Like Tree247Likes
 Old 10-22-2011, 08:09 PM   #1601
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
do we think ~90 IDC is when you are less efficient with atomization and/or are spraying into the spark event?
No, I don't think that is true. I see 100% + From 4k - redline without a problem
-06 MS6
-Corn fed 07 MS3 - Sold
Dano (10-23-2011), wolly6973 (10-23-2011)
 Old 10-23-2011, 08:45 AM   #1602
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Groaned at 25 Times in 25 Posts
Thought someone already proved the point that just because your IDC is 100% doesn't mean that your losing functionality?
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
The Following User Says Thank You to bewsted For This Useful Post:
 Old 10-23-2011, 09:17 AM   #1603
Ziggo's Avatar
Posts: 3,843   (View Stats)
I proved out that the injector pulsewidth (and thus the duty cycle) that we log doesn't properly account for increases in DI fuel pressure. IDC and pulsewidth are still indicative though and roughly anything over 70% and you are getting sub-optimal atomization prior to spark. This number goes down, 3ms is the atomization time, at redline only 9ms total is available, so anything over 66% would be sub optimal, not accounting for spark advance.
Its a sliding scale, slightly exceeding doesn't mean you lost a ton of power or necessarily any at all, but at some point the atomization becomes so bad that it causes spark blowout. Its why I will be working on secondary injectors next.
Ask Me About My:
The Following 4 Users Say Thank You to Ziggo For This Useful Post:
Boosted Beluga (10-23-2011), Dano (10-23-2011), djuosnteisn (11-21-2011), wolly6973 (10-23-2011)
 Old 10-23-2011, 04:54 PM   #1604
bewsted's Avatar
And does that apply to all mixes of e85 ?
Or is that only for pump ?
EWG K04...GETSUM!
 Old 10-23-2011, 05:26 PM   #1605
Ziggo's Avatar
Haven't been able to find atomization information for E85 that I trust. It takes more energy to vaporize than gas, thus the cooling properties and my instinct is that means it takes longer, but I don't know.
I don't have access to the SAE spec that gives the 3ms time and I don't know what conditions that is for, but increased boost pressure and higher BATs will reduce the time to atomize/vaporize.
Ask Me About My:
rfinkle2 (10-23-2011), wolly6973 (10-23-2011)
 Old 10-23-2011, 05:37 PM   #1606
Eth Fiend
phate's Avatar
So I ran a GT3076 car which was running straight 93 octane Saturday night...chalk one up for E85 - @xhymer!!!
It's ok, I'll be tuning his car on eth mix, so it won't be this way for too long, haha.
-06 MS6
Ckmazdaspeed3 (10-23-2011), Dano (10-23-2011), J-Liss (10-23-2011), rfinkle2 (10-23-2011), SWAY (10-26-2011), wolly6973 (10-23-2011), xhymer (10-23-2011)
 Old 10-23-2011, 06:13 PM   #1607
Posts: 9,484   (View Stats)
its all in the tune....
 Old 10-23-2011, 07:10 PM   #1608
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Has anyone determined what the acceptable power level is for stock internals? Seems some of you BT guys are at 450rwhp or so on stock internals.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
 Old 10-23-2011, 07:22 PM   #1609
Ziggo's Avatar
The internals will be torque limited, and some of the k04 gals are running as much torque as the big turbo guys.
Zigatapatalka
Ask Me About My:
Ckmazdaspeed3 (10-23-2011), phate (10-23-2011), rfinkle2 (10-24-2011), wolly6973 (10-23-2011)
 Old 10-23-2011, 07:38 PM   #1610
mrmonk7663's Avatar
So have we found the tq limit yet then ?
 Old 10-23-2011, 08:10 PM   #1611
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
Not really. We know that it CAN hold over 450tq, but nobody has run a car for a long period with that much power so far. So, it will hold that torque, but we don't know for how long yet.
The Following 4 Users Say Thank You to Nataphen For This Useful Post:
mrmonk7663 (10-23-2011), phate (10-23-2011), rfinkle2 (10-24-2011), wolly6973 (10-24-2011)
 Old 10-23-2011, 08:22 PM   #1612
R3L3NTL3S's Avatar
Posts: 236   (View Stats)
R3L3NTL3S is the leader of the worldR3L3NTL3S is the leader of the worldR3L3NTL3S is the leader of the worldR3L3NTL3S is the leader of the worldR3L3NTL3S is the leader of the worldR3L3NTL3S is the leader of the worldR3L3NTL3S is the leader of the worldR3L3NTL3S is the leader of the worldR3L3NTL3S is the leader of the worldR3L3NTL3S is the leader of the worldR3L3NTL3S is the leader of the world
@phate
If you still need a genpu for 100% e85 I will be the first I guess. Im running 75% e85 in this tank. I have about 5000 miles and have been running the E since 3500 miles without the filter starting with low mixes (2/10) up to 75% now.
The only issue I have had so far is having what seems a slightly lower idle with the 75%. No big deal really Just gotta wait for the fuel trims to settle a bit and check part throttle. I asked the gas station clerk what blend of E85 they have and it's class 3 (70% for those who dont know)
Let me know man.
2011 Velocity Red Mica MS3 w/Tech Package
Mods: Stocking out
R3L3NTL3S is offline   Reply With Quote
The Following 3 Users Say Thank You to R3L3NTL3S For This Useful Post:
 Old 10-23-2011, 08:30 PM   #1613
mrmonk7663's Avatar
Out of curiosity...planning for the future, is there a "go to" engine builder for the MS3s?
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
phate (10-23-2011), wolly6973 (10-24-2011)
 Old 10-23-2011, 10:01 PM   #1614
Zigatapatalka
and the later you bring that TQ on the more it will take and the longer it will last....
Reverse boost taper FTW.
 Old 10-23-2011, 10:27 PM   #1615
mrmonk7663's Avatar
Unfortunately reverse boost taper isn't practical when trying to make power with the k04...when I go BT reverse taper for sure.
 Old 10-23-2011, 11:40 PM   #1616
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Hmmm.... I ran 2 gallons of E85 to rule out false kr as the cause of my kr when I was stuck @ 22psi. I was running the D05 w/m nozzle back then (50/50 mix), and kr limited, but I should have been running the D07 for my crank hp & psi. Now with the D07 I safely run 24psi with mostly 0 kr (sometimes 1-2*... which doesn't bother me).... but now I'm stuck @ 24 psi.
I talked to a (somewhat) local Cobb Tuner who welded my slash pipe on for the venturi set up I run. He was super anti-meth (cause it can fail) and saying to run E85. I called him a couple months later, and asked him his thoughts of running a few gallons of E85 in the speeds, which are not designed to handle it. He was more adamant then that I stay away from it... altogether, lol. He didn't realize the speeds were not designed to run E85.
I ordered a D010 nozzle I'll be running soon (hoping for 26-27psi kr free), but still considering E85. My hats off to you guys for experimenting with the corn juice. I'm just waiting for the LT results in terms of how our entire fuel system handles it. By long term, I mean 1 year ++. That, and running E85 would be WAY more convenient for me personally... there's a station at the airport 6 miles away. I have to drive 150+ miles RT to pick up pure methanol to mix, and I tear through that shit.
/sitting on sidelines
The Following 3 Users Say Thank You to dougefresh_ For This Useful Post:
phate (10-24-2011), rfinkle2 (10-24-2011), wolly6973 (10-24-2011)
 Old 10-23-2011, 11:58 PM   #1617
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Well, there will be lots of cross-sectional data here soon. Some doing this, some doing that, etc.
Time will tell.
dougefresh_ (10-24-2011), GLORIFIEDBOZO (10-25-2011), phate (10-24-2011), wolly6973 (10-24-2011)
 Old 10-24-2011, 02:17 AM   #1618
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
James (Enki) has balls. Thursday internal install. Friday change to full E85 mixture, morning drive from tuscon to phoenix and back.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 5 Users Say Thank You to 86AmishMs3 For This Useful Post:
Enki (10-24-2011), GLORIFIEDBOZO (10-25-2011), phate (10-24-2011), rfinkle2 (10-24-2011), wolly6973 (10-24-2011)
 Old 10-24-2011, 07:11 AM   #1619
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Hey guys...
I'm ordering the fuel line today (L33X-13-49XA) THANKS PHATE, and must have missed where you sourced the 03-04 Cobra (supercharged version) fuel filter.
Can I get one of those from a local parts store?
 Old 10-24-2011, 07:34 AM   #1620
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
Yes.
The Following 2 Users Say Thank You to wolly6973 For This Useful Post:
 Old 10-24-2011, 07:40 AM   #1621
rfinkle2's Avatar
Groans: 298
Originally Posted by wolly6973 View Post
Yes.
phate (10-24-2011)
 Old 10-24-2011, 09:14 AM   #1622
Enki's Avatar
Groans: 189
Thanks man, but you forgot to add that I cruised on down with no sleep. The drive home was....interesting.
Car still runs like a champ. Per Phate's advice, just added a bunch of timing to it and hopefully I can get the MAF dialed in. Also, now I know I'm not crazy and converting to e85 has actually made the engine a hell of a lot more responsive at lower throttle inputs (my shifting has become somewhat rough again, and touching the throttle at 80 = decent increase in speed without boost).
The Following 7 Users Say Thank You to Enki For This Useful Post:
86AmishMs3 (10-25-2011), Dano (10-24-2011), dougefresh_ (10-26-2011), GLORIFIEDBOZO (10-25-2011), phate (10-24-2011), rfinkle2 (10-24-2011), SWAY (10-26-2011)
 Old 10-24-2011, 10:25 AM   #1623
another one hooked phate...your plan is coming along nicely
The Following 5 Users Say Thank You to Dano For This Useful Post:
GLORIFIEDBOZO (10-25-2011), phate (10-24-2011), rfinkle2 (10-24-2011), SWAY (10-26-2011), wolly6973 (10-24-2011)
 Old 10-26-2011, 05:41 AM   #1624
snOhio's Avatar
Posts: 330   (View Stats)
snOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the world
so i'll chime in as another genpu owner willing to try some corn. but, i'm stock, and i don't have an AP. based on reading through all 41 pages of this thread, plus bozo's thread, am i correct to assume that i won't really see any benefit without a tuning solution?
Sold: 2011 Black Mica MS3 - JBR 80d RMM, SSP, Anchors, Mudflaps, SRI/TIP
2008 Toyota 4Runner SR5 V6 4WD
2004 Aprilia Tuono - Beowulf exhaust, Gabro chip
1993 Suzuki GS500E - K&N drop in, Supertrapp strap on
snOhio is offline   Reply With Quote
The Following User Says Thank You to snOhio For This Useful Post:
phate (10-26-2011)
 Old 10-26-2011, 05:43 AM   #1625
josurr's Avatar
Posts: 954   (View Stats)
josurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the world
Groans: 156
i wouldn't do anything more than 1 gallon until an AP is installed on your car...
josurr is offline   Reply With Quote
The Following 2 Users Say Thank You to josurr For This Useful Post:
phate (10-26-2011), rfinkle2 (10-26-2011)
 Old 10-26-2011, 06:54 AM   #1626
Agreed. I tried 100% E85 on the stock HPFP with 0 WGDC at 13 PSI and I had SERIOUS fuel pressure issues. It's in my E85 thread.
phate (10-26-2011), rfinkle2 (10-26-2011), wolly6973 (10-26-2011)
 Old 10-26-2011, 08:36 AM   #1627
R3L3NTL3S's Avatar
Please dont do this. It has been a while since anyone has gone zoom-zoom-boom and I would rather you not break the cycle.
Just hang tight until you get your AP
Mods: Stocking out
The Following 2 Users Say Thank You to R3L3NTL3S For This Useful Post:
phate (10-26-2011), wolly6973 (10-26-2011)
 Old 10-26-2011, 09:35 AM   #1628
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
Yes you would be correct. In fact based on @silvapain's thread I would say need to atleast have an AP and upgraded HPFP before going full E85. I would also recommend SRI, DP, and RMM because that's really what's gonna set off the butt dyno off.
The Following 2 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
 Old 10-26-2011, 10:45 AM   #1629
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
I've noticed this as well. The increased timing definitely increases engine response.
Gotta be smooooooth with those shifts on date night or she'll think you can't drive haha!
The Following 2 Users Say Thank You to Alpha For This Useful Post:
SWAY (10-26-2011), wolly6973 (10-26-2011)
 Old 10-26-2011, 10:53 AM   #1630
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
I don't think that phate has a dp and he's making a bigillion lbft of torque.
But, I can't imagine all that power w/o an rmm... Seems like the block would end up in your lap lol!
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
GLORIFIEDBOZO (10-26-2011), wolly6973 (10-26-2011)
 Old 10-26-2011, 11:14 AM   #1631
Enki's Avatar
Groans: 189
I thought he did have a downpipe. I have a gutted stock and am near 366 torque corrected, if that helps.
Ckmazdaspeed3 (10-26-2011), GLORIFIEDBOZO (10-26-2011), wolly6973 (10-26-2011)
 Old 10-26-2011, 02:58 PM   #1632
XLT_66's Avatar
Posts: 850   (View Stats)
Here is my timing table after spending about 2 hours on our dyno. Granted, we were playing with a lot of other stuff besides the timing but this very linear timing map, look at the 2.0 load values since we're over 2.0 the entire pull. Car seems to be running very very well right now.
On 50/50 mix, I made 304WHP/387WTQ in 4th gear on our AWD Mustang Dyno before correction factor brought me down to 297WHP/381WTQ. We pushed it to 22* but the gains were so small that I backed them down again to 20*.
93 Oct @ 18* vs. E85 @ 20* Quite a bit of area between them in the low a mid-range. Only issues we're having is getting the AFR to just sit flat the entire run. It's not going off by enough for me to worry and frankly, I'm thinking I need a stiffer spring in my BPV.
2009 CWP MS3 Sport
SOLD!
2008 Toyota Tacoma TRD Sport 4x4
XLT_66 is offline   Reply With Quote
The Following 12 Users Say Thank You to XLT_66 For This Useful Post:
bewsted (10-26-2011), BigjohnB20 (10-27-2011), Ckmazdaspeed3 (10-26-2011), cld12pk2go (10-26-2011), Dano (10-26-2011), djuosnteisn (11-21-2011), dougefresh_ (10-26-2011), Enki (10-26-2011), GLORIFIEDBOZO (10-26-2011), phate (10-26-2011), SWAY (10-26-2011), wolly6973 (10-26-2011)
 Old 10-26-2011, 03:11 PM   #1633
Eth Fiend
phate's Avatar
Excellent information - that's the first solid data set we have for timing on 50/50.
-06 MS6
 Old 10-26-2011, 03:35 PM   #1634
SWAY's Avatar
Posts: 2,517   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 60 Times in 43 Posts
Damn i need to get my ass in gear and go to the dyno and post up some numbers, im on stock rmm as well bc my jbr broke and stock dp.
~2011 Liquid Silver MS3~ ---->> ZZB
SWAY is offline   Reply With Quote
The Following User Says Thank You to SWAY For This Useful Post:
 Old 10-26-2011, 03:49 PM   #1635
Damn your JBR broke? How many miles and what duro?
 Old 10-26-2011, 04:13 PM   #1636
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
@XLT_66 what is your AFR target? It looks like 11.8? What were you targeting when you were running only a couple gallons of e85?
 Old 10-26-2011, 04:14 PM   #1637
SWAY's Avatar
Groans: 190
Not sure how many miles I got it in mid may prolly like 2k was the 80 duro, the bushing was fucked up soon as I stocked back I was hooked on no vibes haha. Ima bout to get the moly shits insane
Sent from my evo 3d
GLORIFIEDBOZO (10-27-2011)
 Old 10-26-2011, 04:35 PM   #1638
Groans: 134
@XLT_66 u mention unstable afrs at higher rpms. I am on 4 gallons and EVERY TIME I flash a new map my afrs go fucking nuts from 5500 on. In fact I fucked w my maf cal for a long time cuz of it until I gave up and noticed that after like 5 pulls, they stabilize. It's kinda scary to see my afrs hi 12.79 every now and then, but luckily the eth quells the kr:
Also, unrelated, I did see substantial and persistent kr (2.4) when I tried 20° at 6500. So it SEEMS I am still kr limited.
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
wolly6973 (10-27-2011)
 Old 10-26-2011, 04:41 PM   #1639
bewsted's Avatar
@Bucker.....read and learn.....22 * is too much nutsack breath!
EWG K04...GETSUM!
The Following 3 Users Say Thank You to bewsted For This Useful Post:
Bucker (10-26-2011), phate (10-26-2011), wolly6973 (10-27-2011)
 Old 10-26-2011, 07:52 PM   #1640
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
I agree I stick near 20 now myself and refuse to push a tune over that point.
403whp/451ft/lb Dry Shot
The Following 2 Users Say Thank You to Bucker For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.62594 seconds with 42 queries
