Like Tree247Likes
 Old 12-06-2011, 12:26 PM   #2001
Some of this seems to be temperature related. The cold starts being a bitch is definitely temp related.
But at the same time, I've had the car stop building fuel pressure when under 3k rpm after driving it for hours, so no temp dependency in that case. I think there is a temperature variable associated with how much gunk is in the spill valve.
Have you experimented with how much E85 mixture % wise is required for these issues to rear their head?
kritz (12-07-2011), phate (12-06-2011)
 Old 12-06-2011, 12:41 PM   #2002
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Nope, I've been having too much fun when everything does work properly, which is the majority of the time
-06 MS6
-Corn fed 07 MS3 - Sold
Alpha (12-06-2011), GLORIFIEDBOZO (12-06-2011)
 Old 12-06-2011, 01:50 PM   #2003
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I think that people have gone as high as 50/50, or jump straight to 100%.
I think (correct me if I'm wrong) it may be relatively safe to say any mixture up to 50% has been tested, but somewhere between 50% and 100% is the gray area of spill valve fail.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
Boost_creep (12-06-2011), djuosnteisn (12-06-2011), phate (12-06-2011)
 Old 12-06-2011, 02:14 PM   #2004
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
I don't think (correct me if I'm wrong), but it may be relatively safe to say any mixture up to 50% has been tested, but somewhere between 50% and 100% is the gray area of spill valve fail.
25% worked great for me. 2.5 gallon gas tanks are also MUCH easier to work with than 5 gallon tanks IME. You only need so much to reap the benefits.
The Following 2 Users Say Thank You to Alpha For This Useful Post:
phate (12-06-2011), rfinkle2 (12-06-2011)
 Old 12-06-2011, 02:24 PM   #2005
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
It would be nice to consolidate all of the E85 issues (or lack thereof) in a spreadsheet or something, with people stating what percentage(s) E85 they run, for how many miles, what problems they've encountered and when, and what they have tried to address them. It would also be a good way to track LT issues that may arise later for guys only running 2-3 gallons/tank. Just some food for thought.
The Following 3 Users Say Thank You to dougefresh_ For This Useful Post:
GLORIFIEDBOZO (12-06-2011), phate (12-06-2011), rfinkle2 (12-06-2011)
 Old 12-06-2011, 02:39 PM   #2006
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
50/50 mix cleared up ALL of my fueling issues.
The Following 6 Users Say Thank You to Enki For This Useful Post:
Alpha (12-06-2011), dougefresh_ (12-06-2011), JLee1469 (12-06-2011), phate (12-06-2011), rfinkle2 (12-06-2011), silvapain (12-06-2011)
 Old 12-06-2011, 02:45 PM   #2007
Eth Fiend
phate's Avatar
I do love Excel...
dougefresh_ and rfinkle2 like this.
-06 MS6
dougefresh_ (12-06-2011), GLORIFIEDBOZO (12-06-2011), JLee1469 (12-06-2011), rfinkle2 (12-06-2011)
 Old 12-06-2011, 04:03 PM   #2008
Boost_creep's Avatar
Posts: 829   (View Stats)
Boost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the world
I have been thinking about trying only 1-2 gallons, after I'm all done tuning with Dano. I say 2 gallons max because I really don't want to run into any issues or alter my maf table. I really just want to run it as a knock deterent.
I figured that on the straight pump gas, it will be easier to find mbt, then once were done tuning throw in a gallon per fill up.
Opinions?
www.dizzytuning.com
www.facebook.com/dizzytuning
Boost_creep is offline   Reply With Quote
 Old 12-06-2011, 04:14 PM   #2009
Opinions?
You won't hit MBT on pump gas; you'll hit knock well before then. The benefit of E85 mixes is to let you run more timing, so if you want to run a mix you should put it in now and have Dano tune for it.
The Following 5 Users Say Thank You to silvapain For This Useful Post:
Boost_creep (12-06-2011), djuosnteisn (12-06-2011), dougefresh_ (12-06-2011), GLORIFIEDBOZO (12-06-2011), phate (12-06-2011)
 Old 12-06-2011, 04:40 PM   #2010
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
Groaned at 8 Times in 2 Posts
Well, I tested my car on the dyno today with a 75/25 mix of E85/93.
With 50/50 mix, I ran a 1.2 fuel adjustment scalar (you guys don't have this yet) and did about 305WHP/385WTQ.
With a 75/25 mix, i ran a 1.3 fuel adjustment scalar and did the same 305/385 pulls.
Just if you guys were wondering if going full E85 over a 50/50 was worth the issues you're currently seeing...
My money, as it stands now, is that it isn't worth it. You can run timing all the way to MBT on just a 50/50 mix and have none of the problems associated with running higher corn content. (spill valve issues, black gunk, etc)
Now, if we can figure out what the cause of the issues really are, I'd run full E85 just so I didn't have to fill up on two different pumps and because E85 is cheaper. Other than that, I'm going to stick with 50/50.
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD!
2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car
Evan@COBB is offline   Reply With Quote
The Following 22 Users Say Thank You to Evan@COBB For This Useful Post:
Alpha (12-06-2011), atvfreek (12-06-2011), BigjohnB20 (12-07-2011), BlueStreak (12-07-2011), Boost_creep (12-06-2011), Bucker (12-07-2011), charlesfist (12-15-2011), Ckmazdaspeed3 (12-11-2011), Dano (12-06-2011), djuosnteisn (12-06-2011), dougefresh_ (12-06-2011), Easter Bunny (12-07-2011), Enki (12-06-2011), jracer (12-07-2011), Nataphen (12-06-2011), Nliiitend1 (01-02-2012), phate (12-06-2011), Pu Manchu (12-06-2011), rfinkle2 (12-06-2011), Speed_j23 (12-06-2011), superskaterxes (12-06-2011), wolly6973 (12-06-2011)
 Old 12-06-2011, 04:48 PM   #2011
Enki's Avatar
Groans: 189
So you did muck with timing and didn't see any gains above 50/50?
phate (12-06-2011)
 Old 12-06-2011, 04:48 PM   #2012
Hmm. Thanks for that info.
I was just under the impression that tuning with e85 is kinda hard because you will not even get a hint of knock, and cause you to overshoot mbt.
www.dizzytuning.com
The Following User Says Thank You to Boost_creep For This Useful Post:
 Old 12-06-2011, 05:00 PM   #2013
Evan@COBB's Avatar
I didn't mess with the timing when moving from 50/50 to 75/25.
On a 50/50 mix, I can push timing all the way up to MBT, no problem, without knock. What this showed was that by simply increasing the ethanol content on the same map, no gains were found. I can still push up to MBT no problem but don't gain anything by it.
The Following 6 Users Say Thank You to Evan@COBB For This Useful Post:
dougefresh_ (12-06-2011), jracer (12-07-2011), Nataphen (12-06-2011), phate (12-06-2011), Speed_j23 (12-06-2011), wolly6973 (12-06-2011)
 Old 12-06-2011, 05:02 PM   #2014
Posts: 9,484   (View Stats)
we would just need to get your VD plots to work which probably means you would need to find a better location but we could put together a conservative E25 tune. easy peasy and it would be a different car.....but we currently have bigger fish to fry
but by making that change you moved MBT, no? so you need more timing to find it.
i agree that there is probably little gain for all the trouble.
Last edited by Dano; 12-06-2011 at 05:02 PM. Reason: MSF Database - Automerged Doublepost
The Following 10 Users Say Thank You to Dano For This Useful Post:
Alpha (12-06-2011), atvfreek (12-06-2011), Boost_creep (12-06-2011), Ckmazdaspeed3 (12-11-2011), dougefresh_ (12-06-2011), Nataphen (12-06-2011), phate (12-06-2011), rfinkle2 (12-06-2011), silvapain (12-06-2011), Speed_j23 (12-06-2011)
 Old 12-06-2011, 05:06 PM   #2015
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Man... that's weird. As i understand it... ethanol has 2 benefits: 1) the obvious increase in octane (which is actually higher when mixed with petrol than pure e85) and 2) the fact that it's oxygenated... which means it offers more power potential when mixed with the same amount of oxygen as petrol.
I wonder if there are 2 opposing forces at hand... like the power gained from additional e85 was negated from the necessary longer IPW and shittier burn in the cylinder.
Hard to say... but very interesting comparison man.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 7 Users Say Thank You to djuosnteisn For This Useful Post:
BigjohnB20 (12-07-2011), Boost_creep (12-06-2011), dougefresh_ (12-06-2011), jracer (12-07-2011), phate (12-06-2011), rfinkle2 (12-06-2011), Speed_j23 (12-06-2011)
 Old 12-06-2011, 05:30 PM   #2016
FUEL INJECTOR SCALAR!!!!!!!!!!
The Following 6 Users Say Thank You to superskaterxes For This Useful Post:
djuosnteisn (12-07-2011), dougefresh_ (12-06-2011), jracer (12-07-2011), phate (12-06-2011), silvapain (12-06-2011), Speed_j23 (12-06-2011)
 Old 12-06-2011, 05:33 PM   #2017
Eth Fiend
phate's Avatar
I'm not terribly surprised you didn't see any change without changing timing. My power changed very little the closer I got to MBT. SO, even if MBT moved going from 50/50 to your higher mixture, the resultant change in power would be miniscule. From the low eth mixes I've tuned, I don't think we're looking at more than a 5-10hp advantage from 50/50 to straight E85. It is, as you said, much simpler at the pump.
Another note: From some of the eth tunes I have done, I noticed that switching to ethanol with the same boost and timing actually resulted in slightly less power. It did take a little more timing to even things out. And of course, the ethanol allowed us to take timing well beyond what 93 allows. That's just my general observation from a few cars - but the conditions are, of course, not controlled like on a real dyno.
Evan, what sort of timing curve were you running, if you don't mind divulging some secrets
Bucker likes this.
-06 MS6
Alpha (12-06-2011), Bucker (12-07-2011), dougefresh_ (12-06-2011), jracer (12-07-2011), Speed_j23 (12-06-2011)
 Old 12-06-2011, 06:15 PM   #2018
rfinkle2's Avatar
Groans: 298
Evan's timing curve (as posted in user name xlt_66's thread)
edit : Atvfreek linked to the thread below
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (12-06-2011), Dano (12-06-2011), Nataphen (12-06-2011), phate (12-06-2011), wolly6973 (12-06-2011)
 Old 12-06-2011, 06:15 PM   #2019
atvfreek's Avatar
Posts: 7,787   (View Stats)
276HP/318TQ - Cobb AWD Mustang Dyno
This is the timing table he was running before.
Edit. Finkle beat me to it. Lol
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
 Old 12-06-2011, 07:12 PM   #2020
holy mid-range timing batman haha
atvfreek (12-06-2011), rfinkle2 (12-06-2011)
 Old 12-06-2011, 08:55 PM   #2021
Eth Fiend
phate's Avatar
lol, my car and the other full E85 car I had on the dyno both run more timing over the entire rpm range
-06 MS6
Alpha (12-07-2011), atvfreek (12-07-2011), mazdafreak (12-07-2011), rfinkle2 (12-07-2011)
 Old 12-06-2011, 09:10 PM   #2022
Damn, I wish I could run that last line of timing. I don't spend enough time under a load of 2.0 to care about the rest, lol.
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
 Old 12-06-2011, 09:18 PM   #2023
Eth Fiend
phate's Avatar
It's the power of the E!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
-06 MS6
atvfreek (12-07-2011), dougefresh_ (12-06-2011), rfinkle2 (12-07-2011)
 Old 12-06-2011, 10:02 PM   #2024
Got a datalog of my fuel pressure issues tonight. Note this is with the COBB beta map, so the MAF is NOT scaled, and g/s are actual values.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
atvfreek (12-07-2011), kritz (12-07-2011), Nataphen (12-07-2011), phate (12-06-2011)
 Old 12-07-2011, 03:55 AM   #2025
hamptotl's Avatar
Posts: 677   (View Stats)
hamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the world
Wow I am a little late to post this but what the hell.
I run a 5/7 mix of 85/93. Ewhatever the fuck that equates to lol. Anyways I have been working with Dustin on my tune for a while now.
We are at a point of 20* at redline number before that really arent important as of now LOL. My local pump was out of E85 and I was curious. I do run 100% meth and a DO7 so I wasnt to scared but still concerned and said what the hell.
I did three WOT runs with no E85 on my VD road to see what happened. When I compared the pulls to my E85 maps I lost an average 20 hp and 35ft/lbs.
I didnt have an ounce of knock and the car felt slow as shit lol. But the e85 on the exact same map netted much more power.
At this point I am thinking that Dustin kind of hit the Nail on the head. I think 100% e85 would be awesome for ease of fill ups, but I believe that for the most reliable and powerful tune we need to find that happy medium. Where can we get the highest power and no issues. I dont know just throwing it out there.
NatorVA07 1995 Miata M
Sway bars end links butterfly brace bilsteins with sleeves and Jackson Racing Header.
hamptotl is offline   Reply With Quote
The Following 7 Users Say Thank You to hamptotl For This Useful Post:
charlesfist (12-15-2011), Ckmazdaspeed3 (12-11-2011), djuosnteisn (12-07-2011), dougefresh_ (12-08-2011), rfinkle2 (12-07-2011), RichieRichness (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 08:15 AM   #2026
Cleaned my spill valve twice last night. Seems to have fixed my issues for now.
By the way, preliminary results on the new COBB global fuel scalar are promising.
The Following 12 Users Say Thank You to silvapain For This Useful Post:
Alpha (12-07-2011), Ckmazdaspeed3 (12-11-2011), djuosnteisn (12-07-2011), dougefresh_ (12-08-2011), Enki (12-07-2011), Evan@COBB (12-07-2011), GLORIFIEDBOZO (12-07-2011), jracer (12-07-2011), kritz (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 08:41 AM   #2027
Evan@COBB's Avatar
What are your trims looking like? Did David send you several versions of the scalar to try out?
The Following User Says Thank You to Evan@COBB For This Useful Post:
 Old 12-07-2011, 09:05 AM   #2028
Yes, David sent me a 40% and 45% scalar map. I'm using the 40% one right now.
My LTFTs are a bit jacked up due to my spill valve issues, but I've been watching my STFTs as well and it's looking really good. I need to adjust my MAF a bit, as E85 seems to be much more sensitive to small deviations in the MAF scale (saw this on my previous tunes as well). What looks promising is that my idle AFRs are dead on 1.0 lambda, and idle AFR is a value that hasn't been revealed for us to modify yet. This makes me confident that my AFRs will be good for any other fuel tables not yet revealed.
David also confirmed for me that as long as I leave the "keep non table values" box checked in ATR, I can modify the beta maps without messing them up.
The Following 9 Users Say Thank You to silvapain For This Useful Post:
Dano (12-07-2011), dougefresh_ (12-08-2011), GLORIFIEDBOZO (12-07-2011), jracer (12-07-2011), kritz (12-07-2011), phate (12-07-2011), rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 09:59 AM   #2029
Since you are scaling the inj opening time up by 40% then changes in PW are greater per each MAF step change - so basically it's like throwing on larger injectors on a car. Your load sensor resolution drops.
djuosnteisn (12-07-2011), dougefresh_ (12-08-2011), Nataphen (12-07-2011), silvapain (12-07-2011)
 Old 12-07-2011, 10:04 AM   #2030
That's essentially what I was thinking. Since I'm running 40% more fuel, I should expect an increase of 40% in all my fuel trims over pump gas.
 Old 12-07-2011, 11:22 AM   #2031
Captain
Groans: 79
I have 2 maf cal logs, with my previous map and a 20% scaled map, same tank of gas... and the results are almost perfect.... ~-17 LTFT's... ish. I'll compile the data and post up the actual comparisons later today.
I think we need a new thread for the results of the beta scaling stuff, if there isn't one already. Should we keep in the e85 section? Anyone wanna start a thread? If so, add a link here and i'll post my data there. I don't have time right now to start a thread.
Also, soon, i'll be doing some A-B comparisons between the two maps with my oscilloscope on the ms3 (similar to what i did on my 6 a while back), so we can visually see exactly what's going on.
I'm hoping these adjustments are resulting in the injector actually opening up sooner (into the tail end of the exhaust stroke), rather than simply staying open longer. That could be very promising indeed
www.permtuning.com
The Following 9 Users Say Thank You to djuosnteisn For This Useful Post:
Alpha (12-07-2011), Dano (12-07-2011), dougefresh_ (12-08-2011), Enki (12-07-2011), jracer (12-09-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), silvapain (12-07-2011), wolly6973 (12-07-2011)
 Old 12-07-2011, 12:52 PM   #2032
What I am hoping to see is the ability to move the opening time (injection timing) so that we can move it further into the intake stroke as increase VVT in the upper/load RPM. 20* of VVT can mean 10% larger injection window which is significant ... unless of course the stock ECU already moves injection timing with VVT.
Waiting for results on this. Dustin, did you ever scope the VVT effect on injector timing?
The Following 6 Users Say Thank You to Lex For This Useful Post:
Alpha (12-07-2011), Dano (12-07-2011), djuosnteisn (12-07-2011), dougefresh_ (12-08-2011), Nataphen (12-07-2011), Nliiitend1 (01-02-2012)
 Old 12-07-2011, 12:52 PM   #2033
Enki's Avatar
Groans: 189
Made a beta scaling thread here:
COBB AP/ATR Beta Fuel Scaling - Mazdaspeed Forums
djuosnteisn (12-07-2011), dougefresh_ (12-08-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011), silvapain (12-07-2011)
 Old 12-07-2011, 01:00 PM   #2034
Captain
Groans: 79
I scoped the CAM signal.... and as i remember, we surmised that the injection event always started right when the intake valve opened.... so i guess the injection event moved around with VVT.
I'd have to go back and read through our injector thread, or at least watch a few of the videos.
Thanks
I'll throw my little bit of data together right meow and post it up.
www.permtuning.com
Enki (12-07-2011), Nataphen (12-07-2011)
 Old 12-07-2011, 05:09 PM   #2035
Evan@COBB's Avatar
Have any of you guys running E85 pulled your air filter to have a look at your intake lately?
I just found a puddle of oil that was leaking OUT of my filter, into the engine bay, coated my TIH, turbo, IC piping, etc.
Never seen this before and it smells like corn. Granted, I did just track the crap out of my car and I need an oil change... (That's right, a full track day on E85 and it performed like a champ!)
Just wondering if anyone else has seen an increase in blowby is all...
The Following 5 Users Say Thank You to Evan@COBB For This Useful Post:
djuosnteisn (12-07-2011), dougefresh_ (12-08-2011), kritz (12-07-2011), Nataphen (12-07-2011), rfinkle2 (12-07-2011)
 Old 12-07-2011, 05:17 PM   #2036
Posts: 7,290   (View Stats)
I'll check it this weekend, I was on the track on Sunday with doublefusher and we got in a dozen runs. I'll be doing an oil change and want to send it to Blackstone for a check. Plan on doing a seafoam treatment prior to the oil change.
Nator is what it does.
 Old 12-07-2011, 05:22 PM   #2037
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Sounds like someone needs an occ on thier valve cover breather.
tapatawk
Etipp98 is offline   Reply With Quote
The Following User Says Thank You to Etipp98 For This Useful Post:
 Old 12-07-2011, 05:22 PM   #2038
I'm running an OCC, and I haven't noticed any E85 in the crap it collects.
 Old 12-07-2011, 05:23 PM   #2039
Captain
Groans: 79
Congrats on the new BT Dude!!!
Or should i wait a few more weeks before i say that? Haha. Do you have any increased shaft play in that k04? My guess is it's the source of the oil. And the corn smell is simply from blow by. Just like the oil on non-e85 cars wreaks like fuel.
And i'm still undecided if i like or dislike the smell of e85... but i have to admit, it sure is potent lol.
www.permtuning.com
 Old 12-07-2011, 06:54 PM   #2040
Eth Fiend
phate's Avatar
No, sir. Almost 18k miles on straight E85 without that issue (knock on wood). 67k miles on the car, and I've never had the issue (no occ, either).
Damn, as I posted that, I realized I started running straight E85 in May with 49k miles.....so 18k miles in about 7 months
kritz likes this.
-06 MS6
Dano (12-07-2011), rfinkle2 (12-08-2011)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.65661 seconds with 36 queries
