Like Tree247Likes
 Old 11-29-2011, 08:31 AM   #1961
Posts: 9,484   (View Stats)
I think I have a way to narrow this problem down.
-perform a log when rolling into the throttle, and my $ says your afr's are well within a comfortable range.
-perform a log after taking your foot of the gas (i.e. let the injectors shut off / afr's in the 29xx's) and mash the pedal...
It seems, for whatever reason, the ecu can correct @ (I know this is not common opinion on wot operation in these cars) wot only in the first scenario.
@kritz... need those logs please.
you may have something there...sometimes to get down to 2600 RPMs I am downshifting from 5th to 4th on the interstate [hard braking and decel] until I get to those RPMS them immediately WOT. Sometimes I fall in below that range and have to accel a bit before hitting the gas.
could be that some of the guys I am tuning are doing something similar when their logs show lean for no reason.
@Boost_creep do you do this? your latest logs have been great but a few revs ago they were way lean on the first run and I haven't made any maf changes to that degree. I'll look back at those logs to see.
rfinkle2 and Boost_creep like this.
Boost_creep (11-29-2011), kritz (11-29-2011), wolly6973 (11-29-2011)
 Old 11-29-2011, 08:42 AM   #1962
Posts: 7,290   (View Stats)
@rfinkle2
I will get those logs to you asap, those peskie state troopers have been hanging out in my data log test strip. The freaking nerve of them!
Nator is what it does.
rfinkle2 (11-29-2011)
 Old 11-29-2011, 09:42 AM   #1963
Boost_creep's Avatar
Posts: 829   (View Stats)
Boost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the world
I definitely think @rfinkle2 may be onto something there. Yes, I do sometimes ease up on throttle, enough we're the injectors are turning off. I did not even think that could be related to the issue. There is a very good chance that this is why some of the logs are a little wonky.
I'm going to get some more logs for you tonight @Dano
I'll make sure to not do this, and well see the results. Lol.
www.dizzytuning.com
www.facebook.com/dizzytuning
Boost_creep is offline   Reply With Quote
The Following 2 Users Say Thank You to Boost_creep For This Useful Post:
Dano (11-29-2011), rfinkle2 (11-29-2011)
 Old 12-02-2011, 05:01 PM   #1964
I think I'm addicted! I think I will be going to 100% very sooonly. Like next fill up this damn stuff is sweet.
@rfinkle2,@phate,@silvapain
The Following 3 Users Say Thank You to kritz For This Useful Post:
GLORIFIEDBOZO (12-02-2011), phate (12-02-2011), silvapain (12-02-2011)
 Old 12-02-2011, 05:23 PM   #1965
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Based off of recent data posted by our 100 percent E users I would not personally go 100 percent unless you have a back up spill valve for "just in case" or an alternate vehicle should you need to get a spill valve if yours goes out. Just my opinion.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
kritz (12-02-2011), rfinkle2 (12-02-2011)
 Old 12-02-2011, 05:31 PM   #1966
I hearz ya,I'll pull the sucker out and clean it if needed. Drop it in an ultrasonic cleaner with gasoline might do the trick.
mrmonk7663 (12-02-2011)
 Old 12-02-2011, 05:53 PM   #1967
It's definitely addicting .
GLORIFIEDBOZO (12-02-2011), kritz (12-03-2011)
 Old 12-02-2011, 06:12 PM   #1968
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
hahaha, I've gotten a few messages just this week from the E85 or eth mix guys and all have said the same: their car feels slow as hell on straight gas!
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 8 Users Say Thank You to phate For This Useful Post:
atvfreek (12-06-2011), Bucker (12-03-2011), GLORIFIEDBOZO (12-02-2011), JLee1469 (12-02-2011), kritz (12-03-2011), mazdafreak (12-02-2011), paulwalll (12-06-2011), rfinkle2 (12-02-2011)
 Old 12-02-2011, 06:37 PM   #1969
JLee1469's Avatar
Posts: 1,195   (View Stats)
JLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the world
I don't have to tell you this week, I tell you all the time! Oh and winter tires and 30 degree weather ain't helping. At least I look forward to 25+ mpg.
JLee1469 is offline   Reply With Quote
The Following 5 Users Say Thank You to JLee1469 For This Useful Post:
GLORIFIEDBOZO (12-02-2011), kritz (12-03-2011), mazdafreak (12-02-2011), phate (12-02-2011), rfinkle2 (12-02-2011)
 Old 12-02-2011, 10:31 PM   #1970
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
Every time I fill up I miss the gas mileage, but only up to the point that I pull out of the parking lot and punch it
The Following 3 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
JLee1469 (12-02-2011), kritz (12-03-2011), rfinkle2 (12-05-2011)
 Old 12-06-2011, 09:06 AM   #1971
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
Groaned at 8 Times in 2 Posts
All,
I'm looking for some volunteers to help me test some new tables we've opened up. On my car, these tables are allowing me to run 75% E85 to 25% 93 while still running my MAF scaling from 93 fuel. It allows me to run any mixture and can compensate for the changes.
Ideal candidates are proficient with ATR, have a solid MAF scale from when they were on pump gas, and are currently using some sort of E85 mixture.
Basically, I'll need people to send me a copy of a map that they used with pump gas (to get the pump gas MAF scaling) and tell me how much E85 they have in the tank and I'll send them a map back with a few updated tables (that will still be hidden for the time being) to test on their car and for them to datalog. We'll be looking for your trims to stay within reason and for your car to still be able to hit targets in OL.
Send me a PM if you're interested! The people whom I've already contacted, well, feel special.
Cheers,
Evan@COBB
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD!
2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car
Evan@COBB is offline   Reply With Quote
The Following 16 Users Say Thank You to Evan@COBB For This Useful Post:
Alpha (12-06-2011), Dano (12-06-2011), djuosnteisn (12-06-2011), Easter Bunny (12-07-2011), Enki (12-06-2011), jracer (12-06-2011), kritz (12-06-2011), Lex (12-06-2011), Nataphen (12-06-2011), phate (12-06-2011), Pu Manchu (12-06-2011), rfinkle2 (12-06-2011), rghispanic88 (12-28-2011), Todd98SE (12-06-2011), vbt101 (12-06-2011), wolly6973 (12-06-2011)
 Old 12-06-2011, 09:15 AM   #1972
Great to see you giving e85 some research @Evan@COBB!
phate (12-06-2011)
 Old 12-06-2011, 09:21 AM   #1973
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
Thumbs up
That infamous E torque is hard to ignore.
High Five Evan!
The Following User Says Thank You to Alpha For This Useful Post:
phate (12-06-2011)
 Old 12-06-2011, 09:23 AM   #1974
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Responded; will be driving again within a week, give or take a couple of days.
kritz (12-06-2011), phate (12-06-2011), rfinkle2 (12-06-2011)
 Old 12-06-2011, 09:46 AM   #1975
PM sent.
So I have another awesome and interesting issue with fueling...
Now I have only ~60 psi up until 3000 PRM, then I get full pressure. It's interesting because it's like a switch at 3000 RPM; right below it and it's at ITFP pressure, as soon as I hit 3000 RPM I get full HPFP pressure. It's consistent and repeatable.
Any thoughts?
Last edited by silvapain; 12-06-2011 at 09:46 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-06-2011, 09:49 AM   #1976
HPFP desired pressure tables....lol
i have had weird things happen when moving a map forward through a FW or ATR revision.
 Old 12-06-2011, 09:53 AM   #1977
I wish it was a simple table change. I haven't made any map revisions recently, and I was having no FP issues before last night (when this started happening).
I remember there being some sort of low speed resistor for the ITFP... Maybe I need to bypass it?
 Old 12-06-2011, 09:55 AM   #1978
So you fubared my spill valve in what...3 days...or did it ever work?
the resistor is on the driver side frame rail in front of the battery box but not sure that would be the issue.
 Old 12-06-2011, 10:01 AM   #1979
Eth Fiend
phate's Avatar
PM sent.
Any thoughts?
Yeah, mine too Identical issue, except my switch is like 3200rpm haha.
Anyway, I'd be curious to look at the voltage and amperage at the solenoid over the rpm range. Not much else can change, haha. Maybe I'll do some dj style ghetto wiring and hook up my mutimeter and have wires running everywhere, hehe. Yeah, this sounds like a good idea.
ps - I'm back on 93 for a tank. Not sure what possessed me to do this, but I did it. It's an opportune time to get a decent 93 tune, anyway. Dial in the maf curve and actually help out Evan's cause when I switch back to E in a few days.
-06 MS6
Bucker (12-06-2011), kritz (12-06-2011), rfinkle2 (12-06-2011), silvapain (12-06-2011)
 Old 12-06-2011, 10:04 AM   #1980
b...b...but he just installed my SV which was working perfectly on my car...literally took the CDFP off my car, pulled the valve and sent it out. I have two CDFPs you know
I can't believe he was able to phuck it up THAT quickly lol
has to be something else.
 Old 12-06-2011, 10:05 AM   #1981
Enki's Avatar
Groans: 189
Silva, just out of curiosity, could you try reflashing your current map? Also check the AP readout for HPFP desired pressure.
Dano (12-06-2011)
 Old 12-06-2011, 10:08 AM   #1982
Eth Fiend
phate's Avatar
The spill valves are fine. With gas, they work perfectly. As soon as they get some high eth content, they have issues sometimes. We think it could be a lubrication issue with the plunger and collar or the plunger and that little c-clip in the solenoid....
-06 MS6
Dano (12-06-2011), rfinkle2 (12-06-2011), silvapain (12-06-2011)
 Old 12-06-2011, 10:18 AM   #1983
hum....well get my SV outtta there Silva!!!
BTW I ran about 6 tanks of E35 through that valve and 6 tanks of E27 before that but I suppose any petrol will lube the valve up.
Silva could put a few gallons of that old time dyno fuel in there to see if there is any improvement.
yes hot wires, fuel...solid plan.
thinking a bit more....he and you have put thousands of miles on your SVs before you saw any seemingly permanent issues such as this. Then he installs my SV and IIRC he said his pressure was fine but then a day or two later this issue arises.
I just don't see that valve getting worn out in that short of time.
maybe he'll chime in to confirm the new valve did in fact work for a period of time.
Last edited by Dano; 12-06-2011 at 10:18 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-06-2011, 10:20 AM   #1984
LOL. No, I got a junkyard pump in and that's the spill valve currently in my car (and possibly fucked). I'll be sending yours back to you tomorrow hopefully.
I might try bypassing the resistor as a test to see if that fixes the issue.
 Old 12-06-2011, 10:23 AM   #1985
The spill valve worked perfectly for several days and then this happens suddenly.
I checked my HPFP tables and everything looks good
 Old 12-06-2011, 10:33 AM   #1986
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I know who might have some insight on this, but dare I mention his name?
I tried to contact him already about my chirping, but noone answers their pm's on Cobb's forum.
 Old 12-06-2011, 10:37 AM   #1987
The fact that it changes at 3000 RPM every single time, and if I keep RPMs above 3000 I don't have any pressure issues, tells me that something is changing from the control system at this point. Whether it's the ITFP speed changing, or the voltage/amperage on the spill valve, or something else I don't know.
 Old 12-06-2011, 10:38 AM   #1988
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
what about adding marvel mystery oil to help keeps things lubed ?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 12-06-2011, 10:42 AM   #1989
IIRC Silva already runs MMO
 Old 12-06-2011, 10:44 AM   #1990
Yep. I follow the bottle and use 4oz for every 10 gallons.
phate (12-06-2011)
 Old 12-06-2011, 10:56 AM   #1991
ok...back to the SV...I don't see one failing that quickly considering you guys have run them for thousands of miles without this issue...and after a few days one is gonna fail, and begin to work at the exact RPMs each time...isn't this a new failure mode?.
sounds like software to me.
just resave your map and reflash no matter what the tables appear like. it takes 5 minutes.
maybe even change some values in the HPFP tables just to get a different byte size on the map.
phate (12-06-2011)
 Old 12-06-2011, 11:23 AM   #1992
Eth Fiend
phate's Avatar
I know for a fact it is not tune related. I am back on 93 octane for a tank (idk why). But, while I'm on 93, I'm doing some testing.
Before I filled up with 93, my car was VERY hard to start because the spill valve solenoid (SVS?) doesn't like to work when it's cold. It would take a few tries. Once started, it wouldn't work unless above ~3k rpm. While cold and below 3k rpm, it would not work. Once warmed up, it would work fine unless I tried getting into boost below 3k rpm, then it would stop working.
On 93, i have NONE of these issues. The car fired on the first crank this morning, had good HPFP pressure, and never once had an issue.
-06 MS6
Alpha (12-06-2011), Dano (12-06-2011), kritz (12-06-2011), silvapain (12-06-2011)
 Old 12-06-2011, 11:28 AM   #1993
ok boss...very strange.
so do you think the valve doesn't get ruined it just doesn't have enough lube to free itself?
phate (12-06-2011)
 Old 12-06-2011, 11:29 AM   #1994
Enki's Avatar
Groans: 189
Reflashing the exact same map can rule out a potential bug in logic, though. Perhaps there is something going on we can't see.
I only suggested this as there were a couple of times I was having problems and broke the pump down, cleaned it, and flashed a modified map (back when you were helping with my leaky CAL) only to find that my pump was clean; yet for some reason it still helped for a few hundred miles.
 Old 12-06-2011, 11:58 AM   #1995
That's EXACTLY the same issue I'm having right now.
I have a new beta map from COBB now too, so I will try a reflashed map of mine and their map before trying anything else, just to rule out software as a cause.
phate (12-06-2011)
 Old 12-06-2011, 12:01 PM   #1996
How about adding some more 93 until you don't see this issue and then go back to the higher concentration of e85 untill you can duplicate the fp problem. Just a thought.
The Following 2 Users Say Thank You to kritz For This Useful Post:
Ckmazdaspeed3 (12-06-2011), phate (12-06-2011)
 Old 12-06-2011, 12:02 PM   #1997
Eth Fiend
phate's Avatar
I've recompiled my E85 tune(s) in fresh maps a couple different times, so I think it is highly unlikely. I'm going to break out the multimeter tonight to see if I can spot anything interesting with the spill valve as rpm's rise.
-06 MS6
 Old 12-06-2011, 12:14 PM   #1998
Could this be temperature related? Does it change once the car warms up or if it idles for a while?
To test "lubrication" and if the issue is reproduced all the time, coat the spill valve parts in assembly lube. Of course this is given if taking it apart in itself doesn't temporarily also fix the problem.
A scope will give you a good idea about what the control system is doing.
Unfortunately no E85 in Western Canada so I can't play with the good stuff
phate (12-06-2011)
 Old 12-06-2011, 12:17 PM   #1999
The issue started for me after the car sat outside for 24 hours while I was out of town for work. However, it was also an issue this morning after sitting overnight in my heated garage.
I don't have enough data on this issue in my car to be able to tell if it's temperature related.
Lex (12-06-2011), phate (12-06-2011)
 Old 12-06-2011, 12:23 PM   #2000
Eth Fiend
phate's Avatar
Some of this seems to be temperature related. The cold starts being a bitch is definitely temp related.
But at the same time, I've had the car stop building fuel pressure when under 3k rpm after driving it for hours, so no temp dependency in that case. I think there is a temperature variable associated with how much gunk is in the spill valve.
-06 MS6
Lex (12-06-2011), silvapain (12-06-2011)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.60832 seconds with 34 queries
