Epic first post brah; also $10 says pump full of black death. |
I meant he already has a pump full of black death. The E will only fuck his couch. |
So... on the note of stock internals, are most people just running upgraded kmd/autotech internals? I'm starting to think I'm maxing out my upgraded internals. 4th gear pulls get me up to about 2.7 load and my fuel pressures drop like a rock down to about 1300. What do you guys think? Tonight was my first runs/logs at that high of load but I'm pretty sure 100% E might be my problem :( I'll try going back to 50/50 after this tank to see if it helps any. I really don't want to have to buy that crazy $750 PTP stage 2. |
Help the bearded lizard out http://www.mazdaspeedforums.org/foru...d.php?t=112757 Hitting all the places @silvapain posts! |
Is that fifth port project done yet? :sigh1: |
You are the only one of the minnesota guys I have seen talking about running E. That shit is everywhere around here. Two stations within a mile from my house and one within a mile from work. I have run several tanks of a low mix with great results (stock HPFP:dunce:) until I started to up boost and lose pressure...obviously. I was surprised though I have tons of logs over 2+ months showing solid 1800psi with an E25ish blend. Should be getting my internals installed tomorrow though so Im back in it if I do! |
See that's better. But in the spirit of staying on topic; you have a ways to go/learn before trying E85 on a stock car with no tune or logging capability. (unless im mistaken) |
CA is also 10% ethanol. I agree It's a good idea to be prepared. |
Thread resurrection.... Wondering if you guys are seeing a similar trend, and I have a theory on that trend. I've been getting some KR on my pump gas tune, and many of the maps I'm working on are running less timing with more bouts of KR. Onto the theory, assuming your state does not require ethanol be blended into your pump gas, what do you guys think of the idea that refineries are using less ethanol in the blends now that oil / barrell is competitive / much less expensive than it was previously. I noticed for the first time (have been running a pump gas map) that e85 is actually quite a bit more than 93 octane in PA. @phate, @Bucker, @ atvfreek, @Ziggo, @silvapain, @cld12pk2go, @Lex... picking brains... |
Back to e85 mixes I go. |
e85 is at least 40 cents cheaper than 91 in AZ.... but 91 is also down to 3.45/gal... |
$2.74 for E85, $3.34 for 93 octane...Houston, TX...and that is not cheapest in town. |
e85 is the same as premium here currently. At one point it was $.50 more per gallon than premium. I run a 50/50 e85/87 octane mix though, so I suck it up. @rfinkle2 I don't question your logic one bit. I bet that is the case where 10% ethanol is not mandated. |
$3.09 here... And the gas blenders will do whatever is legal that maximizes their profits (as they logically should). Corn prices are starting to shoot the moon due to the drought; some ethanol makers are probably going to start fail if they aren't hedged... |
I have an E85 tester for checking the Erhanol content. They make kits to test lower concentrations as well: http://www.fuel-testers.com/ Buy a kit that can test down to the E10-E0 range and see Finkle. Tapadatass |
I'm going to have to pick one of those up. Thanks for the link. I love gadgets. |
Running seafoam certainly cannot hurt, but has almost no effect on cleaning the valves (as was thought in the past). The residue on our valves needs to be manually removed. |
At any rate, going back to the OTC timing and fuel values cured the KR. Now I'm on 25% ethanol and have moved timing back up to where it was and leaned fuel back to where it was and no KR. |
Should probably make a dedicated thread on it. |
yeah...WTF everyone is a vendor now...even @Bucker right? @Haltech is letting anyone with monies be a vendor it seems...maybe WWpearl is right. KIDDING! edit: WTF @Boost_creep |
Lol... @Boost_creep is with me :) |
haha there goes the neighborhood. |
:theyareontome: |
Damn, finally finished this thing... Epic thread, was great to watch the progression |
Damn thats a lot of reading... |
1 Attachment(s) Has any one look in to the fuel pump for the 2012 ford focus flex fuel DI. It look like the little bro of are 2.3 Green Car Congress: Ford Applying 2.0L Flex-Fuel Capable Direct Injection Ti-VCT Engine in 2012 Focus Can any one recherche the pump? Went to ford today and the focus flex fuel pump is 2 bolts across, the Mazda and Vw are 3 bolts. Still looking if the base can be change!!! |
I being running 4gl 93 to 5.5gl e85 for 2 month now with no problem. I'm getting 24 to 27 mpg with cobb spice tune +5 lambda and 26 to 29mpg with 93 tune +10 Lambda. Base line Mpg 31.9 on 93. I was planing to run for 3 month but went for a ride with my wife yesterday and 280 miles later need to put gas and there were no e85 close to were I was at, so i fill up with 93.:sorry: I will give it and other 3 month and i will take apart my full pump and post some pics. mods: bsd, cork sport cai, vtcs delete, egr delete, cats delete, pcv disconnected from intake manifold and Y of the turbo intake side with catch can. |
| All times are GMT -7. The time now is 11:34 AM. |
