silvapain 01-10-2012 12:21 PM
Originally Posted by ABSpeed3 (Post 1203334)
That is great news, do you have the sizes of the o-rings?
I'll have to look in my notes when I get home. I haven't posted sizes yet, as I won't know for sure if they work until I've done some testing.
phate 01-10-2012 01:00 PM
Originally Posted by GoSpeed3Go (Post 1203320)
has anyone tried mixing a little ethanol and engine oil together and heating it before it ignites obviously to see if whats left is comparable to the sticky crap gumming up peoples pumps?
Mass spec reading was posted about 30 pages back, lolol.
GoSpeed3Go 01-10-2012 01:25 PM
shit. now i gotta start over.
GoSpeed3Go 01-12-2012 07:16 PM
welp this felt good today till i looked at the log when i got home. just floored it in 3rd gear hard no gentle ramping up the throttle. dont understand where this part throttle knock comes from before OL. doin a 2-5 mix now
JacksonMS30 01-13-2012 04:23 PM
Quick question for the e85 gurus. How long can e85 be stored in one of those red plastic gas cans before its no longer safe to use? I've searched and found mixed results as to how long it takes e85 to break down/condensate/absord condensation whatever but basically turn into shit.
Reason I ask is because I have a friend who has about 10 gallons in outside storage that has been there since september. I would like to pick up some cheap e85 thats not 90 miles away, but I don't want to pour trash in my tank... :sad:
phate 01-13-2012 04:55 PM
I don't know the answer, but conventional wisdom says 3 months for gas....and ethanol is highly hygroscopic.....not sure if I would chance it, despite my love for the corn.
JacksonMS30 01-13-2012 05:01 PM
Thanks, I will avoid it like the plague :scared1:
mazdafreak 01-13-2012 05:37 PM
Finally had my first problem today and I can say I DIDN'T like it at all......I went back on 85 to have some funn this weekend.....but its been 20 degrees or so....but going to work this morning, the car felt funny, but then cruising on highway, everytime I gave it gas, my car would just like hesitate/studder....kinda felt like it was gonna die.....scariest shit ever, thought the car was gonna blow up.
But after work, I finally put stock irdium w.e ranged plugs in and cleaned the spill valve....and good as new!!!!!!!!! I can finally boost again! Car feels good till next time :/....but car rly doesn't like cold weather running 85.
Thankfully come Sunday, and throughout the next couple days, its suppose to be about 40s again.
dougefresh_ 01-13-2012 06:00 PM
I'm assuming it doesn't take THAT long for E85 & 93oct to separate, and I'm wondering if I should siphon out the gas that's in my tank. I'm worried about corrosion to the fuel lines (and everything) of the E85 separating and floating up (and just being in there stagnate in general). There's a big difference between letting your car sit for a week, and 3+ months.
Corn Juice is the :saevilw:
mazdafreak 01-13-2012 07:16 PM
Well actually this is the first problem I have had running 85....I think I drove with 85 ~2000 miles....this is the first time cleaning spill valve....I think the cold has something to do with my problem I had, happened after running through a half a tank.
Corn is def the devil.....can't get enough of it!!!!!! Blown turbo haha.
@phate when the spill valve got messed up and shit....it threw a code...like fuel pressure regulator something something low circuit....it was the valve getting gunked up right?? Car runs good now after cleaning it.
silvapain 01-13-2012 07:19 PM
I've never thrown a code when my spill valve stuck.
phate 01-13-2012 07:24 PM
I've never thrown that code when the spill valve drops pressure, but I have caused the cel by unplugging the spill valve while the car is running. That's weird that you got it while driving.
86AmishMs3 01-13-2012 07:42 PM
If its totally airtight then it should be fine. but either way 10g aint much. Buy like 10 5g jugs and stock up at said 90 mile away gas station.
mazdafreak 01-13-2012 08:14 PM
Ohh wait.....I'm so fucking stupid...I think I threw that code when I pulled the circuit fuse out and cranked the car to kill fuel pressure to take spill valve out.....LMAO...I'm so dumb....my bad!!!!!
Well hopefully that was it lol...car is fine now tho...ill clear code and see if it comes back
mazdafreak 01-15-2012 07:25 PM
Well bad news again..........car wouldn't start this morning, it was at least 15 degrees if not colder overnight, and I stayed at the girls house, so car was out all night....went to start it, car started, and.kept dying...I seriously had to crank the car 20 times before the car would stay on, thanks to @phate letting me know about that.
Then, after I left her house, couldn't even get down the road, and well the Spill valve gave out this morning, cleaned it, all good....then drove down to the meet in dekalb boosting a lot with 2 other speeds, and about ~40 mins later right when we arrived, spill valve gave out again....cleaned it, back on 93 now....we'll see what happens now.
85 is very very shitty in cold weather....I have not had one problem before....and now, spill valve keeps getting gunked up I guess.
GLORIFIEDBOZO 01-15-2012 09:00 PM
My car has thrown the code due the spill valve sticking 2 or 3 times but it was only when it didn't have fuel pressure when first starting the car. @phate I believe you were with me once when this happened, it was at the same time as my misfire in cylinder 4
With my car it takes a little bit of letting it crank before it will start and if I let off the clutch right after it starts when its cold it will die.
Sent from my DROIDX using Tapatalk
mazdafreak 01-15-2012 10:15 PM
@glorifiedbozo yeah, idk why I threw that code......and mine started the same way...it cranked, started, once clutch released it would die....but it would die still with clutch in for a couple seconds tho....seriously took 20 cranks till the car actually stayed on.
I just don't understand how my spill valve got gunked up/lost pressure twice in the same day....about 2 hrs later.
Enki 01-15-2012 11:06 PM
Sticky spring; have to clean between the coils on the button valve.
mazdafreak 01-16-2012 02:16 PM
Of the spill valve? Or do I have to pull the pump?
Enki 01-16-2012 03:29 PM
Spill valve; use some needle nose pliers to remove the round piece that remains in the pump when you pull the spill valve. Be careful as to not dump the spring/button valve out into the pump or on the ground; that would be bad.
mazdafreak 01-16-2012 04:10 PM
I cleaned that part....maybe I didn't clean that lil spring good enough.....but thanks! I'll be pulling the pump wednesday to check everything also.
Enki 01-16-2012 04:17 PM
The only way to know for sure if the spring is clean or not is to let it dry then gently squeeze it until the coils compress all the way. If it feels sticky, get to scrubbin or replace the spring with an aftermarket one.
mazdafreak 01-16-2012 04:42 PM
Ahh thanks!! Where would I get an aftermarket one?
Enki 01-16-2012 04:44 PM
Ace Hardware for < $1 7/32 spring. Check the pink elephants and unicorns (my) build thread for more infos and photos.
EDIT:
Updated to reflect actual measured size; apparently this one was in the wrong bin.
josurr 01-21-2012 11:33 AM
@silvapain
how are the o-rings working?
getting ready to buy some autotechs soon and want to do james' spring mod and your o-ring "fix"
ABSpeed3 01-21-2012 02:53 PM
I was about to ask the same thing
silvapain 01-21-2012 04:36 PM
Hard to say. I didn't have any spill valve sticking issues for eight days, after a couple months of having to clean it every five days or so. Then I was hooning about at a NATOR IL meet, activating my two-step to show the flames shooting out the back, and the spill valve stuck.
I went back to straight pump gas this week because it was very cold (highs in the teens), and I was planning on taking a trip and didn't want to mess with the valve.
(edited to fix the iPhones horrible autocorrect mistakes)
kritz 01-21-2012 07:51 PM
Went back to 93, no traction. But will be bringing some down to DC for tuning with @phate on the dyno if it is load bearing. @superskaterxes
ABSpeed3 01-22-2012 03:32 PM
So would you say it would work fine without e85? I'm not on corn right now, but I need to replace that o-ring for peace of mind. Assume you were on pump gas you think it would be alright?
Enki 01-22-2012 06:35 PM
The spill valve and o-ring mod are two completely separate things.
You'll be fine up to 50/50 if my experience is any indication.
josurr 01-22-2012 08:52 PM
right... but you have no data on the spring mod with full e...
Enki 01-22-2012 10:18 PM
ABSpeed3 quoted Silva, whom was talking about his spill valve. The only o-ring related to the spill valve is the one that does the sealing, which, if needed replacing, would likely mean a car on fire.
The only o-ring to replace would be the one on the piston retaining nut, which has nothing to do with the spill valve (hence my comment).
josurr 01-22-2012 11:01 PM
hrm... i thought that silva's o-ring was for the piston...
in either case... i am interested to know if your spring mod fixes the sticking issue, or at least makes it less prevalent, on full e...
Enki 01-22-2012 11:16 PM
It should; higher return force + coils not touching = victory?
josurr 01-22-2012 11:21 PM
sounds like a winning combination to me...
so it was 7/32" ID spring? where's it at in an ACE store?
Enki 01-23-2012 01:56 AM
Next to the wheelbarrows.
ABSpeed3 01-23-2012 09:17 AM
I am talking about the o ring around the piston retaining nut. Is that not what his picture was of a few pages back?
Enki 01-23-2012 09:24 AM
Yes. Why are you worried about this again, seeing as you aren't running ANY ethanol?
mazdafreak 01-23-2012 03:59 PM
I'm gonna have to pick the spring up too and give it a shot.
Zbrit00x 01-29-2012 04:00 PM
im looking to get an e85 tune with a 3 or 4 gallon blend of e85, 10 gallon 91. After my tune I was looking to run just 91 again because of availability of e85 and only use it when I crave more from my dd. Anyone think I would be seeing any specific problems when swapping out tunes and gas from e85 to 91 intermittently.
Page generated in 0.24286 seconds with 11 queries
