numbers and not have to scale all the tables based on load...right? |
tapa dat ass |
if you scaled your maf up by 1.20 + your larger MAF, your load values are not realistic. Maf Vt may not work either but Load def doesn't work LOL I'm not a math guy so can't help you on a MAF vt / power conversion there pimpdaddy :) |
No results yet? |
Phate texted me his numbers from the dyno run. I came. Tapadatass |
What a bunch of cock teasing in here Tappin |
Garbage. phate's next post better be made of Liquid Schwartz. I wanna know them damn results! tap dat ass? |
WTF man. We are waiting... @bewsted I need help on my map, my logs look nothing like yours in load or g/s terms and I am sad. |
Ps. All u gotta do is divide you maf by what ever the % is and you can get a very close # on gs. |
1.5 hours from home still...I WILL post results tonight |
1.5 hrs.. i'm sure its a 15min drive sir (for you) |
Should I just spoil it? it is 300+ / 400+... |
hmm.. a lot higher than I expected (285whp) |
Quit being such a cock tease you fuck... |
id be shocked if he broke 320 |
tapa dat ass |
2 Attachment(s) OK, thanks to all for posting in the last couple hours. I got like 5 hours of sleep last night and the drive home is pretty dull. They kept me entertained :) So anyway, on to the good stuff - got the car strapped down around 10:30 this morning. It was an absolutely beautiful day, there was almost no correction factor for some of the runs, lol. I made a quick baseline pull and the shop owner/dyno operator (Shawn) was like "uhhhh....something's fucked up, it's not reading right...". I wasn't near the computer so I asked him what the deal was, he said "this thing says you put down over 400ft/lb of torque?!?". LOL, yes it did, 1st pull ;) I did my first pull with a 12.2:1 (.83 lambda) tune with 1° less timing than what I was running on the street. Here are my starting timing values (2500-6500): Code: 2500 3000 3500 4000 4500 5000 5500 6000 6500Code: 2500 3000 3500 4000 4500 5000 5500 6000 6500The attached picture "Dyno_Base_Final_Compare_20110828" shows my first pull and the final pull on my .83l tune. I picked up ~20hp over the entire rpm range just by adding timing. After I got finished up with the .83l tune, I wanted to test some leaner conditions. I hate to say it, but Dustin was right saying it doesn't make much difference. I made a baseline .86l pull with 2.5° less timing than my final .83l tune. Stepped up timing from there in just a few pulls and ended up with an almost identical power curve. The attached picture "Dyno_AFR_Compare_20110828" shows the results of changing the fueling. ____________________ Cliff Notes: -Car ended with peak hp/torque of 325/425 -Car made 300+ hp starting at ~3900rpm -Changing AFR's didn't have any significant affect on final power output, even after changing timing. Attached pics of graphs are SAE correction from a DynoJet. Uncorrected numbers are ~5 less than SAE. It was a near perfect day, today. BAT's were in the 115-125°F range throughout the day. Every run was started with coolant temp ~187-190°F for consistency. ____________________ The car feels pretty darn good. It pulls ssssooooooooo smoothly and of course it feels a little faster than what it did beforehand. The flatness of the power curve really surprised me, but the car is damned fun to drive like this. ____________________ Forgot to post this, because someone is bound to ask: "Mod List": cpe CAI Protege Garage TIP Stainless Works Catless Downpipe Fidanza Flywheel (LOL) E85 Sexy tune via Cobb Accessport Stock parts, just to clarify for those who ask anyway: stock TMIC, stock catback, stock exhaust manifold, stack intake manifold, Autolite XP Stock replacement spark plugs...there isn't much done to it!!! |
that is so win phate! :You_Rock_Emoticon: makes me want to go 100% (once i get FP internals)... |
Wow! Good fucking job dude! That timing is crazy! I thought we didn't make much power after your original set up. Does e85 change that or am I just remembering wrong? I've been waiting all night for this post! Another ko4 faster than my 2871! edit: That graph is beautiful! |
baller. |
Christ almighty. New stock turbo records? Lol |
PS - for those I texted - my numbers were off because the comp at the shop was set to a different correction factor. I told Shawn I didn't care what the numbers were, as long as I could compare runs. So I was looking at non-SAE #'s for the text, lol. :oops: |
But man that is some awesome torque numbers!! Man was i good on my guestimate of HP, BUT im much more a torque person! Nice cliff thats some awesome torque numbers! phate, we should get togethor some time soon, my new set-up is almost done and i need a few more vital parts, but i would love to do a 50/50 e85 and let you tune my car. Are you using the fuel pump internals, or the whole fuel pump. |
Guess I need to get my ass in gear....:( |
Can you post data logs from the dyno pulls? Bad ass BTW. Makes me want to go dyno now that I have my 3-Bar MAP sensor... But I guess I need to add some more timing first! :arms: Also, out of curiosity, by what percentage did you end up scaling your MAF curve for straight E85? |
go out and pwn some evos now plz |
12pk IIRC he scaled by 20% as a starting point and tweaked from there. You should do 20% of the whole curve then do a MAF cal on 100% E85. Honestly though I dont know if i would jump right into 100% i would start at like 60/40 mix. then 75/25, then 90 / 10 of e85/93 octane. This should limit the gunk going through your system, and make sure no bugs crop up while running the eth Plus a 90/10 mix will prevent the cold start issues that e85 has. Just be sure to save your 93 tune..... |
POW!!!!!!!!!!!!!!!!!!!! |
Holy crap timing. I know E85 burns slower so it "needs" more timing, but I never expected to see that much of a difference. |
jesus lol ready to throw some more parts on there? haha |
Now imagine with a nice tmic or fmic, DNP manifold, and a nice intake manifold> 350whp. Now peeps see how I was able to dyno 345whp out of a stock turbo srt and how the stock turbo subarus and cobalts are getting 375whp on stock turbo with e85. Mad timing. I put 42 degrees at my bros srt on e85 where it maxed at 30 before e85. |
@phate : thanks. I will be throwing timing at my bitch like no tomorrow now that you did this. How much boost were you running? |
I'm in Decatur you are in Champaign, mucho dinero to tuneage my automobile /nod |
Great numbers and nice looking curve as well. Makes me jealous and want to really take a look at trying to tune in some timing in my map. BTW, did you ever list your mods anywhere? I don't recall what you have on your car. Also, what boost were you running for these runs? Any data logs from the runs would be great. |
| All times are GMT -7. The time now is 11:34 AM. |
