Like Tree247Likes
 Old 10-12-2011, 02:37 PM   #1521
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
JacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the world
Wow I let this thread get away from me. DJ and I are working out my new big MAF intake right now but it will hopfully be squared away before friday. I'll be running a couple gallons of E85 at the track and will do a back to back VD comparo of before and after the E is added.
One thing to note, with the addition of the big maf intake, I now have slight boost creep.
Also, this is with the MBC on lowest setting.
EDIT: Once I get my ex mani and egt gauge, I'll be jumping on a dyno to test out the leaner = better theory. I know there is no hard evidence at the moment to back it up but I would def like to see it work. Lower IDC ftw!
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M. Fifth/Sixth Port Injection -
- P.E.R.M.Tuning -
JacksonMS30 is offline   Reply With Quote
The Following 5 Users Say Thank You to JacksonMS30 For This Useful Post:
Dano (10-12-2011), Nataphen (10-12-2011), phate (10-12-2011), Realgib3 (10-12-2011), superskaterxes (10-12-2011)
 Old 10-12-2011, 06:22 PM   #1522
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
From everything I've seen, the leaner = better theory ONLY applies in condition where you would see high IDC's at high rpm.
The ONLY time I saw a significant increase in power was when I was at 13.3-13.5:1 from just under 6k-RL. This is when my IDC's would have normally been in the mid 90's, but were around 80 instead because of the lean afr.
My theory on that power increase = The leaner requested afr is accompanied by a shorter PW which also creates a lower IDC. This helps tremendously at high rpm because it actually gets the fuel back to being injected efficiently, and fully inside the injection window (before the spark event). This creates a much cleaner, more efficient burn and combustion, which, in turn creates more power.
This is also why I believe I never get blow-out or the black soot at high rpm that the higher hp guys have been seeing.
With all that said... I have not installed my egt guage, so I've gone back to 12.3:1 for the time being...
EDIT: I know it's been brought up before about our IDC's being goofy, and that's the truth... we don't have IDC's the same way a PI car does. There is no electrical/mechanical duty cycle being monitored on our injectors. Our IDC is just a calculation. This calculation can be greatly skewed by your maf scale and OL AFR targets, and I think a closer look into how we can use this ability to work to our advantage would be a great idea...
rfinkle2 and J-Liss like this.
The Following 5 Users Say Thank You to Realgib3 For This Useful Post:
Dano (10-12-2011), JacksonMS30 (10-12-2011), Nataphen (10-12-2011), phate (10-14-2011), rfinkle2 (10-13-2011)
 Old 10-13-2011, 05:29 AM   #1523
havent we decided that IDC is just the amount of time were flowing fuel during the intake/compression stroke? ie 95% IDC means we start flowing fuel right at TDC and stop ~18deg (95% of 360 deg stroke) BTDC? i know whenever i hit 100% i get some nasty ass blowout where others seems to be able to stretch way past that without problems.
phate (10-14-2011), Realgib3 (10-13-2011), wolly6973 (10-14-2011)
 Old 10-13-2011, 06:46 AM   #1524
Ziggo's Avatar
Posts: 3,843   (View Stats)
IDC summary is here:
Logged Injector pulsewidth is incorrect
It's representative, but 100% doesn't mean you are maxed, and under 100% doesn't mean you couldn't pick up more power from reducing it further.
Zigatapatalka
Ask Me About My:
The Following 5 Users Say Thank You to Ziggo For This Useful Post:
Nataphen (10-13-2011), phate (10-13-2011), Realgib3 (10-13-2011), rfinkle2 (10-13-2011), wolly6973 (10-14-2011)
 Old 10-13-2011, 10:37 AM   #1525
100% seems to be the magic breaking point for me. anything below 97 or so and the car pulls fine but above that its just a mess.
we need @djuosnteisn to hook that scope back up and do some additional testing
The Following 4 Users Say Thank You to superskaterxes For This Useful Post:
Enki (10-13-2011), phate (10-14-2011), Realgib3 (10-13-2011), wolly6973 (10-14-2011)
 Old 10-13-2011, 12:26 PM   #1526
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
So, maybe it's time that we start researching modified injectors again. Whoosh worked on it a long time ago, but we are getting more and more people at or near the limit now. E85 tuning especially would benefit since a well tuned BT and E85 pretty much seems to equal 100% IDC.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
The Following 3 Users Say Thank You to Nataphen For This Useful Post:
Enki (10-13-2011), phate (10-14-2011), wolly6973 (10-14-2011)
 Old 10-13-2011, 12:37 PM   #1527
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
You don't need a BT to peg the injectors.
@phate (lol)
Nataphen (10-13-2011), phate (10-13-2011), wolly6973 (10-14-2011)
 Old 10-13-2011, 09:06 PM   #1528
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Fuel pressure is super low. Anthony helped me check pump and its perfect. Now we are thinking it's the relief valve. Anyone have an extra?
The Following User Says Thank You to RichieRichness For This Useful Post:
phate (10-14-2011)
 Old 10-13-2011, 09:08 PM   #1529
Enki's Avatar
Groans: 189
You clean yours out yet?
phate (10-14-2011)
 Old 10-14-2011, 05:39 AM   #1530
Groans: 35
No it's never been taken out. I'm only running 2.5 gallons of e85...I think I'm in the market for a new one
update: Picked one up from Realgib3..thanks Mark and Ant
phate (10-14-2011)
 Old 10-14-2011, 07:16 AM   #1531
Made the switch to straight E85 yesterday.
Here we go.
The Following 8 Users Say Thank You to silvapain For This Useful Post:
Dano (10-14-2011), Enki (10-14-2011), GLORIFIEDBOZO (10-14-2011), J-Liss (10-14-2011), JLee1469 (10-14-2011), phate (10-14-2011), rfinkle2 (10-21-2011), wolly6973 (10-15-2011)
 Old 10-14-2011, 07:48 AM   #1532
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
Here we go.
make me proud danny my love.
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
The Following User Says Thank You to J-Liss For This Useful Post:
phate (10-14-2011)
 Old 10-14-2011, 10:19 AM   #1533
Enki's Avatar
Groans: 189
Guess that means I'm up next. My internals should be shipping today (hopefully).
Dano (10-14-2011), phate (10-14-2011)
 Old 10-14-2011, 04:25 PM   #1534
Enki's Avatar
Groans: 189
Internals shipped today, will be here Wednesday according to tracking. I should have the gas tank empty and ready for the first fat batch of alchie on Friday, which is likely when I'll make my thread.
Hopefully, I can get this downpipe swapped out soonish today/tomorrow morning.
 Old 10-14-2011, 05:10 PM   #1535
Posts: 9,484   (View Stats)
are you going to install a filter inline right before the CDFP like Phate did?
 Old 10-14-2011, 05:13 PM   #1536
Enki's Avatar
Groans: 189
Negative. No filter, no SeaFoam, nothing more than a watchful eye and a toolbox complete with cleaning kit at the ready should it be required.
Dano (10-14-2011), phate (10-14-2011), superskaterxes (10-14-2011), wolly6973 (10-15-2011)
 Old 10-14-2011, 05:42 PM   #1537
haha
just read bozo's thread....maybe the seafoam helped him out or poor Phate was just a fluke case...lol
you and silva will certainly bring more needed data to the table.
how many miles on your car?
I switched to 3/9 blend around 45K and I think I am ready to try 5050
The Following 5 Users Say Thank You to Dano For This Useful Post:
GLORIFIEDBOZO (10-14-2011), phate (10-14-2011), Realgib3 (10-14-2011), rfinkle2 (10-14-2011), wolly6973 (10-15-2011)
 Old 10-14-2011, 05:52 PM   #1538
Enki's Avatar
Groans: 189
I've been running 3/9 for about 2k miles; almost at 30k on the clock.
Dano (10-14-2011), phate (10-14-2011), wolly6973 (10-15-2011)
 Old 10-14-2011, 06:15 PM   #1539
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
haha
I really, really hope we can call mine "worst case". I want to see more people switch to full E85 and reap the benefits. It's such a HUGE difference from gas, and you don't have to do math or move the car when you're at the gas station.
I am looking forward to seeing more people switch. It sounds like we will actually have 5 full E85 mazdas by the end of this month I'm effin EXCITED for these guys!!!
Seeing how other cars 'react' will certainly be interesting.
-06 MS6
-Corn fed 07 MS3 - Sold
Dano (10-14-2011), GLORIFIEDBOZO (10-14-2011), rfinkle2 (10-21-2011), wolly6973 (10-15-2011)
 Old 10-14-2011, 06:47 PM   #1540
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I know most of you guys are moving towards running 100% e85, but all this e-85 talk and results spurred me to go out and get 2 5 gallon gas containers in order to run 3 gallons @ each fill.
The Following 6 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (10-14-2011), Dano (10-14-2011), GLORIFIEDBOZO (10-14-2011), mrmonk7663 (10-14-2011), phate (10-15-2011), wolly6973 (10-15-2011)
 Old 10-14-2011, 07:39 PM   #1541
haha
yes going to two different pumps at each fillup is lame...at least the station I visit is like a 16 pump station and there is always an open pump. 2 of which are E pumps.
GLORIFIEDBOZO (10-14-2011), phate (10-15-2011), wolly6973 (10-15-2011)
 Old 10-14-2011, 07:41 PM   #1542
JLee1469's Avatar
Posts: 1,195   (View Stats)
JLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the world
Shit I'd hop on the 100% if I didn't have issues on 50/50. Seafoamed and filled up 93 today, hope di fuel psi is back to normal.
JLee1469 is offline   Reply With Quote
The Following 4 Users Say Thank You to JLee1469 For This Useful Post:
GLORIFIEDBOZO (10-14-2011), phate (10-15-2011), rfinkle2 (10-21-2011), wolly6973 (10-15-2011)
 Old 10-14-2011, 08:23 PM   #1543
Enki's Avatar
Groans: 189
I believe you got bad fuel; so much so, I'm jumping in the deep end with both feet first.
 Old 10-14-2011, 10:47 PM   #1544
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
You may be right, we had some bad e85 on post for the military flex vehicles that caused all sorts of problems.
I do wish you would run an inline filter though, I ran seafoam way before I even knew about e85 and I would like to know if it will catch it, whether it be bad gas or build up.
Sent from my DROIDX using Tapatalk
The Following 3 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
Enki (10-14-2011), phate (10-15-2011), wolly6973 (10-15-2011)
 Old 10-14-2011, 11:25 PM   #1545
Enki's Avatar
Groans: 189
All the other times a filter has been used, it came out clean didn't it?
GLORIFIEDBOZO (10-15-2011), phate (10-15-2011), wolly6973 (10-15-2011)
 Old 10-15-2011, 08:30 AM   #1546
There are only 2 times that I know of, @phate and myself. Phate started out not using one and after having problems installed. At this point the issue had been resolved and the bad gas or build up or whatever was had already moved through the system. I started out using one in the beginning, but as I stated previously I had been running seafoam religiously every 2k miles long before even considering using E85.
If you swap and use a filter without prior use of additives this would let us know 3 things, 1 is ethanol breaking up build up in the system and causing problems, or are people getting bad gas, 2 is the use of additives prior to swap helping to alleviate the problem and 3 is the filter an effective preventative measure for stopping it.
Regardless of whether you use a filter or not we will most likely find out the answer to 1 and 2. Also you may save yourself some of the ass pain that phate went through initially.
Dano (10-15-2011), phate (10-15-2011), wolly6973 (10-15-2011)
 Old 10-15-2011, 09:37 AM   #1547
Enki's Avatar
Groans: 189
Well, I don't really have any of the stuff needed to set up an inline filter, but with a parts list I could do it.
I'm not really adverse to cleaning the pump kind of often though.
 Old 10-15-2011, 09:37 AM   #1548
Nataphen's Avatar
Groans: 31
Catch me up on this Sea Foam prep thing. Are you just adding a can to your gas tank every so often to keep things cleaned out? I've been doing that, but just not as frequently as every 2k miles. My MS3 would be more of a candidate for the switch I think since I've been up to date on maintenance and Sea Foam treatments since new. My MS6, having 70k miles and not knowing how it's been treated before about 66k miles, has me a little on the leery side. I need more e85 in the area before I consider going 100% really though, the closest station being almost an hour away.
phate (10-15-2011), rfinkle2 (10-15-2011), wolly6973 (10-15-2011)
 Old 10-15-2011, 11:36 AM   #1549
Eth Fiend
phate's Avatar
Let me know how that goes!!
The fuel line bozo and I used is L33X-13-49XA. The fuel filter is from an 03-04 SVT Cobra (the supercharged one).
-06 MS6
Dano (10-15-2011), GLORIFIEDBOZO (10-15-2011), wolly6973 (10-15-2011)
 Old 10-15-2011, 11:43 AM   #1550
Here are the parts. It's the same fuel line that already runs into the pump already so all you have to do is unplug the one from the pump and plug it into the back of the filter, take the new and plug the back into the filter and the front into the pump. (you can tell the back and front of the line by the QD's it uses, although i'm sure it makes no difference I'm just OCD about shit like that)
Originally Posted by glorifiedbozo View Post
So I started talking to @phate about a week ago, and decided I would be the next guinea pig. He had some issue's with the Spill Valve solenoid going bad when he initially switched, so after talking we decided to do a couple things to prep. He sent me a fuel line (Part #L33X-13-49XA) and I installed an inline fuel filter (the one from the 03-04 cobra). I also made an attempt at pulling the in tank pump, however I ran into some issue's. The place I was doing it didn't have the special tool to remove the pump itself, I would have ended up breaking it to get it out. So I decided to proceed and hope the filter catches the majority.
If you have been using SeaFoam since you got the car you are probably good. I did every 2k based on what it says on the can, and the fact that I bought the car with 39k miles on it all ready. Have you used SeaFoam on your MS6 at all?
Yeah there are only 2 E85 pumps with in a 45ish mile radius here and it makes things a pain in the ass. While 1 of them is only like 6 miles from my house and work 15 miles in the opposite direction, so if I get low at work it's 20 mile drive to fill up.
Fucker you type faster then me
Last edited by GLORIFIEDBOZO; 10-15-2011 at 11:43 AM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
Dano (10-15-2011), Enki (10-15-2011), Nataphen (10-15-2011), wolly6973 (10-15-2011)
 Old 10-15-2011, 01:41 PM   #1551
Nataphen's Avatar
Groans: 31
I ran a can through the tank on the MS6 right after I got it, and did the brake booster method and oil change. I'll probably run a couple more cans through the tank over the next 3-5k miles, then upgrade to the KMDs. I would go ahead on the MS3, but it's my wife's car, so I'll probably just leave it as it is with the bolt-ons and tweaked stock tune. Stock power is fine for her, she doesn't care, LOL.
The Following 2 Users Say Thank You to Nataphen For This Useful Post:
 Old 10-15-2011, 02:42 PM   #1552
rfinkle2's Avatar
Groans: 298
Ok. I know this is sissy stuff compared to the 100%'rs, but I just filled up with 3 gallons of e85.
My trims are a mess. LOL.
I had to drive a half an hour each way, but don't drive my car much, so I got 10 gallons of reserve (enough for 2 fill ups).
No close e-85 fml.
The Following 4 Users Say Thank You to rfinkle2 For This Useful Post:
Dano (10-15-2011), GLORIFIEDBOZO (10-15-2011), Nataphen (10-15-2011), wolly6973 (10-15-2011)
 Old 10-15-2011, 02:44 PM   #1553
Nataphen's Avatar
Groans: 31
No close e-85 fml.
I feel ya pain, sir.
GLORIFIEDBOZO (10-15-2011), rfinkle2 (10-15-2011), wolly6973 (10-15-2011)
 Old 10-15-2011, 05:34 PM   #1554
Ranyard's Avatar
Posts: 146   (View Stats)
Ranyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond repute
I'm here on this also. so I have 68k on my car, almost totally stock except for MS CAI, do I just dump a bottle in my tank every 2kish miles to get it clean and ready for AP, tip, at internals, and tune next spring?
"The eagle never lost so much time as when he submitted to learn from the crow" ...nobody
Ranyard is offline   Reply With Quote
 Old 10-15-2011, 08:02 PM   #1555
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
I'm glad your trims were messed up too...Not glad for you having to fix it...but when I added 3 gallons and said my trims were out of whack people told me they should be just fine blah blah blah....and yah they werent haha.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
 Old 10-15-2011, 08:22 PM   #1556
I would do it regardless of car and mods, but yes every 2k miles I would fill up and dump a can in. I also put it in my oil about 500-1k miles before changing it. There is also the vacuum lines but I have never done that (I plan on it soon)
 Old 10-15-2011, 10:20 PM   #1557
JLee1469's Avatar
Just be aware if you will smoke heavily if you put it in the crankcase, at least in my case it did as it thins out the oil... and we know what happens to thin oil in our turbos.
The Following User Says Thank You to JLee1469 For This Useful Post:
GLORIFIEDBOZO (10-16-2011)
 Old 10-16-2011, 07:58 AM   #1558
I only ever put a half can or less in the crankcase. I'm gonna get some oil samples turned in this next change to see how things look.
 Old 10-16-2011, 12:12 PM   #1559
Enki's Avatar
Groans: 189
Yeah, the 80 bucks for a fuel line I'll only use for a short period of time is a bit rich for my blood (tapped out on the internals and tools needed to do the swap). If I'm to do the fuel filter setup, I'll need to wait a while to accumulate fundage.
 Old 10-16-2011, 12:45 PM   #1560
Gimme a week let me see what I can do.
The Following User Says Thank You to GLORIFIEDBOZO For This Useful Post:
Enki (10-16-2011)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.62928 seconds with 36 queries
