Like Tree247Likes
 Old 12-22-2011, 10:06 AM   #2201
Posts: 9,484   (View Stats)
Originally Posted by bewsted View Post
Your better off to run 50/50 on a 6 Gallon basis.... As you can't squeeze much more than 13 gallons in the car and putting 6.5 in would be tough
true dat...I run on a 12 gallon basis as its impossible to rely on getting anymore in there so the mix balances out after a few tanks...besides I don't like driving around with my fuel light on and only 2 stations in town, both at the same end of town.
I think before I started this I could only get about 12.5 in when the light was on and the needle at E.
Going backwards a little bit to the timing on BT setups. I was knock limited at 17* Peak in 90*F ambients with a 3/9 mix @ 12.0AFR @ 22psi/2.4 load. With lower temperatures I could probably push timing a little further but am not interested in making a cold weather only tune. Just another datapoint.
Zigatapatalka
if only we had the higher valued load axis...then you lower advance with the lower load points so you have an all weather tune with the most timing for each season.
@David@COBB where are those load axis?
Last edited by Dano; 12-22-2011 at 10:06 AM. Reason: MSF Database - Automerged Doublepost
speedms6 (12-22-2011)
 Old 12-22-2011, 10:44 AM   #2202
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Groaned at 25 Times in 25 Posts
So true.
I have had a few occasions when the last light of my fuel gauge has gone off, drove a bit, put in 7 gallons of e85, and only fit about 6.5 gallons of 93.
Trust me i had to run on 7/6 a couple times before I figured out I wasn't going to fit another gallon in it.
Problem solved...boost tune!
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
Last edited by bewsted; 12-22-2011 at 10:44 AM. Reason: MSF Database - Automerged Doublepost
bewsted is offline   Reply With Quote
The Following User Says Thank You to bewsted For This Useful Post:
rfinkle2 (12-22-2011)
 Old 12-22-2011, 11:04 AM   #2203
XLT_66's Avatar
Posts: 850   (View Stats)
So, has anyone running E85 been having any issues with the HPFP making a lot of noise? What started as a belief that my turbo was crapping out (which it is) it is also found that my HPFP is making a lot of noise on cold starts. I'll be taking it apart this weekend to have a look at things but from the sound of it, it's inevitable for it to not be scoring the crap out of the internals with the sounds its making. I get the squeaky sounds for a little bit and a "gurgling" of sorts but engine idle and function seems to remain normal. The sounds persist when the throttle is blipped during the first 15-20 seconds after stating the car.
I can't comment on wither or not it is still functioning at high pressure or not as I have my car set on 0% WGDC until I can swap the snail but it sounds terrible.
The issue didn't come up until after I put in 100% corn is the reason I post this here. Sure, it could have happened at any point in time but the fact that it happened when I put in the corn is pretty interesting.
2009 CWP MS3 Sport
SOLD!
2008 Toyota Tacoma TRD Sport 4x4
XLT_66 is offline   Reply With Quote
The Following 2 Users Say Thank You to XLT_66 For This Useful Post:
djuosnteisn (12-28-2011), rfinkle2 (12-28-2011)
 Old 12-22-2011, 11:19 AM   #2204
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Cobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the world
Groaned at 47 Times in 18 Posts
Are you referring to MAF Load axis? or fuel? or something else?
-David@COBB
Cobb Tuning is offline   Reply With Quote
 Old 12-22-2011, 11:31 AM   #2205
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
Dicked. I think it's safe to say that these cars aren't diggin 100% E85. Even 25/75, or at most 50/50, would net us it's full benefits without all these hardware issues we keep seeing.
My car LOVED 25/75.
The Following User Says Thank You to Alpha For This Useful Post:
 Old 12-22-2011, 11:44 AM   #2206
speedms6's Avatar
Posts: 825   (View Stats)
@XLT_66 take a look here Squeaky sound on startup/spoolup i dont run e85 and have this issue sounds like others are, seems to go away once the engine gets warm, only noticed it recently when it got cold out
@David@COBB i think he means the load axis in the ignition adv. tables
The Following 3 Users Say Thank You to speedms6 For This Useful Post:
Alpha (12-22-2011), Dano (12-22-2011), rfinkle2 (12-22-2011)
 Old 12-22-2011, 11:45 AM   #2207
-David@COBB
sorry, Ign load axis to dial in timing above 2.0. This way you could run more timing in the cooler AMB temps/higher load values and walk those commanded values down by say .5* per every two load axis rows so that in the summer months you run less timing when knock is more likely to occur.
BT cars really need this but even K04 cars are sustaining load values above 2.0. I don't think we need the resolution at .31 load in the HT table but if both the LT and HT tables have to use the same axis maybe we can reduce the rez and have a higher load ceiling.
just something for the "wish list" which I believe is already there...maybe its just not possible IDK.
rfinkle2 (12-23-2011), speedms6 (12-22-2011)
 Old 12-22-2011, 12:01 PM   #2208
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
I never fill the car up. The way I do my mix is to keep the same proportion, and I have been doing it for 2 months so my tank is "mixed" even when low fuel. For my 6 gallon mix I simply fill up with 3 gallons of E and 5 gallons of 93. Regardless of whats left in the tank, it is still a blended e85 mix. This strategy has netted pretty good consistency. Stepping up to 50/50 I will simply go 4 gallons of E to 4 gallons of 93 when the tank is low. So 4 percent, thanks guys.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
 Old 12-22-2011, 12:17 PM   #2209
speedms6's Avatar
Ethanol Calculators
you can also use this website to find out how much to add, for some reason it doesnt load on my work comp but does at home
 Old 12-22-2011, 01:21 PM   #2210
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
Those of you adding by the gallon make sure to pay attention to whether or not your regular gas has ethanol mixed in and figure that into your calculations.
The gas I get already has 10% ethanol, so I have to figure accordingly when I fill up.
The Following 2 Users Say Thank You to wolly6973 For This Useful Post:
Alpha (12-22-2011), rfinkle2 (12-22-2011)
 Old 12-22-2011, 01:30 PM   #2211
XLT_66's Avatar
Yeah, I get the exact same sound from the outside. Goes away pretty quickly but that is not a good sound at all. The squeak is two metals rubbing on each other in a bad way. We'll find out soon when I open up the HPFP.
Now, the gurgling sound I can hear inside cabin that occurs only when that squeak is going on is just odd, no matter how you look at it.
FWIW, I'm running the newest version of the KMD internals
2009 CWP MS3 Sport
SOLD!
 Old 12-22-2011, 01:30 PM   #2212
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
XLT, I have the chirp, as well as a much more pronounced ticking (in time with the cam), but I haven't got the gurgle (yet). LOL.
I'm only on 50/50, and think that is where I am going to stay for now.
 Old 12-22-2011, 02:16 PM   #2213
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
When you say chirp, do u mean for like 1 second on a cold start? It almost sounds like a belt slipping but just for 1 second and not again until the next cold start.
 Old 12-22-2011, 05:46 PM   #2214
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Thought the same thing, till i had like 5 of my mechanics huddle around my engine and said it was coming from the pump area.
I kno me and rfinkle both have this issue, and i still do get the sound once in awhile.....but i found out it is the hpfp, since i was full e85.....but if u prime the pump 1 or 2 times before starting, it will not chrip/spinning grinding sound ppl are hearing.
Im gonna take apart the spill valve and clean it, which i think is causing the problem....unless im rly getting bad lube to the cdfp since the switch to 85....never had the problem till i switched to 85...or could be a faulty cp-ecdfp
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
Ckmazdaspeed3 (12-22-2011), rfinkle2 (12-22-2011)
 Old 12-22-2011, 05:50 PM   #2215
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Going back to my Perrin ebcs, and as soon as I get the 3-bar map sensor, I'll be doing a load based tune. As soon as the 93oct + methanol map is done (26psi), I'll be running the 93oct + meth + eth.... E30 mixture. Saving for a pro-tune.
The Following User Says Thank You to dougefresh_ For This Useful Post:
 Old 12-22-2011, 05:53 PM   #2216
rfinkle2's Avatar
Groans: 298
Yes, and also when blipping the throttle.
 Old 12-22-2011, 05:57 PM   #2217
mazdafreak's Avatar
Groans: 124
I only get it at cold start up...never while driving or giving throttle.
713whp/569wtq!
Ckmazdaspeed3 (12-22-2011), rfinkle2 (12-23-2011)
 Old 12-22-2011, 07:38 PM   #2218
mrmonk7663's Avatar
I get the chirping ONLY on cold start. I really thought it was the belt. I've added it ever since I put E in the car....even on a 3 gallon to full tank mix.
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
 Old 12-22-2011, 08:33 PM   #2219
speedms6's Avatar
yeah i assumed thats what the sounds was, i get it right as i start it up and idle high for a couple seconds and only if i hit 1800 fuel press. while the car isnt warm, otherwise i dont hear it.
keep us posted, i did run one tank of 4 gal e85/12gal gas monthsss ago but i dont think that could be enough just from one time
also just put in 6 gal e85 and 10 gal gas tonight, car is a beasttt, posting my results here as we speak if anybody is interested
smoothing out my tune
The Following User Says Thank You to speedms6 For This Useful Post:
 Old 12-22-2011, 11:31 PM   #2220
*knocks on wood*
I have the unfortunate luxury of having two new CDFPs...lol
on 93 my PTP pump was as quiet as a mouse. My CPE rattles like a giant POS with slight throttle lift. I got it after I was already on E25ish and it rattled from the beginning.
On E35 my PTP pump was quite...don't know what pumps/internals you guys have but this might be good additional information for the E85 DB.
PTP pump 10K total miles with 2K E35
CPE 4K miles all with E35.
 Old 12-22-2011, 11:53 PM   #2221
sleepyspeed6's Avatar
Posts: 288   (View Stats)
sleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the world
I have been getting this same noise you guys are talking about, I have stock hpfp internals. I just thought the sound was coming from my intake.
Also to add I am on 5.5 eth 5.5 gas.
Brownie goes back to hiding in the shadowy corner
Hx35 sold
New sc6266
sleepyspeed6 is offline   Reply With Quote
The Following User Says Thank You to sleepyspeed6 For This Useful Post:
 Old 12-22-2011, 11:57 PM   #2222
The shop I'm stopping by tomorrow has a device you hook up to the fuel system that can detect the actual %Ethanol in your tank. I may go there for a pro-tune, then throw in a few gallons of E85 until I hit E30, and then re-tune with MOAR timing. I can do both maps there for $500 on a Mustang Dyno, and have them left unlocked. I've met and talked to the tuner before. He knows his stuff.
I'll start the preliminary tuning tomorrow once I hook up the rest of the Perrin. Once I get the upgraded map sensor, I'll be running high 2s to low 3s load targets, and then higher when running E85. If I get this load tune down the first time, I shouldn't have to mess with it really (load/gear).
 Old 12-23-2011, 12:03 AM   #2223
mrmonk7663's Avatar
Good luck with the tune man!!!
 Old 12-23-2011, 08:23 AM   #2224
bewsted's Avatar
brownie better get internals
@silvapain or @phate
Have you guys fully determined the gunk is due to oil pass into the fuel side of the pump?
EWG K04...GETSUM!
Last edited by bewsted; 12-23-2011 at 08:23 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-23-2011, 08:26 AM   #2225
rfinkle2's Avatar
Groans: 298
I don't know how the factory pump could possibly be holding pressure with a 5 gallon mix...
 Old 12-23-2011, 09:06 AM   #2226
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Black residue is certainly from oil; sticky residue (which has no color) is from the fuel itself.
 Old 12-23-2011, 09:18 AM   #2227
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
Groaned at 8 Times in 2 Posts
I ran my car down to fumes in the tank last night and filled it back up with 100% 93 octane. This morning, after the car sat from 6:30PM-8:30AM, I fired it up and there was no sound from the HPFP.
The past 3 weeks it has been squealing and gurgling at me if it sits for more than 4 hours or so.
So...looks like we have a culprit. (Well, we already knew what the cause was but I guess this confirms it?)
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD!
2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car
Evan@COBB is offline   Reply With Quote
The Following 7 Users Say Thank You to Evan@COBB For This Useful Post:
Alpha (12-23-2011), Dano (12-23-2011), djuosnteisn (12-28-2011), Enki (12-23-2011), kritz (12-23-2011), phate (12-23-2011), rfinkle2 (12-23-2011)
 Old 12-23-2011, 09:23 AM   #2228
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I'm about on E running 93. I'm going to switch back to E85 (straight) and see if I hear this chirping you guys mention. My car is NOISY because of the Fidanza flywheel and TRZ trans mount, so that may be why I never noticed it before.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 12-23-2011, 09:32 AM   #2229
Were you running Marv Mistry Oil in the E
Iirc both @phate and @silvapain run it and I don't they have reported any noise.
If not its worth a try.
Tappin
kritz (12-23-2011)
 Old 12-23-2011, 09:34 AM   #2230
Posts: 7,290   (View Stats)
@Dano
How mucho of the MMO/tank? Me haz the squeeks on 50/50.
Nator is what it does.
 Old 12-23-2011, 09:37 AM   #2231
rfinkle2's Avatar
Groans: 298
They both have the noises (Silvapain and Phate).
Edit: Maybe Phate doesn't have noise, but I'm pretty sure Silvapain does (I'm 100% sure Enki does).
I've tried both Marvel Mystery Oil (as has Silvapain, I tried it on his suggestion) and Lucas Fuel additive with no change in noise.
Squeaky squeak!!
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
Dano (12-23-2011), Enki (12-23-2011), kritz (12-23-2011)
 Old 12-23-2011, 10:10 AM   #2232
@Dano
I haven't needed to use any on E35 and don't know what the mix is. I do have a question for the experts. Do you see any reason to run MMO with E concentrations up to and including 5050? I would think the petrol would provide enough lube.
Also, since our pumps seem to have trouble with 100% E why not try double or triple the amount of MMO than suggested by them? Are there any downsides?
Squeaky squeak!!
thanks finkle for keeping me inline...my brain is getting too old to post from memory...lol
Phate did just post he hasn't heard any noise but his car is noisy...lol.
kritz (12-23-2011), rfinkle2 (12-23-2011)
 Old 12-23-2011, 10:37 AM   #2233
yeah, when you posted your timing earlier, i noticed that and you may be right. I just REALLY HOPE that we can find the smoking gun, whatever it is.
How often do you WOT and how many miles do you put on your car a month? I only ask cuz I do around 50-100 miles a day and get at least 3 and up to 10 pulls in there... not always full pulls.
missed this...I work from home so don't drive my car near that much...100 miles a month...lol
Its like the Dos Equis most interesting man alive
"I don't drive much but when I do I am WOT the entire time"
When I am working on a tune I prab get in 20 WOT runs a day over the weekend.
Ckmazdaspeed3 (12-23-2011), kritz (12-23-2011), phate (12-23-2011), rfinkle2 (12-23-2011)
 Old 12-23-2011, 10:53 AM   #2234
Evan@COBB's Avatar
Never put any MMO or other additives into the tank. I never had any issues when running 50/50 mix for 2500 miles.
Far as I'm concerned, if you don't mind the fact that you have to use two pumps every fill up then I wouldn't run beyond a 50/50 mix. You get all/most of the power/timing benefits of running full E85, slightly better MPG, and as far as my car was concerned, not a single problem at all.
One thing you need to keep track of is your oil, though. Granted I had some hard track miles on my last batch of oil, but at 3500 miles, it was completely broken down and very thin, even when cool and smelled of corn. I would be diligent with you oil changes if you're running the E.
The Following 10 Users Say Thank You to Evan@COBB For This Useful Post:
Ckmazdaspeed3 (12-23-2011), Dano (12-23-2011), djuosnteisn (12-28-2011), dougefresh_ (01-03-2012), kritz (12-23-2011), Nataphen (12-23-2011), Pu Manchu (12-24-2011), rfinkle2 (12-23-2011), Schmitty5 (12-23-2011), Tomas (12-23-2011)
 Old 12-23-2011, 11:15 AM   #2235
Eth Fiend
phate's Avatar
Not sure I completely agree with that. I had >6k miles on one oil change which included tail of the dragon (the trip where things got so goddamn hot, it smelled like someone was welding under my hood, lol), dyno tuning, and god knows how many 100's of wot street pulls. My oil analysis came back the best it ever has. Did you have yours analyzed?
And no, for the question above, I don't run MMO or any other additive.
-06 MS6
Ckmazdaspeed3 (12-23-2011), kritz (12-23-2011), rfinkle2 (12-23-2011)
 Old 12-23-2011, 11:39 AM   #2236
Eth Fiend
phate's Avatar
Guys, I have a confession: I've been running 93 over the past couple weeks trying to nail down a solid tune for when I get caught in a spot that doesn't have E85. I got it to a point where I was getting pretty comfortable with it, timing was pretty solid, boost was pretty solid. I was starting to think E85 doesn't make that much of a difference compared to a proper 93 octane tune.
Then comes this morning. As I posted above, I wanted to fill with E85 to check the 'chirp' which some are hearing. So I'm on empty heading to work and fill up with the maize. Threw on one of my E85 tunes which I thought was for winter, and gave it a few miles to allow the E85 to permeate throughout the system.
A few miles out I gave it a quick 3rd-4th blip and it was one of those moments where you're just like "wtf did I just do?". The fucking car, in a matter of 5 minutes, went from calm, cool, collected, pulling hard MS3; to an absolutely furious animal. I didn't realize just how much of a change it results in. Most of the time I have been running E85, I've been working on one thing or another, working things up slowly. It hasn't been this 'flip of the switch' sort of change. I am, once again, in complete awe of how E85 changes this car.
-06 MS6
The Following 16 Users Say Thank You to phate For This Useful Post:
Alpha (12-23-2011), ChimmyChong (02-22-2012), Ckmazdaspeed3 (12-25-2011), Dano (12-23-2011), Enki (12-23-2011), GLORIFIEDBOZO (12-23-2011), JacksonMS30 (01-10-2012), jracer (12-24-2011), kritz (12-23-2011), mazdafreak (12-23-2011), Nliiitend1 (01-02-2012), Pu Manchu (12-24-2011), rfinkle2 (12-23-2011), SWAY (12-24-2011), Todd98SE (12-23-2011)
 Old 12-23-2011, 11:48 AM   #2237
rfinkle2's Avatar
Groans: 298
I think that the guys would collectively absolve you of your sins!
kritz likes this.
dougefresh_ (01-03-2012), kritz (12-23-2011), phate (12-23-2011)
 Old 12-23-2011, 02:11 PM   #2238
I've been running the recommended 4oz MMO to 10 gallons of fuel, and I still have to pull my spill valve and clean it every 200-300 miles. Been using MMO for about 1500 miles. I am confident in saying that MMO at the recommended concentration does not help.
I just ordered some Klotz Uplon Fuel Lube from Summit Racing for the hell of it. I'll see if this is any less worthless than MMO.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
Dano (12-23-2011), kritz (12-24-2011), phate (12-23-2011), rfinkle2 (12-23-2011)
 Old 12-23-2011, 03:19 PM   #2239
Enki's Avatar
Groans: 189
I no longer have the chirp. Yesterday on my way home, I had no pressure, and didn't this morning when I went to run some errands. I put yet more naphtha in the tank (up to close to half a gallon now) and on the way back (about 20 miles in to the trip) pressure started coming back; when I parked it and went to shut it down, it was trying to hold pressure but occasionally dipped to sub 500 (750 commanded at idle).
I'm going to add more and see if it helps; I am fairly certain my pump issues are due to the internals not quite fitting properly, though. Last I checked, manually actuating the piston (by hand outside the car), it felt squishy rather than linear; it also took far too long for the spring to push the piston the rest of the way out of the pump (I could watch it slowly slide out).
On the additive front, I'm pretty certain any insignificant amount of additive (less than 20:1 ratio of fuel to additive) isn't going to do shit for our cars. Port injected maybe, but tolerances are extremely tight in our pumps.
 Old 12-23-2011, 11:22 PM   #2240
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
So just got caught up here, and realized I need to get off my dead ass and update my thread. I went up to visit @phate last weekend and had some issues. I will get it all up tomorrow in my thread.
Sent from my DROIDX using Tapatalk
The Following 2 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
kritz (12-24-2011), rfinkle2 (12-24-2011)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.64667 seconds with 39 queries
