Like Tree247Likes
 Old 12-29-2011, 10:28 AM   #2281
Posts: 9,484   (View Stats)
depending on the E concentration you will not get any knock. E can remove the knock limitation and allow you to reach MBT. So no blown motors due to knock itself.
Trouble is you will not really know where MBT is without a dyno So once you go past MBT you over stress the rods which can lead to failure but you still don't get any knock.
you can however make much more power very safely by running a mix and say add a degree or so more than you were on 91/93 and knock limited. This is why Phate put together the database so you can see what others are making on dynos with varying E mixes and hardware.
The Following 5 Users Say Thank You to Dano For This Useful Post:
Boost_creep (12-30-2011), djuosnteisn (01-03-2012), Nataphen (12-29-2011), phate (12-29-2011), SJP0tato (12-29-2011)
 Old 12-29-2011, 10:31 AM   #2282
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Groaned at 25 Times in 25 Posts
for the love of god......all i can tell you guys.....tune your knock sensor on 93/91 and then copy it over to your e85 map...DO NOT tune out "ENGINE NOISE" when on your e85 map...
Knock you get while on e85 should raise some alarm to you if you do this all right....My be a good time to back timing down and or get on a dyno and actually tune your shit.
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
The Following User Says Thank You to bewsted For This Useful Post:
 Old 12-29-2011, 06:22 PM   #2283
Ziggo's Avatar
Posts: 3,843   (View Stats)
Dunno, I am still knock limited on a 3/9 mix, and there is no way I am running my 93oct timing +1/2deg. I was knock limited at 9* peak on pump @ 11.2AFR, and the mix allowed me to gain over 80whp through 8* more timing and 12AFR.
Note though, I am using a load tune with the express purpose of keeping cylinder pressures manageable over varying temps. It's only hitting ~16-17psi in the 3-4k range now to maintain ~400wtq with the extra timing and 50deg ambients. Past MBT or not, the extra timing plus a boost tune thats just going for 22psi would be headed towards 500wtq quickly. Even running at MBT significantly increases cylinder pressures while having a small effect on power.
Ask Me About My:
Nataphen (12-29-2011), rfinkle2 (12-29-2011)
 Old 12-29-2011, 07:34 PM   #2284
Ziggo's Avatar
Just some sketches done from memory to illustrate my point. Even reaching MBT significantly increases cylinder pressure. First up your basic cycle using instantaneous combustion.
Now a couple figures for non-instant combustion
The key is you never achieve peak pressure directly at TDC when at MBT; you lose more power by having combustion going on while compressing (hogher pressure at point 2) than gained so you stop adding timing. However going past MBT moves point 3 closer to TDC and up that exponential cylinder pressure curve.
Ask Me About My:
The Following 7 Users Say Thank You to Ziggo For This Useful Post:
86AmishMs3 (12-29-2011), djuosnteisn (01-03-2012), kritz (12-30-2011), Nataphen (12-29-2011), Nliiitend1 (01-03-2012), rfinkle2 (12-30-2011), SJP0tato (12-30-2011)
 Old 12-29-2011, 07:51 PM   #2285
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Attachment 48148
Attachment 48149
hahah at pulling out engine cycle diagrams. A little too much thermodynamics for me.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 12-29-2011, 07:55 PM   #2286
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
^Agreed. @Ziggo, just because I thank you doesn't mean that I have the slightest clue what you're sketching, but I appreciate your effort to explain things to the simple folk here (me).
The Following 3 Users Say Thank You to Nataphen For This Useful Post:
kritz (12-30-2011), rfinkle2 (12-30-2011)
 Old 12-29-2011, 08:07 PM   #2287
Ziggo's Avatar
It all always comes back to thermodynamics!
Ask Me About My:
86AmishMs3 (12-30-2011), cld12pk2go (12-29-2011)
 Old 12-29-2011, 09:28 PM   #2288
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Oh YEAH. Thermo FTMFW!
 Old 12-29-2011, 09:37 PM   #2289
josurr's Avatar
Posts: 954   (View Stats)
josurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the world
Groans: 156
speaking of thermodynamics...
josurr is offline   Reply With Quote
The Following 4 Users Say Thank You to josurr For This Useful Post:
86AmishMs3 (12-30-2011), Enki (12-29-2011), Nliiitend1 (01-03-2012), rfinkle2 (12-30-2011)
 Old 12-30-2011, 05:20 AM   #2290
86AmishMs3's Avatar
Groans: 338
as a chem-e thermo was probably my least favorite....along with process control. I was all about transer, whether it was fluid, mass, or momentum.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
 Old 12-30-2011, 07:49 AM   #2291
P-V diagrams and Otto cycles make me wet.
cld12pk2go (12-30-2011), kritz (12-31-2011)
 Old 12-30-2011, 09:53 AM   #2292
SJP0tato's Avatar
Posts: 322   (View Stats)
SJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the world
My "common sense" way of thinking/explaining is to imagine pedaling a bicycle, but you weigh 2000 lbs or something and can only pedal standing up/full force on the cranks one foot at a time.
You can push down on the pedal when it's parallel with the ground, and get good power, but if you push down earlier you can get more work out of your weight up to a point. At some point the force you're exerting is putting much more stress on the pedals/cranks than is being transferred into the chain to propel you forward. Ever earlier in the cycle almost all your weight is going directly into the crank arm for awhile before it gets around, and it bends/snaps.
SJP0tato is offline   Reply With Quote
The Following 4 Users Say Thank You to SJP0tato For This Useful Post:
Alpha (12-30-2011), kritz (12-31-2011), mrmonk7663 (12-30-2011), phate (12-30-2011)
 Old 12-30-2011, 11:29 PM   #2293
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
As I mentioned in the other thread, but this seems an appropriate place to repost:
'Tis a sad day for the corn burners:
Congress ends corn ethanol subsidy | The Detroit News | detroitnews.com
We'll miss you, subsidy, but your loss won't deter us.
-06 MS6
-Corn fed 07 MS3 - Sold
Dano (12-31-2011), djuosnteisn (01-03-2012), mrmonk7663 (12-31-2011), rfinkle2 (01-01-2012)
 Old 12-31-2011, 12:12 AM   #2294
WTF are you engineers talking about??? i put corn into my car and I go faster...nuf said??
I could throw up a DJ MS paint drawing to illustrate what I mean but I think its clear and besides....I've had too much to drink...
The Following 6 Users Say Thank You to Dano For This Useful Post:
djuosnteisn (01-03-2012), Fatguy729 (01-01-2012), JacksonMS30 (01-10-2012), Nataphen (12-31-2011), phate (12-31-2011), rfinkle2 (01-01-2012)
 Old 01-02-2012, 11:14 AM   #2295
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Thumbs up Switched to E25, first scrapper logs
I went with 4 gallons of E85 today, and topped it off with premium (~E25). I added about 13% fuel up top on my maf curve, and staggered it down to 5% around 125 g/s or so. I've only driven about 12 miles on the new map, and went wot from 2nd-3rd near my house. My wot afrs weren't that bad... a little rich, but not that far off.
Once the map settles, I'll do a maf g/s and cal the lower part of the maf, flash that map, then do some 4th pulls. I could only run 11* timing up top before with 0 kr, but I bumped it to 14* timing for my base map. It hit 14 NP, and no kr, so that's a good place to start. I'll have her leaned back out to 12.0 afrs, and I'm hoping I can run 16-18* timing up top. I'm pushing about 25psi, and I may squeak it up to 26psi.
Too rich/soon to feel any big sotp gains, but I'm hoping once she's dialed that she can break 400whp SAE. We'll see... dyno is less than 3 weeks away, and I need to get tweaking! Also, my IDC% is right around 100% now, and the E85 skewed my maf about up by 30g/s up top.
EDIT: Added a 3rd gear pull from 2,800 rpms to redline. Looks solid, just rich and needs more timing.
The Following 7 Users Say Thank You to dougefresh_ For This Useful Post:
cld12pk2go (01-02-2012), Dano (01-03-2012), djuosnteisn (01-03-2012), Enki (01-02-2012), Nataphen (01-02-2012), phate (01-02-2012), rfinkle2 (01-03-2012)
 Old 01-02-2012, 06:33 PM   #2296
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
looks like some good air ingestion goin on there.
https://www.facebook.com/NorCalTintZone
instagram: sharpdetails
GoSpeed3Go is offline   Reply With Quote
The Following User Says Thank You to GoSpeed3Go For This Useful Post:
dougefresh_ (01-02-2012)
 Old 01-03-2012, 11:55 AM   #2297
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
At your airflow levels... i'd run as little e85 as possible to keep kr away. You need the fuel.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 6 Users Say Thank You to djuosnteisn For This Useful Post:
Alpha (01-03-2012), cld12pk2go (01-04-2012), Dano (01-03-2012), dougefresh_ (01-03-2012), rfinkle2 (01-05-2012), Todd98SE (01-05-2012)
 Old 01-03-2012, 01:50 PM   #2298
driver311's Avatar
Posts: 1,769   (View Stats)
driver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the world
Yes I agree with DJ to an extent. I think you can make more power with the e85/timing combo vs the added 1-2psi and less e85 like he is suggesting. If you can keep your 4g to 8g mixture I think you can make 400whp NO problem. I dont suggest running 4g to a top off. eventually your mixture will be off. When filling next time do 4g to 8g. Make sense? You should be able to go all the way to 19-20 degrees timing without any knock and from the 11 degrees you were at before you will make about 40-50whp more. Id try keeping boost around 24psi and start timing around 16-17 degrees on the dyno and add 1 degree at a time until you stop making power. If you are still around 100% idc I would suggest leaning out some more to around 12.4-12.5 afr to give yourself a lil room on idc. This is still a very safe afr on your setup and will give you that lil bit of breathing room. Good luck and keep us posted. Im excited for your results.
2008 Mazdaspeed3, Fully built then fully parted. Sold
2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily
Mazdaspeed
12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp
11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp
driver311 is offline   Reply With Quote
The Following 6 Users Say Thank You to driver311 For This Useful Post:
Alpha (01-03-2012), cld12pk2go (01-04-2012), Dano (01-03-2012), dougefresh_ (01-03-2012), rfinkle2 (01-03-2012), Todd98SE (01-05-2012)
 Old 01-03-2012, 02:45 PM   #2299
I concur with pulling boost to 24psi and then push timing.
Here are your tradeoffs:
The more boost, the more power.
The more boost, the more fuel needed.
The more boost the more heat, the more knock.
The more heat, the less timing.
The more timing, the more power.
The more fuel (richer) the more cooling.
The more E85, the higher the octane, the less knock.
The more E85, the more fuel needed.
The Following 7 Users Say Thank You to Lex For This Useful Post:
dougefresh_ (01-05-2012), mazdaspeed916 (08-20-2012), mrmonk7663 (01-03-2012), Nliiitend1 (01-04-2012), phate (01-05-2012), rfinkle2 (01-05-2012), Todd98SE (01-05-2012)
 Old 01-04-2012, 08:59 AM   #2300
GoSpeed3Go's Avatar
just think of the things some you could accomplish if we all werent fuel limited.
phate (01-05-2012)
 Old 01-05-2012, 10:02 AM   #2301
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
So has anyone figured out the size of the o-ring that seals around the pump piston? Mine is wearing and I need a new one.
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
 Old 01-05-2012, 10:26 AM   #2302
I bought a full Buna-N quad O-ring kit from McMaster-Carr and it's sitting in my garage waiting for me to find the time to test some O-rings out.
I'll try to get an answer on the size this weekend.
The Following 7 Users Say Thank You to silvapain For This Useful Post:
ABSpeed3 (01-05-2012), djuosnteisn (01-05-2012), Nliiitend1 (01-05-2012), phate (01-05-2012), rfinkle2 (01-05-2012), SWAY (01-05-2012), wolly6973 (01-06-2012)
 Old 01-05-2012, 11:11 AM   #2303
ABSpeed3's Avatar
Groans: 133
Thank you, it is GREATLY appreciated. You da man
08.5 CWP MS3 GT
 Old 01-05-2012, 01:26 PM   #2304
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I'm reading more and more evidence that it may be best to go to a 2 step colder plug rather than back to the stock heat range if running high eth mixtures.
I know many of you guys read as much as I do, but it seems that ethanol is particularly sensitive to preignition.
I think cld12pk2go ran itv24's for a long time on his eth mixes with good luck.
phate (01-05-2012), silvapain (01-05-2012)
 Old 01-05-2012, 02:04 PM   #2305
My car ran much better after taking out my 1-step-colder Denso's and putting in stock heat range plugs.
Alpha (01-05-2012), phate (01-05-2012), rfinkle2 (01-05-2012)
 Old 01-05-2012, 02:05 PM   #2306
Eth Fiend
phate's Avatar
My car has run better on stock heat range plugs compared to ITV22's. When I was running 22's, the car ran shitty at idle and WOT, with some hesitations here and there. The 20's work great until around 35° ambient temp. I would actually like to try ITV16's (1 step hotter than stock) to see how they work in winter.
Quick google search for auto ignition temps of various hydrocarbons, including ethanol and gasoline: http://www.engineeringtoolbox.com/fu...res-d_171.html
And here's an SAE paper if anyone wants to pay for it: http://papers.sae.org/2008-01-0321/
Edit: I think my intercooler delete testing shows just how damn awesome E85 is. back to back to back runs with 230°+ BAT's with full boost and full timing and my shit didn't go nuclear. I really don't think it's a concern, lol.
-06 MS6
djuosnteisn (01-05-2012), Nliiitend1 (01-05-2012), rfinkle2 (01-05-2012), silvapain (01-05-2012)
 Old 01-05-2012, 02:12 PM   #2307
rfinkle2's Avatar
Groans: 298
Alrighty guys, just saying I'm reading over and over again some of the more experienced tuners for many of the platforms quoting various sources, that preignition is an issue with ethanol.
I understand on paper, things can be debunked, but we all know that things don't always behave in nature as they do on paper.
phate (01-05-2012)
 Old 01-05-2012, 02:16 PM   #2308
Eth Fiend
phate's Avatar
Here we go:
Okay, my car kinda freaked out because it's never seen BAT's like this, so it pulled WGDC in the mid range. So let's discuss the top end of these:
Average of 3 runs with normal intercooling:
Average of 3 runs with intercooler blocked by a piece of cardboard (lol):
I'll alter my tune and get more consistent logs if anyone wants me to, but there were NO issues other than the car pulling WGDC, and therefore lowering boost/airflow up to about 5k rpm.
_____
And Ziggo, you were right about the kind of temps the K04 is putting out. This is a 1st-6th gear pull:
That should make you guys appreciate how much the stock intercooler really is doing.
-06 MS6
 Old 01-05-2012, 02:19 PM   #2309
rfinkle2's Avatar
Groans: 298
Phate, you posted that to show bat's< temperatures listed for auotignition in the link you provided?
phate (01-05-2012)
 Old 01-05-2012, 02:21 PM   #2310
Eth/Meth Junkie
cld12pk2go's Avatar
FYI, i have had zero issues with the ITV24's with up to E50.
I am currently in the E35 range without any issues down to 18°F ambient temp so far.
Of course I am now pushing close to 350 g/s actual, which might require something quite different from a K04 at similar ethanol concentration.
The Following 3 Users Say Thank You to cld12pk2go For This Useful Post:
 Old 01-05-2012, 02:24 PM   #2311
Eth Fiend
phate's Avatar
Consider post-compression temps of the same mass of air between a 100° pre-compression charge and a 250° pre-compression charge. Someone want to run some numbers for us???
-06 MS6
 Old 01-05-2012, 02:27 PM   #2312
rfinkle2's Avatar
Groans: 298
I'm not disputing your scientific approach, although I do think that the amount of shit that is stuck to our plugs could tend to cause an issue.
I didn't intend to debunk your science, I'm simply stating what I am reading from some pretty experienced ethanol tuners, as well as some of what I've read from various sources.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
J-Liss (01-05-2012), phate (01-05-2012), SWAY (01-05-2012)
 Old 01-05-2012, 02:41 PM   #2313
Eth Fiend
phate's Avatar
IDK man. Like I said about 50 pages back (lol), I'll let you smart folk discuss why or why not we can or cannot do things, and I'll just keep testing and reporting my findings.
-06 MS6
Alpha (01-05-2012), rfinkle2 (01-05-2012), SWAY (01-05-2012)
 Old 01-05-2012, 02:47 PM   #2314
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
Thumbs up
Ha! I said the same thing about nutrition 5 years ago... It worked out well to say the least.
Firsthand/Frontline empirical data is ALWAYS the best data!
Keep doin your thing playa!
The Following 2 Users Say Thank You to Alpha For This Useful Post:
 Old 01-05-2012, 02:52 PM   #2315
rfinkle2's Avatar
Groans: 298
IDK either Phate, just brought up something I read on numerous sites, numerous times.
I didn't mean to challenge your intelligence, nor your findings, just participating with some of what I read.
It is a commonly excepted issue that ethanol's only weakness is its predisposition to preignition.
Just to show you that I read something I thought was of interest from a credible source concerning plug heat range, the following is from ngk's website:
Fuel Type / Quality
When using an ethanol blend fuel with high ethanol content in high performance applications, a colder heat range may be necessary. The spark timing can be advanced further because ethanol blend fuel has a higher resistance to knock (higher octane). Due to the decreased knock, there will be less audible “warning” from knock before the spark plug overheats and pre-ignites.
Some types of fuel additives in lower quality fuels can cause spark plug deposits that can lead to misfires, pre-ignition, etc.
Alpha (01-05-2012), Tomas (01-06-2012)
 Old 01-05-2012, 03:04 PM   #2316
Eth Fiend
phate's Avatar
I just downloaded the SAE paper. Gonna take a few minutes to read, lol.
-06 MS6
 Old 01-05-2012, 03:12 PM   #2317
rfinkle2's Avatar
Groans: 298
How much was it? I'll split it with you.
You read it.LOL
 Old 01-05-2012, 04:07 PM   #2318
Captain
Groans: 79
Have you guys been checking your plugs much? I'd be real curious to see how yours looked after that IC delete test Clint.
www.permtuning.com
 Old 01-05-2012, 04:17 PM   #2319
Pre-ignition would result in some pretty hefty holes in pistons pretty fast. Anyone had this show up?
Is this the paper. I think I will buy this since I'm a member of SAE.
Pre-Ignition Characteristics of Ethanol and E85 in a Spark Ignition Engine
Last edited by Lex; 01-05-2012 at 04:17 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-05-2012, 04:31 PM   #2320
rfinkle2's Avatar
Groans: 298
That is another issue that is totally different with e85, plug reading.
From what I can tell, you can throw traditional plug reading out the window.
Thankfully, I don't think anyone has seen anything remotely close to that!
That is the paper^
Last edited by rfinkle2; 01-05-2012 at 04:31 PM. Reason: MSF Database - Automerged Doublepost
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.62690 seconds with 38 queries
