![]() | | #1361 | ![]() |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 3292 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,280
Groans: 52
| Not Ranked : 0 score I am NOT a fan of over scaling your maf in either direction for any reason. We were forced to do it in the load cap days, but we shouldn't have to now. The reasons I don't like this kind of scaling are well know. The MAF cal plays a huuuge role in how everything else in the tune is calculated... so instead of scaling the MAF up to run E... you may just want to target the correct AFR's for you Exx mix. I think this is where all this craziness today started with Superskater. Soooo here's my worksheet on finding which AFR to run for you mix of E without scaling your MAF for it... Assumptions: Gasoline Stoich (1L) ~ 14.68 E85 Stoich (1L )~ 9.76 Gasoline Max Power (Rich) ~ 12.5 (.85L) Gasoline Max Power (Lean) ~13.23 (.90L) E85 Max Power (Rich) ~ 6.98 (.72L) E85 Max Power (Lean)~ 8.47 (.87L) So... keeping it really simple... A good Lambda to run, no matter your mix would be around .86L (As Bucker is) because this is in the Max Power range of BOTH gasoline and E85. This means, with less E you could run leaner and with more E you could run richer... but so you don't have to mess with it at all to stay in each Max Power range... just use .86L With this in mind, your AP/DH will still be reading in AFR, so we'll essentially be targeting (.86*14.68)= 12.62 AFR so THAT is the AFR you should be seeing on your gauges. Sooo if you want to change your AFR Targets instead of scaling the MAF, these calculations should get you on the right track. Note: Both MAF scaling and lowering AFR targets are using the same ideas and accomplishing the same thing. I'm just not a fan of MAF scaling, so I figured I'd show this way as well. |
![]() | | #1362 | ![]() |
Groans: 189
| Not Ranked : 0 score This must be at least part of the reason running the OTS boost tune I'm getting a big kick in the pants from running mix; without the MAF cal, it's dropping me right on to 11.6 measured AFR (so just about perfect according to your above chart).
__________________ |
![]() | | #1363 | ![]() |
Groans: 298
| Not Ranked : 0 score I want a kick in the pants too. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | phate (10-01-2011) |
![]() | | #1364 | ![]() |
Groans: 189
| Not Ranked : 0 score Let's take this forepla--I mean conversation to PM.
| The Following User Says Thank You to Enki For This Useful Post: | phate (10-01-2011) |
![]() | | #1365 | ![]() |
Only thing I would add to this is that you want to only change the targets in the OL tables, and that if you do not rescale your MAF, you are going to throw cels on E85. Also, most of the information I have seen shows the best power on E85 in the .78-.82 range, so .86 is a little lean.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
![]() | | #1366 | ![]() |
Groans: 52
Also, some more simple math could be done to find the optimal %L for each mix but I was just using the. 86 for simplicity since it does fall inti the efficiency of both fuels. | |
![]() | | #1367 | ![]() |
| Not Ranked : 0 score Just found something interesting when working the spreadsheet. Two wrongs do make a right. If you were not to scale your MAF and instead use a skewed lambda target, the AFR readout would be correct. Basically, you want to run .78 lambda (7.6 AFR E85), but you didn't scale your maf, so you would command a .52 lambda target to achieve a .78 lambda. Guess what a .52 lambda target is when adjusted for what ATR/ECU will interpert it as. (hint: 7.6) What that means, if you want to skew the fuel targets instead of the MAFCAL, just enter what AFR is max power for the blend you are running into ATR, and it will calculate the skewed lambda target for you.
![]() | | #1368 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score I've been experimenting with 4g to a tank of E85 Ueber Cool Super Fuel but my results are dispiriting. I don't see any higher knock resistance at all. I am at exactly the same point I was when I maxed out my ATP3071 on 93 oct and a D03 nozzle. The attached logs show attempting to increase load by about 10 points which starts to show signs of knock. Running DP TP SRI. No MAF scaling. Just lowered WOT OT values to account for higher LTFTs which are at about 9-15 higher. I probably need to get a better EM and a big MAF housing but I was hoping I could at least get me some 20 gs or so more flow with a E85 blend. Not happening so far. Timing is pretty conservative I think. Anyone else not seeing the promise land ? 3071-17-4th gear on 4gE85.xls 3071-17-4th gear-2 on 4g e85.xls
__________________ ![]() |
![]() | | #1369 | ![]() |
| Not Ranked : 0 score E85 interpolation spreadsheet. enter values in the green cells, it will interpolate the rest for the blends. MSF doesn't allow me to upload the native .ods format, so I saves as a .xls, but I don't know how good the open office translator is. My % scaling doesn't account for the slightly higher density of E85 compared to gasoline, so its conservative. If you use it as a starting point, it will tend to result in richer than intended results.
![]() | | #1370 | ![]() |
| The Following User Says Thank You to Ziggo For This Useful Post: | phate (10-01-2011) |
![]() | | #1371 | ![]() |
| Not Ranked : 0 score I doubt it. The knock disappears completely if I lower timing 2 degs. That's why I also don't think seals are the problem. But may be I am missing something.
| The Following User Says Thank You to Tomas For This Useful Post: | phate (10-01-2011) |
![]() | | #1372 | ![]() |
| Not Ranked : 0 score I don't like your story.... I am going to be down in plano next week for the cobb first thursday meet and I was planning on picking up 10gal of e85 for testing. I am hoping it will resolve my knock issues, which are very similar to yours. 1-2* counts @ ~6300, 10* timing and 20psi. I am seriously considering enabling the ignition comp/cyl and putting a -1 in cyl 3 to see if it helps too.
![]() | | #1373 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score so wait, why would u only edit the OL tables? why cant u set all your CL cruise tables to like E85 stoich so your trims are perfect? P.S. im glad i started this crazy storm because it sounds like we learned alot! (at least i did)
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner |
![]() | | #1374 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score Honestly, unless the table to scale L is discovered, I will stick with the MAF scaling for the sake of myself, people I help, and sanity as a whole.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
![]() | | #1375 | ![]() |
In OL, it won't hit the targets because it never checks the actual vs the commanded thus the need to slew them to be correct. Zigatapatalka
![]() | | #1376 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
| Not Ranked : 0 score Forgive me if you guys are saying this already and I'm just not getting it. The O2 sensor reads in lambda and is translated to AFR in ATR/AP, correct? When targeting and logging 14.68 AFR, would it be technically reading 1 lambda, no matter what fuel you using? When you target an AFR, is it just reading lambda and translating it to AFR for gasoline?
__________________ ![]() ![]() 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
| The Following User Says Thank You to Nataphen For This Useful Post: | wolly6973 (10-01-2011) |
![]() | | #1377 | ![]() |
In CL the ECU will auto correct to hit it's lambda target using the trims.
![]() | | #1378 | ![]() |
![]() Join Date: Jan 2011 Location: Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 658
I thought I would add, that I was a little worried about it being so high. So I went Richer and I started to see KR, I had changed nothing but the AFR. I don't really understand this, maybe someone knows the answer. Looks like I will be going back up in to the 12's until I dyno and can see what timing I can get out of it before MBT.
__________________ Hx35 sold New sc6266 Last edited by sleepyspeed6; 10-01-2011 at 12:52 AM. | |
| The Following User Says Thank You to sleepyspeed6 For This Useful Post: | phate (10-01-2011) |
![]() | | #1379 | ![]() |
| Not Ranked : 0 score Great stuff here e25-30 checking in [3/9 mix] ...no maf scale...WOT trims are perfect...CL trims only +5 cruse and +11 [ouch] at idle so I'll scale those 3 volts LOL I am seeing no WOT AF shift due to E85 yet and 12pk saw no WOT AF shift until around e40 IIRC... so I am, and have been on, the "non maf scale" wagon. Maybe its left over trauma from the load cap scaling days IDK So that only leaves us that are running say 2-3 gallons of E, good maf cal, with only adjusting AF targets for max power. [not even skewing the AF targets if your WOT commanded = actual ] these last few pages have told us what AF/lambda to target for max power hats off to the math gurus and chem engineers for providing us with super cool tools to make our speeds that much faster!! With all that said, I'll leave it to realgib to run 13.5 + AF LOL
![]() | | #1380 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
| Not Ranked : 0 score Wow...seems like we are really over thinking things here. Either way, 21° timing up top is pretty fun: ![]() ![]() Hoping for a dyno opportunity in the morning with ~40°F ambient temps...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
![]() | | #1381 | ![]() |
| Neutral : -1 score Looks like a no-go on the dyno tomorrow tomorrow morning. Will have to wait for the next 40°F or colder opportunity. Bummer.
![]() | | #1382 | ![]() |
![]() Join Date: Jul 2011 Location: Aurora, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,419
Groans: 81
| Not Ranked : 0 score clint has very close to the same numbers...with a intake, dp, and internals lol. BTW he took me for a ride in it today, car is just silly.
__________________ 2004 mazda 3-Daily 2008 mazda 6-Wife 2008.5 Mazdaspeed 3 totaled 1983- FB Rx-7 Soon to be boosted Carb epicness Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler ] |
![]() | | #1383 | ![]() |
Groans: 31
| Not Ranked : 0 score Dude, spell it "tuned." Phate's car has to be a beast with that spool time and that much torque. The steering wheel would just be trying to put you in the ditch every time you went near the throttle.
| The Following 2 Users Say Thank You to Nataphen For This Useful Post: | GLORIFIEDBOZO (10-02-2011), phate (10-02-2011) |
![]() | | #1384 | ![]() |
Groans: 451
@Bob Loblaw
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
| The Following 3 Users Say Thank You to Bucker For This Useful Post: |
![]() | | #1385 | ![]() |
![]() Join Date: Jul 2011 Location: Clarksville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,279
| Not Ranked : 0 score Hopefully tomorrow it will begin, 100% E85
__________________ "Intelligence isn't the ability to store information, but to find it" - Albert Einstein "When I read about the evils of drinking, I quit reading" - Henry Youngman |
![]() | | #1386 | ![]() |
(Thread Starter) | Not Ranked : 0 score OK, guys, fun story: Last week, I was getting some intermittent pressure loss because the solenoid was sticking. So Friday night, I pulled the entire fuel pump and broke it down completely (cause I bought some new Torx bits, and I like working on my car instead of partying or something like that ). It's been ~3k miles since I last did this, and that includes the tail of the dragon trip where I switched to 93 octane.Everything came out pretty damn CLEAN. I mean, there was a very, very slight residue on the spill valve, and there was a tiny bit of buildup in the piece that holds the piston, but overall, this is the cleanest I've seen it since I started running E85. I did a total cleansing of the fuel pump, so I'll continue to monitor this, but I'm a little relieved. The problem, of course, is that I changed multiple things at once. Internals, ITFP, and now the switch to winter blend could be causing this. Not sure which factor was the key here :/
| The Following 8 Users Say Thank You to phate For This Useful Post: | 802MS3 (10-03-2011), Bucker (10-03-2011), Ckmazdaspeed3 (10-03-2011), Nataphen (10-03-2011), Realgib3 (10-03-2011), silvapain (10-03-2011), superskaterxes (10-03-2011), wolly6973 (10-03-2011) |
![]() | | #1387 | ![]() |
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
| Not Ranked : 0 score I'm sure someone has posted this already but I found this e85 calculator @ Miles Per Dollar Calculator also found this article on ethanol blends suggesting some better gas milage numbers opposed to e10 mixtures
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 ![]() Last edited by RichieRichness; 10-03-2011 at 12:32 PM. |
![]() | | #1388 | ![]() |
| Not Ranked : 0 score Slightly OT, but I had a chance to drive phate's car over the weekend, and my GOD that thing pulls hard. I'm very surprised (and disappointed) more cars aren't going straight E85. I'm hooked. Pump internals are hopefully going in my car this month, then I'm switching to straight E85. Tapadatass
| The Following 6 Users Say Thank You to silvapain For This Useful Post: | Ckmazdaspeed3 (10-03-2011), GLORIFIEDBOZO (10-03-2011), JLee1469 (10-03-2011), phate (10-03-2011), rfinkle2 (10-03-2011), wolly6973 (10-03-2011) |
![]() | | #1389 | ![]() |
Groans: 298
| Not Ranked : 0 score I just had a thought that I think would be of help. I know that the gen1 and gen2 have a cluster test that can be performed, and I believe that a pretty accurate display of the fuel level in the tank can be viewed digitally. For those mixing e-85 with 93, I thought it would be handy to use. Instructions here: http://www.mazdaspeedforums.org/foru...er-test-75877/ |
![]() | | #1390 | ![]() |
| Not Ranked : 0 score The DH also can read the fuel level PID and displays in %. Tapadatass
![]() | | #1391 | ![]() |
| Not Ranked : 0 score Hmm, time to start an E85 import business into Canada. Most timing we can run on our "94 octane" here on the west coast is 7-7.5 degrees at redline. Yup, you read that right. Verified on many local cars now.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Lex For This Useful Post: | phate (10-03-2011) |
![]() | | #1392 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
With meth, I went up to 16 then got scared since at that point, nobody knew where MBT was.
__________________ '07 CWP MS3 Forged. | |
| The Following User Says Thank You to BlueStreak For This Useful Post: | phate (10-03-2011) |
![]() | | #1393 | ![]() |
| Not Ranked : 0 score at what boost pressure at red line?
| The Following 2 Users Say Thank You to Tomas For This Useful Post: | BlueStreak (10-03-2011), phate (10-03-2011) |
![]() | | #1394 | ![]() |
![]() | | #1395 | ![]() |
Essentially with the stock turbo we're stuck in the 280-290whp max range here with the best gas we can get.
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #1396 | ![]() |
Groans: 451
| The Following User Says Thank You to Bucker For This Useful Post: | phate (10-03-2011) |
![]() | | #1397 | ![]() |
![]() Join Date: Apr 2010 Location: Aurora, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 41
__________________ ***sold*** 06 MS6 Cobb SRI 3.5" ETS TMIC Cobb AP Sure RMM JBR SSP EBay Catless DP Autotech HPFP Magnaflow - 2013 Scion FR-S 6MT 1993 Mazda Miata with shocks, springs, fsb, GT2560r, Megasquirt | |
| The Following User Says Thank You to event For This Useful Post: | phate (10-03-2011) |
![]() | | #1398 | ![]() |
(Thread Starter) | Not Ranked : 0 score Pretty much.
![]() | | #1399 | ![]() |
Groans: 451
| Not Ranked : 0 score Lol, I want a ride in it...
![]() | | #1400 | ![]() |
| Not Ranked : 0 score so just to make sure i have this straight, people arent seeing a change in WOT targets until greater then E40? i was running the same tank of E20 for the last week and i originally had my targets set to 12.2, then i bumped them to 12.7 and all of a sudden im seeing mid 13's on my log tapering to 12.7 near RL. not sure what happened but i just added some more E85 to make E30 total and im gona keep playing with it.
| Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. | 08Anamoly | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 03-04-2010 01:07 PM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Toyota ponders new pedals, lubrication as fixes in latest recall | Haltech | Automotive News | 0 | 01-22-2010 10:10 PM |
| Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? | Wenis Prinkle | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 07-27-2009 01:47 AM |
| HPFP flow mods, should support 550 WHP | ptperformance | Mazdaspeed3/6 General Discussion | 20 | 01-04-2009 01:56 AM |
