Like Tree247Likes
 Old 09-27-2011, 03:34 PM   #1241
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
im running the standard 2.5 gal of E85 to a full tank of 93. and i put down 274whp 288wtq AWD Mustang Dyno at Performance Race Solutions who said their dyno reads 18% lower than a properly calibrated DynoJet which means id put down 325whp 339wtq Dynojet. Im running 19 degrees of timing up top and im still on stock plugs and turbo with 57k miles on my motor no meth...i still have zero kr with this much timing and only 2.5 gals of e85. when i got dynoed it was well over 100 degrees with the heat index
@djuosnteisn can push the tune even further but he said its uncharted territory and i dont know if i want to take the risk of something going wrong.
here is my thread
PERMED 274whp 288wtg AWD Mustang Dyno
2015 Mazda 6
The Following 4 Users Say Thank You to IshiKage For This Useful Post:
Dano (09-27-2011), djuosnteisn (09-29-2011), Nataphen (09-27-2011), phate (09-27-2011)
 Old 09-27-2011, 03:53 PM   #1242
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I believe I have it now.
1) no matter what mix you are running if your commanded AF = Target AF at WOT you are gold and no MAF scaling required. This is the same as with petrol...no change
2) That target AF doesn't need to be altered for E85 [i.e. 12.0=12.0 and it doesn't need to be richened up to account for E85]
Does everyone agree with that and that "formula" would hold true even at 100% E85?
so for my setup my WOT AF with a 3/9 mix has shown no AF shift. My CL trims are ~+5 at cruse and +11 at idle...soooo I MIGHT scale my idle area but nothing else.
This keeps my load resolution [as poor as it is for the IGN tables] the same.
Yeah, I thought about this earlier but didn't post it. At some point, I just had to stop thinking about it in terms of actual AFR, because I have no way of proving i'm really at xx.xx afr. The only thing I can prove is what lambda I'm at by using:
[Actual AFR] / [14.68] = Lambda
At a point, you'll just start seeing AFR as lambda, cause that's all that matters.
Until then, just use whatever keeps you straight.
-06 MS6
-Corn fed 07 MS3 - Sold
Bucker (09-27-2011), Dano (09-27-2011), wolly6973 (09-27-2011)
 Old 09-27-2011, 04:17 PM   #1243
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
so if I were to alter my OTS LOAD tune ( MAF cal'd, haven't come out with BT maps for MS6).... for a 4/12 gallon mix (MS6 haz 16 gallon tank)
All I needz to do is add timing as long as my AFR's arent fucked and LTFT's SUPER out of whack (and KR is not present)? Earlier in the thread I thought I needed to scale my MAF up 20%, than add some timing (see, I have been reading)?????
That seems too damn easy... No changes to VVT? Load tables?.......
I just traded my MS3 for an MS6 and I'm trying to decide if I should wait for the BT maps to be released so I can use those as a base... I've never really tuned shit besides doing a MAF cal and datalogging the fuck out of things making sure nothing blows.
I have read Abilor's tuning guide about 17,000 times,... But I would feel more comfortable with a base map that is already a boost tune.
I have a station literally 30 seconds away that sells E... I WANT E
SOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
bad.... But I = noob in the tuning department.
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
The Following User Says Thank You to Fatguy729 For This Useful Post:
phate (09-27-2011)
 Old 09-27-2011, 04:55 PM   #1244
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Log from this morning...
Lots of area under the ignition curve these days...
If the weather holds, it looks like I will hit the dyno this weekend.
The Following 7 Users Say Thank You to cld12pk2go For This Useful Post:
06Speed6 (09-28-2011), 11cruzito11 (09-27-2011), 802MS3 (09-27-2011), BigjohnB20 (09-28-2011), BlueStreak (09-28-2011), manelscout4life (09-27-2011), phate (09-27-2011)
 Old 09-27-2011, 04:56 PM   #1245
Eth Fiend
phate's Avatar
LOL, good stuff, Dustin knows what he's doing. I wouldn't go quoting dynojet numbers just on what that guy told you, though. He may have just wanted to make you feel good
Have I told you guys lately that I hate dyno #'s???
-06 MS6
Bucker (09-27-2011)
 Old 09-27-2011, 05:05 PM   #1246
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
I could do this pretty easily, really. Let me work on a tune and I'll see what happens. My priority is getting glorifiedbozo's base map to him (scaling the maf and every other table that needs it). I want to go with a proven method for his car so we can avoid adding variables to this equation. Iwill do some beta-testing with an OTS map.
I may need reminded about this, so Wednesday or Thursday if you want to shoot me a text yelling at me about this, go right ahead
AP is on it's way to @Bucker, they said it should arrive Thursday or Friday, so expecting it back Mondayish. Since I am driving down to Deals Gap this weekend this might be best(actually I'm just lazy and don't want to look up the E85 stations on the way) Am still dropping the tank and installing the filters Friday though so it will just be flash, fill and go.
I blame my slowness on my excessive drinking, which is reciprocal in a way...I mod and tune my car...frustration ensues...I drink...tune some more...more frustration....rinse & repeat.
surely I am the only one who follows this approach...
Of course your the only one, I would never ever do something like this
Bucker likes this.
The Following 2 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
Dano (09-27-2011), phate (09-27-2011)
 Old 09-27-2011, 05:08 PM   #1247
Eth Fiend
phate's Avatar
OK, there's some obvious confusion about how to begin running E85, so let me summarize and take the voodoo out of it. You MUST start with a good MAF cal to do this general outline
If your target AFR's = Actual AFR's, you're good
If your target AFR's <> Actual AFR's, do a maf cal (standard shit for trims and full throttle)
If maf cal was done, figure about how much you scaled it by looking at the change: Average( [New g/s] / [Old g/s] )= [MAF scalar]
If MAF scalar > 1.10, then you might want to consider scaling all other tables which use load on an axis
The point at which you scale the other tables is up to you. 10% is roughly E25 (3 gal E85 with 9 gal 93 octane), and I know most folks are not scaling them at this point.
-06 MS6
Dano (09-27-2011), Fatguy729 (09-28-2011), rfinkle2 (09-30-2011), wolly6973 (09-27-2011)
 Old 09-27-2011, 05:15 PM   #1248
IshiKage's Avatar
Groans: 278
PRS is a race team as well as a performance shop, he has no reason to stroke my ego. also, he didnt tell me what the dynoJet numbers would be. he just let me know that their MD reads 18% lower than a well calibrated DynoJet plus i know its the lowest reading MD's out of all the MDs here in central florida.
the DynoJet numbers is a result of me and Dustins ricer math
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
phate (09-27-2011)
 Old 09-27-2011, 05:26 PM   #1249
2 gallons in the tank, results to follow......
current 2.0L table timing is as follows on 93:
Code:
2500	3000	3500	4000	4500	5000	5500	6000	6500	7000
Code:
-5.80	3.00	4.00	6.50	9.00	10.50	12.50	14.00	15.50	16.50
 Old 09-27-2011, 05:45 PM   #1250
Posts: 9,484   (View Stats)
@cld12pk2go
at what mix point did you begin to see AF shift at WOT and what were your LTFTs at that point?
phate (09-27-2011)
 Old 09-27-2011, 06:04 PM   #1251
driver311's Avatar
Posts: 1,769   (View Stats)
driver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the world
Originally Posted by zenger View Post
20# boost, low fuel light had just come on so 2 gal of 93 4 gallons of E85.
Maf was hitting 4.8 said he didn't want to push it any further. I told him to be conservative, I couldn't have a blown motor at this time. He felt with 22-23# boost and more timing 380-400 wouldn't have been out of the question.
And BTW I'm not a MS3, bewsted
Those are very impressive numbers on a 6 at only 20psi. Very impressed.
2008 Mazdaspeed3, Fully built then fully parted. Sold
2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily
Mazdaspeed
12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp
11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp
driver311 is offline   Reply With Quote
The Following User Says Thank You to driver311 For This Useful Post:
phate (09-27-2011)
 Old 09-27-2011, 06:11 PM   #1252
Eth/Meth Junkie
cld12pk2go's Avatar
@cld12pk2go
I never did see my WOT shift even when running ~6 gal out of 12.5 E85.
Since I didn't understand why that was, I elected to scale the MAF up (and every table with load on an axis pretty much) and am now running 7.5 gal E85 and 5 gal 93 a tank (~E50).
The Following 3 Users Say Thank You to cld12pk2go For This Useful Post:
Dano (09-27-2011), phate (09-27-2011), wolly6973 (09-27-2011)
 Old 09-27-2011, 06:14 PM   #1253
and your LTFTs, did they reflect an expected shift? sorry I know you have already posted that info I just can't remember when or where.
phate (09-27-2011)
 Old 09-27-2011, 06:16 PM   #1254
Eth/Meth Junkie
cld12pk2go's Avatar
Doah, I meant to answer that...
Yes, I was seeing ~14% LTFT, which is pretty close to the expected since my base MAF curve was pretty much at 0% trims on 93 octane.
phate (09-27-2011)
 Old 09-27-2011, 06:19 PM   #1255
hum....WTF?
that makes no sense...so the car has to add fuel in CL to meet AF but without trims it can in OL.
We have one smart ECU
phate (09-27-2011)
 Old 09-27-2011, 06:37 PM   #1256
Eth/Meth Junkie
cld12pk2go's Avatar
hum....WTF?
Yeah, I previously moved my 0-60 g/s up ~10% to help with cold starting on a new tune, which obviously dropped the LTFT in those regions. But the unaltered WOT OL areas still were dead on aim.
I have no hypothesis to explain these observations.
phate (09-27-2011)
 Old 09-27-2011, 06:41 PM   #1257
Eth Fiend
phate's Avatar
Maybe you're really running a 93/93 "mix", and they're just lying to you about the E85
Bucker likes this.
-06 MS6
 Old 09-27-2011, 06:50 PM   #1258
Eth/Meth Junkie
cld12pk2go's Avatar
I wondered about that...but the LTFT shift and the exhaust smell suggest otherwise. lol
phate (09-27-2011)
 Old 09-27-2011, 08:49 PM   #1259
I think I didn't word my questions accurately enough or they were not specific enough.
I do fully understand what scaling the MAF involves thus the reason I keep trying to confirm my thought is correct...that it isn't necessary as long as AF targets are met, and why I don't want to scale mine. Been there done that...got the t-shirt.
I was just side tracked with the whole lambda/stoich ratio thing... thinking that if the car logs AF at 12.0 that it might actually be at 12.2 or 12.5 on E85.
Yes. The numbers in the ATR table are from COBB; the PCM deals in lambda like Phate said. That's what the WBO2 reads in.
The issue is that the PCM uses petrol's stoich value to determine the amount of fuel to add.
Fuel to add = AFR target (lambda) * MAF g/s * petrol stoich
Until COBB reveals this value for us to edit, we have to compensate by skewing one of the other values. So far everyone has done it by skewing the MAF signal; I'm suggesting we try skewing the AFR target.
Once COBB reveals the stoich constant, all we would have to do to switch to E85 would be to change one single value. Makes me wet just thinking about it.
The Following 6 Users Say Thank You to silvapain For This Useful Post:
atvfreek (09-30-2011), cld12pk2go (09-28-2011), Dano (09-27-2011), evidence (09-27-2011), phate (09-27-2011), wolly6973 (09-28-2011)
 Old 09-27-2011, 08:57 PM   #1260
Eth Fiend
phate's Avatar
mmmmm, global modifier (the stoich constant) would be beautiful. Oh well, I'm going to try it.
Let me tell you, though, the scary part of tweaking only AFR's. Many of us have seen ECU's which like to target a seemingly random AFR despite all attempts to reconcile the difference. What happens when an ecu, now targeting 8:1 targets 13:1...that could lead to some impromptu E85 knock resistance research, lol.
Bucker likes this.
-06 MS6
Dano (09-27-2011), wolly6973 (09-28-2011)
 Old 09-27-2011, 09:02 PM   #1261
It won't be any different than it happening on a MAF-skewed tune.
 Old 09-27-2011, 09:07 PM   #1262
Eth Fiend
phate's Avatar
There could be a significant difference, in some cases. Take Bucker's ecu, for example: Went to 13.4:1 AFR under full boost. That was only a 1 point shift in AFR (8% fuel loss). Going from 8:1 to 13:1 is a totally different story - about a 40% loss of fuel.
His ecu would hit 13.4:1 no matter what his MAF curve said...
My ecu doesn't do this, so I'm not terribly concerned with it. But I don't think I would use this method on someone else's car until I, or someone else, can confirm the logic is sound.
-06 MS6
 Old 09-27-2011, 09:19 PM   #1263
A shift from 8:1 to 13:1 is a 38.5% reduction in fuel mass entering the combustion chamber, regardless of whether the MAF or lambda is skewed.
EDIT: Oh! I get what you're saying now. You're saying there might be some unknown table in the PCM still that will have the old lambda values based on petrol. Good point.
I haven't heard of any one else's car doing that.
 Old 09-27-2011, 09:34 PM   #1264
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
There have been a few examples of this behavior, but mine for some reason seems to be the most severe.
403whp/451ft/lb Dry Shot
The Following 2 Users Say Thank You to Bucker For This Useful Post:
 Old 09-27-2011, 09:47 PM   #1265
I see what you are saying...when I was under the load cap I scaled my maf down by like 20% then commanded 9.8AF which ended up being an actual 11.8 or something like that.
you are suggesting leaving the MAF at petrol calibration and just changing the fuel tables.
to me its robbing peter to pay paul or 1/2 dozen 6 the other...with the mentioned caveat that altering the commanded fuel tables could be much worse if the ECU is pulling AF targets from some hidden table.
global multiplier FTW...but I'd say that is a needle in the proverbial haystack for Cobb to find.
phate (09-28-2011), wolly6973 (09-28-2011)
 Old 09-27-2011, 10:05 PM   #1266
It's a difference in table resolution and the fixed load axis values in some tables.
When scaling the MAF, some resolution is lost because the fixed number of table values now have to cover a larger range of MAF g/s. This also happens with the fueling tables, but the value range is much smaller so the resolution loss isn't nearly as significant.
Some tables have fixed load values, and skewing the load reduces the amount of table data pounts that are used by the ECU.
Given that, changing the lambda targets is the better choice, again assuming there isn't some undiscovered fueling table.
 Old 09-28-2011, 04:52 AM   #1267
have you guys ever seen ATR for the scoobies? if you think this is anywhere NEAR the amount of fuel tables we have your crazy. this may be all we need to work with at this point but i would guarantee there is gona come a time when we need more tables to be discovered.
The Following 6 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (09-28-2011), Dano (09-28-2011), phate (09-28-2011), rfinkle2 (09-28-2011), silvapain (09-28-2011), wolly6973 (09-28-2011)
 Old 09-28-2011, 05:58 AM   #1268
Eth/Meth Junkie
cld12pk2go's Avatar
Yeah, I believe we are still missing many tables that the ECU hops to under some circumstances.
Hopefully, there aren't any additional MAF curves...
I really wish we had better load axis resolution though...
The Following 2 Users Say Thank You to cld12pk2go For This Useful Post:
 Old 09-28-2011, 07:56 AM   #1269
heres a little snippet of what im talkign about, it would be REALLY nice to have that kind of knock control too.........
rfinkle2 (09-28-2011), wolly6973 (09-28-2011)
 Old 09-28-2011, 09:08 AM   #1270
Bucker's Avatar
Groans: 451
Neat, but I don't think the end user needs access to 50+ fueling tables, especially with some of the redundancy up there. Hell, and "Auto populate" feature would be nice for stuff like the cruise control tables, etc.
The Following 3 Users Say Thank You to Bucker For This Useful Post:
 Old 09-28-2011, 12:23 PM   #1271
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
This thread has given me confidence to move forward with using e85. great info and some people making gains!
The Following 3 Users Say Thank You to RichieRichness For This Useful Post:
GLORIFIEDBOZO (09-28-2011), phate (09-28-2011), rfinkle2 (09-28-2011)
 Old 09-28-2011, 01:39 PM   #1272
my head would explode if we had all those tbls...LOL
I kinda help my buddy with an 04 STI using ECUedit/flash and yes they have LOTS of tables.
we prap only have 1/4 of what they have but you don't really touch the majority of them on a day to day basis.
Bucker likes this.
Bucker (09-28-2011), phate (09-28-2011), rfinkle2 (09-28-2011)
 Old 09-28-2011, 05:10 PM   #1273
Eth Fiend
phate's Avatar
We have switched to winter blend E70!!
I filled up Monday when the car was on E. Trims are now between -5 and -10%, where they were close to 0 before. Car is now running ~.5 point richer under boost. I'm pretty confident to say we are on winter blend.
I think I'll pull 1° over the entire range just to be safe. We saw that it doesn't make a huge difference to power, so I'm pretty sure it won't cause my usual withdrawal.
-06 MS6
Ckmazdaspeed3 (09-28-2011), cld12pk2go (09-29-2011), Dano (09-28-2011), rfinkle2 (09-28-2011), silvapain (09-28-2011)
 Old 09-28-2011, 05:47 PM   #1274
interesting.
12pk posted the geo map of who changes to what blend and when...need to look that up but IIRC we don't change at all down here in the south.
BTW...do they post the blend change on the pump?
phate (09-28-2011)
 Old 09-28-2011, 05:52 PM   #1275
Eth Fiend
phate's Avatar
interesting.
Nope, it's a surprise. Any time I've asked about the change to winter blend they look at me like i've got a dick growing out of my forehead. I haven't been able to catch one of the fuel truck drivers, either, so I've just been watching my trims.
-06 MS6
Dano (09-28-2011)
 Old 09-28-2011, 05:57 PM   #1276
For those that don't know: Illinois Oxygenates their fuel in the winter - most Northern states do.
I believe Illinois does it mostly with Ethanol, but some states use MTBE.
Correction: Illinois banned MTBE, along with many other states:
http://205.254.135.24/steo/special/mtbeban.html
 Old 09-28-2011, 05:58 PM   #1277
LOL the attendant doesn't even know what E is!
so if you guys are already switching I got to believe we do as well at some point.
not sure it will matter with 2-3 gallons though.
 Old 09-28-2011, 06:08 PM   #1278
Ziggo's Avatar
Posts: 3,843   (View Stats)
Mmmmmm MTBE. My favorite tasty octane treat.
It's what they use in the 109 I buy at the track, but I am pretty sure its banned everywhere. Groundwater and cancer and all that. I thought all fuels are oxygenated with E these days.
Zigatapatalka
Ask Me About My:
phate (09-28-2011)
 Old 09-28-2011, 06:24 PM   #1279
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Arent the fueling tables in the ecu in lambda? In versatune all of the fueling tables are lambda so its easy to set the proper afr regardless of fuel type.
2006 Mazdaspeed 6
 Old 09-28-2011, 06:27 PM   #1280
you can change to lambda if you want
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.63149 seconds with 33 queries
