GLORIFIEDBOZO 10-27-2011 08:12 AM
Originally Posted by SWAY (Post 1099381)
Not sure how many miles I got it in mid may prolly like 2k was the 80 duro, the bushing was fucked up soon as I stocked back I was hooked on no vibes haha. Ima bout to get the moly shits insane
Sent from my evo 3d
Have you talked to Jamie about replacing it?
Dano 10-27-2011 08:15 AM
Interesting dyno proven timing curves starting from 2500
Phate 100% E [dont have a 7K number for him]
Code:
-1        8        10        11.5        13        16.5        19.5        22        24.
XLT 50% E
Code:
4        6        9        10        12        14        16        18        19        20
bewsted ??% [not sure he was on a dyno with these]
Code:
0        6        9        11        12        13        15        17.5        19.5
Dano 3/9 in-progress curve [V Dyno lol]
Code:
1        2        6.5        9        10.5        12        14        16        18        19
RichieRichness 10-27-2011 08:36 AM
Here is my e22 timing curve
Code:
0        3        5.5        7.5        9.5        11        12        12.5        13.5        15
It's kr free. I'm not holding 2+ load values past 5300 rpm so the last few rows are interpolated up.
SWAY 10-27-2011 09:28 AM
Oh yeah been taken care of he replaced it with a moly but I wanted to use stock for a while and I needed some quick cash so I sold it to someone local, this was before I got my tune just right so now I realize I need it. He def took care of me though no doubt.
superskaterxes 10-27-2011 10:32 AM
Code:
4.00 6.50        8.50        10.50        13.00        15.00        16.00        17.50        18.50        19.50
heres mine. on E30.
dont forget these are all gona be different depending on turbo/boost/VVT ect. so dont go trying to meet these for someone with similar mods cause it could be way different.
Dano 10-27-2011 12:08 PM
hum... since we are tuning timing "in the dark" with no KR for feedback its good to see the other timing curves to see if you are even in the ballpark.
Turbo/boost and VVT will not skew the numbers by very much if at all.
on pump the only reason to alter timing due to higher boost is due to higher cylinder temps which you don't have with E. so boost IMO isn't a factor
Turbo isn't a factor as well due to opinion 1 - you are not generating KR due to cylinder heat with a smaller turbo for example. The exception to this is perhaps running LESS advance with a larger turbo in the spool range to generate more exhaust gas heat. [see my retarded curve lol]
VVT is really the only variable IMO.
your timing curve will greatly depend on your mix ratio of course. the higher ratio the less each of the above will effect/limit your targets.
using a tool like VD properly, will help you to determine your individual timing needs :)
discuss...
phate 10-27-2011 12:11 PM
Yeah, don't know if you guys saw this, but E85 loves it some heat:
http://i64.photobucket.com/albums/h1...ed_1st-6th.jpg
Car gets smoother and smoother the hotter the BAT's get, lol.
And yes, that's a 1st-6th pull.
Dano 10-27-2011 12:15 PM
have you switched to OE heat range plugs?
I did for a brief time but thought I was getting even more blowout which turned out to be my FP sensor lol
need to put the hotter plugs back in.
Enki 10-27-2011 12:16 PM
Yeah, I think 140 is the tipping point. Feels really good even with stock intercooler.
phate 10-27-2011 12:33 PM
Yeah, I'm running ITV20's, now. They definitely help.
Alpha 10-27-2011 12:44 PM
Interesting... What are you gapped at with those?
phate 10-27-2011 01:19 PM
.024"
superskaterxes 10-27-2011 01:36 PM
Originally Posted by phate (Post 1100724)
.024"
does your ground strap look like a limp dick? lol
you def cannot correctly gap the 20's anywhere near the .024 range.....
phate 10-27-2011 01:41 PM
LOL, working properly so far :)
XLT_66 10-27-2011 02:19 PM
On pump gas, I've always targeted 11.6. On the corn, I've been trying to nail down 11.8. However, I may end up pushing that up to 12.0 in the future to see how it goes.
I figure I'm really not looking to push it much harder than I am currently (which is pretty hard). 300HP/380TQ to the front wheels is pretty impressive in my book for a little K04 sippin' on corn juice....and that's on our heartbreakin' AWD Mustang dyno.
silvapain 10-27-2011 02:34 PM
I currently target 0.83 lambda on 100% E85. That's 12.2 on the petrol scale.
Enki 10-27-2011 02:49 PM
Still dialing in .82 here; gets hot here in AZ.
Dano 10-27-2011 03:09 PM
12.2 here for me as well on E28 [3/9].
Just about 3/4 of the way through my 1st tank of E35 which I think is where I'll stay for the winter.
go 12.2 or your a huge vag :)
phate 10-27-2011 03:36 PM
LOL, I've seen .93l or so at full boost and full timing. You guys need to catch up.
I target .86l - The car went lean going from E70 to E85 without me knowing it, lol. All was fine, I love E85.
Dano 10-27-2011 03:38 PM
you sir are correct...I want to catch up...but my car had other ideas....lol
I think I am squared away now and can get back to pushing my tune.
Atlanta 10-27-2011 03:45 PM
Originally Posted by 240mazspd3 (Post 1062457)
PRS is a race team as well as a performance shop, he has no reason to stroke my ego. also, he didnt tell me what the dynoJet numbers would be. he just let me know that their MD reads 18% lower than a well calibrated DynoJet plus i know its the lowest reading MD's out of all the MDs here in central florida.
So they are a race team and performance shop and they use a broken dyno?
Isn't that like the guys at the Apple store carrying around Android devices?
Ckmazdaspeed3 10-27-2011 03:50 PM
I seem to be kr limited at around 21° at 7k w 4 gallons. From 6k on I got spurts of up to 2.4.
Also, does anybody else have afrs go crazy after a reflash? Like, I target 12.1 and see between 11.5 and 12.8 from 5500 on for like 4 pulls. Then I end up pretty close to targeted.
Realgib3 10-27-2011 04:21 PM
A. 12.6 is as rich as I'll run.
B. Ck... that's the same point I'm knock limited with <2g
bewsted 10-27-2011 04:36 PM
Update...corn makes stock turbos cry eventually...screaching squeirrel mode for mine...
phate 10-27-2011 04:38 PM
lol, it's not just the corn that does it. It's all that abuse we throw at them for thousands upon thousands of miles - I'm just waiting for mine to croak!!
bewsted 10-27-2011 04:44 PM
It will don't worry....Good thing i have a backup in the garage HEHEHE
Dano 10-27-2011 04:54 PM
Journal bearing turbo spinning thousands of RPMs above spec for thousands of miles. Lol
Nothing to do w e85 me thinks
You both need a GTX3071 like mr 12pk. Damn I want one of those.
Correction: you need a slightly used GT28 :)
Tappin
phate 10-27-2011 04:55 PM
Eff that, K04/E85 is where it's at!!!
Enki 10-27-2011 05:01 PM
I'm pondering a small EFR.
Dano 10-27-2011 05:01 PM
"Such a thing is not meant to last"
Lol
Tappin
Dano 10-27-2011 05:10 PM
haven't seen any AF craziness even on my 1st tank of E35 but it may take a couple of tanks for the ratio to settle in.
Ckmazdaspeed3 10-27-2011 05:12 PM
How eth heads travel out of state:
http://i1226.photobucket.com/albums/...5/2e07ec54.jpg
Dano 10-27-2011 05:26 PM
LOL
and a good bottle of red vino!
Ckmazdaspeed3 10-27-2011 06:09 PM
Not the best pic, but this is my trunk (good call dano):
http://i1226.photobucket.com/albums/...5/9dd267ac.jpg
And just called ahead to confirm that the eth station was open and stocked! Heading to Michigan... Ann arbor
silvapain 10-27-2011 06:20 PM
I'm at about 550-600 miles on E85, and I started losing fuel pressure tonight. FP dropping to 60 PSI when going 80 MPH is a butt-puckering experience.
rfinkle2 10-27-2011 06:20 PM
LOL. That container is all too familiar.
BTW, I received my fuel line, as well as my filter today, and will be upping the mix asap!
bewsted 10-27-2011 08:01 PM
Tappin
64 trim 3076 will = my win....don't worry mr.dano
Dano 10-27-2011 11:47 PM
Hahahahahaha!
Too funny!
The pic and the fact that we r all additics.
Calling ahead to check the avail of corn juice.
Tappin
Dano 10-27-2011 11:51 PM
Haha. Good 4 u. Although I think thats to much turbo for
My liking.
Tappin
Dano 10-27-2011 11:53 PM
Sucks! I feel ur pain my brotha! Different pain yet same results.
Tappin
Page generated in 0.23430 seconds with 11 queries
