Like Tree247Likes
 Old 12-12-2011, 09:08 AM   #2081
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
anyone know where the thread is with the 3 different 3 bar sensors P/N and associated ATR scalars?
IIRC it was started by JumpinJackson and I thought I had it in my tech folder but can't find it.
Stock Fitment 3 Bar Map Sensor Upgrade
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (12-13-2011), Dano (12-12-2011), MattJackson86 (12-14-2011), Nataphen (12-12-2011), phate (12-12-2011)
 Old 12-12-2011, 09:12 AM   #2082
FWIW, I'm running 65.78, 1.00, and 5.41 offset for my -845 3-Bar MAP sensor. I had to adjust the offset down from 5.44 to get it to read right with the car off.
Dano (12-12-2011), Nataphen (12-12-2011), rfinkle2 (12-12-2011)
 Old 12-12-2011, 09:17 AM   #2083
Posts: 9,484   (View Stats)
awesome Finkle!
 Old 12-12-2011, 10:21 AM   #2084
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Groaned at 25 Times in 25 Posts
Im just using the suggested values by cobb on my 3.5..everything seems to be ok. Maybe its really not though LOL
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
The Following User Says Thank You to bewsted For This Useful Post:
rfinkle2 (12-14-2011)
 Old 12-12-2011, 10:30 AM   #2085
It's linear, so as long as your idle vacuum is good and it's reading ~0 with the engine off you're fine.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
Dano (12-12-2011), GLORIFIEDBOZO (12-13-2011), rfinkle2 (12-14-2011), wolly6973 (12-14-2011)
 Old 12-12-2011, 10:52 AM   #2086
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Todd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the world
I attached a log of my latest map, its a 20% E85 with 91 octane mix. Targeting 11.6 AFR's and my timing is the same as Evan@Cobb's minus 2 degrees across the board, 19-19.5 psi tapering to 17.5 at redline.
Does anyone know why the throttle closes slightly around 5200rpm? This has only starting happening after I switched to E85. All of my load tables are out of reach so I don't think its load related.
Thanks,
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
The Following User Says Thank You to Todd98SE For This Useful Post:
 Old 12-12-2011, 11:06 AM   #2087
is your LD table neutered? IIRC LD=TPS adjustment and LEC=WGDC adjustment.
even though you say your load tables are out of reach, my first guess is you are now going over a load limit with the E85.
check your load baro/RPM table...that one got me a while back.
rfinkle2 (12-12-2011), RichieRichness (12-15-2011), silvapain (12-12-2011), Todd98SE (12-12-2011)
 Old 12-12-2011, 11:28 AM   #2088
Todd98SE's Avatar
Yes, LD is zero'd out as well as LEC. Load baro/RPM was set to 2.8 but just for fun I moved everything load related to 5.0. I'll see if that solves the problem later today.
Can minute amounts of wheelspin cause this? I always forget to turn off DSC.
Thanks,
www.MOTOIQ.com
Beater Titan
 Old 12-12-2011, 11:51 AM   #2089
Thanks,
absolutely
 Old 12-12-2011, 12:03 PM   #2090
Todd98SE's Avatar
absolutely
That is probably the problem then. Never thought I'd have to worry about 3rd gear wheelspin until I went BT, thank you E85! I'll have to make it a habit to turn off DSC when I start the car until Cobb can find those tables.
Thanks Dano,
www.MOTOIQ.com
Beater Titan
The Following 3 Users Say Thank You to Todd98SE For This Useful Post:
mazdafreak (12-12-2011), rfinkle2 (12-12-2011), RichieRichness (12-15-2011)
 Old 12-13-2011, 01:08 PM   #2091
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
im on about page 30 in this thread thanks for all youre efforts all you guys. i filled up today with 3.5 gal e85 to a full tank of 91 octane. i am using a cobb ots stage 91 cai tip tune to work off of. i scaled the maf to add 10 percent more fuel and have leaned out my targeted afr to about 11.8 is that a good way to start? any advice is appreciated.
https://www.facebook.com/NorCalTintZone
instagram: sharpdetails
GoSpeed3Go is offline   Reply With Quote
The Following User Says Thank You to GoSpeed3Go For This Useful Post:
 Old 12-13-2011, 01:34 PM   #2092
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
That's a fine way to start. I've done that exact mix on a 2011 and picked up a TON of power over straight 91.
-06 MS6
-Corn fed 07 MS3 - Sold
GoSpeed3Go (12-13-2011), rfinkle2 (12-14-2011)
 Old 12-13-2011, 04:21 PM   #2093
GoSpeed3Go's Avatar
right on man im stoked to try this shit out now that theres some experience with it.
 Old 12-13-2011, 05:44 PM   #2094
AzSpeedin's Avatar
Posts: 47   (View Stats)
AzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to behold
I spent like 2 hours reading the VW forums saying "You can't run it" "Yes you can" "Evo's run it"
Those guys aren't trying to hard for having a year on us to have figured things out.
I have to a add to the e85 thread. With mods listed below w/ a maxed out 91 tune I have experienced some unreal butt dyno improvement with only E30. I'm short of saying this was the single biggest improvement in hp/tq, us 91 guys will see a greater improvement. I'm running minus 1-2 degrees off of Evans@cobb tune, with a make of 18 degrees. I do not have a dyno or ap run, as it has been raining in AZ for 2 days. I had to give my to cents, the power is unbelievable and it seems to not drop off to redline although I'm sure it does. Btw my lifts r within 2 and highest knock I've seen was a .7 although that was in the rain. I'll run some logs in the nxt day or so and dial the tune in.
Early 2010
Ap 91 e85 18 degrees
Ets
Obx test
Corksport intake tip
Autotech
Rmm
AzSpeedin is offline   Reply With Quote
The Following 2 Users Say Thank You to AzSpeedin For This Useful Post:
phate (12-13-2011), rfinkle2 (12-13-2011)
 Old 12-13-2011, 06:42 PM   #2095
bewsted's Avatar
Yea.... I stopped running it on my k04 before xmt66 got pro tuned and was running identical timing to his Cobb pro tune. 50/50 rips hard
EWG K04...GETSUM!
 Old 12-13-2011, 07:42 PM   #2096
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Early 2010
Ets
Obx test
Autotech
Rmm
You join nator AZ yet?
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 12-13-2011, 08:11 PM   #2097
GoSpeed3Go's Avatar
i plan on going 50 50 once i can get a better feel on how it works with this car. anything a e85 newb should watch for even on a little mix like im running as far as fuel trims or afrs?
 Old 12-13-2011, 08:18 PM   #2098
Eth Fiend
phate's Avatar
Not really. The tuning strategy is the same as gas. The only "problem": Addiction
-06 MS6
GLORIFIEDBOZO (12-13-2011), GoSpeed3Go (12-13-2011), mazdafreak (12-13-2011), rfinkle2 (12-14-2011)
 Old 12-13-2011, 08:27 PM   #2099
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
I'm not an addicted!!!
The Following User Says Thank You to GLORIFIEDBOZO For This Useful Post:
 Old 12-13-2011, 08:34 PM   #2100
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
I'm addicted!!!!!! Sucks back on 93 for winter....car is so slow
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 12-13-2011, 09:13 PM   #2101
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
That is probably the problem then. Never thought I'd have to worry about 3rd gear wheelspin until I went BT, thank you E85! I'll have to make it a habit to turn off DSC when I start the car until Cobb can find those tables.Thanks Dano,
For the speed6 you can wire DSC so that the default is to have it 'off' when you start the car, and turn it on by hitting the button (reversed from stock). I bet you can do the same w/ the MS3, but I'm sure it's different, and have no idea if there's a how to for it. I dont think that's high on Cobb's list.
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
rfinkle2 (12-14-2011), Todd98SE (12-15-2011)
 Old 12-14-2011, 06:57 AM   #2102
AzSpeedin's Avatar
Addicted here, with spare fuel tanks at the ready! Not joined az nator, been here for a while and enjoy being a lurker but I may consider it. Thanks
The Following User Says Thank You to AzSpeedin For This Useful Post:
 Old 12-14-2011, 09:15 AM   #2103
GoSpeed3Go's Avatar
freekin crazy stft this morning in the cold 16+- at part throttle lol probably notthe best.
 Old 12-14-2011, 09:19 AM   #2104
Doesn't matter - STFTs fluctuate all the time. Don't max out LTFTs and make sure AFRs at WOT are safe instead.
dougefresh_ (12-14-2011), GoSpeed3Go (12-14-2011), rfinkle2 (12-14-2011)
 Old 12-14-2011, 09:28 AM   #2105
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
STFT change based on any number of variables, and will generally shift pretty good as the engine comes up to temp.
 Old 12-14-2011, 05:55 PM   #2106
GoSpeed3Go's Avatar
welp heres my first log on my 3.5 e85 mix pretty happy i hit my fuel targets pretty good and that new pump is working well any tips or advice. felt good but not all that crazy as of yet obviously. gonna 50/50 probably next fill up.
had my buddy with me hitting the buttons on the ap for me while logging hes got a 400hp e85 evo mr. he said i got alot of catching up to do. lol
 Old 12-14-2011, 05:58 PM   #2107
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
You need more boost and much more timing to get the "crazy" out of it.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
 Old 12-14-2011, 06:06 PM   #2108
GoSpeed3Go's Avatar
yeah im gonna finish reading through this thread tonight on page 32 i think. then ill start turning up some boost and timing very carefully.
 Old 12-14-2011, 07:16 PM   #2109
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
I'm running leaner, more boost, and more timing on 93 octane than you are there. Put the fire to it, sir. 12.2 AFR, 19-20psi, this timing from 2500-6500 is where you should start:
0.00 7.00 7.00 10.00 10.00 11.50 15.00 17.00 18.80
I ended up here on just 2 gallons of e85.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
The Following 2 Users Say Thank You to Nataphen For This Useful Post:
GoSpeed3Go (12-14-2011), wolly6973 (12-15-2011)
 Old 12-14-2011, 08:12 PM   #2110
mrmonk7663's Avatar
I wouldn't ramp timing like that personally. It is better to step it up than command the same values over multiple cells. Makes for a smoother curve and smoother power delivery, and allows you to pinpoint knock points easier. With timing, you go slow. Each car reacts differently.
The Following 4 Users Say Thank You to mrmonk7663 For This Useful Post:
Enki (12-14-2011), GoSpeed3Go (12-14-2011), Nataphen (12-14-2011), wolly6973 (12-15-2011)
 Old 12-14-2011, 08:32 PM   #2111
Eth Fiend
phate's Avatar
I definitely wouldn't consider that a starter curve.
-06 MS6
djuosnteisn (12-28-2011), Enki (12-14-2011), Nataphen (12-14-2011), wolly6973 (12-15-2011)
 Old 12-14-2011, 08:41 PM   #2112
Nataphen's Avatar
Groans: 31
Maybe that's a little ambitious, but he's running more e85 than I was and it's cooler outside now. I'm sure it wouldn't be too far off for a starting point. I would smooth it out more in the end too, but that's just where I ended up when I ran out of that tank of e85, and I still had no KR.
EDIT: Just so that you guys don't think that I'm retarded, here's an actual finished 93 octane tune's timing values from 2500-7000:
-1.00 0.80 3.36 5.40 7.45 9.13 10.55 11.76 12.88 13.99
Very conservative early in the RPMs because I'm still on the stock CDFP, but I do know how to make a smooth curve.
MattJackson86 likes this.
The Following 3 Users Say Thank You to Nataphen For This Useful Post:
GoSpeed3Go (12-14-2011), phate (12-14-2011), wolly6973 (12-15-2011)
 Old 12-14-2011, 08:56 PM   #2113
mrmonk7663's Avatar
LOL, that looks a bit better
 Old 12-14-2011, 09:16 PM   #2114
Nataphen's Avatar
Groans: 31
Yeah, I apologize for my momentary lapse of reason. The below values are what phate speculated to be about MBT through his dyno testing. It would probably be a good plan to not exceed these values, even if you still aren't getting KR.
2500-6500
-1 8 10 11.5 13 16.5 19.5 22 24
The Following User Says Thank You to Nataphen For This Useful Post:
phate (12-14-2011)
 Old 12-14-2011, 09:23 PM   #2115
Eth Fiend
phate's Avatar
2500-6500
Yessir. The only other E85 car I had on the dyno had an almost identical timing curve and made pretty much identical power to my car. He got some spark blowout before we reached my timing curve, but I'd bet it would have ended within .5° of it, considering the prior curves and power gains.
Also, the 2500 rpm value on my car is that low only because it is NOISY down there. It would pull kr through half of my rpm range if I went further. Yeah yeah, I could have increased kr offset, but the power down that low is WORTHLESS, so I chose to leave it low right there I'm betting you could get away with better than 6° right there.
-06 MS6
mazdafreak (12-15-2011), mrmonk7663 (12-15-2011), Nataphen (12-14-2011)
 Old 12-14-2011, 09:24 PM   #2116
GoSpeed3Go's Avatar
cool man ill give it a try. tommorow.
 Old 12-14-2011, 09:28 PM   #2117
Nataphen's Avatar
Groans: 31
The timing retard helps spool time anyway, even though the curve may not look as pretty. Not that the k04 needs that much help, just saying.
@phate, do you have an MBT number for 7k RPM timing? I know that there's no real reason to rev that high, I'm just curious.
phate (12-14-2011)
 Old 12-14-2011, 09:46 PM   #2118
GoSpeed3Go's Avatar
now when im pasting these values in atr i just input them in the lowest table [2.0 load] of the high throttle open loop table knock and no knock?
 Old 12-14-2011, 09:48 PM   #2119
Eth Fiend
phate's Avatar
I do not. Our K04 dies that high, and I shift at 5800 rpm, so I never took it past 6500ish.
-06 MS6
mazdafreak (12-16-2011), Nataphen (12-14-2011), wolly6973 (12-15-2011)
 Old 12-16-2011, 12:45 AM   #2120
mazdafreak's Avatar
Groans: 124
I'm getting bad lubrication to my pump every since 85 swap, but would be fine after priming pump a few times before cold start up.
And now I'm still getting it back on 93....@phate, I haven't cleaned the spill valve, like under it (actually taking the UFO thing off and cleaning underneath it), u think that's causing it??
713whp/569wtq!
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.61383 seconds with 36 queries
