Like Tree247Likes
 Old 12-16-2011, 12:52 AM   #2121
Schmitty5's Avatar
Posts: 979   (View Stats)
Schmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the world
subbing to come back to when I'm ready. wow 53 pages...
2010 MS3 - 13.42 at 107 - street tires - 306whp/338tq Moore automotive (dynojet)
Roadcoursing > all http://www.youtube.com/watch?v=GO-xoFpsgj4
Schmitty5 is offline   Reply With Quote
The Following User Says Thank You to Schmitty5 For This Useful Post:
RichieRichness (12-16-2011)
 Old 12-16-2011, 08:42 AM   #2122
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I'm getting bad lubrication to my pump every since 85 swap, but would be fine after priming pump a few times before cold start up.
And now I'm still getting it back on 93....phate, I haven't cleaned the spill valve, like under it (actually taking the UFO thing off and cleaning underneath it), u think that's causing it??
Odd. Yeah, I think I would take the spill valve completely apart and see what's going on with it. I'm back on 93 and haven't had a single issue (it's kinda nice, haha).
-06 MS6
-Corn fed 07 MS3 - Sold
mazdafreak (12-16-2011), rfinkle2 (12-16-2011)
 Old 12-16-2011, 08:46 AM   #2123
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Phate running 93 is like Jimmy Hendrix without his acid.
Yeah, he could probably play better than most, but the magic is gone.
The Following 7 Users Say Thank You to rfinkle2 For This Useful Post:
Boost_creep (12-16-2011), Bucker (12-27-2011), dougefresh_ (12-16-2011), GLORIFIEDBOZO (12-21-2011), phate (12-16-2011), superskaterxes (12-16-2011), wolly6973 (12-16-2011)
 Old 12-16-2011, 10:39 AM   #2124
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
But Jimmy is dead while Phate continues to mash on dose buttcheeks!
The Following 4 Users Say Thank You to RichieRichness For This Useful Post:
dougefresh_ (12-16-2011), mazdafreak (12-16-2011), rfinkle2 (12-16-2011), wolly6973 (12-17-2011)
 Old 12-16-2011, 11:08 PM   #2125
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
wow. finally finished reading through this thread 54 pages of greatness. i feel like i learned quite a bit about tuning this car from all the accumulated knowledge here. although im sure ill still have plenty of stupid questions to ask you guys. so be ready.
https://www.facebook.com/NorCalTintZone
instagram: sharpdetails
GoSpeed3Go is offline   Reply With Quote
The Following 3 Users Say Thank You to GoSpeed3Go For This Useful Post:
cld12pk2go (12-17-2011), mazdafreak (12-17-2011), rfinkle2 (12-17-2011)
 Old 12-18-2011, 07:28 PM   #2126
GoSpeed3Go's Avatar
so i added timing to my 3.5gal e85 mix tune, i havent really got alot of miles logged on this new revision. coming home tonight i figured i grab a 3rd gear log real fast. its a pretty wide turn to merge on the freeway once it straightened i gave it the go ahead felt some good spining initially! on my new gforce kdwv2s. how does this log look? all criticism and helped welcomed it looks like my fuel ratio is good but kinda wonky i know im targeting 11.7 and 18psi tapering down.
ps im loving e85 more and more.
The Following 2 Users Say Thank You to GoSpeed3Go For This Useful Post:
Dizzy Turbo (12-20-2011), rfinkle2 (12-18-2011)
 Old 12-18-2011, 07:32 PM   #2127
rfinkle2's Avatar
Groans: 298
Looks good, although you are probably going to be able to add some timing up top (later in the rpm band).
Starting to get a little rich @ the end, but welcome to the world of continuous tweaking.
GoSpeed3Go (12-18-2011), RichieRichness (12-19-2011)
 Old 12-18-2011, 07:49 PM   #2128
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Looks ok. Scale down the maf in the end range to bring you closer to target. You barely have any top end timing...you have lots of power waiting for you
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
GoSpeed3Go (12-18-2011), rfinkle2 (12-18-2011)
 Old 12-18-2011, 09:11 PM   #2129
GoSpeed3Go's Avatar
1.00 2.44 6.50 8.00 9.50 11.50 13.00 14.50 17.00
heres my timing @ 2500-6500rpm for my next tune revision
 Old 12-18-2011, 09:56 PM   #2130
mrmonk7663's Avatar
What was your previous timing?
 Old 12-18-2011, 10:04 PM   #2131
Eth Fiend
phate's Avatar
I've seen good 93 octane run that much up top
That's a solid curve so far.
-06 MS6
GoSpeed3Go (12-18-2011), rfinkle2 (12-19-2011), silvapain (12-19-2011)
 Old 12-18-2011, 10:46 PM   #2132
GoSpeed3Go's Avatar
not to sure maybe minus 1-2* near the middle on up.
 Old 12-19-2011, 06:25 AM   #2133
You can go leaner than 11.7. I was running 12.2 on straight 93 pump has.
GoSpeed3Go (12-19-2011)
 Old 12-19-2011, 11:16 AM   #2134
GoSpeed3Go's Avatar
yeah been thinkin bout goin 12.0 once i get things nice and smooth.
 Old 12-20-2011, 08:44 PM   #2135
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Ok, so I'm talking to a chemist about cars right now and particularly the effect of water condensation from ethanol weakening the internals of our engines. I was just curious if this was a major concern for us and if it has the possibility of shortening the lives of our engines?
 Old 12-20-2011, 08:52 PM   #2136
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
What specifically is he stating about "water condensation from ethanol"?
Is he talking about it carrying moisture into the cylinder in liquid form since it is hygroscopic or the fact that the combustion products are heavily water laden?
Neither is an issue IMHO.
The Following 2 Users Say Thank You to cld12pk2go For This Useful Post:
Ckmazdaspeed3 (12-20-2011), Enki (12-21-2011)
The Following User Says NO Thank You to cld12pk2go For This Un-useful Post:
AzSpeedin (12-21-2011)
 Old 12-20-2011, 08:58 PM   #2137
Groans: 134
To keep it simple, why is it your opinion that it is not an issue? To be clear, I'm trying to learn and understand here.
 Old 12-20-2011, 09:55 PM   #2138
Posts: 9,484   (View Stats)
WMI
Got to believe more H2O delivered via this method but I'm not a chemist. Lol.
Tappin
 Old 12-20-2011, 10:06 PM   #2139
Groans: 134
Damn, I need a chemist cuz I'm talking to a chemist! I am just curious how we don't have to worry about engine internals deteriorating due to ethanol?
I am curious about meth too though, because as far as I know (besides hydrolocking) meth/water mixing doesn't result in many blown motors at all?
 Old 12-20-2011, 10:17 PM   #2140
Groans: 134
And are flex fuel engines any different, or is it just the pumps and lines?
 Old 12-20-2011, 10:45 PM   #2141
Eth Fiend
phate's Avatar
Water condensation in a HOT ASS engine in an even HOTTER combustion chamber. Next.
Edit: WTF does this guy mean by "internals"? When we say internals, it means crank/rods/pistons and shit. I hope he means something else, lol.
Edit 2: When it comes down to it, we have no idea what long term affects E85 will have on our cars.
-06 MS6
Ckmazdaspeed3 (12-21-2011), kritz (12-21-2011), silvapain (12-21-2011), wolly6973 (12-21-2011)
 Old 12-20-2011, 10:51 PM   #2142
mrmonk7663's Avatar
We do know the short term effects of E85 on our cars though....POWER!!!
The Following 5 Users Say Thank You to mrmonk7663 For This Useful Post:
kritz (12-21-2011), phate (12-20-2011), rfinkle2 (12-21-2011), wolly6973 (12-21-2011)
 Old 12-21-2011, 05:43 AM   #2143
Eth/Meth Junkie
cld12pk2go's Avatar
I can only ASSuME that he thinks it is a risk that the alky/water will result in oxidation of the exposed metal in the combustion chamber leading to thinning/weakening over time. I would point out the millions of vehicle-years of operation with people running either E85 or water/meth injection as anecdotal evidence that this is a non-factor.
There certainly isn't any condensation going on at those temps in the combustion chamber as Phate mentioned.
Also, the normal combustion products of gas and oxygen are CO2 and water, so it isn't like there is now way more water in the combustion products than before (a little more due to the alky having relatively higher H/C ratio than gas, but nothing important).
The Following 3 Users Say Thank You to cld12pk2go For This Useful Post:
Ckmazdaspeed3 (12-21-2011), silvapain (12-21-2011), wolly6973 (12-21-2011)
 Old 12-21-2011, 05:49 AM   #2144
Posts: 7,290   (View Stats)
On point 2 you are correct Sir! But that is what they make full rebuilds for, I know that beating the crap out of my car on the track and autocross is not giving any extra life to the motor either, but I'm having fun! E85 just adds moar fun till zoomzoomboom.
Nator is what it does.
 Old 12-21-2011, 06:28 AM   #2145
Just the rubber compounds, higher flow injectors/pump, and the tune.
All the smart in this thread is giving me a stiffy.
 Old 12-21-2011, 06:30 AM   #2146
Ziggo's Avatar
Posts: 3,843   (View Stats)
Tell your chemist friend to head back in the lab. The engine probably ingests 10x as much water on a rainy day just through humidity in the air as what ethanol will carry with it.
The only possible in cylinder effect I can think of is the higher fuel requirement resulting in more cylinder wash down leading to loss of compression faster. And I would consider that a very low risk.
My concern over E85 has nothing to do with the fuel. It allows more timing and boost, allowing gobs more torque, increasing the stress on the rods, possibly past their fatigue limit.
Zigatapatalka
Ask Me About My:
The Following 6 Users Say Thank You to Ziggo For This Useful Post:
Ckmazdaspeed3 (12-21-2011), Enki (12-21-2011), kritz (12-21-2011), phate (12-21-2011), RichieRichness (12-21-2011), wolly6973 (12-21-2011)
 Old 12-21-2011, 06:45 AM   #2147
rfinkle2's Avatar
Groans: 298
Flex fuel vehicles also usually have an ethanol content analyzer built in and can adjust the tune if necessary.
Good thing to have given the variability of ethanol content from pump to pump and the winter vs. summer blends.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
 Old 12-21-2011, 06:54 AM   #2148
Groans: 134
Ok, so this came up in a drunken (buzzed is more accurate) debate last night when we were discussing my blown motor. I'll post up more later, but the current thought is that I was probably past mbt in the 4000-6000 range.
He mentioned that the engine was probably weakened (I used the word internals cuz Idk what else could be weakened) by water oxidizing the metals like 12 pack mentioned.
So, flex fuel engines don't have anything special done to them to help them withstand the effects of eth, right? The difference is in the fueling system, correct?
Thanks, replied while I was posting
Zigatapatalka
I think that rain comment should be a critical piece of info.
Last edited by Ckmazdaspeed3; 12-21-2011 at 06:54 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
kritz (12-21-2011), rfinkle2 (12-21-2011)
 Old 12-21-2011, 07:01 AM   #2149
Ziggo's Avatar
You are getting beyond my materials knowledge now, aluminum has a very tough oxidation layer on it that forms nearly instantly when exposed to air, water or no water. It's what makes it so resistant to corrosion and why you have to use a tig welder on it. I can't think of what e85 would be able to do to breach that layer that normal gasoline combustion would not do.
It sounds like you are thinking it would somehow make the materials brittle, like hydrogen embrittlement. I do not think that is possible. It's most likely the rod that failed, which isn't even directly exposed to combustion.
Zigatapatalka
Ask Me About My:
Ckmazdaspeed3 (12-21-2011), rfinkle2 (12-21-2011)
 Old 12-21-2011, 07:09 AM   #2150
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
does your chemist friend know that one of the resulting product of burning hydrocarbons is water? A lot of water is created.
Edit: beat to the punch by another chemical engineer. Chemical engineer >>>> chemist
Most chemists i've met are retarded.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 5 Users Say Thank You to 86AmishMs3 For This Useful Post:
Ckmazdaspeed3 (12-21-2011), cld12pk2go (12-21-2011), littleloogy (10-31-2013), phate (12-21-2011), rfinkle2 (12-21-2011)
 Old 12-21-2011, 07:13 AM   #2151
rfinkle2's Avatar
Groans: 298
Sometimes chemists don't know about cars, and car guys don't know much about chemistry.
We are lucky to have guys here that know about both.
Take it easy on ck. He is a good guy, and reads quite a bit on msf, as well as contributing quite a bit.
The Following 4 Users Say Thank You to rfinkle2 For This Useful Post:
86AmishMs3 (12-21-2011), Ckmazdaspeed3 (12-21-2011), phate (12-21-2011), RichieRichness (12-21-2011)
 Old 12-21-2011, 07:23 AM   #2152
Groans: 134
^^^^ that's why I love Msf. we have chemist/car nerds and those should trump a chemist who is not a car nerd any day.
... When I use my phone for this shit, I struggle to see all responses before replying, so to try and be clear, the fact that I was past mbt was not discussed with hemist friend, he and I were only debating the effects of ethanol (via water) oxidizing (not condensation like I wrote) the internals and weakening them and that causing my fail.
I didn't have the words, but my simple thought was that we have highly educated nerds pursueing and checking in in these treads and if this was an issue, it would surely have been brought up. I just needed everybody to give me their scientific reasons for me to respond.
... "go on with the boriphyll"
The Following 4 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
86AmishMs3 (12-21-2011), cld12pk2go (12-21-2011), phate (12-21-2011), rfinkle2 (12-21-2011)
 Old 12-21-2011, 07:26 AM   #2153
86AmishMs3's Avatar
Groans: 338
Sorry to hear about the blown motor, recent?
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
 Old 12-21-2011, 07:29 AM   #2154
Groans: 134
Yeah, happened Saturday, it's mentioned in my build thread and I'll post my timing tables later and fill in any questions people have over there.
Real, I'm not upset, just embarrassed if I made the past mbt noob mistake. But honestly, the bigger the mistake, the more you learn... Hopefully
86AmishMs3 (12-21-2011), rfinkle2 (12-21-2011)
 Old 12-21-2011, 08:08 AM   #2155
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Groaned at 25 Times in 25 Posts
Don't forget all the random leaness u had
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
 Old 12-21-2011, 08:15 AM   #2156
Older FFV systems used a sensor in the fuel line; newer systems just have an algorithm in the ECU that detects changes in stoich and fuel trims to determine if the fuel is petrol or E85.
Easter Bunny (12-21-2011), kritz (12-21-2011), rfinkle2 (12-21-2011)
 Old 12-21-2011, 08:29 AM   #2157
bewsted's Avatar
@silvapain you so smart me wuvs you
EWG K04...GETSUM!
The Following 2 Users Say Thank You to bewsted For This Useful Post:
 Old 12-21-2011, 08:48 AM   #2158
Groans: 134
Not to stay off topic, but te leanness wasn't that bad... I don't think anyway. I think past mbt timing+thousands of miles and 100s of WOTs makes the most sense.
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
djuosnteisn (12-28-2011)
 Old 12-21-2011, 08:51 AM   #2159
bewsted's Avatar
I never seen your timing im curious as to what you had setup...I know that my very last map on 50/50 was a mirror image of xmt66 cobb pro tune values....
EWG K04...GETSUM!
 Old 12-21-2011, 08:52 AM   #2160
rfinkle2's Avatar
Groans: 298
Ck, who suggested you were past mbt?
Also, how much e85 and meth were you running?
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.58376 seconds with 34 queries
